Magnetism's Mystery. Can you solve it?
  • aljhoa
    Originally posted by theoriaapophasis View Post
    the sun no more "has" a field than does a magnet have a field.
    Nor does the sun "emit" light, light is a field perturbation.
    A person in a pond flapping their arms doesnt emit anything either, its a field (in this case water) perturbation.
    The field around a magnet or the sun is the mediated pressure modalities of the ether itself.
    Iaad (instant action at a distance) cannot be answered with
    1. The atomistic particle bs of quantum, or their "virtual photons" which make up a field, which is insane bs in the extreme
    2. Nor with the conception that a sun/ magnet are emitting fields.
    Iaad can only be answered the same way you answer light and magnetism, that being the substrate to phenomena, the ether.
    @13:23 to 13:27 hexagon stands out
    Al
  • dyetalon
    Originally posted by spacecase0 View Post
    here is an idea for you.
    so, let us take nothing and build on it
    first dimension is length, (clearly just a construct )
    second dimension is area (at a right angle to the first dimension)
    third dimension is volume (the next right angle to the first 2, getting the pattern ?) (now we have 3D space)
    forth dimension is movement (usually spin)
    fifth dimension is a divergent spin (yes, right angle again, think vortex (also known as an electric field))
    sixth dimension is a curled up divergent spin field. yes, this 6th one is a magnetic field.
    and if it matters, the last 3 dimensions are the 3 field forces.
    Yep. Another good theory.
  • TheoriaApophasis
    Originally posted by Iamnuts View Post
    That thing people call an electron, l.
  • spacecase0
    I find it fascinating that if you are looking for funding in physics, it is all in the topics that support quantum physics.
    I can't help but wonder if that funding is part of the control grid on earth, because they do take most all the people that like physics and funnel them into the direction of quantum physics.
    if I were planning funding and was really looking for advancement, I would spend a percentage on currently unsupported ideas and methods.
  • Iamnuts
    Thank you. for your answer. You're obviously not a lover of the "field".
    Would calling it a rope be any good (region of perturbation of the ether)?
    That thing people call an electron, let's refer to it as a probability wave.
    Sack all the particle physics people, it would save billions.
  • TheoriaApophasis
    I'm interested to see how TheoriaApophasis's ideas work when looking
    at the Sun's field which extends throughout the entire solar system.
    The sun no more "HAS" a field than does a magnet have a field.
    Nor does the sun "emit" light, Light is a field perturbation.
    a person in a pond flapping their arms doesnt EMIT anything either, its a field (in this case water) perturbation.
    the Field around a magnet or the sun is the mediated pressure modalities of the Ether itself.
    IAAD (instant action at a distance) cannot be answered with
    1. the Atomistic PARTICLE BS of Quantum, or their "virtual photons" which make up a field, which is insane BS in the extreme
    2. NOR with the conception that a Sun/ Magnet are EMITTING fields.
    IAAD can only be answered the same way you answer light and magnetism, that being the substrate to phenomena, the ether.
  • Iamnuts
    Sun.
  • spacecase0
    Originally posted by TheoriaApophasis View Post
    point , line, circle, sphere, then PHASE.
    same idea, other words. (seems as if we have the same goal)
    I try to choose my words so that the most people can follow,
    but it is all about showing others so that they get it.
    not an easy task.
    I just hope you are not holding back anything.
  • TheoriaApophasis
    a dimension is a definition,
    see them as you like,
    I know people that see only 2 dimensions, "good" and "evil"
    I did mention that the first one was a construct ?
    I did this for a very good reason.
    I personally know of many dimensions, metric, SAE, etheric, and many others.
    if you only see 2 of them in any direction,
    then I worry you may be missing something
    edit:
    I love your work
    what happened to the commercial device you were working on with others ?
    or did I remember that wrong ?
    I want to see what you have built
    and thank you for posting the books of caral krafft, can't tell you enough how much they helped me see the world for what it is
    I suspect that it is only language that is your view VS mine
    ahhh the Krafft cheese books
    that was a gold collection device using diamagnetism of gold to decelerate gold. Thats been built.
  • spacecase0
    theres only 2 dimensions, counterspace (ether etc) and space
    edit:
    I love your work
  • TheoriaApophasis
  • spacecase0
    Originally posted by dyetalon View Post
    due to centripetal spins of what-ever the f*ck a magnetic field is made of.
  • dyetalon
    Mother nature is a sneaky bytch!!! She hides stuff under your nose.
    Can you figure out the image below.....by the way i took these shots last night on two new Magnetic supercells i made.
    Cube magnet on left (all magnetic "poles" look the same, doesnt matter)
    RING MAGNET on the right.
    the FIELD IMAGE on both are identical.......but BOOM! ....one theres NOTHING THERE
    (yes i have the answer)......Can you explain it????? Ooooooooo !!!
    I'm going to try.
    Note: Your 1st image on the left is a pix of the cube magnet pole, not side.
    It correlates directly with your image on the right, which is a pole shot, too.
    OK, my take on this phenomenon is the light goes around the pole
    It's a spinning vortex that won't allow light in. (it's not generating light, so it's not trying to get out). The pressures around the magnets pole are in a similar state as a tornado.
    My thoughts on the subject
  • Danny B
    stuff
    Nope, no pics. I loaned the hairpin to a guy in Elk Grove. He tells me that he is afraid to turn it on. I haven't seen it in quite a while. I'm a builder, not a bencher. I just build one project after another. I built a very nice bike wheel SG with a big motorcycle wheel. Turned it on and thought,,, well, that's nice. I even bought the 10 Interstate batteries that JB recommended. Sent it to a guy in Texas but, he never put it together. Finally, sent it back.
    I'm joining up the Terawatt device with the Hatem device. Dunno if I will ever actually test it. I built the Skinner gravity motor. I'm looking to give it away,,, along with the fuel-less motor. And, I have an 11 gallon HHO cell as designed by Eagle Research. Need to give that away also.
    I built an 3 X 6 wheel with 6 mags for RS in Red Oak, Texas. It was on a common shaft with a large diameter wheel that also had 6 mags. One was axial flux and, the other was radial flux. The 6 in. wheel drove the whole thing. RS said that it worked well. It was kinda SG driving a a gravity field motor.
    He reported that JB said it was well-made and interesting.
    I just keep building interesting stuff.
  • TheoriaApophasis
    Originally posted by Danny B View Post
    I have a related question. I built the Tesla hairpin. Naturally, I put everything in the spark gap just for the hell of it. When I put a Neo magnet in the spark gap, The spark became VERY noisy. The other thing that I noticed was; tiny little points of light, short-lived and random near the primary arc. Like a tiny speck of magnesium was being vaporized.
    This only happened with a neo magnet in the gap. I don't think that it was the plating on the magnet.
    Any theories?
    what no pics?
    noisy due to gyromagnetic precession (lamor frequency) and picking up the arc in very rapid cycles and making a noise
