It looks like the 4 lever shafts in the upper section are driven at their top end
by being attached to the gears. This would mean that the top end of the shaft is orbiting in a circle. then the shafts go through the 2 way, x/y pivot, then the bottom of them sticks out to drive the translation plate. If the top is going in a circular orbit then the bottom must be as well.
I don't understand why folks are saying it goes back and forth or an ellipse.
If the shaft is directly attached to the x/y pivots rods then it can't spin.
So the attachment at the top to the gear must be something on the order
of a universal joint but that can also pivot on the gear.
Both the top and bottom of those lever shafts seem to describe an orbiting cone shaped motion as drawn in the pics.
To me, both the top (coffee can) and bottom weights are sort of being
driven in a hoola hoop type motion.
It's leverage multiplied 3 times at least. first by the cone motion levers,
then by the coffee can weight, then by the large tall bottom weight.
all 4 large gears in the top and bottom sections (assuming they are gears rather than belts and pullies) are turning the same direction so that must mean that there is another gear between them (the large gears) and the central gear. This could mean there is more mechanical leverage from
the gearing.
The whole machine appears to be bolted together rather than welded.
I wonder if that was by design of maybe back then a welder wasn't too readily available in a home shop.
Does anyone know what those turnbuckles and cables are for on each upright.
there must be a clutch in the upper section. His left hand is on that lever.
this machine might take some time to fully engage the clutch or he might have to turn the weights by hand to help it start.
Thanks for posting this. I'm going to attempt to make a small version
using me meccano set.
Tom
the gearing.
Tom
