Mr Lester J Hendershot's magnetic generator.
  • Thought you guys might get a kick out of this ; Hendershot Generator Complete "do It Yourself" Kit Includes 2 5 Hour Video | eBay
    Pricey!
    Please note that I am NOT the seller of this item
    edit: somebody bought it.
    • Still feel annoying when being disturbed cell phone calls? Don’t want this bad thing to happen again and again in your life and work? Ok, do not be anxious, the mobile phone jammer can be your first and best selection. And if you want to know more about this kind of device, gsm signal detector you can gain the useful information you want.
      • Originally posted by Xenophanes View Post
        Too many liars in today's world !
        I would recon that it could not work as Hendershot demonstrated with those non-original values of electrolytic capacitors, also without any foil type core-capacitor tuning arrangements.
        I don't see a proper horseshoe magnet being provided either - large good ones are not cheap, and very difficult to find these days.
        Complete ?
        Do not miss out on Morpher's postings yesterday -
        Cheers ............. Graham.
        • Magnet strength
          Originally posted by GSM View Post
          Hi thx1138.
          I love to read of your magnet findings thx, but do I wonder if our modern magnet versions might actually make it more difficult for us to realistically replicate a Hendershot generator ?
          I will post whatever I find. They are supposed to arrive next week.
          Since we don't really know anything about the magnets that were used everything is a guess at this point. The only reference I've seen is to a "radar magnet". My guess is that would be relatively powerful even in the 1950's. There was AlNiCo and SuCo at the time and, indeed, neodymium will be strong per volume but we don't have dimensions either so there's really no way to determine what the magnetic field strength was. Getting AlNiCo or SuCo magnets manufactured for the project is way out of my budget and I haven't been able to locate any 1950's radar magnets. Even if I could find one or two that would be a problem for replicators and scaling.
          It kind of surprises me that more info wasn't given on the magnets because they such a critical role in the circuit. On second thought, I guess it would go a long way in hiding the critical info.
          Part of my testing will be to determine scalability factors should I ever get anything working. In that regard more magnetism in a smaller area would seem to be a better bet than less. Even at $250 per 60 Watt bulb it still seems to be a non-starter except for emergency power. And doubly so if it is not scalable. It seems like it should be scalable because of the early (20's) reports about the work with airplanes but, again, at this point no one knows.
          The bottom line is that no one knows whether stronger would be better or worse and there's no way to tell until we get one working. So - Onward, through the fog! So they said on the Titanic also.
          • Looking for ring magnets supplier!
            Would anybody know of a good supplier of ring magnets? I have been looking around here and only found one store so far, they're specialized in all sorts of magnets but they haven't got what I'm looking for and custom orders have a minimum of 3000 dollars... that's way out of budget! They do have ring magnets but the inner diameter is at most 1.5 inch, too small and I don't know if it would be possible to increase the inner diameter with machinery.
            What am I looking for? Core ferrite, polarization over the diameter, outer diameter about 3 inch, inner diameter about 2.5 inch, and thickness about 2 inch, or that could be several aligned ring magnets also. If they have a website please include the link.
            TIA!
            • About the ring magnet core material, I mentioned ferrite, but it is more likely Hendershot used alnico magnets or similar alloy, so I'll be focussing on that while searching for one.
              • Ring magnets
                It seems like I've seen some lately in my searches but I'm in the U.S. You might try searching "3 inch ring magnet" or "3 inch speaker magnet" or "dual magnet speakers".
                http://www.dhgate.com/product/profes...158818092.html
                I'm not sure but the speaker magnets might be magnetized through the faces rather than the circumference.
                There are always these but they are only 30 degrees so you would need 12 of them at $33.81 each is $405.72 plus tax and shipping. Not $3000 but not cheap either. They are magnetized through the circumference, have 2" outside radius which would make it 4" diamater outside, a 1" inside radius which would make if 2" diameter inside, and 1" high. Assuming you would need one of these for each cap/coil, we're getting around $900.
                K&J Magnetics - Products
                I'm not sure but I would think it would be possible with a high speed grinder or sanding drum like a Dremel tool. Just stay away from cutting tools and don't get the material very hot. You might need to set up a jig to get any uniformity rather than doing it by hand. Otherwise, you'll end up with a warped magnetic field.
                I had surprisingly good luck with a coarse sanding drum on a Dremel tool in a hole in a hardened steel safe door I needed to enlarge for a new lock. Try it on a scrap piece first.
                I don't have a clue what it will do to the magnetic field, though. My guess would be less material = weaker field. I'm not sure what it would do the poles either since you are asking for circumferential magnetization.
                • magnet strength
                  Magnet strength is always relative. It depends on the situation and saturation, frequency, neutral line shifting, etc, etc. I think in terms of magnets we should be sticking with what was available at the time, like strong alnico magnets. Remember that ferrite material was only used to substitute alloys because it was cheaper but the properties are very different.
                  As you say thx1138, we need to build and fiddle, that's where we'll be able to clear the fog, slowly but surely. There's too much fog nowadays on these devices, and IMO most of the posts we read only add to the thickness of that fog. Also documents that we read won't be 100% trustable.
                  That is why I've decided just like mikec_ut to build first the MK1 device. And I'm guessing I will have to go even further back to find out what Hendershot found out and how he came to the MK1/2 and MK3 designs. Once we have the principles that made him design the MK1/2 and MK3, there are many ways to reap the generated free energy. MK1/2 and MK3 are only some specific implementation of all those possible devices.
                  For the MK3 I'd stay away from any other build than the Arthur Aho one, based on the pictures that crusty published. And even then we would need to check the circuit that he published to see if it was electrically correct. That's our best action plan, and there's not much else we should be doing. Take everything step by step, trying to follow the inventor and get to think like him, using the same stuff he had available. There's no other way. Build, test, publish, change parameters, test, publish, etc.
                  It won't be easy and even worse there's the certainty that - because nobody has built a working replication so far - there are several pieces missing. I think one of them is a ring magnet at least in the MK1/2 (Major Lanphier referred to it but the draft patent did not), and for sure other pieces are missing in the MK1/2/3 device, so we need to be prepared for this.
                  • ring magnet
                    Thanks for this information thx1138, this ring magnet has got me searching all over the place. Speaker or microwave magnets could also be good choices, but nowadays they are very different than the magnets that Hendershot were using I guess and that worries me a bit.
                    Building a ring magnet from several (alnico) pieces would also be ok I think. But that would be plan B or C.
                    Just that you know, I'm working on the MK1/2 replication - have got some coils ready but am on the outlook now for suitable cores - so I'd only need one ring magnet, but it is a thick one - 2-2.5''. And I am assuming circumference polarization but it might also be radial, so will be trying both.
                    Machinery I don't have, so I'd need to find some other person or company to do that for me. If alnico is not within reach, then the ferrite ring magnet I found here in a local store specialized in all sorts of magnets might work fine, several stacked and with inner diameter grinded to about 2.5'' that would be ok I guess. The problem is that it is a ferrite core - this material was not available at the time Hendershot made his first discoveries (1925-1927) so I prefer alnico at this moment.
                    • Magnet info
                      Assuming you can find an alnico ring magnet, the Dremel tool for shaping it is $50><$100. Just don't get one of the really cheap or battery powered ones because they don't have enough power. You can get the individual tools like the sanding drum individually at most good hardware stores. They are handly for a lot of things and have an amazingly diverse array of cutting/grinding/sanding/polishing fittings.
                      MK3: It appears I was right about the hard drive magnet backing plates. They are used to contain the magnetic field so it doesn't interfer with the magnetic media in the disk drive that is used to record data. I'm still not sure about how they can be made into an armature because of their size and shape. But the fact that the material is in every hard drive made means it should be plentiful if I can find a source.
                      But it looks like I was wrong about the read head actuating arm voice coil magnets being magnetized through the circumference of the arc. It appears they are magnetized through the faces. Look at the colored diagram about 1/3 way down the page at this site:
                      Tutorial on the Rotary or Swing Arm Voice Coil Actuator used on modern Hard Disk (Disc) Drives
                      • Originally posted by thx1138 View Post
                        Thanks for the info, sounds doable! Would that Dremel tool also work when working with ferrite cores then, or does that material require other tools? If so, which ones?
                        • Cremel tool vs ferrite
                          I'll try it tonight and let you know.
                          • Dremel tool
                            The only ferrite I had on hand was one of those snap on devices that goes around a cable. It was much softer than I thought it would be. It loaded up the sanding drum very quickly. It also loaded the grinding stones but to a lesser degree. I had a tungsten-carbide cutting tool with flutes along the shaft that worked fine on the both the ferrite and one of the spare neodymium magnets I got out of a hard drive. Be sure to wear eye protection. The tooling puts out a very fine powder from both the ferrite and the neodymium. Sorry, I didn't have any alnico to try it on.
                            The tool I'm using is a Craftsman from Sears. Dremel is the originator of the tool and you can still get them under that brand name but I guess they have licensed them to other people. It is a 28,000 (twenty eight thousand) RPM, fixed speed model. I think it is that high speed that keeps the cutting tool from chiping the ferrite. But at that speed cutting or grinding heats the material being worked rather quickly so be careful. Especially with magnets you'll have to watch the heat.
                            They also have all kinds of cutting tools. I have a diamond edged cutting disk that I use for cutting a lot of different things both hard and soft. Since the diamond is just on the edge and it's fairly coarse it doesn't get loaded up in soft materials. It would probably work well for cutting ferrite rods or toroids into segments.
                            A couple of links follow. The first one shows the tool I use. The second shows the wide array of metal and wood working tools and some attachments to turn it into a router or a drill press.
                            Craftsman Single Speed Rotary Tool with Accessories by Dremel | eBay
                            https://www.google.com/search?q=drem...w=1024&bih=624
                            • Be careful. I heard that dust from neodymium magnets is toxic.
                                Thank you for that warning boguslaw.
                                Seems particles are highly flammable with poisonous fumes as well.
