Don't destroy good capacitor or waste your time. If you draw even micro amperes via the so called Captret configuration, you will alter the capacitor characteristics and when you pull milli-amperes for extended periods you actually risk an explosion from built up gas from the capacitor degrading.
If you play with this type of improper configuration, we suggest you fuse your circuit to prevent a short and fire when the caps give out, this could be bad if you are sleeping and your circuit is running.
Here is a link to picture of damage from a 48 hour run we did at the lab, very back and dangerous results.
A capacity test after extended run proves interesting also.
Damage 1
Damage 2
Damage 3
Normal 4
Dr. Stifflers short paper on the Captret.
Damage 1
Damage 2
Damage 3
Normal 4
