-   Psychic & Paranormal (http://www.energeticforum.com/psychic-paranormal/)
-   -   The Brain is an Advanced Fractal Antenna (http://www.energeticforum.com/psychic-paranormal/8143-brain-advanced-fractal-antenna.html)
MonsieurM 05-19-2011 11:27 AM
I wanted to start this thread, as a repository for all research/example that point toward this simple fact.
Why do you ask? Because it could just be one step away from proving the possibility of telepathy (receiving and emitting waves).
here goes nothing:
Fractal antenna - Wikipedia, the free encyclopedia
A fractal antenna is an antenna that uses a fractal, self-similar design to maximize the length, or increase the perimeter (on inside sections or the outer structure), of material that can receive or transmit electromagnetic radiation within a given total surface area or volume.
Such fractal antennas are also referred to as multilevel and space filling curves, but the key aspect lies in their repetition of a motif over two or more scale sizes,[1] or "iterations". For this reason, fractal antennas are very compact, are multiband or wideband, and have useful applications in cellular telephone and microwave communications.
A good example of a fractal antenna as a spacefilling curve is in the form of a shrunken fractal helix.[2] Here, each line of copper is just a small fraction of a wavelength.
A fractal antenna's response differs markedly from traditional antenna designs, in that it is capable of operating with good-to-excellent performance at many different frequencies simultaneously. Normally standard antennas have to be "cut" for the frequency for which they are to be used—and thus the standard antennas only work well at that frequency. This makes the fractal antenna an excellent design for wideband and multiband applications.
fractal property of nature
Patterns of Visual Math - Fractals in Nature
Fractal in Human Body
Applications of Fractals - Human Body
If you are still not convinced that that fractals, being a math topic, are very important in real life, your opinion might change after finding out that you yourself are made of fractals!
George O. SQUIER: Tree Antennas
George O. Squier ~ Trees as Antennas ( Scientific American, June 14, 1919 & British Patent Specification # 149,917)
It is not a joke nor a scientific curiosity, this strange discovery of Gen. George O. Squire, Chief Signal Officer, that trees --- all trees, of all kinds and all heights, growing anywhere --- are nature's own wireless towers and antenna combined. The matter first came to his attention in 1904, through the use of trees as grounds for Army buzzer and telegraph and telephone sets, which, in perfectly dry ground and in a dry season, functioned poorly or not at all with ordinary grounds. Right then he began experiments with a view to seeing what possibilities, if any, the tree had as an aerial. But in 1904 radiotelegraphy was far more undeveloped than at present, and vacuum amplifying tubes were not thought of.
The New “Power Plants”: Trees Make Electricity?
It appears that a small electrical component company near Boston has figured out how to get electricity out of trees. MagCap Engineering is pretty sure they’ve come up on the next renewable energy revolution. By pounding a nail into the trunk and a conductor into the ground, a faint but consistent charge is detected in a wire running from the tree to the earth.
The New “Power Plants�: Trees Make Electricity? : TreeHugger
It is your Brain that determines the color:
Typically, humans have three different types of cones with photo-pigments that sense three different portions of the spectrum. Each cone is tuned to perceive primarily long wavelengths (sometimes called red), middle wavelengths (sometimes called green), or short wavelengths (sometimes called blue), referred to as L-, M-, and S- cones respectively. The peak sensitivities are provided by three different photo-pigments. Light at any wavelength in the visual spectrum (ranging from 400 to 700 nm) will excite one or more of these three types of sensors. Our mind determines the color by comparing the different signals each cone senses
Seeing color | Causes of Color
How do we hear?
The human eardrum is a stretched membrane, like the skin of a drum. When the sound waves hit your eardrum, it vibrates and the brain interprets these vibrations as sound.
How do we hear?
note: Remember that every interaction we have as human with our surrounding is just an electric impulse interpreted by your Brain (add this to electric universe theory)
example:
Implanted electrodes enable a paraplegic man to stand, regain leg use
GOD Helmet
God Helmet refers to an experimental apparatus used in Neuroscience, primarily in the field of neurotheology. Originally called the "Koren helmet" after its inventer Stanley Koren, it was conceived to study creativity and the effects of subtle stimulation of the mesiobasal temporal lobes.[1] Reports by participants of a "sensed presence" brought public attention to the God Helmet through appearances in several TV documentaries showing it in use.[2]
The apparatus, placed on the head of an experimental subject, generates weak fluctuating (i.e. "complex") magnetic fields. These fields are approximately as strong as those generated by a land line telephone handset or an ordinary hair dryer, but far weaker than that of an ordinary fridge magnet. It is used extensively by Michael Persinger, a neuroscientist at Laurentian University in Sudbury, Ontario, Canada. Persinger has published extensively about the effects on the human brain of the "complex" magnetic fields generated by the God helmet and other similar devices.[3] Many subjects have reported "mystical experiences and altered states"[4] while wearing the God Helmet
God helmet - Wikipedia, the free encyclopedia
Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together
"So far, neural communication has been thought to occur almost entirely via traffic involving synapses, the junctions where one neuron connects to the next one. Our work suggests an additional means of neural communication through the extracellular space independent of synapses."
link:
Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together - Caltech Media Relations
Shape analysis of MR brain images based on the fractal dimension
Olena Buczko*, Paweł Mikołajczak
Faculty of Mathematics, Physics and Computer Science, Maria Curie-Skłodowska University,
pl. M.Curie-Skłodowskiej 1, 20-030 Lublin, Poland
Abstract
This paper presents some results concerning the application of the fractal approach to the
analysis of shape of white brain matter in the magnetic-resonance (MR) images. The fractal
dimension of white brain matter was calculated using the box-counting algorithm.
http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf
:grindaisy:
ImBill 05-19-2011 05:30 PM
This is some very interesting information. I have to say, though, that if you haven't found proof of telepathy, you haven't read enough about it. I tend to look at it from the standpoint of our brains and minds (in particular, our self limiting thoughts and beliefs) are what are standing between us and our natural telepathic ability.
MonsieurM 05-19-2011 05:56 PM
What i am trying to show is that through "evolution" (whichever theory you believe in), the brain took over the function of interpreting sight,sound and touch; in other words it is an acquired Aptitude (what else can be acquired :confused: ). the question i ask myself is what lies next? And i don't think it is a such a giant leap to believe that telepathy is just learning to use the right frequency and knowing how to receive/emit such a wave. The brain will have to learn/be trained also to interpret such signals (ie: god helmet).
And if you read (and believe) the account of abductees, most would say that ETs communicated with them through Telepathy, which means that we human already have that ability ingrained within us.:thumbsup:
just have to know how to unlock it, or which part of the brain needs to be trained/stimulated
YouTube - ‪Emotiv computer game controlled by thoughts‬‏
IBVA Brainwave Controller
YouTube - ‪IBVA Brainwave Controller‬‏
updated post#1 (added human body)
MonsieurM 05-23-2011 11:54 AM
Just wanted to post this info because its representation is nothing more than a Fractal representation:
Multiverse = Many Worlds, Say Physicists - Technology Review
http://www.technologyreview.com/blog...verse%20QM.png
Enjoy :thumbsup:
elias 05-23-2011 12:11 PM
Enjoy :thumbsup:
What a synchronicity, I was watching the following interview with Inelia Benz Just before I saw this.
YouTube - ‪INELIA BENZ : the full interview - with Bill Ryan from Project Avalon‬‏
Inelia was talking about the same thing, infinite parallel realities, and infinite timelines. It is recommended to be watched.
MonsieurM 05-24-2011 07:59 AM
Indeed, Synchronicity....:) :thumbsup:
MonsieurM 05-24-2011 01:43 PM
A better way to qualify nature as Fractal is the Constructal theory:
The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it."
link:
Constructal theory - Wikipedia, the free encyclopedia
MonsieurM 05-25-2011 08:23 AM
I just watched INELIA BENZ's interview, I really liked the way she describes telepathy, it reminded of this post made by metamorpheus :cool: :
Originally Posted by metamorpheus (Post 138017)
I think its a fascinating phenomena, where one coil separated by a distance,with no physical connection, other than by earth ground, will resonate with another coil, its kind of like the phenomena with twins, where no matter how far apart they are, they can feel emotions in the other person. It make you wonder if you could build a circuit to vibrate your brain at a particular frequency to match someone else....might make cell phones obsolete one day.
and by Infunity :cool: :
Originally Posted by Infunity (Post 139899)
I agree with metamorpheus on this matter! This is the basis for all transmission of electro-magnetic waves from one transmitter to a receiver. Most old radios seem to have a tuning aspect so that you can change the connections to the coil to change the frequency with which it will resonate. The greatest implementation of this known to "modern" man is Tesla's last great creation.. the one they never let him finish.. a tower capable of using the earth's resonant frequency matched to his tower to broadcast energy of the earth for use in electrical devices anywhere. This was a further development of the Tesla Coil, which is a good place to start to understand this stuff! I mean, Tesla was one of the first inventors of radio, and definitely before Marconi stole his ideas at Edison's company and claimed he invented it. Well, good luck in your search for resonance! Some say its the key to the universe. If you really wanna dive deep... check out a guy they sometimes claim (but isn't) the son of Tesla, John Hutchinson. He's cleaning up the Gulf using the resonant frequency of the carbon atom and molecules to somehow break apart oil into a plasma state, a nuclear change if anything. Fun stuff!
I think she has the capacity to tune her frequency to match whichever person she wishes to make mental contact with.
More on this:
http://www.energeticforum.com/energe...tml#post139899
:thumbsup:
MonsieurM 05-25-2011 08:31 AM
I think that Tesla was the first to realize the Constructal properties of Nature and was able to use that in order to make a fractal antenna out of whatever he wished and to tap into the scalar waves as well. Some think that Scalar waves travel at the speed of thought (which is of course instantaneous), maybe it is and if so, then Scalar waves and "telepathy wave" are likely to be one and the same. Which leads me back to the title of this thread: The Brain is an Advanced Fractal Antenna:thumbsup:
MonsieurM 05-26-2011 02:29 PM
I would highly recommend that you read this post, it is about dna transfer and maybe a link with the earth's resonance and a clue to our evolution (hope i am not going too far in saying this :embarrassed: )
http://www.energeticforum.com/136257-post20.html
it is also one more clue to nature as having a fractal antenna properties, adding to it the same resonance of two identical coils (ie: the water):D
Note:The human body is about 60% water in adult males and 55% in adult females. that 's one big coil don't you think? :eek:
just like Tesla's Experiment
http://www.reformation.org/tesla-coils.jpg
:thumbsup:
Another info to read:
The New “Power Plants”: Trees Make Electricity? in post #1
ps: i wonder what would happen if you use an ssg circuit on a tree?
link:
http://www.energeticforum.com/new-me...tml#post136257
MonsieurM 05-28-2011 12:20 PM
If you are interested in the subject of Fractal/Constructal properties of nature i would advise you to refer to my other post:
http://www.energeticforum.com/renewa...collector.html
to give a little taste of it (from my latest posting):
From the article:
This apparatus was connected up to one of Mr Rogers’ latest buried antennas --- a single rubber-covered, stranded copper cable, extending westward for a distance of 4,000 feet, so as to be in a plane with the high-power European radio stations. This cable is encased in iron pipe (gas pipe), each 20-foot section of which is insulated from the abutting sections by means of a rubber hose (garden hose) slipped over the pipe ends for a few inches. This is buried in a dirt trench about 3 feet deep, filled in with soil. The cable is insulated at the free end and is connected up as in Fig. 2. The rubber covered wire alone has been used in all sub-aqueous tests, and gives fine results when simply buried in the ground, the decay not being so rapid as probably would be imagined. This latest aerial in the iron pipes is a new development and experiments are still going on with it. It works wonderfully well. The 4,000 foot aerial here described is best suited to receiving radio lengths of 6,000 to 16,000 meters. For shorter wavelengths aerials of smaller dimensions are employed.
Doesn't it resemble the root of a tree:
Tree roots possess an apical meristem (meristematic tissue found at the tip) that is protected by a root cap. The root cap sloughs off its oldest tissues to provide lubrication as the root is pushed through the soil. As the apical meristem grows, it cuts off new cells through cell division, and a zone of elongation is formed directly behind it. In this area, the new cells are enlarging and differentiating into specialized root tissue.
The rate of root growth is quite variable throughout a growing season. Roots usually begin to grow before the tree top does, although root growth is cyclic and responds to environmental changes such as soil depth, water supply, aeration, mineral supply, and temperature.
http://www.extension.iastate.edu/Pag...mages/root.gif
:cheers:
one more info:
the answer to that is as follows:
Fractal Antennas: A Novel Miniaturization
Technique for Wireless Communications
Wireless applications, particularly with multiple
resonances, put new demands on antennas pertaining to size, gain,
efficiency, bandwidth, and more. One promising approach in this
regard is to use fractal geometries to find the best distribution of
currents within a volume to meet a particular design goal. In the
miniaturization of wire antennas it has been found that the
electromagnetic coupling between wire angles limits the reduction
of the resonant frequency with increasing wire length.
Recent
efforts by several researchers around the world to combine fractal
geometry with electromagnetic theory have led to an emergence of
new and innovative antenna designs. Unique properties of fractals
have been exploited to develop a new class of antenna-element
designs that are multi-band and compact in size and have been
shown to possess several highly desirable properties, including
multi-band performance, low sidelobe levels, and its ability to
develop rapid beamforming algorithms based on the recursive
nature of fractals. The purpose of this paper is to introduce the
concept of the fractals and to provide a study and implementation
of rapidly growing field of fractal antenna engineering including
recent developments. The simulated results for Koch fractal
antenna using AWAS and NEC are also provided.
your underground fractal/constructal antenna:
links:
http://www.academypublisher.com/ijrt...0205172176.pdf
ISUE - Tree Roots
:hug:
:cool:
Nadda 05-29-2011 07:21 AM
Great links and info. I think your right and i think there is no doubt we all have the abilities and that, similiar to what ImBill said, most people simply have them locked away within the limits set by their own beliefs.
I think telepathy is a twin sibling to telkinesis. I think both of them are simple communication. One is communication between person to person and the other is communication between a person and everything else. Telepathy being a step higher than telekinesis.
Telepathy needs two way communication, a person who is an emittor and reciever. While telekinesis is one way communication, a person who is an emittor. Static objects seem to naturally be good recievers. Maybe i should ask them to teach me how they do it? lol. For all i know, telekinesis could just be a byproduct of telepathy. The way ive imagined it is as though everyone naturally has a dialup connection and i developed a broadband connection. The only difference being my signal is strong enough to affect static objects that would otherwise go unaffected. I would bet that someone who is telepathic and a good reciever would have an easy time reading my mind. :sshh:
I've never really spent that much time looking at the simularities between the two but I just remembered something i heard a long time ago and its an even bigger connection. It was a video about ascension and the next higher dimension, the speaker being someone who i think is fully credible, spoke about the types of things we could expect to see and that our abilities would then be natural to everyone, that telepathy is the main form of communication. Whats interesting is that he noted, telepathy was not going to be like anything we would imagine, that unlike a spoken language you dont just say a sentence then stop. Our thoughts are ever flowing, day and night they never stop and that anybody at any time could hear you and you would hear them. That the communication is not just direct and singular.
I never spent too much time thinking about that, always thought it was interesting, afterall it would be the end to all deception...But, i just realized that is exactly how telekinesis works and it makes perfect sense for telepathy to work the same way. From my experience with telekinesis this confirms, that is exactly how telepathy will work. As i mentioned though, even if you trained yourself to be a great reciever, most people today would not be good emittors, so im sure it would be difficult it at all possible to hear someones thoughts unless they trained to become an emittor.
MonsieurM 05-29-2011 11:38 AM
I am quoting from a thread I already posted the link earlier, but it fits your description, and it comes from a Great Scientist:
If you place an iron rod in a dark room and cause it to vibrate at first you'll only be able to tell it is vibrating by touching it.
Increasing the vibration to 32Hz will produce a loud and shrill sound and vibration can now be detected by both touch and hearing. Increase that vibration to 40Hz and you can no longer detect the vibration by touch or sound.
If you increase the vibration to 1.5MHz you cannot feel or hear the vibration but you can detect the vibration though the rise in temperature in the iron first warm and then the iron rod will glow red hot and can be detected by sight.
At 3MHz the rod is now producing violet light; increasing the vibration more will produce ultra-violet rays and other invisible radiations that can only be detected by special instruments.
There are so many "vibrations" flowing all around us that are invisible to our 5 senses who can tell how they affect us. Uranium emits and invisible radiation that will kill you. You cannot see it but it is there and kills. Who is to say how the other radiation affects the body and mind.
Isn't it possible that the mind radiates its own wireless transmissions that are received by other minds but we just are unaware of that as of yet. There is no scientific proof for or against this theory, yet so many people will just to the conclusion that it cannot exist. There are among the same people that would have disbelieved radio existed before it was proven that is does exist.
You MUST keep an open mind and use these methods as those successful have already used them to achieve success. Who are you willing to believe, those who have not succeeded or those who have?
Dr. Alexander Graham Bell :notworthy:
want to know how vast the electromagnetic spectrum is , Richard Hammonds does an excellent presentation (starts at 10 min):
YouTube - Invisible Worlds - Out of Sight 1/4.avi
:wall:
MonsieurM 05-29-2011 11:50 AM
I would like you to compare the following pictures, and i'll let you come to your own conclusion :confused: :thumbsup:
http://www.rexresearch.com/montagnier/abstr5.jpg
http://www.kempelektroniks.com/Site_...6628f81d78.jpg
more on this:
I found this document, which i think is authored by Nicolas Tesla, I have uploaded it, so as you can have access to it
Quite different conditions exist in my system in which the electromagnetic waves or radiations are designedly minimized. the connection of one of, the terminals of the transmitting circuit to the ground having, itself, the effect of reducing the energy of these radiations to about one-half, Under observance of 'proper rules and artifices the distance is of little or no consequence, and by skillful application of the principle of "individualization," repeatedly referred to the messages may be rendered both non-interfering and non-interferable. This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.' Nicolas Tesla
a while back i wrote this in a post on fractal antenna:
I think that Tesla was the first to realize the Constructal /fractal properties of Nature and was able to use that in order to make a fractal antenna out of whatever he wished and to tap into the scalar waves as well. Some think that Scalar waves travel at the speed of thought (which is of course instantaneous), maybe it is and if so, then Scalar waves and "telepathy wave" are likely to be one and the same. Which leads me back to the title of this thread: The Brain is an Advanced Fractal Antenna.
Frontiers | Fractals in the nervous system: conceptual implications for theoretical neuroscience | Frontiers in Fractal Physiology
This essay is presented with two principal objectives in mind: first, to document the prevalence of fractals at all levels of the nervous system, giving credence to the notion of their functional relevance; and second, to draw attention to the as yet still unresolved issues of the detailed relationships among power-law scaling, self-similarity, and self-organized criticality. As regards criticality, I will document that it has become a pivotal reference point in Neurodynamics. Furthermore, I will emphasize the not yet fully appreciated significance of allometric control processes. For dynamic fractals, I will assemble reasons for attributing to them the capacity to adapt task execution to contextual changes across a range of scales. The final Section consists of general reflections on the implications of the reviewed data, and identifies what appear to be issues of fundamental importance for future research in the rapidly evolving topic of this review.
I'm glad this document confirms my theory :D
http://www.energeticforum.com/141831-post9.html
http://www.energeticforum.com/142326-post57.html
MonsieurM 05-31-2011 01:41 PM
Now that we talked about fractal, let me share with u some info on water:
Kirlian Photography of
water samples on photographic film©:
1 drop - tap water,
2 mountain water drop,
Teteven, Bulgaria,
3 drop - seawater,
Hammamet, Tunisia,
4 drop - karst and mineral water,
Zlatna Panega, Bulgaria,;
Dr. Ignatov©, Dipl.Eng. Yatsevich©, 2010
http://www.medicalbiophysics.dir.bg/...rlian_film.jpg
"In the Kirlian effect, which is a high-frequency electric discharge in gas, the color of light depends only on gas. It does not depend on the electrodes. It is apparent that the color Kirlian aura carries biological information from the object itself. The observed phenomenon cannot be described and explained from the point of view of the modern physical notions for the color of the light of gas discharge. The fact that different colors are being observed, apparently confirms the opportunity for selective influence on the researched object. The methodic and the results of Dr. Ignat Ignatov are a novelty, because local energy states of the researched object are displayed depending on the colors in his electric aura. This, as a fact, presents new possibilities for the research and characterization of the qualities and properties in a biological and physical aspect of the object. New opportunities are found for the characterization of the biological properties of objects after a certain influence. Dr. Ignatov’s methodic for Color Kirlian spectral analysis can be defined. New notions for color vision are possible to be discovered. It is not clear whether the green color that we see is an averaged effect between the yellow and the blue color, or in some cases it corresponds to a wave length corresponding to the green color of the spectrum (Marinov, Ignatov, 2008)"
The Capacity for Unique Bioinfluence Is Where the Colors of the Kirlian Aura Are (Ignat Ignatov) - Scientific Research Center of Medical Biophysics (SRCMB)
the following website has a collection of links relating to vibrational water, going from the esoteric to the scientific (u pick whichever interests you).
Vibrational water is a term we are using to encompass a broad range of concepts and technologies related to energetic water themes. Vibrational energy is an emerging field in medicine, physics, and agriculture. Thus, related terms include vibrational medicine, vibrational physics, and vibrational agriculture.
Perhaps you will notice that some of these practices deal with subtle energy (e.g., Reiki, sai sanjeevini), while others are grounded in mechanical-biological (e.g., flow forms, Effective Microorganisms). We take a liberal approach and include all of these practices and concepts under this large umbrella known as vibrational water.
Vibrational Water
Vibrational Water:// Standard Chemistry and Physics; A Reference Point
Causes of Color: //Why is water blue? //Vibrations and visible spectrum
Home | Causes of Color
Causes of Color: //Home
Double-Resonance Spectroscopy of Autoionizing States of Water
Double-resonance spectroscopy of autoionizing states of water
Dense Water
Peter Augustin
http://www.dichtes-wasser.de/eng/sta...e_englisch.htm
A fascinating series of articles on properties of water from Peter Augustin. The material probably lies somewhere between metaphysics and standard physics; very interesting!
Selected titles:
The Anomalies of Water – The Foundation of Life
http://www.dichtes-wasser.de/eng/The...s_of_Water.htm
The Muscles in Water
http://www.dichtes-wasser.de/eng/mem...t_englisch.htm
The Biological Vacuum
http://www.dichtes-wasser.de/eng/the...cal_vacuum.htm
Biological life is above all invisible, contractile, vibrating, reflecting muscle
membrane in water.
At the Beginning was the Sound. The Earthworm or The inner Infinity
Peter Augustin
http://www.dichtes-wasser.de/eng/at_..._the_sound.htm
water is present everywhere
Water appears to be one of the most abundant molecules in the Universe. It dominates the environment of the Earth and is a main constituent of numerous planets, moons and comets. On a far greater scale it possibly contributes to the so-called "missing mass" of the Universe and may initiate the birth of stars inside the giant molecular clouds. This paper gives a brief description of water and ice environments with an emphasis on their possible origin and subsequent development in the Solar System. Expanding the scope of hydrology to cover phenomena encountered on other celestial bodies is postulated and discussed.
WATER IN THE UNIVERSE
The Paper
MonsieurM 05-31-2011 11:34 PM
water is the answer, before remember this fact (i ll explain why later):
The Paper
Now I present u with:
WiTricity - Wikipedia, the free encyclopedia
WiTricity is based on strong coupling between electromagnetic resonant objects (ie two water coil) to transfer energy wirelessly between them. This differs from other methods like simple induction, microwaves, or air ionization. The system consists of transmitters and receivers ( a tree for instance) that contain magnetic loop antennas critically tuned to the same frequency. Due to operating in the electromagnetic near field, the receiving devices must be no more than about a quarter wavelength from the transmitter (which is a few meters at the frequency used by the example system). In their first paper, the group also simulated GHz dielectric resonators...
...In the experiment both coils were made to resonate at 10Mhz, allowing them to couple and for "tails" of energy to flow between them.
http://i.treehugger.com/images/2007/10/24/witricity.jpg
doesn't this remind you of Witricity:
ps: I posted this on another thread because this knowledge discovery leads to so many different roads just like a tree ( good thing since there is also a fractal logic to it :cool: )
MonsieurM 06-01-2011 10:31 AM
one more info, which is of great importance, i know you guys would agree with me :D :
Water on the Sun?
An international team of scientists, including a University of Waterloo chemistry professor, has conclusively demonstrated that water (actually steam) does exist on the sun, confirming a breakthrough finding made two years ago.
The team used an innovative method to calculate the water spectrum at sunspot temperatures. The method will be useful in modelling systems with an abundance of extremely hot water molecules, such as forest fires.
Water Found on Sun
note: meet your coil/fractal antenna to harvest sun energy and it also confirms why:
Apparently the Russian scientist Alexander Chizhevsky, who proposed and thoroughly researched links between solar activity and biological response, found that bacteria in water responded to solar flares instantaneously, as opposed to the 8.3 minutes it should take for the photon bombardment to elicit a response."
Just to show you that i was not the first one to think of this concept:
Elaborating the Neoplatonist picture. Agrippa accepts the basic Neoplatonic framework sketched above. God has the Forms in his mind. God created "Angelical and Celestial secondary causes," beings Agrippa also calls the "Intelligences," and God "gives the seal of His Ideas to the Intelligences." The Intelligences then use the "heavens and stars as instruments" to send these copies of the Forms down to humans on the Earth. In exactly the way our souls/intellects control our bodies, the Intelligences -- the Celestial souls -- control the body (=the matter) of the universe. So just as my mind "sends commands" to my body in order for the mind to achieve its aims, so too do the Intelligences/ celestial souls use the stars to achieve their ends. Thus Agrippa agrees with Avicen[na], who says "whatever things are done here, must have been before in the motions and conceptions of the stars and orbes." Agrippa says that "quintessence" -- Aristotle's 5th element, aither -- is what conveys the Intelligences' power to material stuffs: the spirit is contained in "the rays of the stars."
MonsieurM 06-01-2011 11:34 AM
speculative Note: being a fractal antenna made of 60%/55% of water, (in a very simplified manner :) ), I presume that it can also explain some of the results obtained by Mr Masaru Emoto in his rice experiment. According to what i presented you with previously, to obtain really good results, i would advise to conduct this experiment close to a large body of water.
for those interested:
Masaru Emoto - Wikipedia, the free encyclopedia
Weird synchronicity:
Coast To Coast AM - 31.5.2011 - 1/4 - Cosmic Internet
YouTube - ‪Coast To Coast AM - 31.5.2011 - 1/4 - Cosmic Internet‬‏
one last for the road: guess what is toroidal and is dependent on the sun's rotation:
Heliospheric current sheet:
The heliospheric current sheet (HCS) is the surface within the Solar System where the polarity of the Sun's magnetic field changes from north to south. This field extends throughout the Sun's equatorial plane in the heliosphere.[1][2] The shape of the current sheet results from the influence of the Sun's rotating magnetic field on the plasma in the interplanetary medium (Solar Wind).[3] A small electrical current flows within the sheet, about 10−10 A/m˛. The thickness of the current sheet is about 10,000 km...
...As the Sun rotates, its magnetic field twists into a Parker spiral,[5] a form of an Archimedean spiral, named after its discovery by Eugene Parker.
http://upload.wikimedia.org/wikipedi...sheet_edit.jpg
[IMG]http://www.kempelektroniks.com/Site_...6628f81d78.jpg[/IMG]
and don't forget the presence of water in the sun and you have your Cosmic Water Coil capacitor , containing your earth water coil capacitor, containing your tree water coil capacitor , and so on (sounds fractal, no?):D
Heliosphere - Wikipedia, the free encyclopedia
The Paper
"Quantum Water" Discovered in Carbon Nanotubes
Chengdu Organic Chemicals Co. Ltd., Chinese Academy of Sciences
A new quantum state of water found in carbon nanotubes at room temperature could have important implications for life...
...That's a big deal. Reiter and co chose carbon nanotubes because they are an analogue of the conditions water faces when passing through living systems, through ion channels in cell membranes, for example. Biologists have long known that flow through these channels is orders of magnitude greater than conventional fluid dynamics predicts. Perhaps this new state of quantum water is the reason why.
from quantum agriculture
" What Lehrs is describing here is the power of an insulator (dielectric: ie water) to accumulate a static charge from a weak field and condense it into a strong charge that gives rise to an electrostatic field.
Nature's version of:
To amplify the current i think we should look into Tesla's Invention:
http://upload.wikimedia.org/wikipedi...Tesla_Coil.png
The magnifying transmitter is an advanced version of Tesla coil transmitter. It is a high power harmonic oscillator that Nikola Tesla intended for the wireless transmission of electrical energy.[1] In his autobiography, Tesla stated that "...I feel certain that of all my inventions, the Magnifying Transmitter will prove most important and valuable to future generations."[1] The magnifying transmitter is an air-core, multiple-resonant transformer that can generate very high voltages.
any thoughts on what i have posted so far :confused:
enjoy :cheers:
:thumbsup:
MonsieurM 06-01-2011 03:58 PM
found some research on water and quantum properties:
Cooperative and Coherent Water
Cooperative hydrogen-bonding between molecules gives rise to energetically favourable three-dimensional network of supramolecular clusters in liquid water under ambient conditions, resulting in long-range dipole correlation and quantum coherence Dr. Mae-Wan Ho
info on quantum coherence:
http://en.wikipedia.org/wiki/Coherence_(physics)
Positive Electricity Zaps Through Water Chains
Water bound on surfaces of proteins and membranes conducts positive electricity, and could enable cells and tissues to intercommunicate rapidly and efficiently. Dr. Mae-Wan Ho
Can Water Burn?
The case of salt water that can be ignited when exposed to a radio frequency beam and what it could tell us about the structure of water Dr. Mae-Wan Ho
Is Water Special?
Water has a collective structure that’s extremely flexible and dynamic, which may explain some of its ‘anomalies’. Dr. Mae-Wan Ho explains
Quantum Physics Makes Water Different
It is interesting that one of the substance that we are most familiar with, actually can only be explained using quantum mechanics. This is certainly true with water and its properties.
Quantum objects, such as atomic nuclei, have properties of both waves and particles. Quantum effects aren’t usually manifest to the naked eye, but in this case they may be responsible for some of water’s unusual features. “The quantum effect in water is abundantly obvious,” says Alan Soper of the Rutherford Appleton Laboratory in Didcot, England.
If So plus Water on the Sun info, then it explains this:
and this:
Redon files: Quantum Entanglement in Photosynthesis and Evolution
Recently, academic debate has been swirling around the existence of unusual quantum mechanical effects in the most ubiquitous of phenomena, including photosynthesis, the process by which organisms convert light into chemical energy.
and finally:
enjoy ;)
link:
Physics and Physicists: Quantum Physics Makes Water Different
New Science of the Organism - Water
MonsieurM 06-01-2011 11:01 PM
I would like you to watch the following vid and imagine yourself in those places (you will reach a good state of vibration :D )
YouTube - ‪beautiful nature scenery 2 (1080p HD)‬‏
then read the following article and it will make more sense (remember you are in simple terms " a walking, talking adaptive fractal antenna :D ):
Quantum Agriculture
The Alchemy of Capacitance
Dennis Klocek
Dowsers have long been aware of the unsettling effects of fields and moving currents upon the forces of life. Dowsing research has uncovered a great deal of documented proof that sleeping in a weak field or a current can be a major cause of debility which leads to illness. All currents are considered by dowsers to generate fields. Running water, gas, electricity, even geological fault lines and the crystalline lattice of minerals in the earth radiate weak currents. The theory is that an organism resting in these currents cannot maintain equilibrium in its life forces because its own life field is constantly being disturbed. Even if the disturbance is miniscule compared to modern amperages in electric grids, the constant flow of energies is thought to "wick" away life forces and put the organism under stress when it is supposed to be concentrating its life forces. In effect, this image found in the dowsing literature, is an image of conduction (wicking away of current) versus condensing (the alternate induction and capacitance of weak forces which condenses the weak forces into stronger field forces). An organism being influenced by such currents becomes brittle and loses its elasticity. Once it has lost its charge of life, it becomes prey to pathogens from the environment. Plants growing above watercourses, lenses of volcanic materials or fault lines often show such signs of stress. Trees growing over an underground stream will die on the side which receives the ether current from the moving water, or the underground pipe and thrive on the side which does not. Tree roots will form burls when the tree is growing over an active water main or underground stream. Watercourses or changes in the composition of the ground underneath orchards can often be traced by looking at weak or infested trees. Dowsing the area will reveal the presence of a subterranean current. The list of phenomena surrounding conduction currents is extensive and available to anyone caring to do a little research. The result from many dowsing experiments is that conduction weakens life forces.
Capacitance Antennae In a device known as a capacitance antenna, the conductor or coil serves to give rise to a magnetic field by briefly conducting or consuming an electric charge. As the electric charge is consumed it flows through the coil and creates a magnetic field with magnetic forces moving through the field lines. A dielectric or condenser is placed in the magnetic field. The dielectric is composed of many inner layers of an insulating substance like silica. As the magnetic current moves through the dielectric it creates weak electric fields in the many layers of the dielectric where the layers cut across the magnetic field lines. As a result an electric field is created around the dielectric when a capacitor is placed into a magnetic field. The electric field in turn is once again taken into the coil for a brief conduction which once again creates a magnetic field around the coil.
In this arrangement, the capacitor or condenser builds a weak, but constant charge with no current into a strong field capable of holding a lot of power (voltage) but little flow (amperage). The charged field is then drawn through a coil which draws off the charge in a movement which is just the very beginning of conduction. A magnetic field grows quickly as the brief conduction converts the flow of electricity into magnetism. The dielectric is placed so that the magnetic field surrounds the dielectric and causes the dielectric to pick up a strong electrical charge. This is then reciprocally discharged back into the coil to keep the cycle going. The elastic oscillation of magnetic into electric back into magnetic forces causes induction to take place in the condenser and coil and greatly increases the power without an increase in input. This brings two polar forces into a mutual rhythm tic oscillation. However, in this type of circuit the electrical and magnetic forces are not really consumed and no lines of magnetic energy are cut or disturbed, as is the case with power generation apparatus in use today. This model is the basis for wireless transmission. It is also the basis for the electrostatic capacitance antennas in use for the reception of radio transmissions in automobiles. The effect of the capacitor/coil antenna is to make the transmitter appear closer to the antennae than it actually is. The capacitor amplifies the weak signal from the source and the closed induction circuit makes the signal more resonant as the energies are rhythmically oscillated from condenser to coil. The power to drive a speaker grows from the oscillation.
The Alchemy of Capacitance - QUANTUM AGRICULTURE
My Personal Mantra:
Live Curious
If you are you breathe.
If you breathe you talk.
If you talk you ask.
If you ask you think.
If you think you search.
If you search you experience.
If you experience you learn.
If you learn you grow.
If you grow you wish.
If you wish you find.
And if you find you doubt.
If you doubt you question.
If you question you understand
and if you understand you know.
If you know you want to know more.
If you want to know more ...then you are alive
National Geographic
:D
updated post#18
Cheers :cool:
MonsieurM 06-02-2011 03:01 PM
It just occured to me, the Emerald Tablet stating the famous expression:
"As above so below" isn't that how you would describe a Fractal figure :D
The Mystery Of Water ( 60 min doc)
YouTube - ‪1 The Mystery Of Water.‬‏
opened a thread on "how to build a water coil":
http://www.energeticforum.com/renewa...tml#post143025
MonsieurM 06-04-2011 11:50 AM
I was just reading through A thread on Above Top Secret on
The most accurate prophecies i have ever seen., page 1
Mitar Tarabich, (1829-1899) was an illiterate peasant from a small Serbian village called Kremna, he occasionally had prophetic visions of "seeing into the future. Being very religious and his godfather being a local Serbian orthodox priest, he told the priest about his visions.
The priest, Zaharije Zaharich (1836-1918), wrote down mitar's visions in a small book, which got damaged by fire in 1943 when his family home was destroyed by the Bulgarian army. This text is now in the possession of the family of Zaharich's great-grandson, Mr. Dejan Malenkovich.
"People will drill wells deep in the ground and dig out gold, which will give them light, speed and power, and the earth will shed tears of sorrow, because there will be much more gold and light on its surface than in its interior. The earth will suffer because of these open wounds. Instead of working in the fields, people will dig everywhere, in right and wrong places, but the real power will be all around them, not being able to tell them, 'Come on, take me, don't you see that I am here, all around you.'(sounds like water, no?:D ) Only after many a summer, people will remember this real power, and then they will realize how stupid it was to dig all those holes. This power will also be present in people but it will take a long time before they discover it and use it. Thus man will live for a long, long time, not being able to know himself. There will be many learned men who will think through their books that they know and can do everything. They will be the great obstacle for this realization [self-knowledge], but once men get this knowledge, then people will see what kind of delusion it was when they listened to their learned men. When that happens, people will be so sorry that they didn't discover it before, because this knowledge is so simple.
MonsieurM 06-05-2011 11:40 AM
Thank you IndianaBoys for the info :notworthy:
Originally Posted by IndianaBoys (Post 143048)
MonsieurM,
Have been enjoying following your posts.
Have you seen this:
Reflection of Mind Projected Thought into Water Photographed
http://www.shunshentao.com/MIND SCIENCE LAB NOTES.htm
Best regards,
IndianaBoya
from the thread: http://www.energeticforum.com/health...er-easy-2.html
IndianaBoys 06-06-2011 03:31 PM
Frontal Lobes Supercharge
MonsieurM,
You are welcome. Thanks for pulling all the information together!
The following relates to something we are all born with and if understood can be the most beneficial therapeutic tool available. Totally free, No machines necessary, this is on board equipment :)
IndianaBoys
The
FRONTAL LOBES
SUPERCHARGE
by Neil Slade
WHAT IS “POPPING YOUR FRONTAL LOBES”?
Think of the most fantastic, exhilarating, or happiest moment of your life.
Got it?
Now multiply that feeling times a hundred. Or a thousand. Or ten-thousand.
Or a million. That’s what it feels like after you “pop” your frontal lobes. For real.
To pop your frontal lobes you
Click your amygdala forward.
This sends energy all the way through your brain.
“Whoa!” you say. “The best day of my life times a million! Impossible!”
Well okay, let’s examine this “popping” phenomenon in another more
plausible fashion that shouldn’t be too hard to accept as a posibility:
Imagine the most fun you’ve ever had, or more to the point, the best feeling
you’ve ever experienced. Got it? Now imagine figuring out how to feel this feeling once a month, every month. That’s not too hard to accept now is it? How about, once a week, every week? How about every day for the rest of your life?
Mmmmmmmm.....Wow! Yes.
When you learn brain self-control, you “pop” your frontal lobes. This is an
honest-to-goodness physiological brain function. Both pleasure intensity and
frequency becomes your reality. And it is just the tip of the iceberg.
The frontal lobes are the most advanced part of your brain. It is the part of the brain most developed in humans, absent to a greater extent in other apes and lower mammals. Grab your forehead above your eyes with your hand. Everything underneath your hand, the front 1/3 part of your brain is your frontal lobes. Where a chimp or gorilla skull is slanted back from the eyes, a human skull goes straight up from the eyes. This is where your human brain’s frontal lobes reside.
The frontal lobes are that part of your brain responsible for Creativity,
Imagination, Cooperation, Intuition, and Logic- “CICIL”. The frontal lobes are
the part of the brain used for new problem solving, synthesis of new and abstract ideas, concepts of time, and planning.
The amygdala is a biological gateway/switch inside your brain. It is somewhat
like the light switch on your wall. But this amygdala brain click-switch is connected to your frontal lobes. By “clicking” your amygdala forward, you “turn on” your frontal lobes. Clicking your amygdala forward allows electrochemical activity to occur from the base of your brain all the way through to the most advanced part of your brain, the frontal lobes. Your brain lights up. We can see this on a brain scans, literally, as neuro-chemical activity intensifies with frontal lobes increased processes.
In addition, clicking your amygdala forward causes automatic sensations of
pleasure and peace of mind to freely occur. “Clicking your amygdala backward” has just the opposite effect.
“Frontal Lobes Transcendence” is the addition of increased frontal lobes
activity to the point where only positive pleasurable emotions are felt. This is a result of a higher perception of reality and a more successful mode of operation for the individual in her/his environment.
By continually controlling the amygdala you tap into perpetual and unlimited
creative-intelligence-pleasure.
Frontal Lobes Transcendence is like turning on a Perpetual Positive Emotion
Machine inside your head.
It is the smartest part of your brain tickling the “goody spot” (pleasure centers) of your brain whenever you like.
It’s free, and always right there at your neural fingertips.
Frontal Lobes Transcendence is made possible by effortless effort- increased
use of the brain potential already existing inside your head that’s easy to access.
Your brain will run like an efficient, quiet, cool-run, natural machine. You feel
good more and more of the time, and your ability to function and solve problems is tremendously enhanced.
Frustration, anger, fear, pain, and other negative feelings are reduced and
disappear once you “pop” your frontal lobes. As you learn how to see forward with your frontal lobes you will drive around negative emotions in your brain, like you drive around obstacles in the road in your car. Just as a child learns how to walk and outgrows falling down, you will outgrow falling down emotions once you learn some basic facts about how your brain works.
Learning how to click your amygdala forward will greatly enhance your
ability to concentrate on your goals, think clearly, and act more intelligently in your own behalf and for others.
Packed into your three pound cranial package of nerve cells are more
connections than there are grains of sand on all the beaches on Earth. The number or neural connections inside your brain has been estimated as
10,000,000,000,000,000,000,000,000,000,000,000,000 ,000,000,000,000, (CONT.) 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000.
How big is this number? A computer that could handle all the information
your brain can would be the size of Texas. A stack of papers, one sheet for each neural connection, would reach farther than we can see with the most powerful telescope on the planet. That’s a lot of brain connections stuffed between your ears.
If you (we/me/everybody) is using only a fraction of our available brain
potential, what is possible with more turned on?
Getting one’s frontal lobes operating smoothly, efficiently, and strongly is analogous as getting your other muscles to work smoothly and strongly. With practice your body’s muscles do the work you want.
With practice your frontal lobes will do the thought and produce the feelings
you want.
Nerve cells in the brain respond to need and use. Neurons (nerve cells) have
the ability to become larger and develop more connections with other neurons as
activity dictates. For example, a person who uses his hands a great deal will develop more neural connections in the part of the brain devoted to hand coordination than a person who uses hands to a lesser degree. Neurons have the ability to fill in spaces left by old dead neurons, and maintain levels of brain activity: Brain Self-repair.
Recent findings contradict the old belief that one cannot grow new brain cells beyond birth, and that in some instances this is actually a possibility.
MonsieurM 06-06-2011 06:17 PM
thank you for the info IndianaBoys
I discovered also a mental exercise on my own, but one think is required the ability to visualize yourself (takes a little time to get used to) from up top (as if you are looking down on yourself :D ). Now close your eyes, relax, look down on yourself (hint: your brain already knows the position you are in, just ask it to project it for you). Once you are there, seeing yourself down there open a donut coil on top of your head (make it big enough so your body can fit in the middle, your brain likes to respect proportions), and lower it and feel your head going through it until you get to your toes, and back up again.
http://www.rense.com/RodinAerodynami...roid_color.gif
little secret of mine to feel more relaxed and get acquainted with this antenna that is my body (works for me :D )
note: your eyes even closed will tend to follow the up down movement.
if it works on you, i'll show you a trick on how to remember things :eek:
enjoy :cheers:
IndianaBoys 06-07-2011 03:25 AM
MonsieurM.
Yes, very good.
IndianaBoys
MonsieurM 06-07-2011 11:17 AM
for some this may sound Funky :D
memory: need to remember something; simple:
close your eyes, relax, now project a 3d donut in your mind, your brain does it very easily, since it is your first time just explore the donut. When you are done, imagine the donut projecting a light (Remember R2D2 with the hologram projection :D same kind of projection), place the info you need to remember inside that donut light, visualize well for a moment (not long)....you're done, next time you visualize the donut, you'll see the info you wanted to remember...
Again this is my personal experimentation I am sharing with you :thinking:
feel free to explore more of this...and share :)
MonsieurM 06-09-2011 03:49 PM
A picture is worth a thousand words :thumbsup:
http://sphotos.ak.fbcdn.net/hphotos-..._6330324_n.jpg
the way i see it, the waves of oceans provides us with best hint on how energy is transfered from one antenna to the another. think of a surfer riding his wave, now what if i told you that the surfer is the energy you are trying to transfer and the wave the coupled resonance of both antennas.
link to one of the best movies about surf and great music
Videos Posted by FREE RIDE: FREE RIDE - Part 01 | Facebook
link:
BORIS PETROVIC - WORLD FORUM OF SPIRITUAL CULTURE Astana (Kazakhstan) 18-20 OCT 2010 | noosphereforum.org
ImBill 06-09-2011 06:06 PM
All that slick advertising and this is what we are left with for instructions/methodology? How exactly is one supposed to "click" their amygdala forward?
MonsieurM 06-09-2011 06:50 PM
try this: i just did a small research:
The amygdala manages connections and responses between several regions of the brain. It's directly involved with emotional well-being, the flight-or-flight response and fear conditioning. A recent study also suggests that the amygdala plays a role in the complexity of social life.
Activating the amygdala in a positive way stimulates higher order mental processes. This can improve creativity and intelligence while also elevating positive emotions.
The opposite of amygdala activation is negative reaction. When we react to a challenging situation in a suboptimal way, it's processed as a negative emotion. This feeling is regulated by the amygdala. The emotional feedback allows us to easily determine if we are thinking creatively or just relying on survival instincts.
By noticing the difference in thought processes we can consciously control the direction which the amygdala sends its impulses.
Hope this helps :thumbsup:
link:
Brain training - activating the amygdala
personally, i just close my eyes and try to feel the area i want to stimulate, when i do, i try to move that sensation around...:cool:
