receiving energy always less than transmitting energy
Hi all, I was asked by PM if I knew of any experiments where three or more
Tesla coils were used as one transmitter and the others as multiple receivers.
And if the results showed any energy gain. This was recently posted by
Ronotte at OU.com. Very good equipment was used to measure by the looks
of it.
@ T-1000,
Just to add some personal experience on the famous Tesla power issue:
I built and tested a set comprehensive of one transmitter device and 3 receiver devices as per K. Meyl basic Tesla design. I can confirm that TOTAL RECEIVER POWER is LESS than transmitted power. I used professional measuring devices.
So, it is also true that the Meyl's approach a bit different from original Tesla in many ways, mainly: presence of a virtual ground wire interconnecting both TX and RXs, 6MHz operating freq...etc
Roberto
It doesn't even make any sense that each receiver would copy and produce
the same work (energy) as is being done on the transmitter.
Today I've did this and works well. I did a vid to the toroid and bulb which ends in an arcing on my toroid Don Smith primary driver to toroid - YouTube
My secondary is charging the MO caps as I've said before with the avramenko diodes to an SG.
I've tried to light the bulb on the secondary SG but invain maybe I need more HV caps.
Thanks.
Hi Guruji!
good work ! u r catching on. its like trying to learn a bicycle for the first time. U will get the hang of it. appreciate ur initiative and forwardness to experiment.
keep safe high voltages are lethal. and can kill u. safety first experiment second.
ok i will work on step up now concern to thief circuit what value of capacitors and what do the second half of circuit?
the two transistor oscillator is a high frequency oscillator. its like same as u r using for ur flyback trafo but its different in sense its like pushpull oscillator. frequency can be in in 50 khz to 1 mhz. for that u have to use frequency measuring meter. caps are not hv but lectrolytic in oscillator.
values r unknown of caps except hv caps so u have to use hit and trial method. for pushpull oscillator.
how do we get more amps? wot is the source of amps its cold charges. the more u have cold charges they r in air and how to attract them? Hv is the answer and ground is also the answer. spark is just the door for infinite power. continuous supply comes from resonance of this cold supply.
of it.
Then we must ask again zilano and T-1000 if they want to give us better clue
I think it's related to antenna . I'm not experienced... maybe you will tell me why antenna must be matched to impressed frequency ? What would be the opposite artefact to antenna ? Something which will not radiate energy, right ? but what is should looks like ?????
A ring ?
A ring ?
I do not see coils surrounded around transmitting coil in pic just antennas and ball capacitor plates... Not sure if that was correct setup as N. Tesla was talking about.
N. Tesla had plate then receiving high voltage coil on same resonant frequency but not antenna like ronnote did.
of it.
looks can be deceiving! and there is no equipment made for LMD/scalar measurement. all equipment is based on electrons.
and people dont know full conversion of scalar to vector. so measurements cant be right.
rf frequency dimnish and loose energy over a period of time where as LMD are not effected and they get stronger with time.
People can be deceiving too. And looks can tell truths as well.
People keep saying what is possible without offering any evidence. Have you
done the experiment Zilano ?
Here is a challenge, take a 12 volt battery, take 100 watts worth of 12 volt
bulbs, connect them all in parallel to the battery measure the Direct current
level and the voltage while under load. Calculate the power. And note it for a
reference.
Take a Tesla transmitter and receiver/receivers, excite the transmitter with
100 watts input from the 12 volt battery,using analogue meters NOT digital,
measure the input by using large smoothing capacitors between the battery
and the exciting circuit, at least two, one at the battery and one at the circuit,
measure the direct current between them and check it is fairly smooth with
the scope also measure the voltage. Calculate the power input and call this value "M1".
Other smoothing measures could be taken but the important thing is to
measure smoothed Direct Current to the transmitter and from the receivers.
Then take a receiver and rectify and smooth the output to a load so the load
is using smoothed direct current and measure that direct current and the
voltage across the load, then calculate the power then call that value "M2".
Now take as many actual receivers as you want and place them around
the transmitter, using the same procedure as outlined for the measurements
to produce the value "M2" measure the power from all the receivers while they
are all receiving. Then measure the transmitter power again while all the
receivers are receiving.
Don't forget to get some video and pictures to back up what you say happened.
The onus is not on the ones who cast doubt, to disprove what is claimed by others.
The onus is on the ones who make claims to prove the claims they make.
P.S. If you truly wanted to inspire people, or prove Don Smith was not a hoaxer
you would do this simple experiment and show the result. In my opinion.
reference.
Let me first say I haven’t built or tried this experiment set up and so cant personally vouch for it however should you wish to test the multiple receiver theory I would suggest this well explained build with multiple receivers should be able to answer the question, although of course its primary purpose is to demonstrate the longitudinal wave.
The Aviator slot machine✔️ game lets players observe a plane take off and crash⚡ with a random multiplier. Players bet on the plane's takeoff and respond accordingly. Crash games employ RNGs. So there's no sure method to win (RNGs).
this is an open source project in support of the work of prof meyl and of course proving Tesla’s theories
Great post !! Very interesting and unexpected results - good work! Do you have any idea what the supplying voltage and/or frequency was during these tests.
I'm not at all sure “doesn’t radiate any energy” would be the right term, perhaps doesn’t radiate any energy in a form we are currently familiar with might be a better turn of phrase. After all look at the shape and style of Tesla's antenna's
do you know of any present day transmitter feeding a ball ? No of course not! Tesla was transmitting with a full standing wave. A system not taught and actively suppressed since the time of spark gap transmitters.
