Making blank water
  • #31
    Water hologram
    I think to produce the kind of water you are after you would need to burn it in a vacuum otherwise you dont have a pure flame as it is mixing with the surrounding metal and air. The flame is meant to be clear but most i have seen on youtube tend to be a color suggesting that the process itself is dirty or the surrounding air is causing trouble. I saw a guy on youtube simply take a meter long copper tube which had been capped at the end and directed the flame into the tube. The air evacuated and when finished he tipped the pipe up and water ran out so maybe theres a way
    I've always wanted to try super hydrated water which distilled or otherwise water which has had hho bubbled through. I guess another thing you could do if your feeling dangerous and are after alkalizing the body is to pass hydrogen gas through an ionizing chamber and breath it. I know of one person that did this and he measured the ph of his urine and it was more alkaline.
    As for the biohologram I guy by the name of Rick Anderson use to own a site which he closed which looked into esoteric science. He made a biohologram unit to test the process. I dont think he mentioned how well it worked. He also did the same for regenerating the bodies energy field using lorentz field and made the circuit available. He had a plant that was in terrible trouble. Put it in this box in the dark with the unit turned on for a week or so and the plant came back to life after he opened the box at the end of the time. Anyway here is the url if anyone wants to read and build the units
    ELECTMNU
    • #32
      DW
      Distilling water only removes minerals and impurities, but does not alter the covalent bond between H & O molecules.
      What has not yet been determined is the exact mechanism of action as to how the memories are being stored. Find that out and then it will be possible to manipulate it.
      With the Japanese experiments, there is no formal published paper that specifies how the experiments were conducted in order for other research institutions to reproduce. Numerous requests to the faculty have resulted in no replies.
      The big problem right now is that there is no standard to measure "blank water"
      Magnetic fields alter water bonds from 13 to 5-6 moleculular structures. In a sense this softens the water and allows for rapid absorption and interaction with other molecules once ingested, as for tasting sweeter, i am not so sure.
      • #33
        Dialetric constant
        At a guess i would say the dialectric constant is what changes. Patrick flanagas book Pyramid Power contains a small skematic to build such a unit. He was using to measure the field on humans. Basically its an oscillator circuit the skin plays the part of the dialetric.
        • #34
          Wiping water's 'memory'
          Flower essences carry the signatures of plants, or the consciousness of or message of flowers in a solution of alcohol (preservative) and water. If you leave a bottle on a tv, the 'message' is wiped, and it will no longer work. I'd say expose water to 60hz frequency of magnetic / electric fields. Has to be a reason 'they' picked 60hz for energy grid. Suppression of consciousness / aetheric / subtle body stuff.
          So just steam water, collect in glass jar with tap water cooling glass thru tubing wrapped around jar. Expose water to oscillating mag field.
          Viola, blank water?
          • #35
            Since I have been researching Baron Karl von Reichenbach in the past weeks, here are my notes regarding baron's experiments with Od (Orgone energy) and water. This is an excerpt from my blog (sorry the blog is not online - it's on my intranet).
            I will paste relevant parts on water, but you will need to familiarize yourself with baron's research on Od energies to get the whole picture.
            When a tumbler full of water was stirred with a clean permanent magnet real and lasting effect resulted. Water which was stirred with either pole gave characteristically different sensations. North poles produced water stimulant while South poles produced an irritant. It was found that water samples were not chemically changed and that the change must have occurred deeper than supposed.
            Od charged water remained active even when poured among numerous glasses. Luminous Od remained in water samples for long time periods. North pole stirred water remained a tonic stimulant while South pole stirred water remained an irritant of nauseating proportion. In addition it was found that hand-held water retained Od. There was a strict polarity transference from hand to sample. Water activated by the right hand produced energetic responses. Water held in the left hand was nauseating.
            Crystals could charge water samples as did magnets and sunlight. Crystal points projected coolness into the water, the acidulous taste resembling that produced by magnetic North poles and violet spectrum sunlight. Crystal bases gave the same nauseating flavour produced through both South magnetic poles and red spectrum sunlight.
            The quest continues...
            • #36
              Another probatly Answer.
              • #37
                Super Ionized Water
                Am i understanding that circuit right in that its goal is to produce super ionize water. If I will definitly be giving it a go. I remember reading the infomraio on it some time ago and was just blow away by what it could do.
                • #38
                  Any one build Super ionizer
                  I was wondering if anyone has built or taken a look at the super ionizer schamtic. I tried looking for a contact email for the site but none. I was wonderin how do you reckon the electrodes a placed. Are they just two points or is one pole connect a metal surrounding and the other in the middle to create a vortex though im not sure that would work without dc.
                  • #39
                    Back to the subject of water, changing quality of water can be accomplished using pyramids in the scale of the Great Pyramid. I know most of you are dead set on circuits, but it's time everyone looks up para-sciences such as Radionics because that part of our environment is totally neglected.
                    Anyway, try it and see what happens.
                    Any size pyramid will work, the bigger the better I suppose, it does not have to be solid, frame is sufficient, but geometry is an issue, angle of the side face must be 51.86 degrees (cosine of that is 0.6176).
                    Easiest is cardboard sides, everyone has cardboard at home, right?
                    I'll do the math for you...just fill in the figures.
                    If h is the height of one side (the triangle forming the side), s is the side of the triangle, and b is the length of the base of the triangle then:
                    Following that:
                    So cut four triangles, with base size of b and side size of s, having height of h, tape them together b forming the square base and you are done.
                    Next step is absolutely crucial, you must align the pyramid to the magnetic north, it does not matter which side faces it but one must.
                    Patrick Flanagan found out that it does not matter where you put your items in the structure, so it will work anywhere beside the King's Chamber. Use your best judgment, experiment with both, but remember the alignment of the pyramid is the most important bit, beside the geometry.
                    Place the cup of water into the pyramid and leave it there for 10 minutes, then taste the water or do whatever other experiments (Kirlian photography, spectrophotometery, whatever is your thing) and report on findings.
                    P.S. I wish this forum would not mess up my in-line images, HELLO ADMINS ANYONE HOME ?!
                    P.P.S. Nobody said you couldn't have cgi-bin/ in the image tag, argh !
                    • #40
                      Product to lower SG
                      Water is amazing any way you turn your head to look at it.
                      Viktor Schauberger's research shows how an egg shaped container allows water to flow continuously, keeping it alive and cool.
                      Water wants to be at 4 degree Celsius = 39.2 degree Fahrenheit where
                      is it most dense (Specific Gravity)
                      Water is like a Chameleon taking onto itself its surrounding.
                      External "things" can change the internal structure.
                      Schauberger said cool water is healthier and it seems there is research that backs that up now. Meaning the Specific Gravity (SG) does effect how your body is able to use water. Water wants to be at 4 C.
                      A product I found claims SG reduction by using it to stir your water and thus
                      makes the water healthier for you.
                      Well, yes, stirring does cool water and lower SG, but you don't need to
                      purchase anything to do that. It's physics that does makes it happen.
                      No water just being cold isn't the same thing as it cooling itself via .. dare I say, vortexing.
                      Read Amigo's posting, good stuff.
                      Amigo said
                      Now, in theory (I have not tried it yet) I believe that artificially structuring water could be accomplished through implosion, by running the water through a votex of specific geometry, as it is done in Nature, just on a smaller scale.
                      I saw a video, no I don't remember where, how this guy only drinks spring water and he vortexes it.
                      He used two 6 gallons (yes 6, but 5 gallons are ok) plastic jugs, he had
                      some glass ones but those are heavy and hard to find.
                      He took a pipe metal fitting which fit the necks of the jugs.
                      This fitting comes with a rubber lining, it was purchased from the hardware store and is designed to joint to pipes together.
                      It has two screws that tighten the fitting down.
                      He found something else rubber, cut the top or bottom off it.
                      I don't remember what it was, but it created a donut shaped rubber item which fits snuggly into the fitting between the
                      two jugs reducing the opening between the two jugs for a tighter vortex formation. .. You've seen the two soda bottle vortex experiment.. this is scaled up is all. He also keeps his jugs with water wrapped in blankets to insulate cool.
                      Randy
                      • #41
                        Originally posted by Tishatang View Post
                        Hi All,
                        Video here to mix oil with water with Ph of 11.5 using electrolized water only.
                        YouTube - How To Melt Body Fat ~ Drink Kangen Water
                        These units expensive. Must be a cheaper DIY way?
                        Interesting link here on water that purifies everything. Old paper, what happened, or just BS?
                        Tishatang
                        Sounds like BS. Again, with the gov conspiracy crap. I pasted the article below. Make of it what you will. Couldn't find part one, but it's probably more of the same. Guess we'll just have to figure this out ourselves.
                        Here's a link to the article. The one above has nothing. I tried to paste the article but it had too many characters???
                        OT:super-ionized water...this is major league stuff here!!! Part 2
                        • #42
                          Thanks for sharing.
                          Welcome to my Gw2 gold site , I was a love of the game, such Aion kinahDiablo 3 Goldas they are usually the most favorite thing to do.
