  • Wistiti
    The earth is a big ball of steel/iron so when the energy sees a steel rod
    that is nothing special to the earth. The copper is something special to
    electrical charges because copper has a very low resistance.
    So when the energy sees your copper rod it wants to go to the path
    or least resistance leaving the high resistance path through the iron ball.
    Stick with Clarence and his gift to us. Receive his gift of many man hours
    of trial and error. All of Clarence struggles to overcome the lies of the patent
    documents. Clarence gift is only good if we all receive it.
    Thanks Clarence, I heard you the first time
    In my opinion it have more to do with the magnetism than a kind of galvanic effect... If so, a big mass or area of steel may attract it... But maybe I'm wrong...
    Clarence, what is your opinion on this important part of the system?
  • totoalas
    Welcome
    484 is your number for 60hz 234vac or 220vac some say 240vac.
    Be sure you tell me the size of your toroids. If they are close to Bridgeports then you will be right on. It is the industry standard in most cases.
    You will be right on.
    Me and hitby are thinking send some ac into the captor at 30,000volts.
    The captor excites AND injects ac power using rods then collects many times more from the earth.
    But you are going to be away from this design so i hope everything works out. Gotta try something.
    im planning to do the same inject hv from the two prinaries from the 2 ignition coils in last hitbys video to generate current in the captor
  • BroMikey
    Originally posted by masen View Post
    What type of grounding rod is best? Do they need to be copper coated? Does galvanized work or stainless steel?
  • BroMikey
    Originally posted by totoalas View Post
    Thanks Bro Mickey
    Im trying to make as close as possible on Clarence desi9n
    Since the output of the inverters are 110 v ac x 2 and in our country
    220 v ac Live and Neutral ...... im planning to adapt the 220 v ac 60 hz
    primary
    thanks
    Welcome
  • totoalas
    Thanks Bro Mickey
    primary
    thanks
  • masen
    Type of Grounding Rods
  • wayne49s
    Grounding
    Hi,
    Any advice the grounding network? I think this is the most critical part (my previous effort didn't work because of that). What is the spacing between the rods? I might only be able to go about 6 feet because I might hit bedrock; I read the spacing should be twice the rod length. Is there a way to check if the there is enough ground rods by checking the resistance between the neutral post at the inverter and the captor ground terminal?
  • BroMikey
    If transformer cores are purchased for 50hz operation the specs of that transformer must be given 50hz.
    Volts/turn@50HZ and 60hz windings are not long enough so excessive current draw will break down the wire. I think it is a 17 percent variation from 50hz to 60hz. Big changes.
    To refresh on transformer practices look here. I hope you enjoy it.
    Transformers Part 1 - Beginners' Guide to Electronics
    The rest of you who do not have the Engineering tools or have the mind for this type of work, stay home and order.
  • BroMikey
    Thanks Level,
    I just want the winding turns size for a 110 v primary since cores can easily be bought here in China
    most are 22o v ac 50 hz primary Can this be applicable to the circuit also????
    Im planning to buy on Sunday so just making sure i got all the info needed
    If you are going to wind your own toroidal core no matter what Clarence tells
    you then I can help you and others so they do not fail. Many people can not get the exact Bridgeport cores where they live and shipping would cost them $200 USD.
    Clarence has also pointed out that a third transformer is not needed, however the tiny set of 2 loops electrically connected to the 4 input grounding stakes is technically the third transformer.
    Yet Clarence is sure about his diagram having tested this already so please everyone stick to the diagram that Clarence has put up. What I have been doing separating individual circuit branches for your review may be misinterpreted as an open door for redesigning Clarence work.
    It is not an open door for changing anything, just a segmented view to help us all get focused on Clarence layout a piece at a time.
    If totoalas wants to wing it and wind his own primary for 117vac then he or I could call technical support and ask them how to wind our own and that is what I have been telling everyone that I have been doing for years.
    Those guys don't care, they tell me what I want to know WHEN I buy a core, so if you are buying a core that is for 60hz operation at 300va then use 21awg wire and winding only half way around like the picture Clarence posted. If you live inside the USA and can get the cores cheap already wound for $125 each, save yourself the trouble.
    If you are able to wind a toroid then you already spent the money on a winding machine and understand how hard winding toroid's are.
    totoalas!!! you must look for the information on your core and yes 5.2 dia. Each core material supplier has a number that looks like this
    Volts/turn= ???
    At "Bridgeport" ALPHACOREDDIRECT it looks like this V/TURN@ 60Hz 15kG
    Silicon Steel Toroidal Cores - In Stock
    Look at this chart for P/N 110 there you will find a 5.2" O.D core listed. About $40 shipped inside the USA.
    Next look at the Volts/Turn@60hz the number says .483
    This means that each time you wrap a loop of wire around THIS specific core you will get .483volts
    Now to find the number of turns is 117vac divided-BY .483 = 242 turns
    Now if you are going to use a thinner wire to wind a 234volt transformer (117vac +117vac = 234vac) then you will need twice as many turns.
    Maybe 24-25awg wire for 234vac operation at 484 turns at 50hz?
    Are you going to operate at 50hz? If so you can not use 60hz winding information.
  • clarence
    Correct as usual level!!!!
    Originally posted by level View Post
    Hello totoalas. See Clarence's reply above about reading post #6.
    According to that note, Clarence custom ordered the two toroids without the secondary, so that may be why the part number is designated as TD300-1120-P, rather than TD300-1120. I am attaching the specs on the Bridgeport Magnetics TD300-1120 toroid, for which I would guess the toroid dimensions should be the same as the TD300-1120-P, except that the TD300-1120-P doesn't have the secondary wound on it. Clarence can confirm if these toroid dimensions match his toroids or not.
    Hello LEVEL,
    you are amazing sir. your excellent grasp at all times is an outstanding value to all of the members Sir.
    The TD300-1120-P is the toroid that I buy and use. know Level that I previously Built the larger SINGLE toroid Modules and fired them up easily and they put out almost the exact same level of Captor AC amps as B&L's did in their early three Gray Box Demo. their value on the second unit was 116.+ and mine was 126.+ that is why I can say and know that this toroid is excellent for the job.
    thanks again for your post!
    Clarence
  • totoalas
    Thanks Level,
  • level
    Toroid dimensions for the TD300-1120
    toroid winding size and info before i buy the core 5,2 inches? thanks
  • totoalas
    Hello totoalas,
    go back to PAGE 1 - POST #6 to get the CORRECT toroid part specification!
    it DOES NOT have a secondary winding on it!!! and that was the way I ordered it and use it!!! YOU- YOU -YOU are going to wind the secondary
    windings on it which MAKE UP THE CAPTOR LOOP! (the 2/1/2 #4 AWG wire).
    If you use the part information in recent post it will come with a secondary winding on it which will HAVE TO BE REMOVED. AND it will cost more for something you can't use!
    I have tried to get that point across several times but I guess everyone keeps missing it! thanks Sir!
    Clarence
    Hi Clarence
    your toroid info is crystal clear..... im planning to wind my own primary and just buy the core or as you say which ever is cheaper in China......
    so far no luck on junk amplifier and only a 3 inch toroid is in my spare ...... want to minimize the cost as much as possible with near results .......
    thanks again
  • clarence
    Correct toroid specs before ordering
    hi bro mickey and Clarence
    nice diagrams
    toroid winding size
    and info before i buy the core 5,2 inches ?
    thanks
    Hello totoalas,
    Clarence
  • totoalas
    nice diagrams
    toroid winding size
    thanks
