Cr�me de la cr�me (perhaps)
  • #76
    My circuit? That was your circuit - first one in your post above - lol anyway just wanted to mention I built it. Now here is something a bit more interesting. I got this from a scanned PDF member 'wings' posted at OU - Quest for Zero Point by Moray King. Very good book. From pages 78-80 (or 39-40 if you are using the PDF viewer page count) this info I found very interesting and I think relevant to some discussion here. Apologies for below text may not be perfect as it was OCR'd and then quickly corrected some errors.
    " Pappas (1991)hypothesized all sparks produce excessive energy. Shoulders (1991) demonstrated that excessive energy can be created in any electrical discharge that produces EV's. What if every spark naturally produces submicron plasmoids (even smaller than Shoulder's EV 's)? Finally, there is abrupt ion motion on the inception of any spark, fulfilling Moray's hypothesis. There is a strong likelihood of some ZPE coupling in any abrupt electrical discharge. In fact some investigators have proposed that an abrupt voltage pulse with only (vacuum) displacement current and minimal charge motion is sufficient to produce anomalously excessive energy. Bearden (1993) proposed this is his "final secret, and Hyde (1990) used this principle in designing his invention (a mechanical electrostatic field chopper) that reportedly output 20 KW while self running. Hyde stressed there should be no corona present whatsoever. The Swiss ML Converter could likewise be sirnply explained if indeed there were energy in all electrostatic pulses.
    Electrostatic pulses or abrupt voltage spikes are notoriously difficult to tap efficiently as an energy source.
    Many inventors have directed high voltage pulses to recharge batteries with claims of over unity. Unfortunately such pulsing often damages the battery, and of course, an energy machine that cannot self run, but instead relies on batteries, is unconvincing to skeptics.
    Clearly what is needed is a method to convert voltage spikes to a useful form of power, preferably DC. Hyde (1990) had to solve this problem in order to make his machine free running. His solution (described in figure 6 of his patent, also King, 1993) took advantage of the fact that even though the individual electrostatic pulses were of high voltage, the current (and thus power) of each was very low. This allowed Hyde to make a voltage divider current multiplier circuit utilizing a large number of inexpensive capacitors and diodes that could be run in excess of their voltage specification without damage. High voltage electrostatic pulses were converted to amplified current pulses at a lower voltage which were then rectified to DC by Standard means. Hyde empirically solved a difficult engineering problem, and the solution allowed him to build a self running energy machine. An easy to build, efficient, current multiplier would facilitate wide spread experiments to investigate claims of excessive energy in electrostatic pulses or sparks, as well as form the basis for a solid state zero-point energy machine. The following Pulse Current Multiplier (PCM) was inspired by Hyde's invention. The PCM is based on the Standard
    voltage division technique of charging a bank of capacitors in series,
    then discharging them in parallel. Figure 3 illustrates four stages of the
    PCM. In practice it is desirable to have ten or more stages. The high
    voltage pulse is input across the A terminals at the polarity shown.
    The sharper the voltage spike, the better the performance.
    The inductances should be the minimum value necessary to block the
    input, for they must allow the output current (as a slow rise time pulse)
    to pass with minimal attenuation. Hyde did not show any blocking
    inductances in his patent. Since he developed his circuit empirically,
    perhaps long or coiled output wires provided a sufficient blocking in-
    ductance to achieve the same behavior. Ferrite beads might also suffice.
    Since the PCM uses inexpensive components, it offers an economical
    investigation of a possible ZPE coherence associated with high voltage
    pulses and discharges.
    A ten stage PCM amplifies the current by a factor of ten. Two
    such PCM's can be combined in series to create a multiplication factor
    of 100 (Figure 4). The output from the first PCM is impressed across the
    input of the second. Since the pulses entering the second PCM will not
    be as sharp, larger blocking inductances will be required in it. The principle
    can be extended to a third PCM in series to give a multiplication
    factor of 1000. Thus a sharp 40 KV spike could be stepped down to a
    less steep 4 KV pulse and then to a wider 400 volt pulse. The second and third PCM 's will require more robust circuit components since
    appreciable current is being accumulated. Once the pulses become sufficiently wide, then Standard, solid state switching technology can be used instead of the blocking inductances to create a PCM via Standard electrical engineering, voltage division techniques. Such a PCM could be
    employed last in the series. An appropriate configuration of PCM's can
    thus become an efficient voltage spike Converter.
    output current pulse occurs across the B terminals. The inductors' purpose
    is to block the sharp input voltage pulse (via high impedance) and
    channel it down the (low impedance) series path which should be physically short.
    spark energy and what we cannot see ... here the analysis
    discovery34
    and the effect
    • #77
      discovery34
      and the effect
      related to this :
      Spark Gap Experiments
      The Worldwide KAPAGEN successful replications
      • #78
        sorry I'm late machine!
        Originally posted by machinealive View Post
        Well Duncan
        I will take a stab at your question, mainly, because I want you to continue, and for some reason, you always stop, never to finish, and I'm never sure why. I'm not answering because I really know what your getting at, so go easy.
        First, I assume your granite was raised, ridges, and not just a stain?
        So, once upon a time, cells were placed in wooden boxes, which didn't work well.
        Edison used metal box. The metal box would discharge to ground, not good. So now we use plastic, insulator, and it should not matter if you put your battery on the cement floor.
        So if you are getting ridges in the granite, then we have an ion flow, so we either have a magnetic field attracting ions, should probably say, inductive or dielectric field causing ion migration.
        Machine
        • #79
          Hello Duncan
          Thank you for taking the time to post. I was hoping that all you just wanted some input. you mentioned batteries and antennae before and I was always interested, but hard to do everything. I always wanted to try and build a foundry, with an induction heater, I have all the parts( that the smallest parts list I've ever needed). And this is just to simple to not try, plus, you know, I'm a simpleton, so, who knows.. I'll post anything I find, will definitely need to spend some time thinking about LA batteries a little differently.
          Thanks again for sharing Duncan
          Machine
          • #80
            Hello again Duncan
            I should of wrote more. Just so you know, I also believe this is the correct path, but you already know that
            On this occasion I have a possible conjecture that you might find interesting .
            Yes, this is exactly the principle I am seeing in Tesla's machine, to operate. ( and many more, once I realized). Pure induction motor. We'll see. I'm really excited about this.
            I have a 2 phase gen finished, my toroid wound, but I just can't seem to get the time to finish. Over next couple days I hope.
            You know, only a few would even bother to look up what your talking about, but that is life. Maybe One person opens a book, with the intent to learn, with passion, then it was worth it..
            You do know, in Latin, Dr., simply means, teacher.
            I love your spirit Duncan, your a fighter, and whether you like it or not, you are a good teacher.
            Here, for those who can't open books.
            Machine
            • #81
              For the 1%
              Originally posted by Walter Russell
              The law which applies to one effect of motion applies to all, whether sound wave, electric current, color spectrum or octaves of elements of matter.
              • #82
                Russell?
                dR
                Hopefully Duncan won't mind but I have to ask you a question, since you are also a Russell fan, and you are thinking of longitudinal waves a lot.
                I love this Russell pic. How an AC wave developes. Very similar to what Barbosi was talking about in his "just magnetics" thread, the wave is not moving.
                However, in regards to the longitudinal wave. As the stone hits, we get impact. Now, I am thinking, the stones hits, the E's represents reproduction or " reincarnation", of the impact in octave harmonics, along the inertial plane. Could that be the longitudinal wave front? Almost instant, then the AC wave, develops slower.
                Edit should not have said AC WAVE ( on my mind), you know, should call transverse?
                Machine
                • #83
                  The Bells, the bells - the bells are my friend's
                  dR
                  Machine
                  The Jigs Up !
                  Thanks again for your input its always welcome!
                  • #84
                    Duncan
                    The Russell picture seems to be what you were trying to describe! If you have never read Russell's stuff, maybe you should give at least that section a good look over. Earthquakes to music. It's got er all.
                    I always wondered how much I could learn, if I actually tried to build a big heavy old fashioned bell. Russell shows you how. I always wanted to build a pipe organ as well. Lost arts. Such a shame. I'm lucky here in Nova Scotia, we still have craftsman, glass lowers, barrel makers, blacksmiths, you name it.
                    Love this quote
                    "A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects."
                    Robert A. Heinlein, Time Enough for Love (1973)
                    And then there's George
                    http://m.youtube.com/watch?v=hkCR-w3...%3DhkCR-w3AYOE
                    Machine
