The ultimate secret of free energy: Split the postive AND the negative
  • Jbignes5
    ok...
    I appreciate the excitement but calm down lol....
    There is a lot of information to go through. I got the same way and just about everyone rejected my enthusiasm.
    I am glad someone else sees the same thing I was trying to impart. But there are a few issues we need to work out.
    The issue of Nassim is one that yes breaks the ground and starts to form the foundation of these ideas. The thing about Nassim is that he took a lot of his theories from many many sources. Some legit and some not so legit.
    As for the fractals well you can see it in everything in nature. It is a structural result. That means it at some point has a real form. No matter how small it has a basic form. I think the Sierpinski Triangle will do here.
    Sierpinski triangle - Wikipedia, the free encyclopedia
    If you read the whole thing you can see that these special structures have almost limitless surface area. Perfect for holding a static charge in the structure itself on each surface. With each element being a triangle made up of more triangles. These go on forever. That is the fractal we are talking about. That is the underlying geometry that shows up in nature at every turn.
    So yes there is indeed an elementary, as far as we can see particle. But it is smaller then we have the capability to see and hence why we don't understand the minute workings of such and why we see it as a magical event or invisible. It is the stealth conductor because of the material and size of that particle. We will probably never see it but what we can see is the results and can infer the underlying geometry and composition of that particle without having to see it just from observing what happens in nature.
    Now this particle attracts matter, which is neutral and very reactant to the static nature of these particles. These structures are what holds matter together in a never ending dance. If you start to investigate what we do see at the smallest scales we are capable of seeing, you will start to understand how matter can be held together by this process and why most matter has a crystaline base.
    Take metals for instance. Most metals if not all in their natural state have a crystaline pattern when etched by an acid. Lets look at our favorite electrical metal copper:
    Copper - Wikipedia, the free encyclopedia
    See the picture of the etched copper disk and you will start to see a crystaline pattern. Is that something we should get excited about? Well yes. Metals when they transition from a liquid to a solid will lock in the pattern. Well where does that pattern come from?
    Well metals are not the best way to get a snap shot of this underlying network. Water is. Snow flakes are the best example of the network that I speak. A quick study of snowflakes will show you a small portion of the network and curiously it is flat. Why is that? Well if you know that radiative sources like our earth have a network of invisible lines radiating from the center out into space. Well now look at the clouds, which are actually an event that happens at a boundry of density. The clouds or water vapor reside at the boundry of the density change. This is much like a shell. When water freezes it does so in the same manner, oriented on a flat plane of the enery matrix that radiates from our planet.
    How is this done exactly. Well in the middle of our planet there is a lot of matter that is compressed and flowing. This flow causes a static potential to be maintained. That potential is actually the core of our planet. A point charge so massive that it can hold all the matter and us to the surface in layers. And now we know what gravity is. Gravity is actually a static potential
    holding us to this ball of matter<- which is neutral, passing the charge potential quite easily as a lot of experiments have shown.
    Now having a point charge that massive will attract other charges from around our planet and now we know what is happening to our planet and why it is getting more and more energetic. Although what we have been doing isn't helping matters it is not us that is causing the increased activity of our planet as of late. It is the point charge gaining more charges then it can radiate away.
    Now how did ancient man know about this? Well they were calculators. They learned it through watching and recording events in the sky. Some even started looking at their own planet and figured that the planet would and could have a charge and over time that charge would build up to a massive event of discharge. Now I want you to guess when that will be?
    If one wanted to let some pressure out and relieve the strain how would you do that? Pyramid? all one would need to do is create a slightly bigger charge on the tip of the pyramid to draw off or focus the charges away from the point charge of our planet. Very simple logic right. Charge flow would be from smallest to highest charge.
    Just some food for thought.
    Oh by the way what did Tesla say about exceeding the conductor ability to hold together? BANG???
  • lamare
    Originally posted by Jbignes5 View Post
    Lamare you have finally put the light where it belongs. My own attempts to sway the masses on here into thinking along the line of the great Tesla met much resistance.
    Thanks. I'm beginning to believe it just had to be me. It's very strange, but it seems like not only in the theory all pieces of the puzzle start dropping at their place, that is also happening with my whole life. I mean, why did I study Electrical Engineering? Why was I crazy enough to dive into the adventure of getting involved with setting up a political party? Why did I get myself into the anti-software-patent movement? And the list goes on. I did all that because somehow I knew it was the right thing to do.
    Now I see. These were necessary in order to be able to do this. Without my study, I would never have been able to do this. Without my connection to the Pirate Party, I would never have been able to keep the MIBs of our backs.
    So, I'm sure that the life that has brought me this far, has also prepared me for what's to come, and that will be quite something, even though not many people will realise the consequences of what has been posted here at this time.
    And for those people that are interested in spirituality and symbols, you may want to take a look at my avatar here. And look up what this horn stands for. There's a direct link to Germanic mythology, where this instrument was used to call upon Woden or Odin, the God of death and storm, who would wake up and chase the Fenris wulf. The wulf that ate the sun from june 21st until december 21st. So, if this wulf would not be stopped, there would be darkness forever on Earth. So, my ancestors would take this horn and imitate the sounds Wodan would make with his army of the death, flying trough the skies, sitting on his six legged horse called Sleipnir, and do all they could to help him defeat darkness.
    See: Ossenhoornblazers Markelo | Main / HomePage - in Dutch, but there's a small YT film on there you may like.
    And, you know, this horn uses the power of resonance. And let me tell you one thing: This will resonate with awesome power!
    And I know it will work for sure, cause after all, we have used this horn for as long as history goes, every year, in order to make sure the sun would return after december 21st. And it never ever failed all those years!
    ( Now why was this story preserved just at the place where I happened to be born? )
    One more thing on this. See what Tux wears at his feet?
    Those are good old Dutch wooden shoes!
    Whatever you may think of that, believe me, you can kick some **** with those, if necessary.
    And you know, this theory here is just like a pair of those:
    That's gonna hurt all those who didn't want us to have free energy even though Tesla figured this out almost a centuray ago, you can count on that.
    And you know why there's such a big smile on Tux's face? He's got nothing to fear! Cause he's got nothing to hide.
    The transmitters I believe are crystals much smaller then we could ever imagine which were created when our space (Universe) was formed.
    You know, there's an old programmers joke:
    In order to understand recursion, we must first understand recursion.
    So, the point is: there is no elementary particle. It's a fractal!
    And that is mind blowing. Because that means the fractal goes on both ways up to infinity. Up to infinitely big, and down to infinitely small. And *that* is quite something. It means that in theory you can have billions and billions of complete galaxies and everything else you can find out there withing every single piece of matter.
    Go look for the lectures by Nassim Haramein ( The Resonance Project ). Very interesting stuff. You are going to love his "string theory".
    And finally, that suggests the Universe may be a hologram:
    The Holographic Universe
    The Universe as a Hologram
    Update: If you read this, you have a second reason why General Relativity should go to the trash can.
    Aspect and his team discovered that under certain circumstances subatomic particles such as electrons are able to instantaneously communicate with each other regardless of the distance separating them. It doesn't matter whether they are 10 feet or 10 billion miles apart.
    Somehow each particle always seems to know what the other is doing. The problem with this feat is that it violates Einstein's long-held tenet that no communication can travel faster than the speed of light.
    The first reason is given by Dr. Charles Kenneth Thornhill : http://www.etherphysics.net/CKT4.pdf - The whole idea of a fixed speed of light basically originates in a mathematical error. Because they got the Maxwell equations wrong, they used some freak coordinate transform known as the Lorentz transform, which can only work if the speed of light is constant. Now, we *know* the speed of light is not constant in the vicinity of matter. So, really, this is a piece of junk. Sorry, Einstein, you were wrong on this one.
    But, you were quite something too:
    Albert Einstein quotes
    So, I'm sure you'll forgive me for what I said just here.
    Update 2: And of course, Tesla got it right all along:
    PowerPedia:Tesla's Dynamic Theory of Gravity - PESWiki
    "... Supposing that the bodies act upon the surrounding space causing curving of the same, it appears to my simple mind that the curved spaces must react on the bodies, and producing the opposite effects, straightening out the curves. Since action and reaction are coexistent, it follows that the supposed curvature of space is entirely impossible - But even if it existed it would not explain the motions of the bodies as observed. Only the existence of a field of force can account for the motions of the bodies as observed, and its assumption dispenses with space curvature. All literature on this subject is futile and destined to oblivion. So are all attempts to explain the workings of the universe without recognizing the existence of the ether and the indispensable function it plays in the phenomena."
    "My second discovery was of a physical truth of the greatest importance. As I have searched the entire scientific records in more than a half dozen languages for a long time without finding the least anticipation, I consider myself the original discoverer of this truth, which can be expressed by the statement: There is no energy in matter other than that received from the environment."
    Update 3:
    "A hologram teaches us that some things in the universe may not lend themselves to this approach. If we try to take apart something constructed holographically, we will not get the pieces of which it is made, we will only get smaller wholes.
    This insight suggested to Bohm another way of understanding Aspect's discovery. Bohm believes the reason subatomic particles are able to remain in contact with one another regardless of the distance separating them is not because they are sending some sort of mysterious signal back and forth, but because their separateness is an illusion. He argues that at some deeper level of reality such particles are not individual entities, but are actually extensions of the same fundamental something.
    So, there we got our fractal again.
    Update 4:
    Let me finish this with a few quotes:
    Conscience - Wikiquote
    On some positions, Cowardice asks the question, "Is it safe?" Expediency asks the question, "Is it politic?" And Vanity comes along and asks the question, "Is it popular?" But Conscience asks the question "Is it right?" And there comes a time when one must take a position that is neither safe, nor politic, nor popular, but he must do it because Conscience tells him it is right. I believe today that there is a need for all people of good will to come together with a massive act of conscience and say in the words of the old Negro spiritual, "We ain't goin' study war no more." This is the challenge facing modern man.
    Martin Luther King, Jr.
    Gandhi (1982) - Memorable quotes
    You don't think we're just going to walk out of India!
    Yes. In the end, you will walk out. Because 100,000 Englishmen simply cannot control 350 million Indians, if those Indians refuse to cooperate.
    Mahatma Gandhi
    Military-Industrial Complex Speech, Dwight D. Eisenhower, 1961
    In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist.
    We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
    John F. Kennedy - Wikiquote
    The very word "secrecy" is repugnant in a free and open society; and we are as a people inherently and historically opposed to secret societies, to secret oaths and to secret proceedings.
    John F. Kennedy
    Barack Obama - Wikiquote
    We are the ones we have been waiting for.
    Barack Obama
    Then said Jesus to those Jews which believed on him, If ye continue in my word, then are ye my disciples indeed.
    And ye shall know the truth, and the truth shall make you free.
    John 8
    And I John saw the holy city, new Jerusalem, coming down from God out of heaven, prepared as a bride adorned for her husband. And I heard a great voice out of heaven saying, Behold, the tabernacle of God is with men, and he will dwell with them, and they shall be his people, and God himself shall be with them, and be their God. And God shall wipe away all tears from their eyes; and there shall be no more death, neither sorrow, nor crying, neither shall there be any more pain: for the former things are passed away.
    Revelation 21
    Mike Quinsey - SaLuSa, September 1, 2010
    We know that these messages are received mainly by the converted, which have stirred within and sensed the importance of these times. Others take a passing look but if it does not fit in with their present mindset, it will remain outside of their thinking. However, nothing that you read or hear is without its value, and a new idea can lay dormant for a while and then come to life.
    SaLuSa
  • Jbignes5
    Bravo!
    Lamare you have finally put the light where it belongs. My own attempts to sway the masses on here into thinking along the line of the great Tesla met much resistance. All the references you have here is exactly what I was trying to impart to the very intelligent people who hang out in this forum.
    I have to say you have finally gotten it all straight and complete with references.
    Thank you for continuing the fight when I could not go any further.
    If anyone doubts that just look up my posts.
    Fractals, voltage potentials and zero current is what I have been touting all along after my stumbling onto Tesla's work.
    The invention of our current electricity is a much different beast then what goes on in nature and we have confused the two for far to long. I believe that static potential has been the key since the start. It is how nature runs without needing current to supply the energy or motion. It is the source. Self running and organizing all from a network of transmitters of that motion which give it a form. The transmitters I believe are crystals much smaller then we could ever imagine which were created when our space (Universe) was formed.
    Much like table salt and sugar react to a static charge so does these transmitters. Motion without a price except for the initial charging which was done already in the begining. Self generating through the motion of the particle through the fluid or gas of the aether is what maintains it's source and in fact might add to the source as well when there is enough mass or density. This can be seen in the bigger picture of how we(Universe) is speeding up. It is also what lets us see and can be compared to a 3 dimentional lcd monitor based on position of view of the source.
    Have you ever wondered why Tesla said he could shut the lights off anywhere at any time? He knew how to motivate these conductors either in attractive or repulsive manner. Meaning he could evacuate the transmitters for an area and turn out the lights ability to travel into that area.
    So again I thank you for getting it out better then I could but I was up against some steep opposition. I backed away to further my own theory which is almost complete or as complete as I am willing to go and might be swayed to share again if the community would listen. If not then you are doing more then I could have hoped and should suffice to get the ground work and juices flowing back to what Tesla and a few others understood.
  • DrStiffler
    Originally posted by samedsoft View Post
    @Doc,
    Long time, no talk.. Since I have joined a new Danish Wind Turbine company, I could not visit ou.com and this forum..
    Wake01 experiment reminds me correlation between Don Smith experiment.
    So how do you break the loading to primary?
    How UWB interacts in resonance of primary and secondary? (Only a part of spektrum is transferred and rest is reflected to source?)
    Looking forward to hear from you!!
    You are great!!
    @samedsoft
    If you want to look at the wireless end then this applies to wake01, but for pure gain look at wake03.
    Okay how is it configured; Lets call the two L3 coils off the Exciter L3a and L3b, they are connected as Exciter -> L3a+, L3a- to L3b- and L3b+ open.
    The receiver, call the coils Lra and Lrb. Lra+ to 1/3m counterpoise and Lra+ to Lrb+ and Lrb- open.
    Got that, the coils are all counter polarity and the receive load is connected in the center of Lra and Lrb. If you need a simple diagram I can do it, doubt you need it with the picture.
    Now wake03 is driving 60 LED's from about 6mW from the generator and some of this can be just loss to the environment from the generator lead. This coil is special, it is for all practical purpose an L3 like I supply and a couple of special windings on top with a bit of trick phasing. You might remember the ECAT circuit and the poly-phase transformer I used, well this is the same, except at a higher frequency, around 4MHz.
  • samedsoft
    @Doc,
    You are great!!
  • lamare
    @lamare and all
    @Doc, I don't have time to look at this now, but you need to sneek in a high pass filter somewhere to get the jackpot.
    See:
  • DrStiffler
    Along the same line
    @lamare and all
    Lamar, this is three coils set up as shown, the primary is around a DEB coil of #18 wire on PVC the secondaries are open as is the primary. The HV on the primary is in the middle as expected showing a peak here and drops off at both the open and driving end.
    Now yes you can drive the loads from opposite ends as well as a load on each end. The critical factor in this configuration is that the loads must be balanced to obtain the greatest energy in both loads. It should be seen that we have a set of current coils for the secondaries and the required input energy is minimal, like a peak of 26 * 1E-4 = 0.003 (3mW).
    I think modification of the coil layout will do the trick, although I still think we might need balanced loads, otherwise the resonance of each load segment is different.
    http://67.76.235.52/images/wake01.jpg
  • lamare
    Originally posted by Slovenia View Post
    You are to modest. Very well done Arend!!
    Thanks. So now everyone knows how to pull this off and it is more than time that this information is out in the open. Now it really is just a matter of time before science will be shaken all over. The consequences of this stuff are that far reaching that Tesla will finally be recognized for what he was, and how right he was. And let's be very clear about this: this is not my invention, it really was Tesla's. So, Einstein's General Relativity theory will go to the trash can, as will the "big bang" theory. Really, this is ground-shaking stuff. And some tinkerer out there is about to let all that loose on all those poor scientists that are still trying to figure out what gravity is and are smashing atoms together in order to break them into ever smaller particles they can catalog and confuse themselves with.
    Really, we are in for some ride!
    And let's not forget that we could have had all this 100 years ago, which means there would have been no CO2 exaust all those years and there would have been no Mexican Gulf disaster. This was really to be Tesla's gift to humanity, which has been stolen. Not only from Tesla, but from humanity and mother Earth as well.
    But we know who was and still is responsible for that. We know who the powers that were are, how they lied and cheated to keep us in the chains, how they abused our need for energy for their own gain. We know how they messed with our science and how they kept the truth from us. We know how they abused and even killed our children in their sickening satanic rituals. We know how they messed with our holy books and used them against us in their organised religions. We know what they do in their Bohemian Grove and their secret societies like "Skull and Bones" and "Bilderberg". We know what their idea of "environmental protection" is and what the WWF really does in Africa. We know that the whole "CO2" scam is nothing but another bubble of thin air they can tax us with and speculate with on their financial markets. We know how they used us as canon flesh to fight the wars they wanted us to fight for their gain. We know how their financial systems work and how they use that to steal our wealth. We know that the money they have us work for is nothing but thin air. We know how they keep us into debt and treat us as their slaves. We know what kind of toys they have in their secret "black" programs within their "military industrial complex", how they work and where they came from. We know who was responsible for 9/11 and that Al Qaida is just another one of all these secret armies these fascists use to play their filthy games with and terrorize us with. We know about their "depopulation" plans. We know they tried to poison us. We know they tried to kill us with diseases.
    WE know
    Beware of false prophets, which come to you in sheep's clothing, but inwardly they are ravening wolves. Ye shall know them by their fruits. Do men gather grapes of thorns, or figs of thistles? Even so every good tree bringeth forth good fruit; but a corrupt tree bringeth forth evil fruit. A good tree cannot bring forth evil fruit, neither can a corrupt tree bring forth good fruit. Every tree that bringeth not forth good fruit is hewn down, and cast into the fire. Wherefore by their fruits ye shall know them.
    Matthew 7
    Now I've been around and turned some stones. And those who follow my tracks on the internet will find them and all those other stones that still need to be turned. And then all what needs to be done will be done, just a matter of time, you can count on that.
    You may want to listen to an interview John Loftus, former US Nazi Prosecutor, had with me:
    You can find an English translation of most of the article mentioned here:
    You can read all about the WWF here:
    The Coming Fall of The House of Windsor
    You can read all about their toys and where they got them from here:
    Reich of The Black Sun - Nazi Secret Weapons and The Cold War Allied Legend
    And here you can find out everything about how they messed with our science and our holy books:
    Amazing Discoveries | Walter Veith | Brian Neumann | Victor Gill
    Browse Media - Bible Controversies - Amazing Discoveries TV
    I have watched Walter's lectures over and over again. I especially recommend his "Islamic Connection":
    216 - The Islamic Connection (Med) - Amazing Discoveries TV
    I just love a guy who has done is homework and stands for what he believes in, even though I don't agree with him for the full 100%. The essence of what I disagree with him on is this: I think they messed with our holy books right from the beginning.
    So, I've got news for you, guys. Your days are numbered. The truth is out there now and it will go all the way. Really, you've got nowhere to hide. So, I suggest you back off and crawl back under the rock you came from very soon and give humanity back what you have stolen from them all those years and beg for forgiveness, because if you don't, well, I'm afraid you're going to have to pay the price.
  • lamare
    I've only skimmed this thread so far but as I don't see too much in terms of details for building a device.
    The details are here: http://www.energeticforum.com/renewa...tml#post108525
    Basically do as Puharich did, only drive *two* identical loads and drive them in opposit phase. I really can't tell you much more, because I'm just not good at translating the theory into actual working stuff. So, that would be up to others to do. And from what I read from your post above, it sounds like you may be just the one that can pull this off. It really isn't that complicated or out of the ordinary in terms of electronics to use, but you'll see.
    Update: there's one more detail to take care of. You have to sneek in a high pass filter. See: http://www.energeticforum.com/renewa...tml#post108923
    Update 2: if you want to go straigt to the jackpot for an explanation how this works, go here:
  • ewizard
    lamare, Much thanks for this thread and info. It is good to know about the Pirate party and that is a really important bit of info to help with spreading a final design if someone can come up with a complete set of instructions to build an FE device with available components.
    I've only skimmed this thread so far but as I don't see too much in terms of details for building a device. Which brings me to say that there are so many theories out there claiming to generate FE that I think for this to advance people will need more detail for building this. I'm aware of Beardon's info as well as Aspden, Gray, Meyer, Dr. Stiffler and others referenced here. I also know there are a lot of people on this board much more knowledgeable than I am and do hope some will be able to put things together with this info. Perhaps knowing about the Pirate servers will decrease fear of getting the info out. Actually Wikileaks might be a good place to post a complete set of plans for an FE device when we get to that point as I think it would fit in with their agenda.
    I've got some variations saved on Gray's designs I will look at again but for the most part I think I'm lost without a set of instructions to build something. I can build complex circuits and have even designed some in the past but they were all standard electronic circuits with nothing related to FE generation.
    Lost in a sea of theories ....
  • adamo21
    Guys, you can put a high amount of current from the wall to a copper wire over an iron plate you can make the object levitate. Loyd Bushman a senior lockheed martin engineer talks about this, he mentions the problem is the heat from the current makes it unpractical.
    But, if you could split the current with the force that is actually making the object levitate then you could make this practical...This information in the topic sounds like you could apply it to this theory, i bet you would have interesting results any takers?
    Check out this video, it explains some of what i said a bit, it's an interview with boyd bushman.
    David Sereda with Boyd Bushman - Anti-Gravity / UFO Disclosure
  • Slovenia
    Very Well Done!!
    Just continue to study and study and look at the stuff from every single angle you can think off. And then it's actually really simple:
    The last thing you try, always works.
    You know, that's just like when you search for item you have lost. Think about it. It's always the last place you look where you find it.
    -- Arend --
  • lamare
    I don't know how you were finally able to figure this out.
    -- Arend --
  • tutanka
    Why should I?
    Gray, Meyer *and* Puharich did it all exactly the same, so I'm sure it works.
    I'm really not much of a tinkerer myself..
    And you are right about kW and kV, I know the difference. So, as I said, there are a number of rough edges here and there that need to be straightened out. I don't want to edit the thread, though, because this is sort of my sketchbook and I just like to keep that as is.
    Dear Mr. Lamare I have appreciated your thread but you concept seem very similar to Dr. Harold Aspden .. no news for me only an little variation to the theme.. Regards
  • Slovenia
    Genius
    Lamare,
    You are a genius. I don't know how you were finally able to figure this out. Thanks again for sharing the secrets with us.
    Best Regards,
    Slovenia
