-   -   Bessler wheel of the 21st C (http://www.energeticforum.com/renewable-energy/6141-bessler-wheel-21st-c.html)
Matos de Matos 07-28-2010 02:35 PM
Hi everybody:
The auction for the lock combination starts at 100 million €.
The act will take place here at Energetic Forum in a few days.
Don’t lose it.
Meanwhile I would like to hear your opinion on the Bessler wheel.
Thank you
David
http://2.bp.blogspot.com/_nDqIuKRvky...ed+Bessler.JPG
broli 07-28-2010 02:44 PM
My initial bid will be 1 googol €.
Here's my opinion. 300 years is not a nice round number for it to be rediscovered. 666 years sounds much better.
Matos de Matos 07-28-2010 02:51 PM
The intention was to include a poll but I couldn’t manage it.
The poll would be:
A - It is a big watch?
B -It is a over unity
Ps: I am working on the same set up that i published, http://www.energeticforum.com/renewa...how-i-see.html just more tecnological advanced!!!:thumbsup:
It will be ready in a few days.
Matos de Matos 07-29-2010 03:59 PM
Bessler 21st C unlocked
Hi everybody:
Humanity needs this machine more than I need money, and believe me; sometimes cash is short in this side.
I do not have the conditions to prototype it, so I expect that you guys will understand it and try it out.
The two wheels with the angled weights are two pendulums, in the same shaft, same direction of rotation, out phase 180º, Bessler concept, where the two pendulums drive the shaft.
When one is working, the other one starts descending, balancing out.
This adds momentum after one of the wheels hits the sliding pendulum.
The wheels impair a force on the sliding pendulum, changing its trajectory to a small radius, pumping it.
The two wheels rotate in one direction, the sliding pendulum opposite direction and at same RPM.
The force need to pump the
Please spend some time analyzing it, because I believe that the combination of the components is tuned to give acceleration after hand start.
I offered the idea; will you presented the world with a prototype?
Thank you
David
http://4.bp.blogspot.com/_nDqIuKRvky...v4/s1600/1.JPG
http://2.bp.blogspot.com/_nDqIuKRvky...KU/s1600/9.JPG
http://4.bp.blogspot.com/_nDqIuKRvky...s/s1600/4a.JPG
http://4.bp.blogspot.com/_nDqIuKRvky...c/s1600/8a.JPG
http://1.bp.blogspot.com/_nDqIuKRvky...I/s1600/6a.JPG
http://4.bp.blogspot.com/_nDqIuKRvky...0/s1600/5a.JPG
http://4.bp.blogspot.com/_nDqIuKRvky.../s1600/10a.JPG
broli 07-29-2010 06:01 PM
It's novel I'll give you that. And good luck finding someone to build a prototype of it. Ideas there are plenty, builders there are little.
Matos de Matos 07-29-2010 06:50 PM
It is two pendulums 180º off phase that powers a parametric oscillator third pendulum.
They are on the same shaft, counter rotating.
I think that the gain with the parametric pumping will be superior to the force needed to keep the two pendulums off balance that are winging their weight on the third pendulum reducing its trajectory… and cycles again.
All the forces all in the same direction, transformed in different reference frames, and exchanged linearly thru the same shaft.
Unfortunately I do not have the conditions to build a prototype.
It is Beesler´s legacy that may be solved, deserves an international campaign for prototyping.
David
Michelinho 07-30-2010 05:21 AM
Hi Matos de Matos,
I am wondering how you will be able to support the counter rotating pendulum shaft in that position at the heart of the machine as drawn. Since it is spinning and sliding with all the inner space surrounded by moving parts, the offset would drop below the other shaft (no support as drawn) and it would not work. The concept is valid but building it would involve a lot more parts with added complexity.
Take care,
Michel
Matos de Matos 07-30-2010 08:35 AM
Originally Posted by Michelinho (Post 105855)
Hi Matos de Matos,
Take care,
Michel
Hi Michel:
I am drawing as we go, and other opinions are important to correct it.
You are right, and I think that changing the bearings to the inside of the shaft will do it.
Check the attached.
David
Attachment 6153
Michelinho 07-30-2010 07:28 PM
Hi Matos de Matos,
Yes, that is the way to make it work. Keep refining the drawing till you are confident that you have a smooth working design. Hope you can find someone to build it or go for it.
Good luck,
Michel
Matos de Matos 07-30-2010 09:18 PM
Originally Posted by Michelinho (Post 105916)
Hi Matos de Matos,
Good luck,
Michel
Thanks Michel for the support.
Did you see
http://www.energeticforum.com/renewa...tml#post105923
David
