Originally posted by stephenafreter
The fff is directly connected to the HV supply. In most people's Gray circuit, they connct the HV coil to a rectifier diode, then to a capacitor, and then to the HV rod in the Tube. This fff coil is connected between the HV diode and the Capacitor.
Freeukpower, thanks for the great info. Do you or anyone you know have an actual schematic of any of Al's work? I see the blueprints and drawings on the some of the pages you describe, but no actual wiring diagram.
Has anyone seen anybody else got this much continuous output on the grids without arcing? Just curious.
Also, this goes along with one of the articles I read about Gray's power supply. They said that all the accessories he had attached to the output was wired in series. When I hook two lights up to this in parallel, they "fight" between each other. In other words, they both will not light at the same time. When they're hooked in series, they both light.
. If you're going to experiment with different ground potentials, be very careful! I had a big green plasma like arc and somehow got into my power supply and burned the wires up in my soldering iron.
He told me this when I said I was having trouble getting any usable power on the grids. Who knows. He may have been blowing me off since he had never talked to me before. He said he couldnt say much more because he was under some agreement with someone about the technology and was tongue tied for roughly a year. Anyway, I abandoned the Thyratron idea when I found out that they fire like an SCR. You can control when they fire but turning them off abruptly is a whole different problem (assuming the short pulse duration is what gives the effect). To me, this would have to be controlled with a smaller capacitance to get a short pulse, but still would not give the "abrupt" interruption.
Theoretically you can control both when and how long the pulse occurs.
