Ignition Secrets by Aaron Murakami - *** NEW RELEASE ***
  • Ignition Secrets by Aaron Murakami - *** NEW RELEASE ***
    Please support Energetic Forum by purchasing Ignition Secrets from this banner:
    Or click on this link: Plasma Ignition
    Many of you here know about the plasma ignition systems and also the
    simplified method that I came up with.
    But anyone that doesn't want to scan through thousands of messages
    and spend a lot of time with trial, error, etc... can get a concise walk
    through with my book and video package.
    Everything is Vanity
    - - GM Patent for Plasma ignition and engine back in 1975 that runs VERY lean fuel mixtures. I'm sure one day when the planet gets close to sapping its last barrels of oil they will release a 'new' car and say "Plasma technology people!!!" and the dopey brainwashed masses will oohhh and ahh and rush to the nearest dealership.
    Plasma jet ignition engine and method
    TP
      plasma ignition
      Almost EVERY major auto manufacturer has a patent for plasma jet ignitions.
      The latest was in the last couple years I found for Mazda for a rotary with
      a plasma ignitor "plug" too.
      But, I did originate the plasma effect coming from the same power capacitor
      used with a CDI WITHOUT the need for a secondary power supply.
      I also have been able to make it work with MSD units that others couldn't
      and I show an example of this in the videos. The MSD's have choppers so
      the cap isn't connected steadily to the primary of the ignition coil and
      diode but I got it to work with the way I was switching it. Not really sure
      why others couldn't get it to work but I show what I did and what unit
      I used.
        Spark
        Hi there Aaron,
        Thanks for putting together something like this . I have a little 4wheeler motorbike that chews spark plugs all the time (cheap cdi ) so this might be a good time to try some experiments in this area.I haven't got a copy yet but am going to get a copy when i can .cheers Jason
          plasma ignition
          Thanks Jason - just sent you a private message.
            This looks like something i'd be into.
            Have you sold a few?
              Plasma Ignition
              Hi BobbyD,
              Quite a few actually and I haven't even promoted it yet. It is posted in
              this forum and I told some affiliates that is about it. Some affiliates are
              posting it around the forum bit by bit.
              It will be sent to newsletter lists next week, then a lot of people will know
              about it.
              This is the type of response I'm getting:
              "Thank you for Ignition Secrets, I have consumed all materials AND bonuses within hours of immediate download and am already building my own equipment. Please deny me the right for a refund (as I have already received incomparable value and insight) and release me from the need to wait 70 freaking days for the other bonuses.
              Pat Balemi
              Creative Revolutionist. New Zealand.
              PS. You may use my name and testimony in promotions of this material as you see fit.
              I was even contacted by a senior engineer at one of the largest
              auto manufacturers in the world - he was a bit skeptical then I sent him
              the patents owned by his own company relating to a variation of the
              plasma type ignitions! He probably won't be sleeping for a while.
                Ignition Secrets a few Q & A
                I want to answer a few things that have been asked or have come up
                in one way or another.
                Q: Am I claiming to have invented the plasma ignition?
                A: No, I never have. I invented my method of creating the plasma without
                the need of a secondary power supply, only needing 2 points (gap), etc...
                That is what I refer to as the Murakami Ignition because that is exactly
                what it is - I am the sole inventor of it. Anyone claiming that I am trying
                to take credit for inventing the very concept of a plasma ignition system
                is simply spreading misinformation and cannot be trusted. This forum has
                record of all of this and not once have I ever claimed to have invented
                plasma ignitions.
                Comment: There are some that have tried to apply my method to off the
                shelf MSD's and couldn't get it to work. I was told that the cap in the MSD
                is chopped, which of course it is but was told that the cap isn't in contact
                with the primary long enough. Well, it worked with every CDI and MSD I tried
                and in Ignition Secrets, I give a recommendation for a very inexpensive
                MSD unit that has worked perfectly with many tests, etc...
                I give the exact circuit I used to trigger it with no problems. I still do
                not know why others couldn't get it to work - follow my directions in
                the book and videos and you'll get the same successful results I got.
                Comment: Someone that is convinced they are an expert on my own
                experiments thinks that my method won't work on a car with a distributor.
                Well, little do they know that plasma ignition systems have already been
                sold for a while that send the plasma through a distributor and it works,
                period. Skeptics can utilize bypass mode, which I address in the bonus
                package later on - and that is just one small part of the bonus package.
                Q: Is Clickbank a scam?
                A: No, Clickbank is one of the most respected
                online companies that helps digital publishers offer their content with a
                network of thousands of affiliates. I have used them for several years and
                am very happy with them. There are some people that use Clickbank as
                their platform to scam people unfortunately but it is easy to spot them.
                When you see claims that you'll get off the grid for a couple hundred dollars
                or will have some mysterious Tesla magnetic motor that will run itself and
                make your power bill disappear, well, those are all scams. Ignition Secrets
                is a very legitimate book and video series that offers what it claims and
                is backed by thousands of hours of experiments conducted with my own
                two hands. And there are many members here that have a lot of experience
                with all kinds of variations of the plasma ignition systems. It works, it does
                what is claimed.
                Q: Can't I just learn how to do all of this from this forum?
                A: Yes, that is what this forum is for. However, there is so much
                information dealing with plasma ignitions, it is just
                very, very time consuming - I don't know how many people have asked
                me over the last few years to just make it easy for them.
                If it took 100 hours to pour through thousands of posts, wondering what
                parts to buy, etc..., you'd be getting off lucky and if so, at $37 retail,
                your time would be worth 37 cents per hour. Ignition Secrets is the
                best bet that anyone has that wants to zip thru the maze in a short
                period of time.
                  Thanks Aaron, that was the number one reason for me. Your videos also explained the whole range of possibilities and was very thorough.
                  Please continue to experiments and publish your findings!
                  cheers
                    Thanks Mike!
                    Thanks Mike!
                    There are some other things I'll add to the same package when I can.
                    All the fundamentals are there but I will add more - anyone that purchased
                    the package will get any add on's, etc... for no extra charge of course.
                      Spark
                      Hi there Aaron,
                      Thanks for the message you are always so helpful. cheers Jason
                        - Do U have a schematic of some type that I might look at- I might want to dabble in it- Thanks Roland
                          schematic
                          Hi Roland,
                          You can get everything in my Ignition Secrets package by purchasing it.
                          Or you can comb thru the water sparkplug thread for a lot of different
                          variations.
                            Brisk Yttrium plugs
                            Brisk Yttrium non-resistor triple electrode plugs are showing to possibly be
                            the best off the shelf plug you can get. They are about $8 each.
                            I would just leave the ground electrodes and not make a surface gap plug.
                            Tests are done with the stock configuration.
                            The estimates are 20,000 miles with the plasma ignition that was tested. 20,000
                            miles is quite a bit more than just a couple thousand if even that. $8 per
                            plug is nothing if they last that long with the plasma ignition.
                            I will post details of these tests when I can but this is what I'd recommend
                            for a plug to use for plasma ignitions at the moment. Maybe there are better
                            ones but this is what appears to be the best for now.
                              What about the endothermic implosion?
                              Hi Aaron,
                              I just want to ask you if you explain something in your book about a video you made some time ago about the "implosion spark". You shown in a video that a spark can be exothermic or endothermic.
                              Have you written something about this phenomenon in the book? If not, are you planning to write about it?
