Hendershot Replications
  • Thunderbolt
    I've tried to get a copy of the 2 PDFs, Hendershot Mystery PDF & Hendershot Motor Mystery PDF and no such luck.
    Any idea where I can get them from? The only material I'm using is from Rexresearch.com.
    pjotterkjen, is there some way to download this thread for printing and reading offline?
    I've tried to get hold of some 5" stainless tube, you have no idea how hard it is to come buy, may have to get some rolled and welded.
  • pjotterkjen
    Correction / schemas
    All,
    I was reading the 140 pages thick Hendershot Mystery PDF, and I noticed at page 56 that the author mentioned that (W) means Wire. In my opinion that should be Wrench, not Wire, as it is clear from the drawing that it is a wrench that moves the magnet closer to, or further away from the coils.
    Anyone shares my opinion?
    The document is very complete but I am working on the simplification of all the different schema versions (based on Fuchs work) that are redrawn by the author using the same difficult to read schemas to compare. Will publish some comments on this in the near future.
  • pjotterkjen
    Can you elaborate?
    Originally posted by Thunderbolt View Post
    I mean to say built in isolation.
    I'd like to see you elaborate on this. Morpher44, who started this thread, apparently has the same opinion. If you read the whole thread and view his videos you will notice he has done quite a bit of work on separate component testing.
    Others that were active like mlurye were also active and doing testing on specific parts of the device.
    Too bad they are not active on this thread anymore for more than a half year... who knows what they are into now.
    Anyways, look forward to see your response.
  • boguslaw
    Hi
    It maybe not the correct place to ask , but I cannot find that information.... vacuum tubes heater were build as noninductive coil to avoid inrush current. Can you point me to the link describing how that was done (the shape of coil or method of winding) ?
  • T-1000
    Hi
    I would like to share some findings from experiments what happens with capacitor and coil physicaly being and connected to each other.
    In resonant frequency they have few effects:
    1) This type of LC circuit has bright own frequency and goes on its oscillations no matter what input frequency is.
    2) When resonant harmonics/frequency is hit the voltage potentials can quickly go to kilovolts range in free LC of this type.
    3) When there are current coils making standing waves in right angles to capacitor inside these effects are amplified to very high levels.
    The rest of circuit in Hendershot case seems to be LC series resonance so two things most likely follow what was observed in different experiments:
    1) When you have high potential electric field and high current making magnetic field on 90 degrees the NMR conditions are met.
    2) The free electrons are needed to amplify output so first case most likely was making them available on wire due nature of nuclear reaction beginning stage (obviously you don't want allow to develop it to the end so no transmutation of wire) when electrons are taken out from atoms with large amount of positrons (please see N. Tesla work on this)
    Obviously all this stuff comes from my NMR research just I see it fit for Hendershot case after series of experiments was done.
    Cheers!
  • Thunderbolt
  • Thunderbolt
    I think the different parts of the generator need to be built and their behaviour tested and understood before they are assembled to see what needs to be done to get them to work together .
  • Thunderbolt
    Hi pjotterkjen,
    Here's a Captret link
    Le projet CAPTRET "CAPacitor elecTRET"
    The website seems to be maintained by someone with a good level of hands-on experience and scientific discipline, so I tend to take note of his work.
    Check on some of the overunity.com post too.
    I suspect that the non-connected plate holds a charge of some sort that helps to orientate charge movement => current, esp with respect to the basket coils.
    From other areas of research, I've notice that a lot of other guys around the same time as hendershot were discovering alt sources of energy too such as
    1) Cohler - used a combination of 6 bar magnets with coils that had to be moved into oscilation.
    2) Hendershot - expanded on the idea of a flux gate magnetometer. Just a glorified pair of coils at 90' to each other and using the earth mag field to stimuate them. Then built his basket coild system to overcome the direction problem.
    3)Tesla - built some sort of converter for his car, that needed 2 iron rods to be pushed into place to get it going. They could have been rod magnets who knows?
    Obviously, without hard evidence, it's all speculation. but all 3 individual were subject to public and govenrment scrutiny with demonstratable results. So there may be some connection between them.
    Now let's take things on a slightly different slant looking at larger natural magnets. Planetary magnetics.
    If we look at Saturn and Uranus, they have rings of stuff around the equator. The locations would be the regions where mag flux rope are bending back from north->south, OR if you agree that the north and south poles are the origins of the flux at their strongest , then the equator is where they meet at their weakest strength. Now could charge be liberated at that region?
    Atmospheric studies of the Van Allen belts suggest that at certain regions of the atmosphere contain positively charged particles and other regions contain negatively charged particles..
    Piecing this together may suggest that around a bar magnet the may be electrically charged zones that have to be kicked into motion to generate current.
    Going back to hendershots generator, there are 3 main things going on.
    1) Local oscilation
    2) Field generation
    3) Flux cutting/collapse.
    Once the main magnetic clapper kicks in, the oscilation starts.
    The oscilation sets up a field in the 5:1 transformers.
    A static currnet 'may' be setup similar to the charged rings around some planets (mentioned above)
    The field induces rotation on the ring current in the previous step.
    Since the current would move in a constant circular path, and not oscilate directly, a weave pattern is superimposed on most of the windings.
    The last coil,L4 I think, is then woven in the bog standard manner to derive its' power from the rest of the the device when the filed collapses on the transformer.
    ATM, this is largely speculation based on what I've read and what experience I have of electromagnetics.
    Experimentation and hard work will seperate facts from fiction.
  • pjotterkjen
    Captret
    Hi Thunderbolt, can you elaborate a bit more on the captret you mention? The hand-made capacitor indeed has three plates but only two are connected and nothing is actually connected to the third plate which actually separates the other two and is electrically floating. So how do you see this idea?
    I think Morpher44 could answer your Q about the clapper.
    My idea is that the clapper is part of the circuit so Hendershot would have a means to hear if the circuit would come alive, the same as he used a lamp for visual indication, and a simple voltmeter to measure small voltages (leaving in the middle as to where it was connected). As well as being a frequency throttle, together with the two transformers, which define the frequency of the a-stable multivibrator which the Hendershot device is very similar to.
    Looking forward to your reaction.
  • Thunderbolt
    A possible way forward...
    Hi Guys,
    I've been reading stuff about this generator for a while and I'm slowly acquiring parts for my own build.
    There are a few points I've noticed:
    1) Hendershot mentions that the first prototype cut lines of earth magnetic flux;
    2) The generator could only work when line line with the earths mag field.
    3) He managed to overcome the direction issue, and we have rough drawings of how he claimed to do it.
    4) there are 2 halves of a circuit that have to work with each other to generate power, though a common load, a bit like a 12v->240vac inverter transmformer.
    5) there is also the clapper circuit.
    6) large external caps
    7) 2 hand made cap
    8) some images of the generator have the external 5:1 transformers on the inside of the hand made caps.
    I suspect that the clapper is used as a base oscillator, used to energise the transformers, then that causes a mag field to rise and fall on the basket coils.
    By creating you own source of mag field, you can make the device independent of the Earth's mag field.
    There may be something else going on with the hand made caps as they have 3 plates not the 2 in the schematics and there is a individual out on the web that has seen an unsual effect with electrolytic caps where the case of the capacitor can generate a potential too. look for Captret, or Electrolytic capacitor and Electret. I don't have the link to hand.
    So the first question is, has anyone got the clapper working in isolation yet?
    A
  • pjotterkjen
    More details, please
    Hi Smokey, great post, having read the whole thread I have the impression you're probably the only one that actually has built one specific version of the Hendershot device, and I'm very curious for your results sofar.
    You mention you have built the device that Arthur Aho built just before Hendershot died. The diagram that Edward O'Brian afterwars produced while at his home contains a shortcut at the right 'capcoil'. I wonder what correction did you make in your replication?
    Furthermore you mention both your 'capcoils' are at 7,800 pF, while most drawings mention a value of 7,800 nF. Or is that just a typo?
    Finally, what method did you use to match resonance of both 'capcoils'? I mean it is great to have both capacitor parts at exactly the same value, but the point here is to exactly match the resonant frequency of the whole component. So my question is how did you measure and tune the resonant frequency of each 'capcoil' - in-circuit?
  • David G Dawson
    Hendershot Generator
    Hello Morpher44,
    Have only just found your Forum and thankyou for beginning an information source on Lester Hendershot.
    Have a unit built to the Mark Hendershot 'Archive' schematic which I have noted as having a problem as it is unbalanced.
    Currently have the Arthur Aho circuit built but results have been negative.
    I built an Inverter using a multivibrator using a split-reed V6804 (4 volts) and replaced all of the Magnet/Iron bar/bell ringer coils and this was activated into the 'Archive' circuit with some interesting results.
    I was in the middle of removing the existing transformers when an arc developed which when measured, registered some 11,000 volts!
    Picture of the arc at site below.
    There is absolutely nothing in the circuit (EM wise) that could transform this 4 volts into that figure as I measured some 80 v ac at the output of the Inverter and my transformers are 6.7:1 (ex Blaupunkt TV 'commutation coils').
    So there is some phenomena occuring within the series of coils that is amplifying this voltage and could be basketweave related as this is in the unknown area of the Caduceus/Mobius coil.
    Believe this to be a plasma event as the transfer can be activated without any arcing whatsoever.
    There is more information and pictures here but is open only to those that are actually building the Hendershot device and you will be required to register to join:
    Yahoo! Groups
    Those of you who show interest in this device but not building, will be able to see all the information here on this Forum as I transfer the detail across.
    I am currently going through your detail and finding out what matters and what doesn't and you are doing OK at this point but collectively we might be able to pull this one off.
    Notes of interest are that the twin coils used are out of bell ringer wall telephone circuits and measure 500 ohms each and you can also find these on Fire & School Bell alarm systems.
    You were way down on this figure and need to go much higher and a good indication is to wave a magnet along the length of the coil to see the voltage being induced (more on this).
    The two I have here are from Ericsson and Westinghouse, both Wall Telephones.
    The home-made capacitor detail is also there and it is a requirement to wash the electrolyte off the aluminium plates else you get a capacity something close to the original you dismantled.
    Mine were 1,000uF 450v Ducon (Australia) and without washing still measured 800 uF.
    This is NOT a capacitor any longer but 'something' else and was called an 'aerial' and this may equate to the EH antenna or Fractal antenna.
    This is very close to your UHF TV antenna, two receiver arms with a reflector behind but wound into a helical pattern.
    Draw this out on paper with the dimensions given and see the result, quite interesting and probably an Aether receiver (vertical/helical) and similar to the muscle arrangement around your Heart.
    Both my caps are at 7,800 pF and using paddlepop wooden sticks to maintain this value and works well.
    The paraffin is there to solidify the caps as they are floppy in build and don't believe they have any other purpose than to keep the capacity from drifting.
    The Carbon/Graphite might come later as an amplifying medium.
    The Video/Book is a scam, I built that version and knew, as I gained further information, that it was not going to work as the home-made cap was not even considered.
    This is the 'heart' of this device and my belief is that what Lester built here is the same organisation as your Heart that keeps you alive and is using the same Aetheric/Cosmic energy used to maintain the heartbeat.
    I call this the 'Heartbeat Machine'.
    Frequency (EM) calculated for L4 Copper and L3 Copper is the same as you at 200 khz but with a sig gen attached, comes down to somewhere around Earth Resonance at 148 Khz.
    I have Leds attached to the terminals of the non-polarised capacitors and these are working from both directions meaning that electrolytics are out and what we have is a swinging voltage throughout the system that is working from two directions - a see saw/heartbeat/swing/push-pull, call it what you will.
    Non polarised caps from Hong Kong at reasonable prices, Ebay.
    Will put up some pictures of what is relevant and these will be full size on the Forum page.
    Keep up the good work and back shortly with some pics.
    I have been working with Eric Dollard and his 'Crystal Radio/Set Initiative' and his 'Cosmic Ray Detector' and some other Vacuum Tube projects (which all worked) but have had to put that aside for the Hendershot project.
    Smokey
  • pjotterkjen
    Paraffin wax and electrets
    We know that Hendershot used paraffin in his 'capcoils' most likely to fix the position and after that to be able to tune capacity (not inductance) with the G-like clamps and thereby tuning the resonance frequency of the total component.
    There have been speculations that this paraffin could have been used because it can have special electrostatic effects. The phenomena that can be archieved under some specific circumstances is called 'electret' where the dielectric material is left with a specific stress and thus when placed in between two plates generates a constant voltage.
    "Electrets are prepared from pure parraffin wax by irradiation with β-rays followed by formation in a constant electric field. The charge of the electrets is measured by means of the inductive method and with Faraday cylinder. The dependence of the electret charge on intensity of forming field, forming time, irradiation time, and storage time after irradiation, and the permanence of the charge, are investigated. Electrets prepared in this way have charges of the same order of magnitude as thermic electrets made from carnauba wax and formed in similar forming fields."
    Now could Hendershot - maybe even without knowing - having used paraffin and where this electret effect has been helping to trigger his 'capcoils'? Or did he know the secret very well and kept it for himself, knowing it was one of the key factors to start the generator?
    This is an interesting thought and of course, the wax that he put in between the capacitor and the coils had to be liquid. If only an external field be applied during the hardening of the paraffin, the permanent stress can be created. The only absent ingredient is the irradiation with β-rays, or maybe the paraffin contained some special ingredient at that time that only Hendershot knew of - radium maybe?
    So apart from having two identical capcoils and the tuning process afterwards, in my opinion the paraffin should receive special attention and is a very important step to give the generator some initial potential to start oscillate and actually amplify the energy that flows to either 'capcoil'.
  • Ruphus
    CAP_COIL Photo by ufopolitics | Photobucket
    UFO I have been thinking of a similar design. I was thinking of winding the coil from the top plate up like you have but continuing out and then back down along the field lines in the above pic but still perpendicular. What I visualize is a coil like a ping pong ball but it has a funnel at the top and bottom whos points are at the center of the coil and it has two halves. I had thought of winding it so N and S poles were in the center. I had also wondered of using the starting end of the wind in the center to end up connecting to the bottom outside end of the wind.
    I hope that it clear as mud?! Im terrible with drawing pictures.
  • pjotterkjen
    Fuchs's simplified schema
    I found today that Fuchs (a user on the German overunity forum) publication of a simplified schema is correctly done and represents the schema that Ed Skilling had drawn when he examined the Hendershot Generator from the inventor himself. Fuchs also provides an explanation of how the circuit could behave when actually set in oscillation.
    The schema below is very readable. The document Fuchs published was in German language and I happen to be reasonably able to read it and so will be examining the document to see if I can make some sort of pilot test out of it.
    The main question is what Hendershot first discovered, that is, which part of the schema was first developed by him?
