Imhotep Car Relay Charger circuit - Adding additional Coil?
  • Imhotep Car Relay Charger circuit - Adding additional Coil?
    Hi Folks,
    I'm new to the forum and a bit of an electronic newbee, (from an engineering technical perspective, though have tinkered with circuits/schematics, proto'ed on breadboards and soldered circuits together all my life) but have been following energy issues and many threads on this forum for awhile now. Just getting up the nerve to reach out and ask for some help on my own experiments.
    I have tried the basic Imhotep car relay circuit with mixed success. Yes, I've been able to charge a battery, using smaller 12V lead acid batteries having about 4V difference between source and charge, to the point of a little less than a 2V difference with impressive radiant/COP > 1 statistics. But then, the source battery voltage starts dropping significantly, and little or no charge gain is made. Charging time is also very slow.
    While recognizing the undeniable/enormous teaching and inspirational value of Imhotep's creation, I was seeking tipson how to augment the circuit to improve it's practical value.
    From reading Peter Lindemann's radiant energy book, I've developed the opinion that there are inherent strengths in the use of physical triggers such as relays, commutators and spark gaps. In fact, the Car relay itself provides a physical spark gap, even if resistors and caps are used for snuffers, like people are doing with the replications/augmentations of Imhotep's CFL circuit. I've followed the threads on all that, especially Lidmotor's, because many of his own modifications retained the use of a relay. Then there's the easy availability of the normally off 87 - 30 circuit option to fire something else during the nprmally closed, power-off cycle. So I persist in working with it for now, rather than exploring other oscillator configurations, like transistor/trigger coil trifiler, 555 etc.
    BTW I'm all for exploring other trigger methods, especially solid state 555 pulsing. One could, for instance use the same 555 circuit in the Bedini cap pulse battery charger for more than charging/swapping batteries -It could pulse HV to a spark gap or coil as a trigger isolated from and driving the resonant/radiant energy generator sub circuit.
    But I have been disappointed that more hasn't been discussed about using the car relay circuit just as a battery charger - how to tweak it to make it more effective/faster at charging. Granted, lots of ideas could be extracted from the CFL threads, but I'm lacking some understanding of how to translate the circuits people were evolving there, back to the object of recovering as much energy as possible for charging a battery, rather than running a motor/fan or CFL in tandem while charging.
    In his generous free ebook, Patrick Kelley discusses this circuit on 6-21 (399 in the pdf doc). He suggests a new circuit on 6-22/p400 in which the voltage of the source battery is doubled to 24v and a coil or coils are added across the coil of the relay.
    Well, I tried the 24v source with much success, although I picked a bigger project which has not displayed any COP > 1 benefits but rather has been reconditioning a dead (for 9 years) deep-cycle marine battery. That in itself has been a minor miracle! The charge battery was not responding to a regular charger and remained about 6.5v. I took 4 new 'disposable' (not if I can help it!) heavy duty 6v lamp batteries and parallel wired them for 24v as the source. After a week of continuous charging with the basic Ihmhotep car relay circuit, the charge battery is up to 10.5v and the source is down to 15.5v But now that the charge battery is reaching full capacity and the source voltage is losing it's potential edge over the charge battery, the source battery voltage is dropping much faster and the charge voltage is slowing it's ascent.
    Now I've acquired two ignition coils and want to try and add them. I ran jumpers from the coil contacts on the relay, i.e. 85 and 86 to the positive and negative of the ignition coil primary (no connection made to either the HV/+ output or case/-) Nothing happened in Neon only/no charge battery test mode (no buzz nor light). Then I tried a very simple coil in parallel with the coil connections - take the 22 gauge spool from a Radio Shack magnetic wire kit, carefully pull out the ends and scrape them and you've got a fairly robust air core coil. Same results. I'm thinking that these coils being bigger than the relay coil may be somehow overwhelming the smaller coil's ability to generate a magnetic field when wired in parallel. I'm still learning about the how impedance, resistance and capacitance of a big coil effects this circuit, but suspect that here's where I'm failing.
    So my questions are as follows; first, am I wiring the additional coils in correctly? maybe an additional coil should be in the circuit in series with 87a and the positive to the source battery instead? Do I need some additional components to balance the big coil(s) with the little relay coil? In the case of an ignition coil, is there a way to recover more energy coming out of the secondary coil HV+/case- instead of lighting CFLs with it? Or if no connections to secondary exist, does the Back-EMF HV spike feed back through the primary coil as a reverse voltage?
    Oh and...not at the moment a very important question to what I'm doing...but speculative - has anyone tried to put another big coil on the 87 - 30 power cycle (not to drive a CFL load, like Lidmotor did) as well as one on the 87a - 30 side and channel the two spikes to the battery - kind of like a two cycle engine?
    Any input would be much appreciated. Thanks.
    - Godfrey
    I did, it melt the contact point and jam the relay. I use very cheap relay, but I also read other experience the same thing.
    When we add coil the output increase considerably. But the spark make it difficult to keep the relay running. Mine always stop after some minutes.
    As result I use solid state now that produce much faster charge than relay. The reason is because relay is slow. While coil will add power, it produce less overall.
    Example
    Relay = 100 unit at 5 Hz
    Solid state = 1 unit at 5000Hz
    The end result is relay produce 500 unit a second where solid state produce 5000 unit per second. Solid state win.
    In term of reliability and noise production, solid state version win too.
    My solid state conventional efficiency is at least 45% now.
    Here is my video showing spark when adding car coil
    YouTube - Unwanted spike in a relay
    I have two circuit, but I forget which one I use in video.
      My Setup/PCB
      Thanks for your post, Sucahyo! From looking at your circuit, I think I've got the same connections - parallel with the relay coil. But my coil causes the circuit to fail. A simple, non-polarized induction air coil also causes the circuit to fail.
      Thanks for the tips. I see you used a resistor and capacitor across coil as a snuffer to eliminate the arcing which caused your relay to melt.
      I'm still scratching my head over this one, though. I've attached pics of my setup.
      If anyone can tell me where I'm going wrong, I'd appreciate it. Thanks.
      - Godfrey
        No, notice that the connection is different. The one with capacitor is more reliable but slower. Capacitor and resistor are control of how long the relay will turned on. But it won't prevent melting.
        I also experience similar problem with my first one. Try my capacitor version.
        BTW, I think your diode is much too small. Imagine if 1 amp at 12V is running trough the coil then you shut it down to 24V battery. You still need at least diode that allow 500mA to pass trough. From the picture I imagine it has 100mA rating.
          PCB Diagram attached
          Hi Sucahyo,
          Thanks for your post!
          Yes, I see what you’re saying now, the second circuit powers the ignition coil from the normally open connection, instead of the normally closed one.
          Wouldn’t that second circuit produce two alternately timed spikes?
          I now think the induction coil I was originally control testing against the ignition coil, is shorting out. I just swapped it for smaller induction coil, which I know works, and the circuit runs normally. It’s hard to observe any performance boost, however. In, fact when the charge battery is disconnected, in neon only test mode, the light dims when I add the coil.
          Connecting my ignition coil still prevents the circuit from working. It’s a really cheapo UC-12T, but should work.
          BTW, I just want to confirm - you are not connecting the HV of the ignition coil secondary to anything, just the two normal + and – terminals, right?
          I wasn’t sure how apparent the connections were on my earlier PCB pic, so I’ve attached an additional diagram that makes it clear.
          The only difference I see in your first circuit from mine, besides leaving out the neon and switch, is that you connect the negative power coming in from the source battery to 30 on the relay. Mine runs to 87a by way of the switch. This doesn’t really make a difference until making the modifications of your circuit 2, when it’s essential for switching properly back and fourth from 87a to 87. I think I may also have the poles on the coil reversed, but I’ve already tested swapping the pole connections on my ignition coil and it yields the same results. So I’m still stumped, but at least I got one small coil to work with my circuit.
          Me too, it’s only rated for 40 amps, and very generic.
          I’ve been working on a 555 pulser circuit myself. Can you share a schematic?
          I would still like to get my relay circuit which is similar to your first one, working with an ignition coil and therefore want to get to the bottom of where things are going wrong at the moment.
          Do you mean it controls the actual on time duration? Or are you talking about frequency of oscillation?
          I will! Thanks.
          Godfrey
            Yes, I would only collect the spike from the car coil.
            Mine jammed before I observe the charging effect. I would not dare to test it on battery with such spark though ...
            Mine is $0.3 one. You can tighten or loosen the spring to make it self oscillate in case you use first version.
            I connect it CFL too. I also use transformer too, turn down your volume:
            YouTube - Neon driver using Imhotep circuit, 90mA !
            I keep changing the wiring that my actual circuit may be different from picture , as long as it works it is fine.
            You don't need to concern car coil polarity if you don't run it for days. If it is, make sure it is the common leg that connect to battery positive.
            I keep busting 555 that I prefer this circuit now, ignore the bottom diode:
            or this:
            On time will affect frequency. The off time is always brief.
              Hi Sucahyo,
              Thanks for the schematics! Will analyze further.
              So where is that relay coil spark going? Is it maybe helping cause:
              You don't show a neon in your circuits. Are you using one as a safe outlet for surges?
              I thought 1N 4007's were sufficient. Not so?
              I'm still not getting why my ignition coil causes my circuit to fail. I have attached a schematic for further clarity. As you can see, there is no connection to the secondary. Maybe this needs a load like a CFL?
              One test that just worked for me was to put the coil where the charge battery is. This could actually be a promising option. Feed the high voltage spikes coming from the relay coil into the primary of the ignition coil, then the spikes from its secondary could feed the battery. I think I may combine your capacitor feature with this idea and see what develops. The circuit will need an additional diode channel the second spike correctly.
              Also, I might try a circuit firing two coils...one off 87 and the other off 87a. If I can pull that off, it would double the frequency as well as the power spikes.
              Godfrey
                I don't use neon because neon reduce overall punch. My car coil do have load.
                It is rated only 100mA. Replace it with 2Amp diode.
                I just try it, I can't make it work without capacitor, maybe not enough power from the battery. I think you should try the capacitor one. Just put any capacitor above 10uF in parallel with 85 and 86, and see what happen. Use higher capacitance to get longer ON time or 1K potentiometer in series. Put the coil between 85 and 87.
                I tried it but have no success. Maybe too little amperage to drive it.
                I think the one at 87A will prevent self oscillation, but see if you can work it out.
                  Updated/published photos
                  Hi Sucahyo,
                  I just realized that my last diagram posted is not only badly formatted, but also wrong!
                  Since my basic relay charger is a successful replication of Imhotep’s, here are my updated pics, published, for the benefit of other readers:
                  Here is my schematic of Imhotep’s originally published circuit:
                  Photo of my battery charger:
                  Closeup of the PCB:
                  A diagram of the PCB connections:
                  A schematic of the circuit augmentations with references back to the PCB connections:
                  Good tip. Thanks!
                  I think I’ll try this, before I move the coil, first.
                  Ok, will try this also.
                  Yes, I’ll do that too, and update you.
                  I keep busting 555
                  IMO, the 555 pulser part of the charger circuit should be completely isolated from the resonant generator portion by use of an opto-isolator, etc., to spare it from voltage spikes.
                  - Godfrey
                    I don't think it would help. I busted many 12V fan just because I spark the output, while my circuit still survive. It happen because the 12V fan use same power source. Spike EMP can travel bypassing diode or capacitor. Having independent power supply is not practical for me.
                    Besides, I highly believe that opto coupler will muffle the output considerably. If you read spec, the fastest opto coupler is in micro second range while transistor is in nano second range. We need very fast switching to get radiant. Besides, people usually use transistor that is more expensive than 555. Neon is their protection. I don't use it because my circuit rarely busted if I am carefull.
                    Good luck with the project .
                      Spike path
                      Hi Sucahyo,
                      I spark the output
                      You mean you spark across a gap?
                      You mean it can still get past something like this and blow the chip?
                      What frequency range do you think is optimal for an ignition coil?
                      - Godfrey
                        No, spark that happen when we connect a charged battery while the circuit is running. Spark on secondary do not kill my 555.
                        Yes. But a 555 controlled 2N3055 usually survive because of its poor switching.
                        At the ignition coil intended frequency. Usually under 100Hz.
                          Hi Sucahyo,
                          I've been busy working on a new test board with terminal connections so I can change things around easily. Looks like I committed to PCB too soon Besides, the harness for the relay has big wires which are hard to adapt to the small holes of the PCB. A board with barrier terminal strips can handle that meaty wire much better.
                          I've been doodling up some new schematics for the scenarios we've previously discussed. Will post updates on my progress soon.
                          Meanwhile, using the existing Imhotep circuit, I successfully topped off the charge of a small SLA battery that been failing earlier to charge past about 10.5V using only a 12 volt battery for the source. Earlier, when the battery didn't charge any more, I then tried to top it off with a standard trickle charger and it failed to do so. Now with the augmentation of doubling the source battery voltage, this battery tops off nicely and only took hours (several) instead of days to work. This battery had obviously been reconditioned to accept only a radiant charge from being subjected earlier to the Imhotep circuit.
                          I have to be fair about the significance of my dead marine battery reconditioning success. The charging is slow - So what! The 4 little disposable 6 volt, not even Alkaline, batteries are really no match, capacity-wise, for this big marine deep cycle battery. Yet, in a week of continuous charging, it went from a dead 6.5 volts, all the way to lively 10.5 volts. That's pretty decent performance. Here it is working:
                          The limitations I have experienced, do illustrate that the radiant energy effect does not magically cancel out the need for an adequately sized source battery to match the one being charged.
                          Sparks and heat: I also wanted to stress that my relay still feels absolutely cool to the touch even after days of continuous running. Here it is running in test mode, disconnected from the charge battery and lighting up the neon bulb:
                          Test mode is the only time, so far, that I can see a spark in the relay at all. I have cut a little window and glued clear plastic over it, so I can keep an eye on the relay contacts. Here is a closeup with a little blue spark visible on the right (the yellow sparkle on the left is just room light shinning off curvature of a brass contact).
                          And here is the ignition coil that causes the circuit to fail when connected:
                          I've been thinking about this. If you don't use the relay coil spike, shouldn't it be dealt with by putting a protection diode across like this:
                          http://www.kpsec.freeuk.com/images/diopro.gif
                          I came across some images of yours that also seem relevant to our discussion.
                          http://a.imageshack.us/img116/6789/r...otepno2fc7.png
                          http://a.imageshack.us/img75/2208/re...otepno3ny3.png
                          http://a.imageshack.us/img184/8868/r...otepno4hm1.png
                          Can you tell where to find your original thread describing them?
                          - Godfrey
                            Congratulation .
                            You meant capacity or voltage? Because we are able to charge 12V battery with 3V source with radiant method.
                            I have two way to charge a battery
                            - the top is for conditioning (almost never do that because the bottom one also do it)
                            - the bottom for everyday charging
                            That is weird, what is the current consumption?
                            Yes, that is the way to save transistor. But I don't think we need that. Putting a diode like that kill the radiant and waste them.
                            More importantly, it force the coil to draw more power. Notice that the coil consumption will at least double if you do that. Current consumption on a radiant circuit will usually increase if you utilize or diode short the radiant part. My stingo do not but self oscillation terminate instead.
                            I came across some images of yours that also seem relevant to our discussion. Can you tell where to find your original thread describing them?
                            Here
                            http://www.energeticforum.com/40036-post2096.html
                            still learning at that time, still wondering now, but I believe that is the flow.
                              Hi Sucahyo,
                              I meant capacity.
                              That's incredible! Haven't seen anywhere near that kind of performance yet.
                              Is this the finalized circuit for your 'Stingo'?
                              That is weird
                              Really? I thought that was a common phenominon of radiant circuits. Just to clarify, I'm using 'cool' here not to mean cold, but complete absence of the typical warmth a circuit develops after running for awhile. My basic Imhotep circuit runs continuously for many days without developing any apparent warmth in the relay, etc. at all.
                              Haven't measured current yet on my multimeter during tests so far. I'll let you know how that works out when I run my next tests.
                              Sorry, I'm not quite understanding. Are you saying the Stingo circuit doesn't protect the transistors with a diode? What mechanism terminates the self oscillation?
                              Here is my proto board w/terminal strips:
                              I decided to start by trying some basic configs (before incorporating your cap/pot idea).
                              This is the first circuit I've been testing (not an approach you recommended, but wanted to rule it out):
                              Here is a diagram of the terminal board:
                              This time the coil worked. In fact, disconnecting the coil turned off the circuit. But the results were mixed. The neon does not light in test mode. I can't get a neon bulb or CFL to light if attached to the Charge Battery leads. The spikes seem to occur, however.
                              It's difficult to measure results. Got any tips for detecting radiant spikes?
                              - Godfrey
