  • daviniobb
    Core material
    Hello everybody.
    I am trying to replicate Clarence's revision of the B&L device with no good results at the moment. If it is possible I would like Clarence to answer some questions, please.
    Does the core have to be necessarily composed of ferrite? If it is not necessary, which material could be appropiate?
    Must the core shape to be toroidal? Why or why not?
    Thank you in advance.
  • boguslaw
    It should also depend on years of being a member...
  • vidbid
    One Thousand or One Million - It Makes No Difference
    You only have to post 1,000 times to be a gold member. But of course as you can see none of the posts have to make any sense.
    That's exactly right. You can post whatever you like, even re-posting what others have posted, including videos.
    You can even post demands that others show their work.
    Of course, all such demands can be readily denied with complete and utter equanimity because they're absolutely meaningless.
  • BroMikey
    Originally posted by djarno View Post
    Stuff is getting freaky now.
    1500 heater runs maximum performance ofcourse with an 1000Watt inverter.
    I melt my cable, even with an voltage controller.
    Remember that a 1000 watt inverter is too small to power
    up 4000 watts at the load.
    From what I understand of this CAPTOR system that Clarence
    built and tested is that the battery charger must be powerful
    enough to keep the battery charged. So let's say I wanted to
    power a 100 watt light bulb plus send 250 watts from the
    charger to the battery to keep the system a float.
    Now I have a 100 watt light running for free because my battery
    is kept charged. Remember that you are not doing that.
    This is why your inverters catch on fire. Here is what you need.
    Using a 1000 watt inverter and a 500 watts charger you now can
    send 200-400 watts around the system in hopes that you can get
    extra energy to flow. If you have 60 rods.
    If you have 1 rod it will be less and so on. But you have to have
    something to start with that will not catch on fire plus many rods
    to run max COP's.
  • djarno
    Originally posted by tvka View Post
    Seems too lot about electricity to explain to you...
    There are AC and DC capacitors...
    However, if capacitor shows short, it's rather broken
    On both lines amp's drop to 0 (or minimum not sure), which goes through ground loop which is like 90 volt depending on load aswell weather (ground wetness, I don't sprinkle it whole day for wet ground), voltage spikes to 227 volt and the 1500 heater runs maximum performance ofcourse with an 1000Watt inverter.
    Only occurred 2 times for 4-10 seconds, while looking at the volt meter varying.
    There is no capacitor.
    See pictures.
    I try to record and replicate it .
    Also I removed the second toroid as I melt my cable, even with an voltage controller.
  • djarno
    It's AC condensator for sure.
    Anyways I'm going to experiment more and more.
    Pictures and video's coming
  • tvka
    Voltage drops, while current increases.
    Disable some grounding means more voltage drop. I have no 12v capicitator only 220 and 450 but 450 will kill the inverter and the 230 doesn't seem to charge to 230.
    But the capicitator might be broken, how can I test? Ohm or resistance meter? 😢
  • djarno
    Friend, I absolutely believe in your sincerity
    Clarence setup will never work- because of voltage source in primary.
    I explained in previous.
    Yet, as you have grounding, (I have none) can give you idea
    Take 220/12 V transformer and series connect it with 50/60Hz resonant capacitor (huge)
    Why 12V? resonance has to increase it.
    And figure how to disconnect primary- transform will be crucial
    May be Yuri_L method.
    I understand russian perfectly. Yet video was not assuring.
  • tvka
    Protocol ?
    Perhaps, I'll still have to try it with sufficent load (thus 1000 watt or less) and disable the ground. If 'amp' building doesn't occur it is more then transformer right ?
    I have no reason to spread false information here. I only want it to replicate OR 'debunk'. I also still have to look if more load is pulled when amp building utilizes in the transformer(s).
    Any suggestions ? I understand that you won't accept video's as they can be faked, but once again I have no reason to do so.
  • tvka
    I am sorry tvka, I wish I could understand.
    I don't understand everything you write but
    I am glad you are impressed
    Keep trying maybe I understand you later.
    Keep trying. Better late than never
  • clarence
    [QUOTE=wantomake;278467]Thanks my friend and fellow can kicker,
    Yes it takes time and energy for life's needs.
    I look forward to your next project "alternate potential system instead of ground rods". If I'm reading that correctly.
    More later,
    wantomake[/QUOTE
    Hello wantomake,
    I need a PM please.
    thanks,
    Clarence
  • BroMikey
    Originally posted by mobigozer View Post
    BroMikey, maybe contact Youtube-user Stivep1/ Wesley can help with the communication to YURI?
    H
    Yes if we need to but Yuri is well able to do his video in english.
    Wesley is a good choice for translating.
  • BroMikey
    The Schumann resonance is a set of spectrum peaks in the ELF'''''''''''''''''''''''''''''
    ''''''''''''''''''''''''''''Since 1980 it has risen to over 12 Hz. And now at 14.1 Hz.
    '''''''''''''''''''''''''''''''''''''''''''''''''' '''' The system must be in phase with Schumann frequencies?
    The system is told to collect energy from the ground in a specific
    format. 120vac at 60hz. Thx for the history, I hear this about earths
    resonance being higher now but I never have confirmed any of it.
    Someone says if I pick up more electrons then my voltages will
    go higher but instead voltage is held the same while earth CURRENT
    is harvested and used at the load.
    I am not to much at explaining this stuff and I am only speculating.
  • JESUS PIÑA
    No, these systems use inverter frequency 50hz or 60hz to
    collect usable energy so we can run a refrigerator. 7.83hz
    is no good for motors. The system puts in a 50hz or 60hz
    frequency and 120vac in tiny amounts forcing this small
    bit of energy into the ground. Then the earth adds more
    to the same format. The Captor sets up the voltage and
    frequency, but only provides 5 percent of the load.
    The earth energy piggy backs more electrons.
    Ride that wave gentlemen. It's like surfing, you get the
    board pointed in the right direction and let that ocean
    wave carry you home.
    You need 60 rods.
    The Schumann resonance is a set of spectrum peaks in the ELF (extremely low frequencies: "extremely low frequency") of the electromagnetic spectrum of the Earth. Since its seventh overtone (harmonic) is located approximately 60 Hz. The lowest rate, while the high intensity of the Schumann resonance is at about 7.83 Hz. The detected overtones extend to the range of kHz (kilohertz). The resonance of Earth (Schumann Resonance) has been 7.8Hz for thousands of years. Since 1980 it has risen to over 12 Hz. And now at 14.1 Hz. I think when in 1752 American Benjamin Franklin (1706-1790) investigated the natural electrical phenomena. The particularly famous his experiment in which, flying a kite during a storm, showed electric shocks, I think the truth was not an electric ray, but a burden Schumann resonance induced by the time was 7, 8 Hz. The system must be in phase with Schumann frequencies?
  • djarno
    Hi!
    Sorry, I will not accept videos. Protocol, if you can
    This story has nothing to do about ground. It's transformer story.
    Yuri_L maybe has solved it. Lenz law is not broken- just utilized.
    So voltages in ordinary transformer are in-phase, secondary current lags 90deg. By adding fat secondary shorted and some portion of primary counter winded MAY Be in that portion EMF is induced to counteract primary consumption and fully utilize energy stored in transformers core.
    Protocol ?
