You don't need CERN. All you need is a piece of wire of known length, a function generator, and an oscilloscope or voltmeter or ammeter.
Meyl is measuring one resonant frequency, assumes that propagation to equal the velocity of light (it's not. EM waves only travel at the velocity of light in a vacuum, not through the conductors of a coil), and then measures a second resonant frequency then concludes that the propagation is "faster than light" on that basis alone. I assume you've heard of harmonics. Also, longitudinal waves is not "scalar". The mathematics for that is given in Eric Dollard's quote above.
When you know the length of a conductor, then you can calculate the propagation velocity of a wave travelling along it from the amount of time it takes to reach the other end.
From http://www.energeticforum.com/eric-d...ompendium.html
There's no actual faster than light velocity involved. The propagation velocity of the coil is "faster than light" because the wave travels from one turn to the next rather than following the whole length of the conductor all the way around, giving the result of a higher resonant frequency than one would calculate from the wire length using the conventional frequency/wavelength/speed of light relationships. The propagation velocity is dependant on the geometry of the coil.
He's teaching false information regarding Tesla.
New Extra Coil #3:
Diameter = 8.28cm
Height = 8.28cm
93.25 Turns
Conductor Length = 24.256 Metres
Luminal Wavelength = 97.024 metres
Luminal Frequency = 3089.879 kc
Free Space Frequency = 5778.074 kc
Measured Frequency:
Direct connection = 3676.7 kc
10pF coupling = 3990.5 kc
Free Space Propagation = 187%
Measured Propagation (10pF coupling) = 129.14% velocity of light
Measured Propagation (direct connection) = 118.99% velocity of light
Diameter = 8.28cm
Height = 8.28cm
93.25 Turns
Measured Frequency:
7) EXTRA COIL DIMENSIONS AND CONSTANTS
Diameter: 8.4 feet
Height: 8.0 feet
Number of Turns: 100 numeric
Mean Length of Turn: 8 meters
Total Length of Turns: 800 meters
Luminal Wavelength: 3200 meters
Luminal Frequency: 94 Kc/sec
Free Space Frequency: 176 Kc/sec
Actual Frequency: 116 Kc/sec
Free Space Propagation: 187%
Actual Propagation: 123%
Diameter: 8.4 feet
Height: 8.0 feet
Originally posted by Solarlab
