Tesla Chargers | Products
YouTube - Universal Battery Charger | 1AU | Tesla Chargers
I have a great testimonial for one battery I've charged over the last few
days with the 1AU Universal Charger available at Tesla Chargers | World's Most Efficient, Effective & Advanced Battery Chargers
My friend gave me a battery out of his Nissan Sentra that has been sitting
since last spring or summer. It is a typical 12v car battery.
When I measured the voltage, it was sitting at 0.76 volts!! Not even 1
volt.
I hooked up the 1AU and put it on the #6 setting for the highest amps 12v
selection.
After the first charge cycle, it charged up to the 12v range and dropped
and settled at the mid 11's.
I charged it 3-4 more times (without drawing a load) and it was getting
close to 12. I checked the fluid only after these several charge cycles
and it was a little low in each cell, but not much - still covered all plates
so I just topped up to the bottom of the plastic hole.
After the first charge after topping it off, the battery settles at 13.00v.
I hooked an inverter to the battery and ran a 110v lamp that is adjustable
with 3 settings..bulb is 60w and I would imagine it would be pretty
accurate to guess the settings would be 20w, 40w and 60w.
Anyway, I ran it on the middle setting for 40w and it held like a champ for
about 5 hours and I couldn't get it below 12.43v over that period of time
and I didn't want to wait. So I hooked the charger back up last night
before going to bed (early this morning) - I just checked and the battery
is settling at 13.35v!
There is no question it pulls a load as I did it last night so the charge is
real. I'm sure the battery wasn't in that bad of shape as the cells have to
not be damaged to recover it and the sulfation was just sitting sulfation
and not from deep damaging discharge.
In any case, I have a battery that is rejuvenated almost like new after
sitting in freezing temps outside throughout the winter at less than 1
volt and here is is now at almost 13 and a half.
After the current charge cycle ends, I'll load it to the full 60w bulb until
it gets to 11-11.5 or so then recharge. I bet I can get it to sit at close to
14v if not more.
volt.
selection.
14v if not more.
