    Ok Cifta interesting good to know that there are magnets with polarized face
    Ok Dragon maybe it was a simple motor but was very geniusly built to hide batts.
    Regarding this Zilano schematic did anyone had success on this? Can one use a flyback instead of Tesla coil without coils?
    First, about the batt charging, I am using 2 12v 7amp hr batteries with a Kacher, the topside of the Kacher is earthed, when you do this the entire area becomes electrified. The batteries seem to collect this charge and do not discharge.
    Now as far as using a Tesla coil or a flyback for "charging by induction", well they dont seem to work as well for me. I have found that a true sinewave works way better. I have not been able to get a sinewave from a tesla coil even when in resonance.
    • check out professor meyl
      I can really just say again to check out professor meyls work, as he provides the physics for these phenomena.
      • Originally posted by kajunkreations View Post
        I'm "hungry" of every kacher schematic. Can you post yours ? My problem is the bad luck in constructing anything (devices just start to fail when I'm nearby ) but I really want to see kacher plasma output on top. Working slowly on this but I have only one schematic when oscillation is started by push button between base and collector of transistor. I would like to build kacher which can automatically start.
        • Attached Files
          • Length and width
            Originally posted by atta View Post
            Hi all.
            Don says :- "voltage is in length and current is in width "
            can someone explain this?
            thanks in advance.........
            Hi,
            I was hoping that you would be answered by someone with coil building experience, but as that no longer seems likely, let me try to clarify by explaining my (purely theoretical) understanding of what Don said.
            He was speaking about a Tesla coil L1/L2 combination. The L2 coil gets a voltage generated in it through the action of the L1 coil. Don envisaged the L2 coil standing upright when he was speaking, and so, when he says that the voltage is proportional to the height, he is just saying that since each turn in the L2 coil has the same voltage in it, increasing the number of turns by making the coil taller (i.e. greater height) means that the output voltage will be increased.
            A far less obvious comment applies to the L1 primary coil, and Don says of it that the larger it's diameter, the greater the output current can be. So, he might describe that as current and "width" (of the L1 coil) being related.
            In passing, Don said elsewhere that using a Tesla pancake coil primary placed underneath the L2 secondary coil has a multiplying effect on the output power, the multiplying factor being related to the diameter of the pancake coil, the larger the diameter, the greater the boosting of the output power.
            Hope this helps.
            • @ Patrick
              "#5546 Good Working Circuit"
              Thank you Patrick as usual outstanding effort worth a study,
              JJ
              • various threads are overlapping
                So as not to double post, read my posts here, it just may apply
                Mike
                • I've figured out how Richards Willis Magnacoaster/Vorktex coil and 2 magnets works as a generator
                  It is quite simple but purhaps not the way you would have thought.
                  It is a Magnetic Resonant Oscillator i.e oscillates a magnetic field at resonance.
                  The two opposing magnets are like if you would load 2 springs against each other, pulling or pushing with equal force.
                  If you pull or push in at the center connection between the springs it will load one way and when you let go the try to return to the center of equal force.
                  But as nature is not digital it will not stop at the center but will overshoot a couple of times before settling and you have oscillations like a coil ringdown but with a magnetic field instead.
                  As the coil is situated inbetween the magnets it will be able to shift the magnetic field in either direction and "load the springs"
                  When it releases, the magnetic field rings down but as the coil is in this magnetic field it will generate several CEMF kickbacks, like shaking one of those flashlight and you have several kickback pulses.
                  And I can tell you that it works
                  But it is very sensitive to how hard you tension the magnetic field and how much power you put into the coil charging it.
                  I have added a secondary winding to it that makes it easier to extract the power from the kickbacks.
                  How about that now
                  • Kacher
                    Kajunkreations thanks for response. Can you post the schematic of your Kacher?
                    • Hi Stoker
                      From reading your posts, I assume that your L1 coil with the heavy wire is a full wavelength and L2 is two 1/4 wavelength coils wound opposite in direction to each other. Is that right?
                      What frequency do you use?
                      Thanks for all the great posts.
                      • length and width
                        Originally posted by Patrick Kelly View Post
                        Hi,
                        Hope this helps.
                        thank u very much Patrick i am a real admirer of your work.Its marvellous!!
                        Thanks for sharing such a knowlegde........
                        I never heard don saying about pancake coil previously.I just gave it a thought last night and came to same conclusion about pancake coil.So today i made my own and experimented a little.The results are good but still require a greater dedication and further exploration.
                        I am of the opinion by width DS meant the pancake coil..........may be
                        thanks again I am honoured by your response!
                        • I think Don was trying to point out that:
                          Voltage = Length
                          Amperage = Width
                          This can easily be seen in HV diodes as well as coils. I'm sure there are other components that follow the same rule.
                          Coils with lots of turns makes high voltage and pancakes make amperage.
                          Someone please correct me if I am wrong.
                          Here is my recent email with Bruce.
                          Me: Why did Don say he had working devices and had a unit that did 415v, 240v & 120v?
                          Bruce: He probably did have functional prototypes but they weren't self
                          sustaining. He was close but I held back my favorite gems from
                          him because I knew that he would have ended up taking credit
                          for my research that lead me to them. I worked too long for this
                          to happen again. I liked Don because he was the only person I
                          knew who was so close, someone who I could talk to who
                          could relate to my research but I knew deep down that he would
                          have told people what he got from me was all of his ideas. I seen
                          him do this with some of the knowledge that I shared with him
                          and with many people as well. I really got burned a few times
                          when I was younger and I'm getting to old now to deal with this
                          type of disrespect.
                          • GREETINGS LADIES AND GENTLEMEN
                            BELOW IS A SCHEMATIC THAT I HAVE BEEN EXPERIMENTING WITH AND I ALMOST HAVE ALL THE BUGS WORKEDOUT OF IT.
                            IT IS DON SMITHS SUIT CASE DEVICE BUT IT PUTS OUT AC. DON'S CIRCUIT PUTS OUT DC AND HAS MORE PARTS ADDED.
                            WHICH I MAY ADD IN TIME BUT I AM REFINING IT AS BEST I CAN AS I GO.
                            IT SHOULD BE EASY FOR ANYONE TO REPLICATE THIS . I SHOW ALL THE PARTS AND DEVICES.
                            IF I LEFT ANYTHING OUT JUST ASK ME . ANYTIME I'M AVAILABLE. ONE THING ABOUT THE COILS ON THIS DEVICE
                            AND EVERY DEVICE I HAVE BUILT I WIND THE COILS THE SAME WAY AND I DON'T NEED CAPS.
                            I DECIDE THE WAVELENGHT OF L1 OR L2 IN FT, INCHES OR MM'S IF NEEDED THEN I ETHER DIVIDE OR MULTYPLY THE VALUE
                            BY . 25 FOR 1/4 WAVE LENGTH AND WIND THE COILS WITH THE SIZE WIRE I HAVE CALCULATED. I DON'T TAKE
                            ANY CONSIDERATION FOR THE # OF TURNS UNTIL IT IS WOUND. THEN I KNOW THE # OF TURNS AND THEN I LEAVE ENOUGH
                            FOR THE CONNECTIONS. I HOPE THIS MIGHT HELP SOMEONE THAT IS HAVING TROUBLE WITN FINDING THE RIGHT
                            CAP WHEN THERE IS A WAY TO DO IT WITHOUT NEEDING ANY CAPS FOR RESONANCE. ALL YOU HAVE TO DO IS
                            KEEP UP THE THE ACTUAL LENGTH OF YOUR WIRE AND THEN DIVIDE OR MULTIPLY BY .25 FOR OR YOU CAN DIVIDE
                            OR MULTIPLY BY 4 EVEN FOR THE OTHER SIDE OF THE COIL. I HAVE DONE IT OVER AND OVER ON EVERY DEVICE I HAVE MADE.
                            THIS CIRCUIT WORKS AS IS BUT STILL I AM GETTING MORE VOLTAGE OUT THEN I NEED. SO I STILL NEED TO
                            AJUST THE VOLTAGE DIVIDER SOME MORE. AND THE SELF RUN PART IS STILL IN PROGRESS IT NEEDS REFINNING.
                            REGARDS
                            • SLOW-N-EASY Update!!
                              SLOW-N-EASY,
                              Thanks very much for sharing your update with us!!
                              Best Regards,
                              David Fine
                              • Originally posted by SLOW-N-EASY View Post
                                REGARDS
                                Hi Slow and Easy!
                                ur getting on right track! Congrats! I feel Happy wot u achieved. and wish u to achieve more!
                                good luck!
                                ps: do check the output u r getting is cold or hot. try a small incadescent bulb with filament and touch it if u feel heat then its hot electricity if it feels cold then its cold electricity.
                                rgds
                                zzzz
