Hi all, I have been experimenting as usual. There was a young man who posted some intriguing you tube videos in the past.
He later removed those videos.
A video showed him powering 100 5mm white leds using a speaker wire pancake coil wired as a joule thief.
The output of all the leds was very impressive, full brightness and the efficiency was spectacular.
This motivated me to continue experimenting with joule thief type circuits.
Where a feedback coil is used, which allows the circuit to pulse itself and when the circuit is tuned,
allows for nice performance and efficiency.
I have been testing different coils and came upon a nice combination of parts.
The latest promising results, I'm using at least 100 feet, though it might be more, Ethernet network cable, it has eight 24awg. insulated,
solid copper wires inside that we can use.
I wired them all in 2 wire pairs, so we now have effectively 4 wires.
One of the wire pairs is used for primary coil, another is used for the feedback coil.
The other 2 wire pairs are placed in series and used as a secondary coil.
The secondary coil option seems to help get the voltages higher and into some sweet frequency spots.
The joule thief circuit is not stock, it is tweaked for more efficiency and is running an older 6 watt Eco-smart led bulb.
The secondary coil has an ultra-fast diode attached to one output end, to rectify the primaries magnetic collapsing field,
into a 100uF-450volt electrolytic capacitor.
The output of the capacitor is connected to the 6 watt Eco-smart warm white led bulb and the light output is quite impressive,
considering the power input.
Input is 30 volts - .0009 amps or 1 milliamp or 30 milliwatts input.
Using a boost converter for powering oscillator.
The light output, lights up my computer desk and immediate surrounding area, to perform all normal tasks
that a 1-2 watt efficient led bulb from Ikea, etc. would provide.
I'm very happy at these results and somewhat surprised, even though I'm well aware others have done similar things,
such as the other mans youtube videos.
I would suggest other people re-examine these joule thief circuits, especially using secondary coils and letting it loose,
with the high voltage it wants to produce.
Has anyone else, in the past or present, observed interestingly good results with a joule thief circuit, as I am observing?
Your comments are welcome.
