Ernst
The deeper you travel down this rabbit whole - the more narratives that you will find that "explain" how it works. Each has its fervent followers.
What we are short of is proof that the scientific communities will agree upon. Or should I say proof that the public domain scientist will agree upon.
Technically you should be able to accumulate and utilize ambient power in some form, to do work. There are systems that require less power as you add load. On the face of this, that is not consistent with "it was provided by the power station" as an explanation. And even to strengthen that case, when you drive the circuit from a battery - there is no utility.
If you have such interest, and an open mind many Single Wire Power systems are likely creating radiant or like events - wave events that are harnessing HF high density power that once transformed can drive conventional loads. There is much evidence that suggests that a radiant or like event is an exchange with the environment. In fact, if you really want to keep it simplest - isn't all power energetically birthed (primal source) from the potentials that make up the ambient?
Only man could be arrogant enough to believe that he invented electricity. Nature organizes just fine without man's opinions and perspectives. A static charge? Lightning? Both examples of natures way of balancing the micros to the macros, that naturally occur in potentials to equilibrium. Potentials that build and balanced as a natural component of unlimited forces that exist all around us.
When we pick one flavor of energetic belief and spread it like gospel, we shut off our brains and all other possibilities.
When collaborating to gain new understandings there is no voice less important. Each of us cannot impose our limited "it can only be this" belief as a filter to new thinking.
The largest body of innovation will first exist in the counter-intuitive. For those with such ambition, we must each leave our comfy chairs of belief and join at a round table and exchange ideas. From this, all is possible.
Single Wire Power - A Search for Ambient Power to do Wwork
There is one more perspective.Originally posted by Bob Smith View PostFor me, this would be the crux of the "antenna" issue. Please correct me if I have misinterpreted the positions.
It seems to me that one perspective envisions an AC charge at resonance moving across the capacitor plates, and through the load and into/along the wire leading away from the load.
On the other hand, there is the perspective that an AC charge at resonance reaches the proximal plate of a capacitor and induces a difference in potential vis a vis the distal plate. The ambient medium, seeking to restore balance, would respond through the distal plate, with a responding charge of its own, matching the frequency of the incoming charge. In this sense, though it might appear that the charge might be moving through the capacitor, something different is actually happening. I believe that it is in this sense that DavidE is looking at the capacitor and wire leading away from it to and from the load as an "antenna." I believe Don Smith has an illustration in one of his videos which illustrates this effect. Perhaps someone can post it. If I'm able to find it, I will.
Please correct me if I'm wrong in interpreting these two positions.
Bob
The inner circuit; capacitor plate - load - capacitor plate, has a neutral charge meaning that it contains evenly distributed positive and negative charge. When the outer circuit; capacitor plate - generator - capacitor plate, is energized it induces an electrical current in the inner circuit by alternately attracting and repulsing charge on the capacitor plates.
When the outer circuit plate of capacitor A is made positive, then the outer circuit plate of capacitor B will be made negative, thus the inner circuit plate of capacitor A will attract electrons while the inner circuit plate of capacitor B will repulse electrons.
In this way the inner circuit gets polarized. The next half cycle the polarization will be opposite, so the electrons will have to move through the inner circuit from capacitor A to capacitor B. Meaning that there is a current in the inner circuit, without a true (conductive) connection to the outer circuit and without any role of the ambient medium.
I use the same mechanism to power ignition coils with 240 V mains power. If you're interested I can provide a picture and/or diagram.
Ernst
Now I see what you're saying. However in the things I've shown there is no capacitor in series, the output comes directly from the coil.Originally posted by Bob Smith View PostFor me, this would be the crux of the "antenna" issue. Please correct me if I have misinterpreted the positions.
Bob
Personally I see many problems with the idea in relation to the stout copper bars experiment. To begin with, the nodes are present, which is explained by the standing wave principle as Tesla observed and described it. How would the nodes be produced by the atmosphere?
Also if you were to charge something, it's true that nature will want to restore balance, but that will usually be in the form of heat to cold, high potential to low potential. That is to say, energy will escape out of the system in an effort to equalise itself with surrounding space. All of space is unlikely to try to charge itself up to match the potential of an experimenter's little contraption. The sun's energy radiates to the cold of space, but space doesn't try to heat itself up to restore the imbalanced condition.
All in all I don't see why anyone would be led to believe that anything "unconventional" was happening. The effects are unusual, but I don't see how they imply some gaining of energy from the environment and such.Last edited by dR-Green; 06-12-2015, 12:59 AM.
For me, this would be the crux of the "antenna" issue. Please correct me if I have misinterpreted the positions.Originally posted by dR-Green View PostTesla lore indeed. The point in all of this is that the use of a capacitance terminal that enables a filament bulb or such loads to work from one wire in such ways has nothing to do with the terminal being an antenna or receiving anything from the environment or any other source. That idea simply isn't necessary and it doesn't explain anything because that's not what can be observed to be happening.
Bob
Tesla lore indeed. The point in all of this is that the use of a capacitance terminal that enables a filament bulb or such loads to work from one wire in such ways has nothing to do with the terminal being an antenna or receiving anything from the environment or any other source. That idea simply isn't necessary and it doesn't explain anything because that's not what can be observed to be happening.Originally posted by DavidE View Postwayne.ct
Argumentative? Spirited exchange based on two very different perspectives. For me the sun does not rise and set based on Tesla lore. His contributions to our current quality of life are beyond debate. But many others have followed in his footsteps bringing forward even broader energetic possibilities.
wayne.ct
I'm talking about single wire transmission, and I believe I've already said the radiant energy patent is based on receiving energy from the environment. Also that you may use natural activities to your advantage.
There is nothing to suggest that energy comes from the environment to cause a load to work with one wire.
From Colorado Springs Notes
Originally posted by Nikola Tesla... In this experiment the entire energy supplied to the structure or capacity C had to pass through the lamp.
Originally posted by Nikola TeslaBy providing capacity in any way, so as to enable the lamp to take more energy, the potential required may be reduced at will.
Capacitors are used in high pass filters and for DC blocking because DC can't pass through the open circuit. But AC quite readily passes through. Bigger capacitance allows lower frequencies through. Cutoff frequency increases as capacitance is decreased. You hear it in effect every time you listen to music, as it's all filtered and EQ'd. That's how the electronic audio equipment works.
1/4 wave resonance (for example) is possible because a standing (quarter) wave distributes itself along the length of the conductor. There are different potentials at every given point along the conductor despite the fact in your mind you think it's a short circuit or it should all be at the same potential. It's not at the same potential 5cm down the line because the potential is distributed according to the standing wave. That's also why sparks appear at the top of a Tesla coil and not along the whole thing. There's a potential gradient from ground potential to the terminal potential.
The picture illustrates in a neon tube what occurs on the stout copper bars or supposed hairpin circuit. Light and dark, or energised regions, appear according to the driving wavelength/frequency. Connect your bulb to the high potential point and it will light. Connect your bulb to the low potential point, and it won't.
Tesla explains it all very well in his article on the experiment.Last edited by dR-Green; 06-11-2015, 10:40 PM.
Regarding DavidE and dR-Green
One of you is being reasonable and carefully reading what the other is saying. The other of you is being argumentative and NOT carefully reading what the other is saying. Still, you are beginning to talk at cross purposes. It is obvious to me that during a thunderstorm the atmosphere at altitude is at a different potential than earth and a rather conventional device could be constructed to capture the "ambient" energy. THAT "ambient" energy could add up to a substantial amount with the correct device. Therefore, you are both right. At the same time however, you both appear to be very stubborn and hard headed. I hope you resolve your differences, but you are going to need a lot of "luck".
Dollard on Electricity
[VIDEO]https://www.youtube.com/watch?v=yQuNvqbH6ac[/VIDEO]
dR-Green
In general I can see no matter what inventor or what invention, in your view the ambient does not energetically participate in any way. In fact your view is even more implicit... if power shows up in the ambient, it was placed there by artificial means.
So is it your wave theory that has power jump from plate to plate on a capacitor to power a load (hairpin circuit)?
Not at all. It's hard for me to consider that air will jump into a balloon on it's own accord, when the pressure inside the balloon is greater than it is outside.Originally posted by DavidE View PostIt appears hard for you to consider that energy could be like air, its everywhere. I am quite sure before man, there was energy and not the other way around.
As far as single wire transmission is concerned I see no reason to believe or suspect that anything "unconventional" in terms of gaining energy from the environment is going on. It's just a transmission system. No power is transmitted that you did not input.
If you are using the earth as the transmission medium, which itself has a natural resonant frequency and various natural electrical activity, then it's conceivable that you might be able to work with it to your advantage, but that hypothesis requires tuning so that the whole thing becomes one continuous system.
The radiant energy patent is an entirely different principle and is not a tuned system. Stick a metal plate in the air and it will charge a condenser, but a transmission system is a transmission system, one wire, no wires, or however many wires as you like.
dR-Green
Where did you say that the power was coming from to light these loads?
dR-Green
I like the way you simplify Tesla's work, but there are many others that have published significant bodies of work from theoretical to practical that shed light on a larger story. Like Bedini, Moray, Smith, Casimir, Beardon, etc.
If you consider their experimental work, there is often a less conventional explanation for why power appears at places that you would not normally expect, when filtering results with traditional understandings.
Referencing these inventors above, who do you think is less than credible relative to their offered energy perspectives?
