  • Flow up
    "He who knows himself best knows his Creator best" -- Rasa'il Ikhwan as Safa, I, 76. ( The Brethren Of Purity )
    Encyclopedia of the Brethren of Purity - Wikipedia, the free encyclopedia
    The Encyclopedia of the Brethren of Purity (Arabic: رسائل اخوان الصفا‎) also variously known as the "Epistles of the Brethren of Sincerity", "Epistles of the Brethren of Purity" and "Epistles of the Brethren of Purity and Loyal Friends" was a large encyclopedia[1] in 52 treatises (rasā'il) written by the mysterious[2] Brethren of Purity of Basra, Iraq sometime in the second half of the 10th century CE (or possibly later, in the 11th century). It had a great influence on later intellectual leading lights of the Muslim world, such as Ibn Arabi,[3][4] and was transmitted as far abroad within the Muslim world as Al-Andalus.[5][6] The Encyclopedia contributed to the popularization and legitimization of Platonism in the Arabic world.[7]
    read on ....
    ...to shun no science, scorn any book, or to cling fanatically to no single creed. For [their] own creed encompasses all the others and comprehends all the sciences generally. This creed is the consideration of all existing things, both sensible and intelligible, from beginning to end, whether hidden or overt, manifest or obscure . . . in so far as they all derive from a single principle, a single cause, a single world, and a single Soul." - (from the Ikhwan al-Safa, or Encyclopedia of the Brethren of Purity; Rasa'il IV, pg 52)
    World Pyramids - The Great Pyramid, Only Facts
    Ten Constant Facts
    1.Height: 146.5 meters (480.6 ft) tall in original but in our days is 138.8 meters (455.4ft) because of erosion and absence of the pyramidion and outer facing blocks (casing stones).
    2.Each base side was 230.4 meters (755.8 ft) long, now it’s 227 meters (744.7ft) because of absence of outer casing stones and erosion.
    3.The total mass is 5.9 million tons.
    4.The volume with an internal hillock is close to 2.5 million cubic meters.
    5.The closest number of all blocks was estimated in 2.3 million separated blocks of different size, volume and mass.
    6. Amazingly high precision. Based on measurements taken on the north eastern casing stones, the mean opening of the joints is only 0.5 millimeters wide (1/50th of an inch). Four sides of the base have an average error of only 58 millimeters in length. The base is horizontal and flat to within ±15 mm error that is unbelievable precision for so colossal construction even in our modern architect.
    7.The pyramid (sides of square base) is extremely closely aligned to the North pole with only 12 seconds of arc error.
    8.The ratio of the perimeter to height of 921.6/146.5 meters equates to 2π to an accuracy of better than 0.05%! It makes the Great pyramid the greatest and ideal mathematical model realized in the Great Pyramid.
    9.Pyramid has four clear visible sides oriented to the Earth cardinal points but in fact the pyramid has 8 sides! The centers of the four sides are indented with an extraordinary degree of precision forming the only 8 sided pyramid. The effect is not visible from the ground or from a distance but only from the air, and then only under the proper lighting conditions.
    10. Construction material. 2.3 million limestone blocks and granite stones. The largest granite stone was found in the chamber well known as a “king chamber” weigh 25 to 80 tones which were transported more than 500 miles away. At least 5.5 million tons of limestone, 8 000 tons of granite and 500 000 tons of mortar were used for the construction of the Great Pyramid in Giza.
    The pyramid, which measured 1.85 meters at the base and had a height of 1.40 meters, was decorated with wonderful inscriptions
    The Mystery of the Missing Pyramidion of Khufu - Reality Sandwich
    4. The father of it is the sun, the mother the moon. The wind bore it in the womb. Its nurse is the earth, the mother of all perfection.
    Gods of Ancient Egypt: S Hu
    Shu (Su) was the god of light and air and as such personified the wind and the earth´s atmosphere. As the god of light he represented illuminated the primordial darkness and marked the separation between day and night and between the world of the living and the world of the dead. As the god of air, he represented the space between the earth and the heavens, and gave the breath of life to all living creatures. As a god of the wind, sailors invoked him to provide the good wind to power their boats. The clouds were considered to be his bones, and he supported the ladder by which the deceased souls could reach the heavens.
    Deodato - Caravan Watusi strut [1975] - YouTube
    addendum:
    ... Black Heat - M & M's - YouTube
    Mpulsive solar flare measuring M2.3 erupts
    Impulsive solar flare reaching M2.3 at its peak time erupted on September 23, 2014. The event started at 23:03, peaked at 23:16 and ended at 23:28 UTC.
    Wave propagation occurs when high-pressure compression waves push against areas of lower pressure in the atmosphere. Sound waves move at the speed of sound (1130 feet per second at sea level and a temperature of 68º F).
    MUM 2600 – Chapter 2 Notes
    and
    Baalbek - A Colossal Enigma
    The massive and elegant Roman stonework and columns pale by comparison to the megaliths they were built upon. The temple very visibly incorporates into its foundation, stones of some 1,500 tons. They are some 68 x 14 x 14 feet
    The wall around the Temple of Jupiter, some 30 miles from Damascus, the capital of Syria, in the size of blocks used, holds the all-time record, with 59 of the largest stones ever quarried. Built around 150 A.D., after the Syrians’ conversion to the gods of the Romans from the god Baal, they wanted to build a greater temple than anything to be found in Rome. For sheer massiveness, they achieved their goal.
    This wall is 30 feet above the ground level. Three of the biggest solid blocks of stone every cut by man are in this wall.
    The largest measures 63 feet long by 13 feet high by 10 feet thick. Each of these blocks weighs around 1000 tons
    http://www.labyrinthina.com/Coral%20...0A.%20Lake.pdf
    Archaeoacoustics - Wikipedia, the free encyclopedia ....
    Ancient auditory illusions reflected in prehistoric art?
    He traveled to England and demonstrated that Stonehenge does indeed radiate acoustic shadows that recreate the same pattern as interference. "My theory that musical interference patterns served as blueprints for megalithic stone circles—many of which are called Pipers' Stones—is supported by ancient legends of two magic pipers who enticed maidens to dance in a circle and turned them all into stones," Waller noted.
    ... Disco Power
    Sound and vision: Visual cortex processes auditory information too
    Stonehenge Sound Study Suggests Iconic Rocks Were Picked For Their Acoustic Properties (VIDEO)
    * see also Hornfels
    Acoustic properties[edit]
    Hornfels have the ability to resonate when struck. Michael Tellinger had described these stones in South Africa also known as "ring-stones" due to their ability to ring like a bell.[citation needed]
    The Musical Stones of Skiddaw are an example of a lithophone made from Hornfels.[3]
    New dig suggests Stonehenge was built to align with summer and winter solstice
    Analemma
    for more check out :
    Healing With Sound. ... Stonehenge - Crystalinks
    Sonic booms in nerves and lipid membranes
    • thirteen in one,
      the mystical number.
      HEBREW GEMATRIA: Values from 20 - 29 / HEBREW GEMATRIA: Values from 30 - 39 ( find Baal ) / HEBREW GEMATRIA: Values from 60 - 69 etc....
      Based on the qualities of man are the Brothers:
      each shall direct the unfoldment of being,
      each shall channels be of the Great One.
      The Emerald Tablets of Thoth - Secret of Secrets
      The Colonnade of Amenhotep III contains 14 papyrus-headed columns, some fully 50 feet in height and 32 feet in circumference
      Location Mexico State
      Region Mesoamerica
      Type Pyramid, Pyramid of the Sun - Wikipedia, the free encyclopedia
      Part of Teotihuacan
      Length 223.5 meters (733.2 feet)
      Width 223.5 meters (733.2 feet)
      Volume 1,184,828.3 cubic meters (41,841,817 cubic feet)
      Height 71.2 meters (233.6 feet)
      The dimensions of the Pyramid of the Sun incorporate 'Pi' in the following way: (4 x Π) x h = Perimeter / Circumference of base. (21) The pyramids base area is almost the same as that of the great pyramid of Ghiza. (21), (12), The height is almost half.
      Grid Reference: 19° 42' N, 98° 51' W.
      Teotihuacan, Mexico
      Life-Death Figure
      This sculpture of a man carrying a human skeleton on his back exemplifies the dualism of life and death that permeates Huastec and Mexica (Aztec) art. Representing life, the human figure is the Aztec wind god, Ehecatl-Quetzalcoatl, who created humankind and is identifiable by his J-shaped ear pendants. Representing death, the skeletal figure with a protruding heart wears a collar and skirt decorated with a half-circle motif that was associated with the sun and the planet Venus. Venus, called the morning star, was another important god, thought to pull the sun across the sky and down into the underworld. Densely patterned designs on the sculpture’s arms and legs include ears of corn, which, like the sun and Venus imagery, are related to agriculture, fertility, life, and death
      Dimensions: Height 62.375 in
      26 x 11 1/2 in.
      Brooklyn Museum: Arts of the Americas: Life-Death Figure
      Tres Zapotes, Mexico.
      Grid Reference: 18° 28' N, 95° 26' W.
      Monument A: Height 1.47m (4.82 ft). Carved from a block of Basalt. Current location, Community museum, Veracruz. Monument Found near the Calendar stone (Stela C), Stirling (seen kneeling beside it) had this to say of it:
      "...The head was a head only, carved from a single massive block of basalt, and it rested on a prepared foundation of un-worked slabs of stone ... Cleared of the surrounding earth it presented an awe-inspiring spectacle. Despite its great size the workmanship is delicate and sure, the proportions perfect. Unique in character among aboriginal American sculptures, it is remarkable for its realistic treatment. The features are bold and amazingly Negroid in character..." (3)
      Located on the slopes of the Tuxtla mountains, this is one of the most important Olmec cities, and the first to be written about in 1868, along with the first reports of colossal heads. Tres Zapotes is sometimes referred to as the third Olmec Capital, as it followed on the demise of both La Venta and San Lorenzo.
      The average height of the moai is about 4 m (13 ft 1 in) high, with the average width at the base around 1.6 m (5 ft 3 in) across. These massive creations usually weigh in at around 12.5 tonnes (13.8 tons) each.
      All fifteen standing moai at Ahu Tongariki.
      Aruna Stambha[edit]
      In the last quarter of the 18th century, when worship had ceased in the temple, the Aruna stambha (Aruna pillar) was removed from the entrance of Konark temple and placed at the Singha-dwara (Lion's Gate) of the Jagannath temple in Puri by a Maratha Brahmachari called Goswain (or Goswami).[26][27] The pillar is made of monolithic chlorite and is 33 feet 8 inches (10.26 m) tall . It is dedicated to Aruna, the charioteer of the Sun god.[27]
      Region: India
      Konark Sun Temple - Wikipedia, the free encyclopedia
      • The Pyramids of Giza 29.9792° N, 31.1342° E
        The speed of light (at 299,792.458km/s) is encoded in the latitude of the great Pyramid. At its center the pyramid is 29.9792º north of the equator <1>
        Sound waves move at the speed of sound (1130 feet per second at sea level and a temperature of 68º F ) is also encoded in the great Pyramid
        S Hu (Su) was the god of light and air
        Utterance 272
        392: To say the words:
        "O height which has not (yet) been reached,
        Gate of Nun, Unas comes to you!
        Let this (gate) be opened for him!
        "Is Unas the Little One there?"
        "Unas is at the head of the servants of Re,
        Unas is not at the head of the gods who create trouble!"
        The Pyramid Texts Online - Antechamber South Wall
        Sufis believe that, expressed in one way, humanity is evolving to a certain destiny. We are all taking part in that evolution. Organs come into being as a result of the need for specific organs (Rumi). The human being's organism is producing a new complex of organs in response to such a need. In this age of the transcending of time and space, the complex of organs is concerned with the transcending of time and space. ( The Transcendence of Time in Shamanic Practice, Michael Harner, SAND 2011 - YouTube ... Gino Soccio - "Dancer" (1979) - YouTube )
        ... How are these organs developed? By the Sufi method. How do we know that we are developing them? Only through experience.
        Lefties Soul Connection Code 99 - YouTube
        Our Connection To Something Bigger: The Archetypes of C.G. Jung - YouTube .... Black Heat - Chip's Funk - YouTube
        .... 1. Water in the solar system predates the Sun
        2. Water has Memory - YouTube
        3. Luc Montagnier -- DNA Teleportation -- article & patents application
        A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
        According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
        Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
        4. Scientists Have Found That Memories Can Be Passed Down Through Generations In Our Genes
        5. "Quantum Water" Discovered in Carbon Nanotubes | MIT Technology Review
        ( On Earth, all known living things have a carbon-based structure and system )
        6. Cosmic Puzzle Solved? --"Why Every Organism on Earth is a Right-handed Double Helix"
        electrons in cosmic rays -- which are mostly left-handed
        7. DNA is a fractal antenna in electromagnetic fields
        ... The Harry Roche Constellation - Spiral - YouTube
        bifilar coils
        https://answers.yahoo.com/question/i...3122043AA3Ls3F
        SOME NUMBERS FOR YOU;-
        10 base pairs /turn of DNA helix = 34nm (=10 nucleotides /chain)
        Size of 1 nucleotide = 0.34nm
        Size of AT or GC base pair = 1.085nm
        Width of DNA molecule = 2.3nm approx.
        ( also The average adult has a blood volume of roughly 5 liters (1.3 gal),[3] which is composed of plasma and several kinds of cells . Blood accounts for 7% of the human body weight).
        Tesla's intent was to condense the energy trapped between the earth and its upper atmosphere ( S Hu ) and to turn it into an electric current. He pictured the sun as an immense ball of electricity, positively charged with a potential of some 200 billion volts. The earth, on the other hand, is charged with negative electricity. The tremendous electrical force between these two bodies constituted, at least in part, what he called cosmic energy. It varied from night to day and from season to season but it is always present.
        Besides the Tesla Tower the site also included a 94 by 94 foot red brick building housing transmission equipment/laboratory/factory floor space.
        This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.
        N. Tesla
        Resonant Response Of The Human Nervous System
        "A nerve fiber or axon, along which an electrical impulse can travel, includes a CYLINDRICAL membrane with one CONDUCTING fluid (electrolyte) inside and another outside. By mechanisms similar to those in batteries, a potential difference of the order of .1V is maintained between these fluids."(1)
        Long, thin, conductive materials with certain properties respond similarly to exposure to near resonant field, as does a high inductance RLC circuit. The sharpness of the resonant response in a RLC circuit is a result of the inductive component being large in value.
        "---the human body absorbs RF energy more effectively at a frequency where body length is about .4 ( 4/10 ) the wave length and the body's long axis is aligned with the incoming electric-field polarization. This condition is known as "whole-body resonance."
        the nervous system (or components thereof) could be viewed as a much less massive subsystem of significant different effective length and with a much higher Q value due to both structure and chemical composition. The "Q Value" being defined as the sharpness or reactivity of the system to field at or near specific resonant frequency.
        In computing values for a RLC circuit where the inductance is given as .1 Henry and solving for the capacitance to tune the circuit to an effective length of 68 inches
        read on
        Insulated_electrical_conductor
        provision is made for enveloping the patient in a high potential and, in certain instances, a high frequency electric field, and for applying to the patient, while so enveloped in the electric field, radiations and emanations having therapeutic value.
        Thomas H. Moray: Transmutation of Low Grade Ores by High Energy Bombardment
        For, in his patient work, the alchemist must be the scrupulous imitator of Nature ( Charlie Whitehead and The Swamp Dogg Band - LETS DO IT AGAIN - YouTube ), the Monkey of creation, according to the genuine expression of several masters.
        Fulcanelli
        Solar storm of 1859... The Solar Wind And Hallucinations ... Astrophysicists find fractal image of Sun’s ‘Storm Season’ imprinted on Solar Wind
        Black Heat - Check It All Out - YouTube .... Manifesting the Mind Footprints of the Shaman 2009 - YouTube ... Dolphins are attracted to magnets
        • Curiosity Causes Changes in Brain Structure : News : Headlines & Global News
          dimethyltryptamine (DMT) and hallucinations + The Solar Wind And Hallucinations
          it seems that DMT comes in the form of a black tar-like substance and it is smoked ....
          Hookah - Wikipedia, the free encyclopedia .... or is it HU KA ... Bob Marley & The Wailers: Three Little Birds - 1977
          One physician has reported that the release of endogenous DMT is highest at the moment of death.
          some more .....
          Silbury Hill - Wikipedia, the free encyclopedia
          At 40 metres (131 ft) high,[1] Silbury Hill – which is part of the complex of Neolithic monuments around Avebury, which includes the Avebury Ring and West Kennet Long Barrow – is the tallest prehistoric human-made mound in Europe[2] and one of the largest in the world; it is similar in size to some of the smaller Egyptian pyramids of the Giza Necropolis.[3] Its original purpose is still highly debated
          The base of the hill is circular and 167 metres (548 ft) in diameter. The summit is flat-topped and 30 metres (98 ft) in diameter
          51°24′56″N 1°51′27″W
          On the 5th of July, 2009 an awe inspiring Mayan Motif Crop Circle formation was reported at Silbury Hill near Avebury, Wiltshire.
          Cerne Abbas Giant - Wikipedia, the free encyclopedia
          The figure depicts a huge naked man, about 180 ft (55 m) high and 167 ft (51 m) wide.
          E S HU / Ptah ... http://www.google.com/search?q=The+B...geticforum.com
          ... Willie Bobo Midnight Lover - YouTube
          Atlantean builders in all parts of the world constructed a global infrasound network as an array of piezoelectric stone temples and pyramids in perfect alignment with natural focal points of planetary resonance. According to this sacred geodesic wisdom, the pools, petroglyphs and hilltop temples at Altavista, Mexico (21.07°N 105.17°W) were built 7,880 miles from the Great Pyramid, comprising 31.66% of Earth's mean circumference, where infrasound can be efficiently transduced into an EM field.
          The very stone itself was considered maternal --'the Motherstone'-- for this profound synchronization effect, and for many thousands of years was signified in textual format by the mesmerizing Paleo-Sanskrit glyph pair: Mi-Is.
          The double spiral formation is a hypnotic extension of the basic hieroglyph pair composed of nested semicircles: mi, meaning "waning, diminishing", and is for "waxing, swelling". Combined into a legible grouping known as a ligature, this double spiral mi-is petroglyph denotes "synchrony, rhythm" (above).
          * so Is Is = double "waxing, swelling"
          Scientific recognition for all such Paleolithic cultural remnants has been denied by academic suppression of this most ancient of all known hieroglyphic languages, being the antecedent of Sumerian, Egyptian and Mayan logographic text forms.
          The petroglyph of a stick figure ( E S Hu ) with arms raised can be found in all parts of the world, yet displays a more complex expression in the Altavista rock art complex. Generally understood as signifying cosmic receptivity, with the figure's arms and legs taking the form of twin tuning forks, the context of the figural petroglyph at Altavista offers several interesting factors informing our interpretation.
          The square represents Indra, the planet Jupiter, praised as 'the one' for its Giant Red Spot and resounding infrasonic emanations that were transduced by the world's pyramid network for the benefit of humanity. A ligature combining the square Jupiter glyph and the double spiral 'synchrony' glyph forms a square spiral. Many examples of square spiral signs engraved in basalt at Altavista are given symmetrically in pairs or mirrored in sets of four, reading: mi-is Indra mi-is Indra , meaning "synchrony (of) Jupiter..." (above).
          Cernunnos ... Herbie Mann - Me mph Is Underground (1969) - YouTube
          The Egyptian historian Manetho referred to Memphis as Hut-ka-Ptah (meaning "Enclosure of the ka of Ptah")
          Ancient Egyptian concept of the soul - Wikipedia, the free encyclopedia as in Ka La Ma
          The Sahara All Stars - Take Your Soul - YouTube ... U Roy - Natty Rebel/Soul Rebel - YouTube
          Read more: Resonance In the Altavista Petroglyphs - Mexico - The Altavista Paleolithic Ruins - MessageToEagle.com + House of Daedalus: The Astrological Body: Part One: The Planets and the Chakras
          ... Booker T and the M.G.'s - Love Wheels - YouTube .... Gary Byrd - Are You Really Ready For Black Power - YouTube
          Dynamic auroras visible for the fifth day in a row
          For the 5th day in a row a crack in the Earth's magnetosphere is allowing solar wind to reach Earth. Although a full geomagnetic storm is not required to generate auroras at this time of the year, coronal hole effects and multiple solar sector changes currently affecting Earth are fueling them.
          Electric Sparks May Alter Evolution of Lunar Soil | NASA
          NASA: There Is A Giant Square Structure Hidden Under The Moon
          Andrews-Hanna added that the "pattern of gravity anomalies on the moon is so strikingly geometric and in such an unexpected shape that it is forcing us to think in new and different ways about the processes operating on the moon".
          The working theory is that the early molten moon cooled in a similar way to the early Earth, where lava tends to cool in hexagonal columns. This happens because where three cracks intersect, they tend to do it at 120-degree angles - and a hexagon is the only shape on a flat surface where all the angles can be 120 degrees.
          Saturn's_hexagon
          * Helena Petrovna Blavatsky affirms: “Now we have but to remember that Siva [Shiva "the Transformer" ] and the Palestinian Baal, or Moloch, and Saturn are identical ….” (SOURCE: Helena Petrovna Blavatsky, Isis Unveiled, Vol. 1: Science [New York, New York. Trow's Printing and Bookbinding Company, 1877], p. 578)
          see also Baalbek - A Colossal Enigma
          .... Black is Beautiful: A Black Madonna gallery | Queen of Heaven
          Vi Sani Raua Ra Yoni
          Black, a symbol of yin energy
          Obsidian - Wikipedia, the free encyclopedia
          ... Nearly all of the imported obsidian found in Egypt is of a pure jet-black variety .... obsidian, which is a natural glass.
          According to the Oxford English Dictionary, the majority theory is that al-kīmīā is derived from χημία, which is derived from the ancient Egyptian name of Egypt (khem, khame, or khmi, meaning "black earth", contrasting with the surrounding desert.) Therefore, alchemy is the "Egyptian art" ( Lou Johnson - Beat - YouTube ) .[1] However, it is also possible that al-kīmīā was derived from χημεία, meaning "cast together".[4]
          ps: what else is black ... Petroleum - Wikipedia, the free encyclopedia ( http://www.energeticforum.com/256064-post5263.html ... Ancient Egyptians Hoarded Crude Oil )
          Mummia, Mumia, or "Mummy" is either a substance used in the embalming of mummies, or a black tar like paste derived from the "sweat or "tears" of rocks. used as a "medical preparation".[2] The former sense relates to substances such as "asphaltum", bitumen, or "mineral pitch"[3] or carabe[4] which have in the past been used as one of the ingredients in the preservation process of mummies.
          Reportedly, the black color of the mummies was attributed to the use of this pitch,[6] although it is known nowadays that the blackened color is only a result of the drying process which the bodies would undergo. Nevertheless, this erroneous notion caused the belief that all mummies contained large amounts of asphaltum in their making.
          ( coffee or black ( dark ) chocolate works too ... Maceo Parker - Soul of a black man - YouTube )
          fun fact :
          Jews commemorate Yom Kippur, the holiest day of the Jewish calendar, and Muslims celebrate the holiday of Eid al-Adha,a feasting celebration , on the same day for the first time in 33 years.
          Sunday, Oct. 5
          • Mysterious Female[edit]
            The Valley Spirit never dies ( Valley of the Kings - Wikipedia, the free encyclopedia ... The area of the Theban hills is subject to infrequent violent thunder storms, causing flash floods in the valley. / Valley of the Queens - Wikipedia, the free encyclopedia ... Imhotep )
            It is named the Mysterious Female.
            And the doorway of the Mysterious Female
            Is the base from which Heaven and Earth sprang.
            It is there within us all the while;
            Draw upon it as you will; it never runs dry. (chap. 6, tr. Waley)
            Fela Kuti - Lady (HQ) - YouTube
            chapter 8
            The highest good is like Water.
            Water gives life to the ten thousand things and does not strive.
            It flows in places men reject and so is like the Tao.
            In dwelling, be close to the land.
            In meditation, go deep in the heart.
            In dealing with others, be gentle and kind.
            In speech, be true.
            In ruling, be just.
            In business, be competent.
            In action, watch the timing.
            No fight: No blame.
            LaO-TSHU
            Second Chakra: Water (Vam) Jupiter Sagittarius and Pisces
            .... Got To Give It Up (Parts 1 & 2) - Marvin Gaye (1977) - YouTube
            Ancient Egyptian solar ships - Wikipedia, the free encyclopedia
            The Khufu ship is an intact full-size vessel from Ancient Egypt that was sealed into a pit in the Giza pyramid complex at the foot of the Great Pyramid of Giza around 2500 BC. The ship now is preserved in the Giza Solar boat museum.
            The Khufu ship is one of the oldest, largest, and best-preserved vessels from antiquity. It measures 43.6 m (143 ft) long and 5.9 m (19.5 ft) wide.
            Ra in his solar barge
            ps: did you know :
            Sirius is Dog Star and brightest star | Brightest Stars | EarthSky
            The brightest star visible from any part of Earth is Sirius in the constellation Canis Major the Greater Dog. Sirius is sometimes called the Dog Star. Follow the links below to learn more about Sirius, the Dog Star and brightest star.
            At 8.6 light-years distance, Sirius is one of the nearest stars to us after the sun.
            At completion, the Great Pyramid was surfaced by white 'casing stones' - slant-faced, but flat-topped, blocks of highly polished white limestone. Visibly all that remains is the underlying step-pyramid core structure seen today. In AD 1301, a massive earthquake loosened many of the outer casing stones,
            and
            are you familiar with
            Fukushima Daiichi nuclear disaster - Wikipedia, the free encyclopedia ...
            a nuclear disaster at the Fukushima I Nuclear Power Plant on 11/03/11
            Global Rumblings: Japan Earthquake And Tsunami Caused By "Solar Flare"
            • “If one should desire to know whether a kingdom is well governed, if its morals are good or bad, the quality of its music will furnish the answer.”
              ― Confucius
              ps: yhur body is also ... yhur Kingdom .... Bob Marley - Rastaman Vibration - YouTube
              Bob Marley - Easy Skanking - YouTube ....
              http://en.wikipedia.org/wiki/Kohl_(cosmetics)
              Galena eye paint (later termed Kohl "Black" in Arabic from the Akkadian word for the cosmetic) was widely applied in Ancient Egypt. Upper eyelids were painted black and lower ones were colored green, as depicted in ancient texts that describe the use of both black galena and green malachite.
              A group of researchers in China tried to find some scientific basis of this claimed property of lead sulphide (Galena) relating to absorption of sun rays when applied into the eyes in the form of Kohl.[12] The authors reported the ultraviolet (UV) absorption spectra of a thin film of lead sulphide prepared on “Indium Tin Oxide” (ITO) substrate. The spectra showed that lead sulphide thin films had higher absorption and lower transmittance in UV light band which further increases with the increased deposition voltage.
              other uses for lead sulfate .... Galena ... Crystal radio - Wikipedia, the free encyclopedia
              Radio receiver, Basel, Switzerland, 1914
              ps: think tesla bifilar
              It gets its name from its most important component, known as a crystal detector, originally made with a piece of crystalline mineral such as galena.[1] This component is now called a diode.
              .... http://www.google.com/search?q=Energ...geticforum.com
              the Pyramids were built mainly of limestone ....
              Perovskite crystals have been mistaken for galena; however, galena has a better metallic luster, greater density, perfect cleavage and true cubic symmetry.[5]
              Perovskites: the future of solar power? | Guardian Sustainable Business | Guardian Professional
              Perovskite solar cells show hydrogen production promise | Chemistry World
              Occurrence[edit]
              Found in the Earth’s mantle, perovskite’s occurrence at Khibina Massif is restricted to the under-saturated ultramafic rocks and foidolites, due to the instability in a paragenesis with feldspar. Perovskite occurs as small anhedral to subhedral crystals filling interstices between the rock-forming silicates.[7]
              Perovskite is found in contact carbonate skarns at Magnet Cove, Arkansas ( ManataKa: the origins of Hot Springs, Arkansas | The Red Mountain Post ), in altered blocks of limestone ejected from Mount Vesuvius, in chlorite and talc schist in the Urals and Switzerland.[12] and as an accessory mineral in alkaline and mafic igneous rocks, nepheline syenite, melilitite, kimberlites and rare carbonatites. Perovskite is a common mineral in the Ca-Al-rich inclusions found in some chondritic meteorites.[2]
              A rare earth-bearing variety, knopite, (Ca,Ce,Na)(Ti,Fe)O3) is found in alkali intrusive rocks in the Kola Peninsula and near Alnö, Sweden.
              The Story of ManataKa The Place of Peace
              The Lady of the Rainbow, referred to as Ix Chel by the Maya, was said to have presided over the peace in the valley.
              .... Ixchel or Ix Chel (Mayan: [iʃˈt͡ʃel]) is the 16th-century name of the aged jaguar ( a feline ) goddess of midwifery and medicine in ancient Maya culture ( Ixchel Moon Goddess - Wikipedia, the free encyclopedia )
              Her codical name is now generally rendered as 'Chak Chel'. The designation 'Red Goddess' seems to have a complement in the designation of the young goddess I as 'White Goddess'.
              - The Sacred Mountain and the Valley of the Vapors... For thousands of years, this magnificent site was the gathering place of many nations. Tribal leaders and spiritual elders made pilgrimages to the Great Ma-na-ta-ka Mountain to sit in great councils with many tribes. Some came every seven years, others came every eleven years, and others made the journey more frequently depending on local custom. Tribal leaders prayed and made peace offerings to the Creator, the Great Manataka - "Place of Peace Mountain" and each other.
              .... Zapping the brain with tiny magnetic pulses improves memory Bob Marley - Stir It Up (432 hz Frequency) - YouTube
              addendum:
              Blood Moon: Stunning total lunar eclipse will occur on Wednesday - Science - News - The Independent
              Ixchel was already known to the Classical Mayas. As Taube has demonstrated,[5] she corresponds to goddess O of the Dresden Codex, an aged woman with jaguar ears.
              In the Dresden Codex, goddess O occurs in almanacs dedicated to the rain deities or Chaacs and is stereotypically inverting a water jar
              ... Bob Marley - Ka Ya - YouTube ... Bob Marley - Soul Rebel (432 hz Frequency) - YouTube
              hint : 4 32 Hz ----> 4 13 1 ( The Cosmic 432 - Part 1 - YouTube )
              Four is it in qualities,
              shining in each of the planes of existence,
              but thirteen in one,
              KUKULKAN PYRAMID at Chichen Itza on Mexico's Yucatan . Also known as the El Castillo (The Castle) and Quetzalcoatl, Kukulkan
              Pyramid has staircases on all four sides.
              With each staircase comprising 91 steps, the four show 364 steps
              with the upper platform being the 365th step.... Wake Up and Live - Bob Marley - HQ Sound [HD] - with lyrics - YouTube
              on a side note ( Pattern matching ) :
              Nikola Tesla, Pointing to 'Grevious Errors' of the Past, Explains Radio as He Sees It at Age of 77 - He Expects Television
              "I consider this extremely important,. said Mr. Tesla. "Light cannot be anything else but a longitudinal disturbance in the ether, involving alternate compressions and rarefactions. In other words, light can be nothing else than a sound wave in the ether.. " ...
              Tesla Sees Evidence Radio and Light Are Sound -Apr 8, 1934 .... S HU
              Exploding water with 42712.2Hz ----> 4 9 1 2 2
              Post From JoesCell2 (this is the opinion of a private person):
              Keely found that water will explode at a frequency of 42,712.2 Hz. ... did it with a Quartz Bowl ( tuned at 432 Hz ... like a Tibetan Bowl ) : ....Think Quartz and how symmetry applies to magnets because that is how quartz crystals are formed, via symmetry. The 42,712.2Hz was applied to a quartz bowl with distilled water at which time it EXPLODED and disappeared.
              PowerPedia:John Keely - PESWiki
              alpha_and_beta quartz
              both alpha quartz and DNA are coaxial helices
              • Three M-class solar flares erupted from southwest quadrant
                Om - Wikipedia, the free encyclopedia
                Om (written universally as ॐ; in Devanagari as ओं oṁ [õː], औं auṃ [ə̃ũ], or ओ३म् om [õːm]) is a mantra and mystical Sanskrit sound of Hindu origin (geographically India and Nepal), sacred and important in various Dharmic religions such as Hinduism, Buddhism, and Jainism. The syllable is also referred to as omkara (ओंकार oṃkāra) or aumkara (औंकार auṃkāra), literally "om syllable", and in Sanskrit it is sometimes referred to as praṇava, literally "that which is sounded out loudly".
                Om or Aum is also written ओ३म् (o̿m [õːːm]), where ३ is pluta ("three times as long"),
                13 From this are & do come admirable adaptations whereof the means (or process) is here in this. Hence I am called Hermes Trismegist, having the three parts of the philosophy of the whole world
                O M KA RA
                The Bhagvad Gi:tā (17.23) has:
                om tatsatiti nirdesho brahmanstrividhah samratah
                "OM, tat and sat has been declared as the triple appellation of Brahman, who is Truth, Consciousness and Bliss."
                14 . That which I have said of the operation of the Sun is accomplished & ended.
                Emerald Tablet - Wikipedia, the free encyclopedia
                just a thought : when you read the word HERMES .... it sounds like :
                Hu R M Is ( Mi Is )
                ... Earth Wind & Fire - Let's Groove - YouTube
                S HU ------> Sowilo – Rune Meaning | Rune Secrets ... HU
                food for thoth : SHu Man Resonance ... Fela Kuti- Sha Ka Ra / Cha K Ra - YouTube
                The ancient Egyptian god Shu is represented as a human with feathers on his head, as he is associated with light and air. This feather serves as the hieroglyphic sign for his name. Shu could also be represented as a lion,
                or with a more elaborate feathered headdress .... KUKUL KA N ... . Air is represented in the Aztec religion by a snake to the Scythians, a yoke to the Hindus and for Greeks as a sword, In East Asia, air is seen as the equivalent of wood[citation needed]
                * Etymology[edit]
                From Ancient Greek κυκλῶν (kuklôn), present active participle of κυκλόω (kuklóō, “I encircle”), from κύκλος (kúklos, “circle”) ... cyclone - Wiktionary
                image : Sihasapa - Blackfoot (Lakota)
                The LaKȟóta people (pronounced [laˈkˣota]; also known as Teton, Thítȟuŋwaŋ ("prairie dwellers"),[1] and Teton Sioux ("snake, ") are an indigenous people of the Great Plains of North America.
                They were agriculturalists and may have been part of the Mound Builder civilization during the 9th–12th centuries CE.[1]
                the Cahokia Mounds UNESCO World Heritage Site near Collinsville, Illinois, the mound size was calculated in 1988 as about 100 feet (30 m) high, 955 feet (291 m) long including the access ramp at the southern end, and 775 feet (236 m) wide.[1] This makes Monks Mound roughly the same size at its base as the Great Pyramid of Giza (13.1 acres / 5.3 hectares). Its base circumference is larger than the Pyramid of the Sun at Teotihuacan
                Monks Mound - Wikipedia, the free encyclopedia
                Hu Nab Ku
                The Templo Mayor (Great Temple) was one of the main temples of the Aztecs in their capital city of Tenochtitlan, which is now Mexico City.The temple was called the huei teocalli
                Templo Mayor - Wikipedia, the free encyclopedia
                Quetzalcoatl in his form as the wind god, Ehecatl.[2] The main temple devoted to Huiztilopochtli and Tlaloc, measuring approximately 100 by 80 m (328 by 262 ft) at its base, dominated the Sacred Precinct.[3]
                Tlaloc is easily identified by his characteristic mask giving the impression of eyeglasses and a mustache. Blue is his dominant color and of his mask. His body and face are often painted black, and water is often depicted dripping from his hands.
                Phenomenon - the Civilization page - Aztec Gods -Tlaloc
                Although Templo Mayor had its northern section dedicated to Tlaloc, the most important site of worship of the rain god was on the peak of Mount Tlaloc, a 4100-meter-high mountain on the eastern rim of the Valley of Mexico.
                did yhu know :
                Sumer (ShuMer, Sumeria, Shinar, native Ki-en-gir) formed the southern part of Mesopotamia from the time of settlement by the Sumerians (about 4000 BC) until the time of Babylonia (around 2000 BC). Its location was in the southern part of the Tigris-Euphrates plain
                People from Sumer did not refer to themselves as “Sumerians”. It is a term that was first applied by the Akkadians. The Sumerians called themselves "the black-headed people" (sag-gi-ga) and called their land Ki-en-gi, "place of the civilized lords". Their language was called by them eMe.Gir.
                Groundation * The Seventh Seal - YouTube ... Burning Spear * Mother - YouTube
                http://en.wikipedia.org/wiki/Air_(classical_element)
                image of Gods of Ancient Egypt: Shu
                What does Shu K Ra N mean? .... Thank yhu S
                "Shu F" شوف which means "see," "look,"
                Tibet's Dalai Lama hints he could be the last in his line ... 14th Dalai Lama - Wikipedia
                Bob Marley - Iron Lion Zion - YouTube
                The etymology of the word Zion (ṣiyôn) is uncertain.[2][3][5] Mentioned in the Bible in the Book of S amuel (2 Samuel 5:7)
                Zion - Wikipedia, the free encyclopedia .... see also Psalms 137:3 .... Psalms 147:2
                • Samuel ----> Sha ma el ----> Shamash -
                  http://en.wikipedia.org/wiki/Sowilō
                  Coincidentally, the Phoenician letter šin from which the Old Italic s letter ancestral to the rune was derived was itself named after the Sun, shamash, based on the Egyptian uraeus hieroglyph.
                  ps: Ancient Egyptian necklace found on the skeleton of a 'virgin priestess' in Siberian burial mound
                  Let's Funk with yhu a bit : Alpha Blondy & The Solar System - Psalm 23 - Jerusalem - YouTube ... ALPHA BLONDY Miwa - YouTube
                  did yhu know :
                  "On January 4, 2008, a reversed-polarity sunspot appeared—and this signals the start of Solar Cycle 24,"
                  Are Traders Really Just Driven By the Sun?
                  Global financial crisis in September 2008 -
                  Stocks fell dramatically Monday in Europe and the US despite infusion of funds into the market for short term credit.[57][58] In the US the Dow dropped 777.68 points (6.98%),[59] the largest one-day point-drop in history
                  Interesting Points of View :
                  Are human beings robots? Interview with Dr. Rupert Sheldrake
                  NEW Santos Bonacci - 'The Lamb of God' Syncretism with Santos Bonacci
                  Alpha Blondy - Sebbe Allah .... Panda Dub - Ra Star machine
                  Addendum
                  List of Australian Aboriginal mythological figures -
                  Pan-continental[edit]
                  Rainbow Serpent , Snake, a common feature of the art and mythology of Aboriginal Australian cultures[3]
                  Ka Ro Ra, creator god
                  Bluetongue Lizard, an elderly trickster
                  Uluru
                  Description
                  Uluru is one of Australia's most recognisable natural landmarks. The sandstone formation stands 348 m (1,142 ft) high, rising 863 m (2,831 ft) above sea level with most of its bulk lying underground, and has a total circumference of 9.4 km (5.8 mi).[5] Both Uluru and the nearby Kata Tjuta formation have great cultural significance for the Aṉangu people, the traditional inhabitants of the area, who lead walking tours to inform visitors about the local flora and fauna, bush foods and the Aboriginal dreamtime stories of the area.
                  also :
                  ... St Germain - So Flute :
                  Caral-Supe: The discovery of 32 flutes made of Pelican and Condor Bones at Caral, echoes the Palaeolithic Old-world fascination with bird-bone flutes. Several horns made from Llama or Alpaca bones were also found. (3) The Caral-Supe civilisation, dated at c. 2,600BC is now recognised as a south American 'mother' culture.
                  The bone-flutes were found between the pyramids within the large sunken amphitheatre, with enough room for hundreds of people during community gatherings. The 32 flutes made of the wing bones of pelicans were tucked into a recess in the main temple.
                  Caral Complex, Peru. ... Bone Flutes.
                  Rasta Kokopelli ( or is it Ra in Bow ) .... panda dub - in dub we trust - YouTube ... Baaba Maal * Yiriyaro /Percussion Storm - YouTube
                  Lee "Scratch" Perry stating that dub is "the ghost in me coming out".[14]
                  The term dub had multiple meanings in Jamaica around the time of the music's origin. The most frequent meanings referred to either a form of erotic dance or sexual intercourse
                  John Corbett has suggested that dub could derive from duppy, a Jamaican patois word for ghost
                  Versions" and experiments with studio mixing (Late 1960s)[edit]
                  In 1968, Kingston, Jamaica sound system operator Rudolph "Ruddy" Redwood went to Duke Reid's Treasure Isle studio to cut a one-off dub plate of The Paragons hit "On The Beach".
                  Dub (music) - Wikipedia
                  Storm God Worship: Ancient Cult Complex Discovered in Israel
                  October 13, 2014: A massive cult complex, dating back about 3,300 years, has been discovered at the site of Tel Burna in Israel.
                  While archaeologists have not fully excavated the cult complex, they can tell it was quite large, as the courtyard alone was 52 by 52 feet (16 by 16 meters)
                  The archaeologists said they aren't sure who was worshipped at the complex, though Baal, the Canaanite storm god, is a possibility.
                  bombay dub orchestra - Spiral - YouTube
                  to turn, move round, bore through, perforate; writhe, be pained; to be loose, free, common, profane; to revolve, a flute; piper; one thrust through, dispatched, slain; unholy, unclean; defiled; a prostitute.
                  pr.n. "Wise".
                  ... see also Flute : Srimad Bhagavatam Canto 10 Chapter 21
                  SB 10.21.14: O mother, in this forest all the birds have risen onto the beautiful branches of the trees to see Krishna. With closed eyes they are simply listening in silence to the sweet vibrations of His flute, and they are not attracted by any other sound. Surely these birds are on the same level as great sages.
                  Lecture 3, part 2 ... Herbie Mann - Push Push 1971 - YouTube
                  By a strange coincidence, Uolm is the birthplace of Einstein some hundreds of years later. But on the night of September 16th, Descartes had a dream and in this dream an angel appeared to him, this is documented by his own hand, and the angel said to Descartes, "The conquest of nature is to be achieved through measure and number." ( ie : ... Logos ) And that revelation lay the basis for modern science. Rene Descartes is the founder of the distinction between the res verins and the res extensia, the founder of modern science, the founder of the scientific method that created the philosophical engines that created the modern world.
                  Let's Flow a bit more .... <º)))>< ... Af-rui-ka/Afuraka/Africa N Culture * Dub YouTube
                  It is a little-known fact that the Egyptians enjoyed hunting with Boomerangs.
                  Tuthmosis IV and the Sphinx Dream Stela
                  The world shall be yours in its length and in its breadth, as far as the light of the eye of the lord of the universe shines
                  Dream Stele - Wikipedia
                  “Music is liquid architecture; Architecture is frozen music.”
                  Johann Wolfgang von Goethe
                  a generator works on the same principle
                  Pyramid of Djoser - Wikipedia, the free encyclopedia
                  Djoser
                  Coordinates 29°52′16.56″N 31°12′59.02″E
                  Constructed 2667–2648 BC[1]
                  Type Step Pyramid
                  Height 62 metres (203 ft)
                  Base 125.27 metres (411 ft) (larger)
                  109.12 metres (358 ft) (smaller)
                  The Pyramid of Djoser (or Zoser), or step pyramid (kbhw-ntrw in Egyptian) is an archeological remain in the Saqqara ( or is it Sha Ka Ra ... ) necropolis, Egypt, northwest of the city of Memphis.
                  Shabaka Stone - Wikipedia, the free encyclopedia
                  The Shabaka Stone is a relic from the Nubian Twenty-fifth Dynasty of Egypt incised with an important Egyptian religious text, the Memphite Theology.[1]
                  It is a stone slab measuring 66 cm in height and 137 cm in width ( other size mentioned 92 x 138 cm )
                  The Sha Ba Ka Stone is also noteworthy in that it places Ptah as the center of existence and as the creator god. It is the principal surviving source of these traditions about Ptah. ... E S Hu
                  High Tone - Spiral Snake - YouTube
                  Amulet of the God Thoth ( aka Te Hu Ti ) as Ape with Wadjet-eye
                  Medium: Faience, glazed
                  Dates: ca. 664-30 B.C.E.
                  Dimensions: 1 5/8 x 3/4 x 7/8 in. (4.1 x 1.9 x 2.2 cm)
                  Ya Hu wah / YHu Wah ( *wah wah spring )
                  ps: Spectacular long duration eruption beyond the east limb ... Major solar flare measuring X1.1 erupted from southeast limb ... Fela Kuti - Power Show - YouTube
                  • Open SeSaMe .... (in Arabic ) IFTAH Yā SimSim .... said Al i Baba .... Ali Baba and the Forty Thieves from the 1001 Nights .... i Baab Al ..... Let's Start
                    Ptah's original name in Ancient Egyptian is reconstructed to have been pronounced as *Pitáḥ based on the occurrence of his name in hieroglyphics, ptḥ, surviving into Coptic as Ptah, just as it is now written in English. The name was also borrowed early on into Greek as Φθα Phtha. The meaning of his name, which can be translated as "the opener," is somewhat ambiguous, though it may be related to the "opening of the mouth" ritual that was often credited to him. (Budge 1895, cviii) However, it should be noted that the only uses of this verb in Egyptian texts place this "opening" in a very particular context, as represented by the verbs "to engrave," "to carve," or "to chisel"—a usage that is also paralleled in Hebrew. (Budge 1969, Vol. I, 500) In this way, the god's name echoes his association with crafting and creation.
                    Phtha Yā Mi Is ...... Herbie Mann ~ Spirit Of The Dark
                    *Yami language ... also known as Tao ... Yami is known as ciriciring no Tao, or "human speech," by its native speakers.[1] ( reminds yhu of KUKUL KA N )
                    Ptah = Phi + Theta - + Alpha -
                    Phi is also used as a symbol for the golden ratio
                    In its archaic form (A symbol of a cross within a circle) theta is used as a symbol for Earth.
                    Alpha was derived from aleph, which in Phoenician means "ox".[4]
                    Shu F ( Ph ) also http://en.wikipedia.org/wiki/Apis_(god) + Uruz Rune Secrets + Astrological Signs, Numbers and Letters and their Correspondence
                    * One of the titles of Ra is "Ra Ur", meaning among other things "Ra, the Great One".
                    H. : 1,26 m. ; l. : 1,76 m.
                    ... Mikey Dread - Zodiac Signs
                    ... Legs-forward (hieroglyph)
                    Meaning of Ma Hu / mahō is used in Japanese, ....Fela Kuti - Gentleman - YouTube
                    when you express joy , one says : hur rah
                    what is the slang word for vagina / Yoni : hu-ha
                    but did yhu know
                    huha means to wander (to Flow ) . ( from http://rup.eke.to/019/maui_and_egypt.html ... see Ka Hu Na )
                    Both Ptah and Atum had the title of Huhi the eternal
                    Other Name for Eve: Huwwah
                    ... Phtha Yā Huwwah Huhi Yā Huwwah ... Fela Kuti Ma tress ... A Cunning Linguist Ka Ma Shu T Ra Stylee .... Mikey Dread - Heavy Weight Sound DUB
                    .... Rivers Of Babylon
                    addendum :
                    In the original text of the Hebrew Bible, the Hebrew letters for Jah (YH) occurs 50 times - 26 times alone and 24 times in the term Hallelu'yah. Jah
                    Thoth aka "Djah Hu Ti" Egyptian God of Writing, MaHu and Science
                    Oracle Centres
                    "Ka Ra Nun aK "(Thebes), Egypt - Karnak is the mother oracle to all other oracle centres. The name translates as 'The most perfect of places'.
                    Location El-Karnak, Luxor Governorate, Egypt
                    Region Upper Egypt
                    Coordinates 25°43′7″N 32°39′31″E
                    Type Sanctuary
                    ... <º)))><
                    Great Hypostyle Hall -
                    The Great Hypostyle Hall of Karnak, located within the Karnak temple complex, in the Precinct of Amon-Re, is one of the most visited monuments of Ancient Egypt. The design was initially instituted by Hatshepsut, at the North-west chapel to Amun in the upper terrace of Deir el-Bahri. The name refers to hypostyle architectural pattern.
                    The hall covers an area of 50,000 sq ft (5,000 m2). The roof, now fallen, was supported by 134 columns in 16 rows; the 2 middle rows are higher than the others (being 33 feet (10 m) in circumference and 80 feet (24 m) high).
                    "Djah Hu Hi" (hieroglyph) ... Herbie Mann - Bird Walk - Huha
                    The term 'Earth Navel' was applied to several 'sacred' locations from the ancient world
                    Earth Navel's aka Om ph al os
                    Noun[edit]
                    os (plural ora)
                    (rare) A mouth; an opening.
                    In particular, either end of the cervix, internal (to the uterus) or external (to the vagina).
                    Irish[edit]
                    Noun[edit]
                    os m (genitive ois, nominative plural ois)
                    (literary) deer
                    or ------------
                    Etymology 1[edit]
                    ōs (mouth)
                    From Proto-Indo-European *h₁éh₃(o)s (“mouth”). Cognates include Hittite 𒀀𒄿𒅖 (aiš, “mouth”), Sanskrit आस् (ās, “mouth”), Old Church Slavonic оуста (usta, “mouth”) and Old Irish á (“mouth”).
                    .... ( capitale Ω ) ωμ Φθα ..... Om Phtha ōs
                    * The word literally means "great O" (ō mega, mega meaning 'great')
                    *the Greek Mu (Μ, μ). Semitic Mem probably originally pictured water ( Wah )
                    *Omicron (uppercase Ο, lowercase ο, literally "small o": Όμικρον, o mikron, micron meaning 'small' in contrast to omega) ... As Above ...
                    Blackstones - Open The Gates ...
                    ... Hut-ka-Phtha (meaning "Enclosure of the ka of Ptah" or is it Open SeSaMe ....) .... Hu (mythology) + Sia (god) = SHu as in "Shu ph"
                    In the New Kingdom, both Hu and Sia together with Heke, Irer and Sedjem were members of the fourteen creative powers of Amun-Ra. By the time of Ptolemaic Egypt, Hu had merged with Shu (air)
                    *Hu = Hw just like Eve ... HuW wah ... What does Hawa mean in Arabic?
                    ... Mikey Dread - Roots and Culture - YouTube
                    O_O ..... "Shu ph" ... Why golden ratio pleases the eye: US academic says he knows art secret
                    According to Bejan, these arguments are academic. Whether intentional or not, the ratio represents the best proportions to transfer to the brain. "This is the best flowing configuration for images from plane to brain and it manifests itself frequently in human-made shapes that give the impression they were 'designed' according to the golden ratio," said Bejan.
                    SKIP SKIP DIP SKIP DIP ....
                    The Pyramid Code - The Empowered Hu Man
                    The lamps are different
                    But the light is the same. ~ Rumi
                    14 4 means "Light and Sound ( see previous posts ) "
                    9) By this means you shall have ye glory of ye whole world & thereby all obscurity ( aka Ignorance ) shall fly from you. ( Emerald Tablet of Hermes )
                    Happy Diwali
                    the "festival of lights" on 22 / 10
                    Mikey Dread - Saturday Night Style - YouTube
                    did yhu know :
                    The heaviest moai is a shorter one located at Ahu Tongariki. It weighs 86 tons.
                    Only 1 of all moai statues has legs. This is the famous small kneeling moai, called Tukuturi. Some believe that Tukuturi is related to the Tangata Manu (Bird Man) cult.
                    and
                    are you familiar with Synodic Astrology: The New 32-year Saturn-Orcus Synodic Cycle ( thank yhu MC )
                    By 2014, Orcus conjoins the stars of the sextant
                    Orcus is working with the theme of exploration, of uncovering a blueprint or map that leads to a new picture, a new reality; to emerge from the belief structures and constructs of mind that are merely based upon the convenience of our collective consensus
                    The association of Orcus with oaths is quite curious, the issue of living our "soul oaths" is a fundamental facet of the new 32-year Saturn-Orcus Synodic Cycle.
                    other interesting Patterns
                    Muhammad: Legacy of a Prophet -
                    Muhammad: Legacy of the prophet ( Latin propheta .. proPhtha. ) is a PBS documentary film about the life of the Islamic prophet Muhammad based on historical records
                    Three years in the making, the documentary tells the story of the seventh century prophet ( at age 40 ) who changed world history in 23 years, and continues to shape the lives of more than 1.2 billion people.
                    • yhur turn Ka La Ma ..... "E.V.E." .... with all the info on this page
                      * the fourteen creative powers of A Mu Nun -Ra
                      FIVE ( 13 in 1 ) is the master, the Lord of all magic -
                      Key to The Word that resounds among men.
                      SIX is the Lord of Light, the hidden pathway,
                      path of the souls of the children of men.
                      EIGHT is he who orders the progress;
                      weighs and balances the journey of men.
                      NINE is the father, vast he of countenance,
                      forming and changing from out of the formless.
                      The Emerald Tablets of Thoth the Atlantean - 1 ... "Shu Ph" also http://www.energeticforum.com/264140-post5280.html
                      Early history[edit]
                      Amun and Amaunet formed one quarter of the ancient Ogdoad of Hermopolis, representing the primordial concept or element of air or invisibility (corresponding to Shu in the Ennead), hence Amun's later function as a wind deity, and the name Amun (written imn, pronounced Amana in ancient Egyptian [5]), meaning "hidden".[6] It was thought that Amun created himself and then his surroundings.[1]
                      Amun rose to the position of tutelary deity of Thebes after the end of the First Intermediate Period, under the 11th dynasty. As the patron of Thebes, his spouse was Mut. In Thebes, Amun as father, Mut as mother and the Moon god Khonsu formed a divine family or "Theban Triad".
                      Amun
                      one more info :
                      The Element of Spirit - The Elements :
                      The Fifth Element - A Ka Sh A - Spirit
                      Basic nature: unknowable;
                      Type of energy: projective/receptive;
                      Colour: purple or black;
                      The Elements emerge from Akasha, the immutable, changeless source of all energy. This is the realm of potentiality: of promise, of paths not yet taken, of unformed galaxies, of outer space.
                      The regions of the hippocampus in the brain are called the cornu ammonis – literally "Amun's Horns", due to the horned appearance of the dark and light bands of cellular layers.
                      2 Functions
                      2.1 Role in Mem ory
                      2.2 Role in spatial memory and navigation
                      Hippocampus - Wikipedia, the free encyclopedia
                      Hippocampal activity during music listening exposes the memory-boosting power of music -
                      psyche rock ...
                      ... yhu should be able to read the following :
                      Open SeSaMe .... (in Arabic ) IFTAH Yā SimSim .... said Al i Baba .... Ali Baba and the Forty Thieves from the 1001 Nights .... i Baab ( Door ) Al .....
                      O this cavern that separates the gods, too secret for the spirits, too difficult for the gods,
                      the one in it is called feller of the cat-fish.
                      Hail, this cavern,
                      I have come to see the gods who are in you.
                      Open your faces, unwind your headcloths at my approach.
                      I have come to make your offering-loaves.
                      The feller of the cat-fish has no power over me,
                      the disease-demons shall not come after me, the fiends shall not come after me.
                      I live on the offerings with you.
                      Book of the Dead 149 ... * Ctrl F + Hw
                      Chapter 149o (Mound 14)
                      O this mound of Kheraha, keeping the Flood from Djedu,
                      sending the Flood measured and placed in bushels, guiding it to the mouth of the eater,
                      giving divine offerings to the gods and voice offerings to the spirits.
                      This serpent that belongs to it is in the double cavern of Abu at the mouth of the Flood.
                      It comes with water, and stands at this district of Kheraha at this first council of the waves
                      until it sees in its hour of silence of the night.
                      O gods of Kheraha, of this first council of waves,
                      Open to me your bound land, reveal to me your canals.
                      I have power over water, I rest in the waves, I eat grain, I rest with your provisions.
                      Raise me, so that my heart may be great like the god that is in Kheraha.
                      Make your offerings for me,
                      provisioned with the fluid coming from Osiris.
                      I cannot be untied from him forever.
                      The composition designated 'chapter 149' by Lepsius, from its position in the Ptolemaic Period papyrus of Iufankh, presents a numbered series of fourteen 'mounds' in the underworld. Each Mound is addressed with reference to its inhabitants or landscape, and the encounter is used to empower the deceased: in this way, each potential obstacle to new life is converted into empowerment of the deceased.
                      Most of the fourteen parts of chapter 149 occur for the first time in the Eighteenth Dynasty, and are only known from this chapter; some parts recur as separate compositions in the Book of the Dead, some already occur in the Middle Kingdom (about 2025-1700 BC) among the funerary compositions written on the sides of coffins (the 'Coffin Texts'), and one section echoing one of the compositions inscribed on the walls within the Old Kingdom (about 2686-2181 BC) pyramids ('Pyramid Texts').
                      ... Mikey Dread " Ancestral Dub"
                      Chapter 149i (Mound 9)
                      O this Ikesy, too secret for the gods, whose name the spirits fear to know,
                      which those that enter cannot leave except for this noble god,
                      who causes fear of him for the gods and terror of him for the spirits.
                      It is a flame with the air of destruction for nostrils and mouths.
                      He did it against his following, to prevent them breathing his air,
                      except for this noble god who is in his egg.
                      I have come before you to be in your following.
                      I come and go in Ikesy, and is doors are opened for me.
                      I breathe the air in it, and have power over its offerings.
                      ... Bird in a Silver Cage (1977)
                      Book of the Dead Chapter 77
                      Sources for the composition: before the New Kingdom, this transformation formula occurs on early Middle Kingdom coffins ('Coffin Texts' number 302).
                      This chapter is among the Formulae for assuming the shape of a divine being animal, or bird. found in the Book of the Dead of Nu
                      Formula for taking the form of a falcon of gold
                      I am risen, I am risen as a great falcon emerging from his egg,
                      I fly up and alight as a falcon of four cubits in length,
                      its two wings of fine greenstone,
                      I have come from the chest of the evening boat.
                      I have brought my heart from the eastern mountain.
                      I have alighted in the morning boat.
                      I have brought those who are in their offerings bowing down, to give me praise.
                      I am risen, I am complete, as the beautiful falcon of gold upon the heron-perch.
                      whose words Ra goes in to hear every day.
                      I sit among those great gods of the Sky-water,
                      the two fields of Hetep are laid for me in my presence,
                      my abundance receives my heart.
                      Nepri has given me a throat,
                      I have power over the keeper of my head.
                      Gods and Goddesses
                      14 4 Knowing the names of the keepers of the seven approaches
                      ... <º)))><
                      Pyramid of the Magician ( mahu tsu Ka i in japanese ) .... Fela Kuti - Ariya
                      Alternate name Pyramid of the Dwarf,Pyramid of the Soothsayer ( Oracle / proPhtha)
                      Location Campeche
                      Region Uxmal
                      Coordinates 20°21′34″N 89°46′17″W
                      Type Temple
                      Width 81m (267ft)
                      Height 40m (131ft)
                      According to one account, a magician-god named Itzamna was single-handedly supposed to have erected the pyramid in one night, using his might and magic.
                      A slightly different version of this tale is recounted by Hans Li in The Ancient Ones: Legend tells that this temple-pyramid was built by a powerful dwarf magician, who was hatched from an egg by his mother.
                      In Yucatec Maya mythology, Itzamna (Mayan pronunciation: [it͡samˈna]) was the name of an upper god and creator deity thought to be residing in the sky. Little is known about him
                      From the Late Postclassic Paris Codex back in time to the Pre-Classic San Bartolo murals, god D (Itzamna) has the so-called Principal Bird Deity - perhaps the Yaxcocahmut mentioned above - for a transformative shape (see figure). The bird often holds a bicephalous snake in its beak. Its head sometimes resembles that of a rain deity; at other times, it is more like that of a bird of prey, perhaps the laughing falcon believed to be a harbinger of rain.[6]
                      Music ... Player One - Space Invaders ... solar flares online
                      Music formed the chief part of education in ancient Ireland as in Greece, where the same word signified a song and a law. Laws, religion, sciences, and history were all taught in music to the Irish people by the Ollamhs, or learned men.
                      The Mesoamerican ballgame or Ōllamaliztli in Nahuatl (Nahuatl pronunciation: /oːlːamaˈlistɬi/) was a sport with ritual associations played since 1,400 B.C.[1] The rules of Ōllamaliztli are not known, but judging from its descendant, ulama ( or Hulama )
                      The Great Ball-court: The Great Ball-court is 545 feet long and 225 feet wide overall. It has no vault, no continuity between the walls and is totally open to the sky.
                      The sound waves are unaffected by wind direction or time of day/night. Archaeologists engaged in the reconstruction noted that the sound transmission became stronger and clearer as they proceeded. .
                      fyi:
                      Ollamh is a lovely word. this word Ollamh is pronounced like Uh-Luv. (Love). Beautiful word!
                      Shu K Ra N Moon
                      ... Om Phtha ōs ... DONNA SUMMER - I feel love (1977)
                      • forgot to add : .... Uh-Luv to love you baby ...
                        .... Genomic data support early contact between Easter Island and Americas
                        In the most widespread version of the game, the players struck the ball with their hips ( zodiac sign correspondence Medical astrology
                        .... Mikey Dread Zodiac Signs )
                        yhu know there is an interesting concept / interpretation of the word Death ( besides La petite mort ):
                        In fact, the Khemitians ( KMT ) ... (who Hakim called the very ancient and highly sophisticated, pre-dynastic Egyptians) never spoke of death ---but, rather of “westing”, reflecting the paths of our sun and stars.
                        Egypt and 2012: What did the ancient Egyptians tell us about this great time of transformation?
                        fyi: on July 23, 2012 , Earth survived near-miss from 2012 solar storm: NASA
                        Book of the Dead ... would become .... Abracadabra ... Journey to the West - ( shu ph also : The Liberation Through Hearing During the Intermediate State / Tibetan Book of the Dead )
                        It deals entirely with the earlier exploits of Sun Wukong, a monkey born from a stone nourished by the Five Elements, who learns the art of the Tao, 72 polymorphic transformations, combat, and secrets of immortality, and through guile and force makes a name for himself, Qitian Dasheng , "Great Sage Equal to Heaven"
                        Journey to the West Chapter 77
                        This chapter is among the Formulae for assuming the shape of a divine being animal, or bird. The following version is from that found in the Book of the Dead of Nu
                        Formula for taking the form of a falcon of gold ... Chase
                        its two wings of fine greenstone, .... "Shu ph" also Jade Emperor
                        Nepri has given me a throat ( Log Os ),
                        "Shu ph" also : Chinese pyramids
                        There are many stories in Chinese mythology involving the Jade Emperor.
                        The Jade Emperor (Chinese: 玉皇; pinyin: Yù Huáng or 玉帝, Yù Dì)
                        It was said that the Jade Emperor was originally the crown prince of the kingdom of Pure Felicity and Majestic Heavenly Lights and Ornaments. At birth, he emitted a wondrous light that filled the entire kingdom. When he was young, he was kind, intelligent and wise. He devoted his entire childhood to helping the needy (the poor and suffering, the deserted and single, the hungry and disabled). Furthermore, he showed respect and benevolence to both men and creatures ....
                        After 1,750 kalpas, each kalpa lasting for 129,600 years, he attained Golden Immortality. After another one hundred million years of cultivation, he finally became the Jade Emperor (using the given figures, this period before his becoming the Jade Emperor lasted for a total of about 226,800,000 years.)
                        One of the myths describes how the Jade Emperor became the monarch of all the deities in heaven. It is one of the few myths in which the Jade Emperor really shows his might
                        He was saddened because his powers could only ease the suffering of humans. He retreated to a mountain cave to cultivate his Tao. He passed 3,200 trials, each trial lasting about 3 million years
                        1 Chinese mythology
                        1.1 Origin
                        1.2 Vanquishing evil
                        1.3 Creation
                        1.4 In The Journey to the West
                        1.5 The Weaver Girl and the Cowherd
                        1.6 The zodiac
                        Journey to the West
                        the Buddha gave this task to the monk and provided him with three protectors who agree to help him as an atonement for their sins.
                        These disciples are Sun Wukong, Zhu Bajie, and Sha Wujing, together with a dragon prince who acts as Xuanzang's steed, a white horse
                        The Uffington White Horse is a highly stylized prehistoric hill figure, 110 m long (374 feet), formed from deep trenches filled with crushed white chalk. The figure is situated on the upper slopes of White Horse Hill in the English civil parish of Uffington
                        Nearby features
                        . Dragon Hill is a natural chalk hill with an artificial flat top, associated in legend with St George[9]
                        "By tradition, the Uffington White Horse was made in honor of the Celtic goddess Rhiannon . Less well known is that the same goddess was also symbolized by birds ( Birds and humans have similar brain wiring ). "
                        Fleetwood Mac - Rhiannon [with lyrics] - YouTube
                        White Buffalo Calf Woman (Lakota: Pte (or ptah... ) Ska Win / Pteskawin / Ptesanwi) is a sacred woman of supernatural origin, central to the Lakota religion as the primary cultural prophet. Oral traditions relate that she brought the "Seven Sacred Rituals" to the Teton Sioux
                        SKA REGGAE ROCKSTEADY .
                        Rhiannon has a growing and varied tradition across the modern Pagan, Goddess, and Celtic tradition communities since the 70s
                        The November 22, 1977 solar flare
                        Night Fever 1977
                        Modern-day scientists are just learning about the energies of the Sun. Ancient knowledge of the Mayan Wisdomkeepers denote a 23-year cycle of the Sun. Eleven years inbreath (solar maximum), 6 months moment between the breath and eleven years outbreath ( solar minimum) repeating of 6 months between the next phase. The Male energies are in sync with this Sun cycle, expressing as 23 days (micro) and 23 year (macro) cycles that regulate hormone functions in the physical body.... The Brothers - Fire
                        Understanding Mayan Cycles ( no other source mentions it ... )
                        Study shows women's menstrual cycle phase impacts sexual preference for composers of more complex music
                        Pregnant women respond to music with stronger physiological changes in blood pressure
                        Mi, meaning "waning, diminishing", and Is for "waxing, swelling". this double spiral mi-is petroglyph denotes "synchrony, rhythm" (above)
                        ... Air Cosmic Bird
                        nice spikes ... Quetzalcoatl
                        ... Witch Queen - All Right Now (Astrolabia Discotheque) ... nut
                        food for thoth :
                        The Revolutionary 1960s
                        Pedal to the Metal: The 25 Greatest Wah Solos of All Time ... Wah-wah pedal
                        The creation of the wah pedal was actually an accident
                        HENDRIX: WAH MASTER ... read comments
                        .... Ocean Breeze
                        ... Electrical stimulation of brain alters dreams, ... Medical Applications - WikiRota
                        Halloween or Hallowe'en ,[6] also known as Allhalloween,[7] All Hallows' Eve,[8] or All Saints' Eve,[9] is a yearly celebration observed in a number of countries on 31 / 10
                        Halloween
                        .... Season Of The Witch (1968) - YouTube
                        • ... Brian Auger & The Trinity - Listen Here - YouTube
                          how many stars do you count next to Nut's Huha .... and how many next to Nut's ōs (mouth).... Drum Solo (Part 1)
                          The Letter Tet ... as in Ba S Tet or Nu T ( teth /tav ) :
                          The Mystery of Tet
                          Tet is a paradoxical letter in that it reveals both good (tov) and evil. The form of the letter is "inverted," suggesting hidden goodness, like that of a woman who is pregnant with child. However, sometimes the potential for goodness (tahorah) is perverted, and impurity or filth (tumah) results.
                          Tet is the least frequently occurring letter in the Scriptures (Yod is the most popular). The letter first appears in Genesis 1:4:
                          also :
                          Tet = Theta - = Teth - Wikipedia, the free encyclopedia
                          According to Porphyry of Tyros, the Egyptians used an X within a circle as a symbol of the soul; having a value of Nine
                          HEBREW GEMATRIA: Values from 1 - 9
                          and
                          KMT -------> The Letter Kaf / Khaf + The Letter Mem + The Letter Tav
                          Km (hieroglyph) - Wikipedia
                          The owl is often associated with wisdom. Symbolically, an owl sees into the unknown, the unconscious, the “spirit world.”
                          Significance of tav[edit]
                          In gematria tav represents the number 400, the largest single number that can be represented without using the sophit forms (see kaph, mem, nun, pe, and tzade)
                          *The letter Aleph is the "father" of the Aleph-Bet, whose original pictograph represents an ox, strength, and leader. It's numerical value is one (and also 1,000) and it is a silent letter.
                          "shu ph" also : Tau ( the T found on the back of a scarab )
                          In the beginning God created the heavens and the earth. Now the earth was a vast nothingness with darkness upon the surface of the deep, and the Divine Presence hovered upon the surface of the waters,. And God said," Let their be light." and there was light.
                          Genesis 1:1-3
                          The Hebrew Story Letters of the Tarot: TAV (Tau / Taw or Tao )
                          <º)))><
                          The Letter Nun + Nu (mythology)
                          .... note the solar boat looks like " The form of the letter Tet or Tav "inverted," suggesting hidden goodness "
                          144 Knowing the names of the keepers of the seven approaches ... Book of the Dead
                          According to religious doctrines of the time, it was in this chamber, which the ancient Egyptians called the golden hall that the regeneration of the deceased took place. This decorative pictogram of the walls in the burial chamber drew inspirations from chapters 144 and 146 of the Book of the Dead:
                          in the left half of the chamber, there are passages from chapter 144 concerning the gates and doors of the kingdom of Osiris, their guardians, and the magic formulas that had to be uttered by the deceased in order to go past the doors .... Valley of the Queens - Crystalinks
                          Nun is thought to have come from a pictogram of a snake (the Hebrew word for snake, nachash begins with a Nun and snake in Aramaic is nun) or eel. Some have hypothesized a hieroglyph of a fish in water for its origin (in Arabic, nūn means large fish or whale). The Phoenician letter was named nūn "fish", but the glyph has been suggested to descend from a hypothetical Proto-Canaanite naḥš "snake", based on the name in Ethiopic, ultimately from a hieroglyph representing a snake
                          -----> The hieroglyphic language equivalent of the water ripple is n, the letter N, as a phonogram
                          some interesting parallels :
                          Osiris - The First Messiah: Was Jesus The 'Second Coming' Of Egypt's Christ ( aka : Ye Shu A ) ? - MessageToEagle.com
                          In the beginning was the Word, and the Word was with God, and the Word was God. The same was in the beginning with God. All things were made by him; and without him was not any thing made that was made. – John 1:1-3
                          Word = Log ōs
                          .... Taw
                          You shall not do injustice in judgment, in length, in weight, or in measure. - Leviticus / Vayikra 19:35 ... ( ‘Dan’ means judgment )
                          see also Tuthmosis IV and the Sphinx ( aka : Hw ra N ) Dream Stela ( previously posted )
                          The shape of the ת Tav is comprised of two letters: to make a ת Tav you unite a ד Daleth ( fourth Hebrew letter ) and a נ Nun ( the fourteenth letter of the Hebrew alphabet ) ( = 144 ) . You can see the Daleth on the right hand aspect of the Tav, and you can see the Nun in the left hand aspect of the Tav. The letters דנ Daleth-Nun spell ‘Dan’ in Hebrew. ‘Dan’ means judgment.
                          ת .... Tuatha Dé Danann
                          Ohue .... Cymande - Listen - YouTube
                          "shu ph" also HEBREW GEMATRIA: Values from 50 - 59
                          fun "facts":
                          in Arabic the word "Development ( تطوير )" = Taw Teth Ur as in Personal Development
                          Siva [Shiva "the Transformer" ] and the Palestinian Baal, or Moloch, and Saturn are identical ....
                          Baal Shem Tov
                          . The title Baal Shem Tov is usually translated into English as “Master of the Good Name,” but at least two other translations are possible:[1]
                          "Good Master of the Name," taking "Baal Shem" as a unit, meaning one who "owns the [holy] name" therefore has the power or uses Divine names to cure illnesses and perform miracles. I.e., an effective baal shem.
                          "One who has a good reputation in the community," since in Hebrew idiom, "Baal" can mean "one characterized by" and "Shem" can mean "reputation," thus "one characterized by a good reputation."
                          on a side note
                          1959 The Year that Changed Jazz - YouTube .... Take Five - Dave Brubeck (long version) - YouTube
                          .... Study of jazz players shows common brain circuitry processes music and language
                          in spring 1923 the fantasy magazine Weird Tales launched, and was soon serving up macabre wonders by Robert E. Howard, Clark Ashton Smith, and, of course, H.P. Lovecraft... CtHulHu - Wikipedia, the free encyclopedia ... Kiko - YouTube
                          • did yhu know: Thoth "His designation in inscriptions was "The Lord of E Sh MooN" ( Other Name for Moses : Mo Sh E meaning "to pull/draw out" [of Water: N]. )
                            The Air That I Breathe
                            The ancient book of wisdom at the heart of every computer
                            Gottfried Wilhelm Leibniz was a philosopher and mathematician in search of a model. In the late 1600s Leibniz decided there was a need for a new, purer arithmetic than our common decimal system. Leibniz discovered the model for this new arithmetic in the five-millennia-old book that is at the heart of Chinese philosophy: the I-Ching, or Book of Changes.
                            This ancient text was such an influence on Liebniz that he titled his article on the new arithmetic: "Explanation of the binary arithmetic, which uses only the characters 1 and 0, with some remarks on its usefulness, and on the light it throws on the ancient Chinese figures of Fu Xi". Fu Xi was the legendary first author of the I-Ching. The arithmetic Liebniz described was binary code, which is used in almost every modern computer, from iPhones to China's own Tihane-2 supercomputer.
                            with this in mind .... re-read this post : http://www.energeticforum.com/265830-post5288.html + Human brain, internet, and cosmology: Similar laws at work?
                            I Ching - Wikipedia, the free encyclopedia
                            The I Ching uses a type of divination called cleromancy, which produces apparently random numbers. Six random numbers are turned into a hexagram, which can then be looked up in the I Ching book, arranged in an order known as the King Wen sequence.
                            The Zhou yi is attributed to the legendary world ruler Fu Xi. According to the canonical Great Commentary, Fu Xi, who lived around 2800 BC, observed the patterns of the world and created the eight trigrams (Chinese: 八卦; pinyin: bāguà), "in order to become thoroughly conversant with the numinous and bright and to classify the myriad things."
                            Hexagram 14 ( + Hexagram 4 )
                            Hexagram 14 is named 大有 (dà yǒu), "Great Possessing". Other variations include "possession in great measure" and "the great possession". Its inner trigram is ☰ (乾 qián) force = (天) heaven, and its outer trigram is ☲ (離 lí) radiance = (火) fire.
                            ... I Ching: 14 Great Possessing
                            ( + I Ching: 4 Enveloping )
                            ... Fela kuti - Black Man's cry - YouTube
                            Fire ( Fu ) , the inner fire,
                            is the most potent of all force,
                            for it overcomethall things and
                            penetrates to all things of the Earth. .... read on
                            There is also an ancient folk etymology that sees the character for "changes" as containing the sun and moon, the cycle of the day. Modern Sinologists believe the character to be derived either from an image of the sun emerging from clouds, or from the content of a vessel being changed into another
                            In the Zuo zhuan stories, individual lines of hexagrams are denoted by using the genitive particle zhi, followed by the name of another hexagram where that specific line had another form. In later years, the word zhi was interpreted as a verb meaning "moving to", an apparent indication that hexagrams could be transformed into other hexagrams
                            Zhi in Confucian literature | Unpolished Jade
                            meditate on the image / Form above and you'll find 8 6 9
                            ps : The Great Pyramid of Giza has 8 Sides - YouTube
                            Egyptian:
                            Old Kingdom Egyptians recognized a group of eight deities, four male and four female, with the female bearing feminine forms of the male names: Nu, Nanet, Amun, Amunet, Kuk, Kauket, Huh, and Hauhet. Each pair represents a primal force, water, air, darkness, and infinity, and together they create the world and the sun god Ra from the primordial waters. Together, these eight are known as the Ogdoad, and this context is borrowed by other cultures which may represent it with an octagram
                            Octagrams - Eight-Pointed Stars
                            for more : Understanding BaGua, I Ching, Binary Code, and DNA - YouTube
                            The Master was playing, one day, on a musical stone in Weil when a man carrying a straw basket passed door of the house where Confucius was, and said, "His heart is full who so beats the musical stone."
                            confucius, the analects - 14
                            Under the Chen is a symbol of the primordial waters of the Nun but also the perfume of the Eye of Horus that comes from the horizon.
                            note the Nine Strings ... ye ye de smell - YouTube
                            How sound and smell can create perfect harmony | Science ... btw : bastet's name means, "she of the perfume jar"
                            ... Entheogenic Shamanism Ancient Astronauts History - YouTube
                            It was referred to as the Nine Bows in the stele that sits between the paws of the Sphinx ( aka : Hw ra N ) as well as in Line 1656 of the Pyramid Texts (Faulkner). This line participates in a prayer (Utterance 600) for the Osiris King and his pyramid seeking protection from the Great Ennead and its 9 powers or potencies.
                            Egypt, 1989: A Potent Detour (Post 5) | Bruce Lyons - Unexpected Journey
                            Like the Australian Aborigines, the Egyptians were very sensitive to the Earth’s main dipole magnetic field. To associate the Benben Stone with iron was to associate it with the capacity for iron to support a magnetic field. Temples, crypts, dolmens, menhirs, were designed to capture and concentrate the magnetic field as well as accompanying electrostatic energy that made the cavern, crypt or dolmen pregnant with the serpent current (telluric?) that would in turn induce it to open the serpent-in-the-spine
                            Mysteries there are in the Cosmos
                            that unveiled fill the world with their light.
                            Let Hu who would be free from the bonds of darkness
                            first divine the material from the immaterial,
                            the fire from the earth;
                            for know ye that as earth descends to earth,
                            so also fire ascends unto
                            fire and becomes one with fire.
                            He who knows the fire that is within
                            himself shall ascend unto the eternal fire
                            and dwell in it eternally. The Emerald Tablets of Thoth the Atlantean - 1
                            Jade burial suit - Wikipedia, the free encyclopedia
                            The discovery in 1968 of two complete jade suits ( see Jade Emperor ) in the tombs of Liu Sheng and Dou Wan in Mancheng, Hebei.
                            The jade suits of Liu Sheng and Dou Wan consisted of 2,498 plates of solid jade connected with two and a half pounds of gold wires.... Prince Sheng Liu, who died in 113BC.
                            In crystal therapy Green jade ( 2,498 plates ) is associated with the 4th chakra, the heart center, with water and signs of Cancer, Pisces, Libra and Virgo:
                            - being associated with the heart chakra, it is useful to treat stress, anxiety and disorders of blood circulation and as an aid to memory
                            - being associated with the heart chakra and the sign of Virgo, it is the stone of love par excellence
                            - being associated with water, has effect on the sphere of the emotions and on the feminine sphere (once more, love, then intuition and compassion), on kidneys, stimulating and regulating their function the expulsion of the calculations, as well as it strengthens the immune system.
                            JADE, the stone that charmed man since Neolithic times
                            ps: Scientists: Glass dish unearthed in Nara ( Japan ) came from Roman Empire
                            addendum: Mahjong is usually played with a set of 144 tiles.
                            One of the myths of the origin of mahjong suggests that Confucius,[1] the Chinese philosopher, developed the game in about 500 BC
                            The myth also claims that Confucius was fond of birds, which would explain the name "mahjong" (maque 麻雀 = sparrow).
                            Sister Rosetta Tharpe - His Eye is On the Sparrow
                            fyi:
                            Inspiration His Eye Is on the Sparrow ( spired spir·ing: to rise in or as if in a spiral )
                            The theme of the song is inspired by (Matthew 6:26)
                            .... Kalakuta Show
                            ... One day
                            *[CHORUS] NOVEMBER 23
                            • Thanks
                              That was a little gem of a video
                              It makes the most sense re those trying to explain shamanism, cave paintings, sound/science of acoustics and the resultant flight/journeying through natural energies.
                              Good to see the 'alien' thing being debunked.
                              • ... Time ( dub Pink Floyd )
                                O_O ... Do homing pigeons navigate with gyroscope in brain?
                                Owls, Synchronicity and the UFO Abductee by Mike Clelland
                                Kecksburg UFO incident
                                The Kecksburg UFO incident occurred on December 9, 1965, at Kecksburg, Pennsylvania, USA.
                                Others from Kecksburg, including local volunteer fire department members, reported finding an object in the shape of an acorn and about as large as a Volkswagen Beetle. Writing resembling Egyptian hieroglyphics was also said to be in a band around the base of the object.
                                for more : forest ufo incident egyptian hieroglyph - Google Search
                                .... Gordon Lightfoot Sundown - YouTube Crosby Stills & Nash - Southern Cross
                                Hallucinogenic Plants May Be Key to Decoding Ancient Southwestern Paintings, Expert Says
                                Mikey Dread - Roots and Culture - YouTube ... Cannabis extract can have dramatic effect on brain cancer, says new research
                                Lightning will increase by 50 percent with global warming, research says
                                Transcranial magnetic stimulation
                                Cooray and Cooray (2008)[78] stated that the features of hallucinations experienced by patients having epileptic seizures in the occipital lobe are similar to the observed features of ball lightning. The study also showed that the rapidly changing magnetic field of a close lightning flash is strong enough to excite the neurons in the brain.
                                ... Nikola Tesla reportedly could artificially produce 1.5″ (3.8 cm) balls and conducted some demonstrations of his ability, but he was truly interested in higher voltages and powers, and remote transmission of power, so the balls he made were just a curiosity.
                                ... This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.
                                Nikola Tesla
                                Ball lightning - Wikipedia, the free encyclopedia .... UFO? Meteor? Blast? Massive light flash over Russian Urals stuns locals, scientists
                                Giant sunspot returns and it's bigger and badder than ever
                                Sun's rotating 'magnet' pulls lightning towards UK
                                The Sun may be playing a part in the generation of lightning strikes on Earth by temporarily 'bending' the Earth's magnetic field and allowing a shower of energetic particles to enter the upper atmosphere.
                                Everyone Is Loving the Odd Uranus Storm - Dumb Out
                                Uranus (mythology))
                                Uranus or Father Sky was the son and husband of Gaia, Mother Earth
                                The most probable etymology is from the basic Proto-Greek form *(Ϝ)ορσανός (worsanos) derived from the noun *(Ϝ)ορσό- (worso-, Sanskrit: varsa "rain" ). The relative Proto-Indo-European language root is *ṷers- "to moisten, to drip" (Sanskrit: varsati "to rain"), which is connected with the Greek ουρόω (Latin: "urina", English: "urine", compare Sanskrit: var "water," Avestan var "rain", Lithuanian & Latvian jura "sea", Old English wær "sea," Old Norse ver "sea," Old Norse ur "drizzling rain")[6] therefore Ouranos is the "rainmaker" or the "fertilizer". Another possible etymology is "the one standing high in order" (Sanskrit: vars-man: height, Lithuanian: virus: upper, highest seat). The identification with the Vedic Varuna, god of the sky and waters, is uncertain.[7] It is also possible that the name is derived from the PIE root *wel "to cover, enclose" ( see The Gnostic Book of Changes - Hexagram 4 ) (Varuna, Veles).[8] or *wer "to cover, shut".[9]
                                *Confucius, one of the greatest teachers who ever lived, obviously took his teaching method from the Judgment of this hexagram:
                                The Master said:"I won't teach a man who is not anxious to learn, and will not explain to one who is not trying to make things clear to himself. And if I explain one- fourth and the man doesn't go back and reflect and think out the implications in the remaining three-fourths for himself, I won't bother to teach him again."
                                And so it is with the oracle (the Self) -- the deeper one gets involved in the Work, the more difficult the lessons become, so that one is always kept in a position of relative Inexperience. There are times, when a simple answer would suffice, that you will receive an ambiguous image, which (if you do three-fourths of the work), will lead you to a profound insight.
                                see also : THE FOOL, URANUS
                                ... Fela in performance (1971) - YouTube <º)))>< Fela Kuti & Roy Ayers - 2000 Blacks got to be free
                                for yhur own fun : I Ching Online - the Online Book of Changes
                                .... - Speak to me Breathe - YouTube... Any Colour You Like - YouTube
                                Light Of The Third Millenium (Austin) (Terence McKenna) [FULL] - YouTube .... Monkey Banana - YouTube
                                DMT can be found in many species of plants. Genera such as acacia, anadenanthera, mimosa, piptadenia, and virola are some examples. DMT is also produced in the human pineal gland, a small reddish-gray gland (about the size of a pea) near the center of the brain.
                                Easy Star All-Stars - Brain Damage - YouTube
                                One of the functions of the pineal gland is the production of melatonin. The pineal gland and melatonin help regulate sleep-wake cycles (circadian rhythms). The production of melatonin by the pineal gland is stimulated by darkness and inhibited by light.
                                *: Nu, Nanet, Amun, Amunet, Kuk, Kauket, Huh, and Hauhet. Each pair represents a primal force, water, air, darkness, and infinity, and together they create the world and the sun god Ra from the primordial waters
                                The coil referred to on a previous occasion was finished with exactly 689 turns on a drum of eight feet in length and 14" diam. The wire used was cord No. 20 as before stated so that the approximate estimate of self-induction and other particulars holds good.
                                "Tesla's New Discovery" January 30, 1901 by Nikola Tesla
                                Help with Ed Leedskalnin Riddle , any idea .
                                What do you believe is the most important discovery Tesla had found, in the book Colorado Springs Notes.
                                The solution appeared that july 4th 1899.Stationary wave field in the Earth. I think these particular ground waves were around 68 khz carrying low frequency information with no modification of the oscilllator.
                                ... Telsa : Colorado Springs Notebook -- July 1-31
                                A circadian rhythm /sɜrˈkeɪdiən/ is any biological process that displays an endogenous, entrainable oscillation of about 24 hours ... *The earth orbits the sun at approximately 18.5 miles per second (66,600 mph)
                                at Earth's surface the acceleration of gravity is about 32 feet per second squared
                                Serendipitously, the lab discovered that a nonvisual environmental factor, negative air ion concentration, also has an antidepressant effect. Negative ions (in nature or from electronic air purifiers) had long been presumed to have a nonspecific positive effect on wellbeing, and might be exploited as a placebo control for light therapy.[citation needed] The lab tested low ion levels vs. high ion levels in a set of randomized, controlled, double-blind clinical trials.[9] The high concentrations showed significantly greater antidepressant effect for both seasonal[10] and nonseasonal depression, as well as when administered after waking or during sleep.[11][12]
                                Michael Terman
                                see also : Biologists explore link between memory, circadian rhythms ... Bee brains offer insights into how human memories form
