In this post I shall disclose to you a working and proven free energy concept that can easily be incorporated into a motor or linear actuator, that will provide the rotor/load with unlimited thrust in one direction. This effect will never wear off. This concept is remarkably simple and thus possibly overlooked. This concept is so easy to implement that it can be built by almost anyone. Using this concept an unlimited amount of energy can be recovered through electromagnetic coils or any other mechanical means of your choice such as pumping water against gravity.
This concept is based on Howard Johnson's concept, only much more effective. For the first time his "secret" is revealed to you. This concept is also able to directly prove the existence of an ether.
To replicate this concept only 2 rectangular bar magnets are required. However, more would be preferred since the effect is amplified with greater field strength. The bar magnets must be magnetized through thickness.
To see how to replicate this setup for yourself see the video at Concept.wmv - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com and view attached photos. The concept in the video shows a linear setup exerting a directional thrust on a magnet and little imagination is required on how it can be furthur be developed into a closed-loop overunity motor. It is imperative that the attached photo be read if you plan to build a rotary device. Completing the loop is very possible, but requires an additional design modification overlooked by Howard Johnson replicators. Multiple rotors would be required, being 30 degrees out of phase with each other (Similar to the Perendev Concept)
Please share this information with everyone. Everyone has a right to see this information and a greedy attitude is the reason such information has not been available earlier.
Its now up to YOU to make a difference. YOU have the knowledge and the power.
Credit of this concept and the attached photo belongs to Joseph H Cater. The photo being an excerpt from his book "The Ultimate Reality".
Dr Yin
