Also a box with 12 magnets on the rotor running at 2800rpm is going to have a lower RMS waveform average than a 24 magnet box
12 x 2800 divide 60 = 560 hz
24 x 2800 divide 60 = 1120 hz
Your nichrome filaments are not designed for 100hz-1000hz inside the light bulbs. You will have no idea of the kind of power that machine can produce until you use a load that is properly matched to the output. You may need three bulbs in series.
Motor Generators
Yes, that coil data was wrong.
with iron cores you can get 120 volts at 1.5 amps per coil.
But run it over 30 minutes and it heats up too much.
With these new coils heat is not an issue. But he is only getting 77 volts at 1.3 amps out of a coil PAIR. Now that is with a 12 magnet rotor and not a 24 like the new machine. It is also with mismatched coils, so the numbers could be much different.
Yeah that guys box is smooth at 1100rpm. Lets hope if he goes to 3x that fast it will also
hey dave, i thought you gave the new coil data. Are you saying the data was wrong? You going to next years conference?
288v x 1.35 a per coil pair
I have a working machine. I have ALWAYS had a working machine since the day Old Clunker was built. The day the rotor exploded it wasn’t working for a few days, but bistander is the only one who will jump on that. Even when it wasn’t running, the machine still existed, and within a few days it was working again. I WILL always have a machine. Old Clunker is so noisy you can’t talk over it. It won’t stay in adjustment. And frankly, I haven’t felt safe in the same ROOM with it since the rotor exploded.
For those reasons, Black Beauty was built. But it did not produce near enough power with the all North magnet rotor design, so I am assembling Black Beast. It will be together soon. My buddy who built it already has HIS together. But he is a machinist and can easily mate old parts to new. It takes me more time. I got his video of it running last night. I need to route out a section or get shorter bolts. I will get them tomorrow.
The NEW machine COULD out produce the old machine with a 24 magnet rotor in it instead of 12, if I put the same coils in it. But then it would get hot after about 30 minutes. So I am using coils we have found that don’t get hot and am STILL looking for a better core material. With the new cores, this machine MAY not produce as much as old clunker. I won’t know until I have it running.
I am making a series of videos on the machine and how it is put together. I am on video #7 right now. When I am done with the machine everything you need to know to build it will be in those videos.
Bye is doing what he always does, jump the gun, calling you everything except a white boy. 14,15th and 16th version data collection in progress and Bye thinks you don't have a "ROYAL FIZZBIN"
It takes time to build and compile.
Originally posted by bistander View PostNine days ago you said that you had a working device.
That is a bold lie.
Truth is that you did not have a working device
Truth, Turion. Face reality. Piling on more and more lies,
