Well just in case any of you might miss it and in case OrionLightShip is too humble to point you over there I think everyone interested in Don Smith's work would benefit looking here: Don Smith meets Eric Dollard I'm still trying to absorb the info and implications but it sounds big. It's just a 3 page document so don't miss checking it out as I think it can be highly relevant to work here.
right alignment and right frequency.Originally posted by HaanZilano,
what is it that we are missing in our understanding of caduceus and bifilar coils?.
Your previous mentions of caduceus coils was being discussed yesterday - so it's timely that you are back.
Halbach array - Wikipedia, the free encyclopedia
....Last edited by zilano; 05-21-2012, 11:33 AM.
Copper rod
I've did experiments and continue to do. The thing is that when I followed your schematics one of them the copper rod to charge the source battery as you had posted no charge came to my electrolyte caps.Originally posted by zilano View Postunless u experiment and understand no proof canbe satisfying to u. kapanadze and don showed proof but still they r doubted. thats why i always inspire people to learn more and experiment and see it yourself.
don device is not self running. where as kapanadze's is. rodin coil acts as current amplifier.
rgds
zzzz
Now tell me how can I believe you now?
send me ur schematic. the way its wired in ur circuit.Originally posted by Guruji View PostI've did experiments and continue to do. The thing is that when I followed your schematics one of them the copper rod to charge the source battery as you had posted no charge came to my electrolyte caps.
Zilano
do your remember the flywheel circuit that Ghazanfar_Ali was refering too. I believe he used this on the primary instead of a LC circuit.
Does anyone else know how to make a flywheel circuit.
daveHalf of the Answer is knowing the right Question
This is releavent to the Don Smith device in that Ali said he switched over to using the Don Smith setup.
I was busy finalizing my device. In fact I shared it with a company and now sharing the patent in a few days. there was a drawback that the mosfets got heated due to high current drain and capacitor with initial charge used to lose its energy. So I altered the output stage and followed Zilano technique and achieved fly wheel effect to make it a pure self running device. Its just ingenuity of your mind that u have a starting point from me to end up with a good result.Half of the Answer is knowing the right Question
A tank circuit bounces the charge back and forth through the primary, this changes the polarity of the primary with every bounce, we need the flywheel effect this will keep the polarity in the primary the same every pulse.
flywheel circuit on primary
cw and ccw secondary's
resonance between primary and secondary's
this is the secrets to makeing the Smith device work
A tank circuit works great for a Tesla coil because you want horizontal emission but not with the Smith coils with the Smith coils you want resonant lock and you cant get this lock with a changing polarity.
Maybe Im on everyone's ignore list
dont connect capacitors in series. connect them in parallel. and insert a ferrite rod in the inductor feeding avramenko diodes.Originally posted by Guruji View PostHere is the schematic. Sorry for rough sketch but I don't have electronics software.
zzzzLast edited by zilano; 05-21-2012, 01:45 PM.
hi Dave!Originally posted by Dave45 View Postflywheel circuit on primary
you r not ignored. yes u r right we must have flywheel effect on primary.
rgds
zzzz
Copper rod
Dave I always was gentle with people as far as I know.Originally posted by David Fine View PostGuruji,
Thanks for being a gentleman and sharing your sketch!!
Best Regards,
David Fine
Zilano thanks for your help. My capacitors are in parallel not as the sketch posted before sorry. This is the right one. Many inductors have their own ferrite rod. I've tried a big one and wound coil too but still no charge is coming to caps.Originally posted by zilano View Postdont connect capacitors in series. connect them in parallel. and insert a ferrite rod in the inductor feeding avramenko diodes.
zzzz
