  • BroMikey
    This one is for BYE, watch your head. More nursery rhyme sciences for the weak minded.
  • BroMikey
    Click image for larger version  Name:	heins-law1.jpg Views:	0 Size:	153.9 KB ID:	498524
    Click image for larger version  Name:	heins-law2.jpg Views:	0 Size:	321.1 KB ID:	498525
  • BroMikey
    Been doing some cancellation magnet tests. Jordan wanted to try it out and noticed that the smoothness was shocking. Doing our best to balance between counteracting forces such as metal between magnets (repulsion magnet attracts) we are enjoying our new innovation.
    I our case at low speeds of 1000 rpm's when adding the extra magnets (the big 1" long half inch square) the amp draw slightly increases only 20ma, well worth what happens later at higher speeds. It is a magnetic bearing which gives a freedom in getting up to the higher speeds much faster at a lower voltage. These are tiny machines and to be fair I need a tachometer. Right now it is a game of "seems like" just going by sound.
  • BroMikey
    Originally posted by lotec View Post
    Im not sure what would cause Newton to nearly give himself a frontal labotamy with a long spike inserted into the corner of his eye, but I tend to think that physics wasnt the only thing on his mind. If empty space were truley empty then what difference would mass make?
    Thanks for the good work and the cool links.
    Now that is funny. You are welcome. The empty space was between his ears.
  • lotec
  • BroMikey
    Click image for larger version  Name:	1*B1iOPlrmO0HVqXffqLRhxQ.png Views:	0 Size:	179.0 KB ID:	498511
    Unfortunately, his equations were wrong.
    If we use Newton’s laws of motion to calculate positions on earth using our GPS satellites, it would start out alright…but by the end of a single day they would be off by miles. [1]
    They also give very close, but still incorrect answers to how Mercury’s elliptical orbit changes over time. [2]
    Using his equations to make predictions of objects around black holes or moving near the speed of light yields even more inaccurate results.
    Essentially, if you’re trying to answer questions about objects moving at extremely high velocities or in extremely strong gravitational fields, Newton’s equations simply give you the wrong answers.
    If only there were a super genius that could invent new interpretations of light, mass, space, and time, that fixes all of these problems…
    Newton didn’t know about the speed of light or the fact that things like neutron stars and black holes exist. But he did know that “if [he had] seen further, it is by standing on the shoulders of giants”.
    These insights triggered successive ontological reawakenings for humanity and uncovered new understanding which we set foot upon today in our endeavor to see further still.
    Newton was wrong and so was Einstein, and that’s okay because their insights are fundamentally important steps towards a more fully accurate understanding of reality and our existence.
  • BroMikey
    Unsolved mysterious Lenz law, rubbish
  • BroMikey
    Newton parrot
  • BroMikey
    corrections to lenz's law, newtons 3rd law
  • alexelectric
    Not going to happen bi. Not now. Not ever.
    That series of videos, along with the output of the coils is what we started sending to Aaron before Greyland got sick, and will not be shared anywhere else until after the conference. And NEVER here. Just the links sent to people who are actually building.
    Thanks Mr Dave.
    We continue in the practice to have better yields, hopefully more people are encouraged to experiment and enjoy the challenges that are obtained
  • BroMikey
    Strategically placed magnets on a 14" dia- placeholder at 12" X 3.14 = 38" space for 24 1" magnets leaving 38-24 = 14" of gap area left over to space between magnets 5/16" slots where metal is removed, think about it. Gaps slightly great than 1/2"
    Place holder can be silver soldered into normal rigid material plus balancing can be achieved by the proper cutting of slots.Just bangin out a rough questimate.
    Click image for larger version  Name:	rotordesign3.jpg Views:	0 Size:	85.8 KB ID:	498480
  • BroMikey
    For those of you following the continual upgrade of this innovation please note Thanes new rotor designs which he has many. This one solves many problems. Not only is Thane an EE he is also good on the mechanical end. Liquid plastic rotors are out of the question for large power generation applications as heat would turn them into more like rubber. The gaps are also just a little wider between magnets to stop bleed over with CNC slots between magnet holders. The core only sees air in between poles on the rotor much like the silly rubber design (Sorry dave) but with super durability. Power plants need steel rotors as does any EV traveling down the road in 120-130 index heat plus heat from the coils to be of any practical use to the public. I pick on Dave but he got the job done, time for the rest of us to get off our azzez and carry the ball down line.
    Problem solved. hats off to you Mr Heins ole buddy ole pal. I count 24 magnets on an approx 14" rotor dia.
    Click image for larger version  Name:	rotordesign.jpg Views:	0 Size:	95.9 KB ID:	498478
  • BroMikey
    Nuts and bolts for the genX freaks
  • BroMikey
    Show me one, please.
    3rd party proven by Michael Moore, more to follow, same as my video's
  • bistander
    Manufacturers are picking up the innovation. Unlimited range
