This is the guy who invented a special motor for Greyhound Bus Lines that the government would not let them buy. Does anyone have any updates on this?
What ever happened to Eneregy Inventor Rory Johnson?
Plans
Excelerator,Originally posted by EXCELERATOR View PostThis is the guy who invented a special motor for Greyhound Bus Lines that the government would not let them buy. Does anyone have any updates on this?
At one point I received what looked like a complete set of blue prints for the Rory Johnson, self running electric motor. It was really complicated and operated on a theoretical basis I did not understand. I probably still have the plans somewhere in my mess, but I have never heard of anyone else even trying to replicate his work.
Sorry,
Peter
Can you explain it please more, where you see something like a Conflict in P.L's Answer or that this Reply is not polite?Originally posted by EdwardFranklinPeter this is no way to answer . . if you have conflict with some one you can politely tell them
Its a clear Statement, that the Schematics look complicated, and at a theoretical Basis.
What is your Problem here at your Post #1.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Sorry for the Confusion
Dear Edward,Originally posted by EdwardFranklinPeter this is no way to answer . . if you have conflict with some one you can politely tell them
I apologize if my previous post was too short for you to understand, so here is my second attempt.
1) Dear Excelerator, yes I have heard of the Self-running engine invented by Rory Johnson.
2) Six or seven years ago, one of my colleagues sent me what appeared to be a complete set of blueprints for the construction of the Rory Johnson electric motor. It included a brief explanation of its operating theory.
3) I believe that I even took the plans and showed them to John Bedini at one point. This must have been sometime around 2006.
4) The theoretical explanation of how the machine worked was unique, and I had never heard of any other system running on it's principles.
5) After studying the plans for a while, I didn't really understand why the machine could both self-energize and convert the electric currents into mechanical energy. Apparently, I did not understand the theory.
6) I am not saying that it either worked or didn't work. I am saying the theory was unique and unfamiliar to me and the plans showed a very complicated design, and that I did not feel competent to evaluated it.
7) Since then, my office has been moved 3 times, and I currently don't know where the plans are, as I don't have all of my files out and available.
8) Beyond this, I have never heard of anyone ever trying to replicate Rory's work.
I hope that makes things clearer.
PeterLast edited by Peter Lindemann; 04-10-2012, 03:08 PM.
spammer
I think he is a spammer simply here to post 5 links to the same website in his signature line. I'll delete it after you all see this.Originally posted by EdwardFranklinPeter this is no way to answer . . if you have conflict with some one you can politely tell themSincerely,
According to Rex Research, he passed away.Originally posted by EXCELERATOR View PostThis is the guy who invented a special motor for Greyhound Bus Lines that the government would not let them buy. Does anyone have any updates on this?
Rory Johnson: Magnatron engine
The Rex Research article sure makes it sound like the motor was harvesting its own back EMF spikes produced via wide mica spacings in its commutator, and using it to increase its own power. The larger than usual "off" time allows the BEMF spike to be generated and harvested. Probably where most other motors need to go.
Bob
There must be more to it than this...otherwise Peter would not comment on his lack of knowledge on how it worked.Originally posted by Bob Smith View PostThe Rex Research article sure makes it sound like the motor was harvesting its own back EMF spikes produced via wide mica spacings in its commutator, and using it to increase its own power. The larger than usual "off" time allows the BEMF spike to be generated and harvested. Probably where most other motors need to go.
Bob
Thanks for update but...
Originally posted by Armagdn03 View Post
Thanks for the update but do you know how and when he died and give us a link to follow-up on? ThanksThe harder you work the luckier you get!
Not sure if this'll provide any further info. I'll read thru it this weekend if I can. Doesn't seem to be too much out there
Howard Rory Johnson: Magnatron – Light-Activated Cold Fusion Magnetic Motor for Energy Invention Suppression Cases
Bob
Bucket of Cold Water
Hello Folks,
The plans I saw for the Rory Johnson motor, with Rory Johnson's signature on the papers, were for a self-energizing, electro-mechanical machine. It was started with a starter motor to bring it up to the speed at which self-energization over-came the losses. It would then continue to accelerate up to it's operating speed, at which time a mechanical load could be taken from it indefinitely.
So, I am a bit dismayed at the explanation in the previous post. To put this into perspective, I would remind you that this was the 1970's. The term "cold-fusion" didn't exist. Lasers were first demonstrated in 1960 with both the "ruby rod" type and the "helium-neon" type in use in the 1970's. There were no such things in this machine. Neither was Gallium metal nor Deuterium gas specified in the plans.
Even if they were, I cannot imagine of what use these materials might be in the operation of an electric motor. These early Lasers required very specialized power supplies that were not present. Gallium metal MELTS at 85 degrees F for G**s sake! Deuterium gas was not commercially available and would have been very expensive. The interaction of these components would sound more probable in a Plasma Engine, like the PAPP system. I can only assume that the person who wrote that account had no direct knowledge of the Rory Johnson Motor, and was exercising an extreme form of literary "free association".
I also saw no provision for the collection and recycling of inductive discharges. This process requires high speed, high power solid-state diodes which did not exist in the 1970s.
To the best of my recollection, the machine had permanent magnets, magnetic core material, copper wire windings, and a frame assembly. The magnetic fields moved through a complex 3-dimensional pattern, both radially and laterally to make their circuit. The permanent magnets (also not strong in those days) were just to get the process started. It was the 3-dimensional magnetic circuits that I could not fully image in my mind. The machine had a level of complexity that I knew would cost a fortune to try to replicate.
Something this complicated never appears all by itself. There must have been a long, R&D development period, including many lesser prototypes, with this design as the final result. Without knowing any of the history, I just had no basis to begin an analysis. At that point, I just stopped thinking about it.
I'm still looking for the plans. I found the mailing tube that they were sent to me in, but they were not in there. I'll post them if I can find them.
PeterLast edited by Peter Lindemann; 04-14-2012, 07:12 PM.
Hello Mr. Lindemann
Hello Mr. Lindemann,Originally posted by Peter Lindemann View PostHello Folks,
Peter
A pleasure to have you around on this Post!
The Info I posted prior I gathered from this site:
Johnson Patent:
Howard Johnson: Permanent Magnet Motor
And the portion I posted was just a briefing of the whole Document.
I have not deeply researched this type of Motor any further than this article goes.
As you wrote above, the Motor will require a Starter Motor just like Edwin Gray Motor, in order to develop the operating speed at which the Capacitors will be charged enough to keep 'firing' by themselves?
As you could read in that article, the text comes from different sources-writers, including a guy who was a Technician at Greyhound working on winding electrical motors-alternators, and He met Mr. Rory Johnson...
However, Internet is full of wrong information as it also provides very accurate ones...
Many thanks for your clear explanation.
I will keep researching on this motor...and it will be great if you could find those plans!
After Post Edit:
Now after looking closely to both links above, am more confused...lol
...I see a Howard R. Johnson Motor and also The Rory Johnson Motor...are they the same person-motor?
Could it be Howard R, middle name "Rory"...?
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Does anyone have copy of patent of death certificate?
Does anyone have a copy of Rory's patent or death certificate? How about a news link as to when and how he died?
Thus far I have found 19 free energy inventors who have died sudden and bizarre deaths and I am now curious to know how Rory passed. See this link
Plasma Battery Inventors Disappearing Regularly *|* Peak Oil News and Message Boards
Also, I just received an email from one of my exchange student friends in Moscow, and he says the body of missing energy inventor Dimitri Petronov was recently found in the Volga River minus his hands and teeth. He said the guy was identified by scars and a tattoo. I will post more details after he sends me the news article he saw in a Russian newspaper.
Damn - being an energy inventor seems to be a dangerous occupation!Last edited by EXCELERATOR; 04-20-2012, 04:07 PM.The harder you work the luckier you get!
