stable 555 driver
  • stable 555 driver
    dont know about anyone else but hae been down the track of sourcing and building various 555 drier circuits, this is the one ive found best .
    ahura
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    ahura
    The main problem with the 555 is , each time you change the duty cycle , you affect the frequency.If you want something that is by 100 time more usefull than a 555, use a TL494CN , voltage controled . Cost 0.79$ so its realy cheap.
    Best Regards,
    EgmQC
      If you want something that is by 100 time more useful than a 555, use a TL494CN
      Do you know where to find some examples of a circuit that uses it? I have no electronic skills.
        Middle of that page.
        The MEG Project gateway
        Best Regards,
        EgmQC
          Tl494
          AC/DC and DC/DC Power Supplies - PWM Power Supply Controllers - TL494 - TI.com
          TL494 datasheet, Pinout ,application circuits PWM Control Circuit
          There is also SG3524, used in John Bedini Patent -Pulse Charging Battery and Driving Other Devices with Pulse, from 2003.
          Vtech
          General D.Eisenhower
          http://www.nvtronics.org
            Best Regards,
            EgmQC
            like i said "555 driver" there are other chips/config available.
              Best Regards,
              EgmQC
              mmmmmmmm, the MEG , not even going to go there ! TL494CN different story !
                Best Regards,
                EgmQC
                Yes, most of the applications shown in the web include 555 circuits that shift their frequencies when duty cycle is changed.
                I have already referred to a link and also showed a 555 circuit in which the two variables do not "see" each other after their any adjustment, see here:
                Yes, a TL494 is also a good solution. Using a CMOS version of the 555 gives a very little input power consumption for its own operation, this may be a benefit in certain circumstances and also it has a 2-3MHz upper frequency limit versus the some hundred kHz of the bipolar timer versions.
                rgds, Gyula
