-   -   Harvesting Energy From the Sun Using Crystals (http://www.energeticforum.com/renewable-energy/8480-harvesting-energy-sun-using-crystals.html)
Felix_the_cat 07-03-2011 07:26 PM
I have read on several place on the web that the atlanteans used sunlight harvesting crystal has a power source. Big metalic domes were used in combination with crystals. Does anyone know where to find info on that?
Atlantis and Crystal Technology (article) by John P Johnston on AuthorsDen
« There were three main categories of programmed crystals. Those in the first category were programmed with the teachings of the Ascended Masters. Those in the second category were imbued with sound and color, so that they emitted both healing and developmental energies. Those energies both purified and refined the three lower vehicles of consciousness, eventually aligning the personality with the vibration of the Soul. A third type of crystal was infused with pure energy. That energy was not assigned a specific purpose; rather it was used as a general source of power. The first two types of crystals facilitated advanced learning and spiritual development. The third type of crystal provided an energy source that supplied affordable power to all of Atlantis.»
Freezer 07-03-2011 08:04 PM
You might be interested in this video.
YouTube - ‪4-22 In Search Of... The Bimini Wall (Part 3 of 3)‬‏
MonsieurM 07-03-2011 09:13 PM
Solar power without solar cells: A hidden magnetic effect of light could make it possible
Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
Quartz
Although quartz is not conductive (meaning it doesn't carry electricity like most metals such as copper), it has certain electrical properties that make it very useful for certain electronics. In particular, it is piezoelectric. "Piezoelectricity" is a word derived from the Greek word "piez" or "piezein", meaning "to press"; Piezoelectric materials are non-conductive materials which generate electricity when you subject them to pressure, and vice-versa: They undergo physical deformation when you run electricity through them. If you compressed a pice of quartz using a pair of pliers or a vise, it would generate a very small electrical charge, and if you connected a piece of quartz to either end of a battery, the crystal would bend or warp slightly. These effects are too small to be visible to the human eye; You won't actually see the crystal bending or shaking, and you won't notice sparks coming from it, but there will be very tiny effects, and these can be detected and used by electronic circuits.
Information on electronic quartz crystals
Quartz resonators consist of a piece of piezoelectric material precisely dimensioned
and orientated with respect to the crystallographic axes. This wafer has one or more
pairs of conductive electrodes, formed by vacuum evaporation. When an electric field is
applied between the electrodes the piezoelectric effect excites the wafer into mechanical
vibration. Many different substances have been investigated as possible resonators, but
for many years quartz has been the preferred medium for satisfying the needs for
precise frequency generation. Compared to other resonators e.g. LC circuits, mechanical
resonators, ceramic resonators and single crystal materials, the quartz resonator has
proved to be superior by having a unique combination of properties. The material
properties of quartz crystal are both extremely stable and highly repeatable. The
acoustic loss or internal fraction of quartz is particularly low, which results in a quartz
resonator having an extremely high Q-factor.
The intrinsic Q of quartz is 107 at 1 MHz.
Mounted resonators typically have Q factors ranging from tens of thousands to several
hundred thousands, orders of magnitude better than the best LC circuits
. The second key
property is its frequency stability with respect to temperature variations....
...Modes of vibration, cuts and
frequency ranges
The AT-cut resonator uses the thickness shear mode of vibration (fig.3). A standing
wave is set up in the crystal blank by the reflection at both major surfaces of traverse
waves travelling in the thickness direction. The major mechanical displacement is in the
plane of the crystal at right angles to the direction of wave propagation. At resonance
an odd number of half wave lengths are contained in the thickness plane of the crystal
blank
. Therefore the thickness is the primary frequency determining dimension.
http://www.scapro.se/text/jauchkristallara.pdf
:cheers:
MonsieurM 07-03-2011 09:43 PM
just FYI:
the Law of Crystallization provided by Walter Russell in his magnum opus The Universal One
http://4.bp.blogspot.com/_XEdakZFo-O...allization.png
for the piezoelectric property see also : Radiation pressure
Radiation pressure - Wikipedia, the free encyclopedia
Radiation pressure is the pressure exerted upon any surface exposed to electromagnetic radiation. If absorbed, the pressure is the power flux density divided by the speed of light. If the radiation is totally reflected, the radiation pressure is doubled. For example, the radiation of the Sun at the Earth has a power flux density of 1,370 W/m2, so the radiation pressure is 4.6 µPa (absorbed).
:thumbsup:
MonsieurM 07-03-2011 10:06 PM
one more think i would like to add and i think it is very important
If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.
— Nikola Tesla:
http://2.bp.blogspot.com/_XEdakZFo-O.../Nine+Star.jpg
want to know more check out this post:
http://www.energeticforum.com/131976-post6.html
also
Quartz Crystals
Electron Tubes by John Morecroft, 1933 starting page 334...
Fixing Frequency by Piezo-electric Crystal
Quartz Crystals
:thumbsup:
andronover 07-04-2011 05:37 PM
"You cannot invent, you can only discover" - Gordon Plummer
This is wisdom!:thumbsup: :thumbsup:
/Peter
MonsieurM 07-04-2011 06:10 PM
/Peter
Thank you :notworthy:
here is a person who did create a circuit that is quite interesting:
Steven GIBBS Hyper Dimensional Resonator
How to use HDR
There are several methods to use HDR, but most of mine will focus on using Steven Gibbs Hyper Dimensional Resonator – HDR for astral time travel to the future. This is accomplished by entering a meditative state of mind and exteriorizing my soul.
Basically, I use an HDR with a double terminated quartz crystal and a barium oxide bar magnet. The bar magnet is attached to the end of the HDR electromagnet and the quartz crystal is placed inside the witness well. Before I place the quartz crystal in the witness well, it will be charged up inside a crystal pyramid.
These energies are what boost the frequency of my astral body and allow me to jump to the future. If my jump is only a month I am OK, but if I need to do a long jump, like a hundred years into the future, then I use a Tesla Coil alongside the HDR. The Tesla coil provides the zero vector that I use to tunnel into the future. You need more energy to travel further.
Steven Gibbs -- Hyper Dimensional Resonator -- astral time travel
type in google: rexresearch (or keely net) and quartz, then just select any link you'd like to explore...Maybe you'll notice a pattern in the use of crystal...
:D
:thumbsup:
MonsieurM 07-04-2011 06:48 PM
To all those who already built resonators to capture/amplify ambient energy and get a few microvolt, maybe Quartz resonators is the way to go....:confused:
from what i have read, it is the perfect tool for coupling and amplifying :D
MonsieurM 07-04-2011 08:15 PM
also
Gravity Nullified
Quartz Crystals Charged by High frequency Currents Lose Their Weight
those willing to do some further research, here is a trick:
Although some remarkable achievements have been made with shortwave low power transmitters, radio experts and amateurs have recently decided that shortwave transmission had reached its ultimate and hat no vital improvement would be made in this line. A short time ago, however, two young European experimenters working with ultra-short waves, have made a discovery that promises to be of primary importance to the scientific world.
The discovery was made about six weeks ago in a newly established central laboratory of the Neuuartadline-Werke in Darreskein, Poland, by Dr Kowsky and Engineer Frost. While experimenting with the constants of very short waves, carried on by means of quartz resonators, a piece of quartz which was used, showed a clearly altered appearance. It was easily seen that in the center of the crystal, especially when a constant temperature not exceeding 10 C / 50 F was maintained, milky cloudiness appeared which gradually developed to complete opacity. The experiments of Dr Meissner, of the Telefunken Co,, along similar lines, according to which quartz crystals, subjected to high frequency currents clearly showed air currents which ld to the construction of little motor based on this principle. A week of eager experimenting finally led Dr Kowsky and Engineer Frost to the explanation of the phenomenon, and further experiments showed the unexpected possibilities for technical uses of the discovery.
Kowsky & Frost -- Gravity Nullification -- Science & Invention, Sept. 1927
remember this article i posted
doesn't it sound similar :D
Joel McCLAIN & Norman WOOTAN
The Magnetic Resonance Amplifier
With low-level ultrasonic input signals, the Magnetic Resonance Amplifier (MRA) produces usable direct current power at levels above unity. This circuit is based upon the work and theories of John Ernst Worrell Keely, and is offered into the public domain in his memory.
Introduction ~
Without lengthy discussion about the aether, tetrahedral geometric aggregate resonance or the Rule of Nines, it is possible to understand this circuit as basically a tuned magnetic and quartz amplifier..
Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
http://www.rexresearch.com/mra/5bknet.jpg
What is an ultrasound?
Ultrasound is a safe, painless diagnostic procedure that uses high-frequency sound waves to create images of organs and body structures.
now you get the idea :D
:cheers:
MonsieurM 07-04-2011 09:46 PM
About this:
use this
Parabolic to fiberoptic (open source project)
Parabolic to fiberoptic - Open Source Ecology
Jeffery Gordon has proposed and constructed prototypes for arrays of small parabolic dishes concentrating sunlight into fiberoptic cables. a 1 mm diameter cable can carry about 16 watts (due to the limits of concentrating ability) of sunlight into a nearby lab where it may be used for various processes. The advantage of this setup is that the array of small dishes can track the sun like a flat panel collector, and do not require huge support structures. Also, the sunlight can be used in a controlled environment, rather than precariously at the top of some large structure. This enables such things as the creation of nanostructures through solar ablation and surgical procedures with beams of sunlight rather than lasers. Both of these have been accomplished by Dr. Gordon.
one more thing to add:
Fractal structures of gold obtained by diffusion limited
aggregation in alkali halide crystals
http://joam.inoe.ro/arhiva/pdf8_3/3Enculescu.pdf
Electromagnetic Wave Localization in Photonic Fractals
http://www.jwri.osaka-u.ac.jp/public...scp-takema.pdf
Fractal structures have no periodicity and no translational symmetry like crystal structures.
:thumbsup:
:beamup:
MonsieurM 07-05-2011 12:37 AM
posted this earlier in another thread, but this thread is a more suitable:
Originally Posted by goldsphere (Post 146555)
I have started reading his book The Evolution of Matter. I highly recommend everyone to do the same. I understand why Moray went on to work with transmutation in the years after he demonstrated his wonder box.
Adept Alchemy
Part II
Modern Arcana
Chapter 5
Adept Alchemy (Robert A. Nelson): Transmutation of Lead to Mercury
Prof. Arthur Smits and Dr. A. Karssen (Univ. of Amsterdam) published reports of their alleged transmutation of lead into mercury and thallium in 1924. Their work was inspired by that of Prof. Miethe, who claimed to have transformed mercury into gold in a modified Jaenicke mercury ultraviolet lamp. (4, 5)
The lamp was constructed of lead quartz. Two legs (A, B), ending in narrow tubes, contain two steel electrodes cemented with sealing wax. The electrodes were inserted in two small removable copper water coolers (G, H). Pure liquid lead was poured into storage vessel C, after which the open end was sealed off. The lead was kept liquid at 350o C by an electric furnace around C. Tube D contained capillary F and terminated in stopcock K, which was connected to a mercury diffusion pump (Fig. 5.1)....
...After that we burned the lamp at 40 A/80 V for 10 hours
why you ask? how about this:
see also Sprink experiment: Leon Sprink - Antigravity - patents
Thomas Henry MORAY
Radiant Energy Receiver
[p. 66] Dr Moray... described the radio detector he had developed... He compared it to what was commonly known as the crystal of a crystal set . However, his detector was superior since it could drive a loudspeaker without the use of a battery...
about
It is a Fractal set up of the Crystals (just search crystal and fractal :thumbsup: )
Computational Modeling of New Kinds of Fractal Antennas and
Fractal Frequency-selective Structures Based on Them
Abstract| Authors' realized modeling of two kinds of fractal antennas with similar structure, but different algorithms of development. The first antenna geometry is a figure "Life Flower" and the second one is series of crossed circles nested to each other. The obtained results were analyzed and conclusion of the practical applicability for these antennas was made. The obtained theoretical results allow us to conclude that synthesized fractal antennas have multi-band and wide-band features. Besides the direct usage, such fractal structures performed on micron-level may reveal an application in a wide class of new fractal frequency-selective materials and surfaces. The applicability sphere of fractal antennas in modern technologies was shown: cellular communication, wireless information transmission and reception, and radar location devices. Also application filed was described for fractal antennas in modern technology: cellular communications, wireless receiving and transmitting information devices, and radar.
http://www.google.com/url?sa=t&sourc...KlN5Rob9nwlwYA
Cycles, fractal patterns, and exponential functions
If you want to understand the world as a system then you need to investigate three key components.
Cycles
Fractal patterns
Exponential functions
:D
Here are some of the authors I have studied
Fred Harrison(18 year land price cycle)
Nokolai Kondratieff (60 year price/debt cycle)
Oswald Spengler - book: "The Decline of the West" (1500-2000 civilisation cycles)
Martin Armstrong (8.6 year PI cycle, fractal patterns)
Robert Prechter (Elliott waves, fractal patterns, 300 years)
Chris Martenson (exponential functions, 10,000 years)
Most authors try and model the world with only one of these components. Martin Armstrong was the exception as he used 2 components (cycles and fractal patterns)
Winston Churchill said, "The further back you look, the further forward you can see."
So why not create a model that incorporates all three components and goes back as far as the Big Bang.
Cycles, fractal patterns, and exponential functions - General Discussion and Questions - Forums at Chris Martenson
Remember Walter Russell's periodic table, if not see
http://www.energeticforum.com/psychi...-so-below.html
:cheers:
MonsieurM 07-05-2011 12:22 PM
this is is also relevant:
If you look more carefully you'll see that the common thread is...:
Hubbard Coil Runs Boat On Portage Bay Ten Knots An Hour; Auto Test Next
Moray valve
"I started my experiments with the taking of electricity from the ground, as I termed it, during the summer of 1909. By fall of 1910 I had sufficient power to operate a small electrical device, and I made a demonstration of my idea to two friends... This demonstration in the early stages consisted of operating a miniature arc light... It soon became evident that the energy was not static and that the static of the universe would be of no assistance to me in obtaining the power I was seeking...
Hendershot Motor
Hendershot Lived in Michigan Detroit
Edward V. GRAY
from California
Stanley Meyer: Water Fuel Cell
Tariel Kapanadze's device
In my explanation, I will try totaly to exclude the pressence of the water, as seen in the
movie
http://www.rlabato.com/docs/principl..._Kapanadze.pdf
Now one last quote for you guys, from The Great Nicholas Tesla:
This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body
I'll give you one clue:
The human body at about 60% water in adult males and 55% in adult females.
:thumbsup:
MonsieurM 07-05-2011 10:17 PM
one more info i would like to add:
Gustave Le Bon: The Evolution of Matter --- Complete text
It results, then, from what precedes that the formation of electric aigrettes is accompanied by an enormous production of invisible light. With a high frequency resonator the quantity is so great that illumination of the platino-cynanide can be produced up to a distance of more than 5 meters.
Among the causes of error which I must point out, there is one which has never, to my knowledge, been mentioned anywhere, and is of considerable importance. I refer to the superficial alteration of a strip of quartz exposed for less than a quarter of an hour to the sparks of the electrodes. It becomes covered with an almost invisible layer of particles of dust which suffice to render it opaque to the ultraviolet rays inferior to 0.250 microns. When quartz thus altered is used, it is as if use were made of a strip of thin glass, opaque, as we know, to the extreme ultraviolet, and all the effects observed are falsified. This cause of error, which occasioned me much loss of time, is very easy to avoid, since it is sufficient to wipe the quartz with fine linen clothe every 10 or 15 minutes.
search quartz on this page (CTRL + F :D ) Gustave Le Bon: The Evolution of Matter --- Complete text
why ? how about this:
:cheers:
MonsieurM 07-05-2011 10:33 PM
also related to previous post
Kiril CHUKANOV
Ball Lightning
In keeping with the focus of the present invention, the inventor has discovered that low- dielectric-constant substances are advantageous because of their ability to withstand and maintain high or intense electrostatic fields. As such, dielectric container 150 is preferably comprised primarily of quartz, ceramics, or porcelains, as these provide the necessary electron layer (or dielectric) within the wall of dielectric container 150, thus allowing the wall of dielectric container 150 to serve as one side of the double electron barrier needed to contain the energized electrons (or other particles). In the event the present invention is performed without the use of dielectric container 150, other mediums, for example dry air, which is an excellent dielectric, may serve to create the necessary conditions for generating the quantum macro object of the present invention.
Ball lightning has been known to last from a few seconds to greater than 150 seconds. These relatively long lifetimes are one of the most intriguing features of ball lightning as this may suggest that the ball possesses some inherent energy source independent of external sources see post above. On the other hand, some balls have been reported to fade out quietly, while others disappear abruptly, and occasionally with an explosion or by breaking into small fragments. On the whole, observers report detection of no radiant heat from the balls, even when the ball passes by at close range.
:thumbsup:
Kiril Chukanov: Ball Lightning
hope you are enjoying this...because i am :blowout:
MonsieurM 07-06-2011 10:11 AM
here is a nice presentation from IEEE - The world's largest professional association for the advancement of technology on quartz oscillator and resonator (use internet explorer browser to view)
Quartz Crystal Resonators and Oscillators
Quartz Resonator & Oscillator Tutorial
also
RF Energy Harvesting Design Using High Q Resonators
Abstract-This paper presents a new method for rectifying low
ambient radiation sources to supply autonomous measurement
systems such as microsystems. An impedance transformation with
high quality factor (Q) in front of a Schottky-Diode using a quartz
resonator at 24 MHz is presented. In addition to an analytic
computation and nonlinear simulation of the rectifier circuit
with Advanced Design System (ADS) software, the circuit was
built and the efficiency of the RF Energy Harvesting system was
measured. The design has been optimized to achieve maximum
sensitivity. The measurement results show a sensitivity of -30
dBm (1 p,W) for DC output voltage of 1 V and an efficiency of
more than 22 %.
Index Terms- RF energy harvesting, wireless energy transmission,
ultra-low-power rectifiers, RF-to-DC conversion passive
RFID
http://www.imtek.de/content/pdf/publ...mws_cavtat.pdf
:thumbsup:
MonsieurM 07-06-2011 10:10 PM
A while back i posted the following on this thread: http://www.energeticforum.com/new-me...dic-table.html
Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
than 5 000 experiments that living cells transmit information through photons (in 1981).
We can describe the experiments simply as follows:
- Cells are bathed in a nutrient solution in two spherical flasks made of quartz. The two flasks are touching
each other. If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
impaired every time and always have the same symptoms, whereas they should be protected from the toxic
influence of other cells by the quartz sides.
- If you use glass flasks, the second cell colony is protected.
- The transmission between the two colonies is made by ultraviolet radiation.
*** These same three Soviet scientists measured the cell radiation using a photomultiplier. "Normally living
cells emit a constant stream of light rays. When a virus enters cells, radiation changes: it first increases -
then silence – then new increase, then gradual attenuation of radiation in multiple wavesuntil the cell
dies. This recalls the cries of pain of an animal.
*** In 1974, Simon STSCHURIN, said: "The cells affected by different diseases have different radiation
characteristics. We are convinced that photons are able to inform us long before the onset of pernicious
degeneration to disclose the presence of a virus ".
Today, scientists worldwide are exploring this phenomenon:
- In Australia, the correlation between cancer and ultra-hight- throuhput radiation is under study.
- In Brazil, fundamental studies are being conducted to understand light transport in cells.
- In China, the action of light on cells is currently studied.
- In Japan, research is trying to make an early diagnosis of cancer from cell radiation
link:
Light biology - quetanglais
more on info found here:
Biophysics And the Life Process
:thumbsup:
MonsieurM 07-06-2011 11:13 PM
found some good info for you guys...:cool:
Silicon dioxide - Wikipedia, the free encyclopedia
check out the Crystalline forms of SiO2 Table, for instance the α-quartz
Helical chains making individual single crystals optically active; α-quartz converts to β-quartz at 846 K
and now read this info:
An electrostatic spatial resonance model for coaxial helical structures with applications to the filamentous bacteriophages.
It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
note: looking at the table and the geometry of quartz, i would refer you to http://en.wikipedia.org/wiki/Synergetics_(Fuller)
also both faujasite(also known as zeolite, sound familiar :D )and melanophlogite crystals looks like they could have some great potential...:cool:
http://upload.wikimedia.org/wikipedi...teStucture.png
check out rexresearch zeolite :D
http://folk.uio.no/pouln/faucell4.gif
:thumbsup:
MonsieurM 07-07-2011 09:55 PM
did anyone ever try quartz in the center of a rodin coil or starship coil :confused:
:thumbsup:
isn't the starship coil a concentrator of magnetic field :confused: , could be a nice add on to amplify the effect....:confused:
check this out:
http://www.energeticforum.com/renewa...tml#post106504
I have been lurking and building for a couple months now, but I felt I should contribute back in true open source style, now that I have what I consider to be of interest. The following linked video shows my permutation of the OMNBB using a 24 point bifilar starship coil with a discrete high impedance generator coil operating at very high frequency, with upgraded components and some small additions. I call it the FlowerPower device.
The "jumpstart" motor is essentially an identical circuit, with the exception of 2 variable resistors as opposed to one, slightly different diodes, a standard bedini on a radio shack hockey puck spool, and a 1" rotor. Lucky to get 500hz on that, but that is trying to move lots more mass too. I have not tried the smaller (@?) 1/4" rotor with the hockey puck coil. I suspect performance would be similar, although there may be some gain to be exploited by starships "antenna-like" design. The starship does concentrate the magnetic field of the coil in the center, which is very handy.
YouTube - ‪Rodin starship coil experiments. (TEST2)‬‏
:thumbsup:
would love to hear about it....:notworthy:
MonsieurM 07-07-2011 10:36 PM
This lecture was a great inspiration to me:
In the Nature of Things - A talk by - Gordon Plummer
the first half of this vid is just as good:
YouTube - ‪The Universe is a super hologram‬‏
:thumbsup:
MonsieurM 07-09-2011 10:55 AM
About Joel McCLAIN & Norman WOOTAN The Magnetic Resonance Amplifier, posted earlier:
In the MRA schematic below, there is a tunable low-power oscillator which supplies a signal to one side of a barium titanate transducer. The opposite side of the transducer is connected to a primary coil which is wrapped around a barium ferrite magnet core. The opposite end of the primary goes back to the oscillator.
the barium titanate transducer:
An Introduction to Piezoelectric Transducer Crystals…
Piezoelectric Materials and their Properties
http://www.bostonpiezooptics.com/fil...o_to_Piezo.pdf
Piezoelectricity - Wikipedia, the free encyclopedia
in google, search also "barium titanate quartz coupling", a lot of info is available check out pdf docs , you'll see some fractal applications in the telecom industry
:thumbsup:
totoalas 07-09-2011 04:33 PM
Frequency alteration
Check out helpful waves.com
MonsieurM 07-09-2011 05:50 PM
Mitigating Joint Pain- A Second Look at Tuning the Weak Field of Quartz Sand | Helpfulwaves.com
YouTube - ‪Tuning Quartz Sand for Self Healing with an Audio Speaker‬‏
thank you for this nice add on, do you look for a particular figure when you charge the quartz sand:
http://www.energeticforum.com/renewa...phenomena.html
i know that piezoelectric crystal are used as vibration sensors
Piezoelectric Materials for Vibration Sensors—The Technical
Advantages of Piezoceramics Versus Quartz
http://www.wilcoxon.com/technotes/tn...zovsQuartz.pdf
see also Piezoelectricity - Wikipedia, the free encyclopedia
:wall:
MonsieurM 07-09-2011 08:14 PM
Chladni figures for a square steel plate (adapted from Waller 1961) demonstrates the fantastic variety of standing wave patterns that can arise from a simple resonating system. A square steel plate is clamped at its midpoint and sprinkled with sand. It is then set into vibration either by bowing with a violin bow, or by pressing dry ice against it. The resultant standing wave patterns are revealed by the sand, that collects at the nodes of the oscillation where the vibration is minimal.
http://sharp.bu.edu/~slehar/webstuff/hr1/gollub.gif
Harmonic Resonance Theory: An Alternative to the "Neuron Doctrine" Paradigm of Neurocomputation to Address Gestalt Properties of Perception
now compare the image above with this crystalline structure of quartz picture, which picture matches the crystal structure ? :
Huifang XU, et al -- Zn Oxide photoelectrolysis
Abstract: Materials scientists at the University of Wisconsin-Madison have designed a way to harvest small amounts of waste energy and harness them to turn water into usable hydrogen fuel. The process is simple, efficient and recycles otherwise-wasted energy into a usable form...
....More specifically, certain piezoelectric materials, including but not limited to .alpha.-quartz (SiO.sub.2), ZnO, or BaTiO.sub.3, among others, have unique piezoelectric properties where the piezoelectricity is an intrinsic property of the material, such that no physical/chemical doping (cations or anions), chemical additives (including transition metals) or any forms of implantation are needed to create these properties. In addition, one of the materials having these properties, i.e., quartz, is also one of the most abundant minerals on the Earth's surface (i.e. beach sands). As a result, by using quartz as a material in the process, the hydrogen production via direct-water-splitting can be achieved at a low cost, and, because quartz is a natural material that is environmental friendly, no pollution issues are created by the process.
This is probably the best way to get the resonance of an element (such as quartz), if you can match the cymatic figure that is created at a certain frequency(on water or quartz sand) to its structure.
Cymatics.org
:thumbsup:
Golden Mean 07-09-2011 09:01 PM
5 Attachment(s)
Awesome thread!
I have been researching this area extensively lately and have developed an inexpensive method to build a light tube transmission system.
All you need is PVC, mylar (2mil or 4 mil) and miter saw or other angled cutting system. Mylar is simple rolled up inside the PVC pipes and angles are created by cutting corner PVC pieces at 45 degree angles. Works very well!
I am currently testing a passive "light trap" geometry using my namesake (Golden Mean) to passively capture sunlight and transfer it down the light tube.
So far, I've successfully shot a laser light and maintained much of the coherence through the spiral and out the light tube if the right angle of entry is set. (See attached pics) This small test prototype is not even optimized or completed yet as I am on to a much larger 3' x 4' x 22" spiral with a 2" PVC pipe for the middle and a black painted copper pipe going through the center for a solar heating test. I'll post more pics when time allows as I have a million things going on in multiple realities all at once and it can be quite taxing at times!!
Let's create the reality we wish to experience and give everyone a fair chance to explore who they are more fully by removing poverty from this planet and reduce crime to minimal levels.
Many Blessings to All.
Golden Mean 07-09-2011 09:02 PM
More pics of the 3'x4' spiral light trap...
MonsieurM 07-09-2011 09:22 PM
Originally Posted by Golden Mean (Post 147101)
Awesome thread!
Excellent project Golden Mean :notworthy: ,.. I would love to hear updates on your project
in a way you are forcing the light to vortex...interesting concept :thinking: Victor Schauberger style....:D
http://i1206.photobucket.com/albums/...d_3d_elips.jpg
When you have succeeded in focusing the light could you try it on a quartz crystal:
:cheers:
MonsieurM 07-09-2011 10:09 PM
http://en.wikipedia.org/wiki/Hans_Jenny_(cymatics)
Hans Jenny (16 August 1904, Basel - 23 June 1972, Dornach) was a physician and natural scientist who is considered the father of cymatics, the study of wave phenomena.
Jenny made use of crystal oscillators and an invention of his own by the name of the tonoscope to set plates and membranes vibrating. With the tonoscope, quartz sand is spread onto a black drum membrane which is 60 cm in diameter. The membrane is set into vibrations by singing rather loudly through a cardboard pipe. The sand now produces complex symmetrical forms, known as Chladni patterns named after Ernst Chladni who discovered this phenomenon in 1787. Low tones result in rather simple and clear pictures, while higher tones form more complex structures.[1]
BTW: Hans Jenny was a student of Buckminster Fuller
MonsieurM 07-09-2011 10:20 PM
also
However, Buckminster Fuller and his students such as Hans Jenny(4) were able to recreate these waveforms using colloidal suspensions or dyes in liquids. Again, certain frequencies resulted in standing waves with visible and equally spaced nodes in three dimensions. The patterns formed by these waveforms were exact matches for the Platonic Solids5 with the vertices’ positions being defined by the nodes. The problem to be solved is that there are only five possible geometries, ie Octahedron, Star Tetrahedron, Cube,Dodecahedron and Icosahedron. For the Diatonic scale we obviously need seven shapes.
The solution appears to have been resolved by combining Pythagorean wisdom with the Hindu scriptures.(6) All the Platonic solids fit exactly within a perfect sphere which is the shape of the fundamental frequency at the beginning of the octave. Its closest relation, the Icosahedron, actually appears twice, once as an inner version within the Octahedron and once as an outer version following the Dodecahedron.(1) Thus we have a complete octave of shapes to match the Diatonic scale.
The Shape Of Sound
Pythagorean wisdom with the Hindu scriptures.(6) [B]All the Platonic solids fit exactly within a perfect sphere which is the shape of the fundamental frequency
in other words all comes out of Zero
The concept of zero as a number and not merely a symbol for separation is attributed to India where by the 9th century AD practical calculations were carried out using zero, which was treated like any other number, even in case of division.[10][11] The Indian scholar Pingala (circa 5th-2nd century BC) used binary numbers in the form of short and long syllables (the latter equal in length to two short syllables), making it similar to Morse code.[12][13] He and his contemporary Indian scholars used the Sanskrit word śūnya to refer to zero or void.
MonsieurM 07-10-2011 12:47 AM
Patrick Kelly's Notes
Pavel Imris was awarded a US patent in the 1970s. The patent is most interesting in that it describes a device which can have an output pwer which is more than nine times greater than the input power. He achieves this with a device that has two pointed electrodes enclosed in a quartz glass envelope which contains xenon gas under pressure (the higher the pressure, the greater the gain of the device) and a dielectric material...
...An optical electrostatic generator which is effective for producing high frequencies in the visible light range of about 10^14 to 10^23 Hz. . . .
The present optical electrostatic generator does not perform in accordance with the accepted norms and standards of ordinary electromagnetic frequencies.
now it does :D
the extra energy comes from:
http://www.rexresearch.com/imris/ca951836-d3.gif
Pavel Imris: Optical Electrostatic Generator -- 900% Efficiency
:thumbsup:
Golden Mean 07-11-2011 05:19 PM
:cheers:
I plan to do some crystal experiments eventually. Just got some crystals this Spring off some land my family owns in northern MN ... and am Sun-cleansing them in my greenhouse and garden areas until I have time to work with them more in a more "concentrated" way. :grindaisy:
Have a great day!
