Motor Generators
Like this?Originally posted by Rakarskiy View Post...
https://www.kjmagnetics.com/calculat...calcType=block
PS: I haven't found anywhere else yet, a similar methodology for calculating the resulting ampere force
https://www.calctool.org/CALC/phys/e...ism/ampere_law
history lesson of Tom B. MEG
Originally posted by Lunkster View PostMotionless Switching Magnetosphere Electric Generator
This Generator is designed in the shape of the Magnetosphere.
The core of the generator has a common switching coil(electromagnet) with
two large permanent magnets on each side of the coil. There are fins
around this core. There will be several fins around the core so that
the assembly will look like a sphere. The fins have permanent magnets
spaced out in the fin in such a way to move flux from one magnet to the
next magnet in the fin and then through the core finally flowing
through the fin again. One the outside of the permanent magnets in the
fins are coils. The coils are spaced farther from the permanent magnets
so that the normal flux flow moves from one permanent magnet to another
producing one large ring of flux flow using the core as part of that route.
The magnets and coil in the core are larger that the fin magnets so that the
core can handle the travel of the sum of flux flow from all of the fins in
the generator.
This generator design is different than the Sphere Generator I have already
designed because it uses permanent magnets in the core rather than
core material. I believe the permanent magnets will provide better
assurance that the large ring magnet function will work. At least it should
work better than core material. Also, there is only one coil per permanent
magnet in each fin rather than more coils in the sphere generator. The
reasons for this change are that having one coil outside the permanent
magnet means it is farther away from the core, this will reduce negative
interaction between the fin coils and the core magnets. This design
will also allow more fins to be placed into the generator. More fins
means more power generation. The coils in the fin need to be large
enough to handle the flux that will be moving through the coils.
The operation of the generator is about the same as the sphere generator
I have already designed. This new design will operate with more power
and efficiency.
The way this generator operates is that each fin assembly works in conjunction
With the common core assembly. The normal flux flow is of each fin is through
the core creating a large ring magnet. So, the generator will have several large
ring magnet actions being performed at the same time.
There is one large coil that has a core that supports all of the flux flowing
Through its core when the power is off to the generator. Once the power
Is turned on to the coil, the coil produces a magnetic field that opposes
The direction of flux flow through the core. What this does is it breaks
The large flux ring flow of the flux for each of the fins. The flux then
Looks and fins the next easiest route for the flux to flow. Most of the
permanent magnets in the ring will then start to use the core in the coil
that is closest to it in the fin assembly to travel through to get to the
other side of the permanent magnet. The reason it takes this route is
because the core material is an easier path than an all-air path to get to
that side.
The electric power generation is performed through the coils that are
Beside the permanent magnets in the fin assemblies. The is wire wrapped
around the coils cores that will have electricity flowing through them
as a result, change in flux movement. In fact, there is flux either starting to
flow through the coils or reducing their flux flow with each change in the
electrical condition on the one electromagnet at the center of the generator
core. With the best switching speed for the generator, it means that the
electromagnet can operate at a 50% duty cycle while each coil in the generator
can collect alternating current 100% of the time. So, the generator uses one switching
electromagnet operating at a 50% duty cycle to be able to collect electrical
energy from several coils at the same time.
The electrical energy to produce a magnetic field for a 50% duty cycle in this
Generator should be a lot smaller than the several coils producing electrical
Energy from the several permanent magnets that are changing their flux
Routes. This is similar to a FET or transistor where a larger amount of energy
is being controlled by a smaller one.
Please build one of these, you will be glad you did.
I have written three books on unique generator and motor designs along with several applications for them.
It has come to mind that the best invention would be a generator that does not need outside energy to operate it.
This generator design utilizes the internal power that is already in permanent magnets.
This is my best design so far.
Once you have free electrical energy production, then the efficient motor designs I have are not as valuable because you can still
use the current ones. But if you want an electric car that never needs to be plugged in, then I would still pursue
the motor designs in my books sold through kindle direct publishing.
LunksterLast edited by BroMikey; 12-11-2021, 05:14 AM.
