-   -   gravity waves found (http://www.energeticforum.com/renewable-energy/5690-gravity-waves-found.html)
david lambright 05-06-2010 06:12 PM
gravity waves found
this wave is what heat and all EM spectra travel on. if 2 candles are placed 180 degrees apart on a disc, the flames point towards the center of axis, away from the artificial gravity created by spinning. an energized PMH [leedskalnin] is spun,and artificial gravity over 1G will push the orbit of force out and since magnetic current flows to metal , dense metal like gold held at plane,now this force streams off bending light like a heat wave!...i will post a video as soon as i can. i have unlocked the mystery! check this out..if you hold a metal weight over the center of mass, its weight increases! this model works...more soon. p.s. i do have the only working model, i need to share this with the world!
Xenomorph 05-06-2010 06:33 PM
Go ahead. Many people are probably curious to see what you claim here.
nat1971a 05-06-2010 09:11 PM
wow!! can't wait for the video
thedude 05-07-2010 12:28 AM
:welcome: to the Energeticforum David! Looking forward to seeing what you have to show. :) Sounds intriguing.
david lambright 05-07-2010 06:27 AM
i figured out leedskalnins generator
i figured out leedskalnins generator ,but i can not get the video posted!..any way check this out- when i aim my laser at the device,from 10 feet away, i can feel a force pushing back !! in the video i will show that this force can be seen and it is distorting light like a heat wave..you will see it too as soon as i figure out how to get this video posted...tonight hopefully.
sebosfato 05-07-2010 06:34 AM
Hi david
try youtube
Best luck to you
Harvey 05-07-2010 06:58 AM
You definitely have our attention :thumbsup:
rave154 05-07-2010 04:34 PM
This sounds FASCINATING :thumbsup:
Joit 05-07-2010 04:39 PM
you can post at Home - EnergeticTube.com*-* Where technology goes LIVE!, i never got Problems there,
but maybe you use a *flv format, not sure if mpeg works.
Freezer 05-07-2010 06:16 PM
If you need any help posting the video people here can help. Let us know what programs you have and formats you are using. I'm sure everyone here is interested in what you have described, sounds very intriguing. Sounds like your device can focus chi energy..
Uploading videos to youtube-
Uploading Videos - YouTube Help
Youtube tricks-
10 Youtube URL Tricks You Should Know About
uusedman 05-07-2010 07:51 PM
Eagerly awaiting your video post. This is amazing.
elias 05-08-2010 06:05 AM
I have always thought fire is something that moves opposite gravity and maybe this proves that there are too kinds of streams involved here and stream downward which we may call gravity and a stream upward, which Schauberger called Levity.
amir shah 05-08-2010 07:48 AM
...if 2 candles are placed 180 degrees apart on a disc...
Would you detail a description of your experimental set please?
disc diameter
distance between candles
is the disc spinning?
at how many rpm?
are the candles directly fasten onto the disc?
which material is the disc made of?
thank you
amir shah
Harvey 05-08-2010 08:18 AM
Doesn't the spinning flames leaning in simply demonstrate that artificial gravity produces the same effects as mass gravity? After all, heat rises only because cooler air sinks in a gravitational field. IIRC, growing plants exhibit the same response. So it does not surprise me that the new vector produced by two gravities, (natural and artificial) pulling in different directions, would result in the leaning nature of the plants and flames.
A couple of years ago I posted this video called the Plasma Puzzle where cold plasma leans away from gravity where convection is not involved. This experiment was hard to produce because it required a specific spiral vortex in the stream to demonstrate the effect. That particular device was returned because the plastic overcoat peeled off and the new one does not give that tight spiral. I'm sure there are enough of these out there that others can duplicate the experiment.
So I agree that there is some interaction between EM radiation and Gravity that begs an explanation. :)
:cool:
david lambright 05-08-2010 09:31 PM
gravity waves found
here is the link..http://www.youtube.com/watch?v=rGNY0yJBmds...i know ...i am making another video as we speak..more soonest
david lambright
rave154 05-08-2010 11:21 PM
David,
thanks for the video, ( i know myself the difficulties of posting videos, getting the right codec etc etc blah blah )...
in your video, when youre holding the two peices of non-magnetisable metals either side of the spinning PMH and you say you can feel a repelling force.......could you tie a piece of string around one piece of metal.....start the pmh spinning....then slowly bring in the metal hung on the string..and hopefully show the outward deflection on the cam?
Also, It was hard to see/understand what you meant when you were using the laser pointer.
Hope this helps,
David. D
Harvey 05-09-2010 12:23 AM
david lambright
I will need to see a better video - perhaps it is my monitor but I could not see what was being demonstrated, even with the brightness up. It was hard to understand what exactly was being shown. This may be do to my lack of study of Ed's work which for me is very superficial thus far.
You say you can see the energy - in what form do you see it?
Thanx for sharing your discovery with us :)
Joit 05-09-2010 12:53 AM
Hi there,
For the Holder, it doesnt really matter, if its one or two Coils, only the Force will be stronger, so far the Coils can close the Circle.
Your non magnetic Material, i think, it induces eddy current in it, that is, what you feel as force.
At all interesting Video, maybe need some more thoughts on it.
dambit 05-09-2010 02:31 AM
David L,
Your enthusiasm is admirable however the resolution of the video is so low I can hardly make out what anything is. Also titanium is a low density metal, maybe a denser metal would be better suited, lead or maybe even mercury.
Cheers,
Steve
david lambright 05-09-2010 08:33 AM
crummy video quality
sorry about the video quality...i am making another one ,i promise HD quality,while you wait I will describe the last video. There is a swirling vortex of energy in between the generator and the steel cylinder i am holding. when i feel the cylinder start to pull down this force seems to get more visible[swirling vortex]. every one who has seen it says the same thing, like a "heat" wave. there are no wires, batteries and there are no magnets. there is an unseen force at work here. this force bends light!! think about it-- what else bends light? there is a cold energy field all around the generator,i will try and rent a FLIR camera to get a clearer image of the field. if i hold the cylinder at 10 degrees off center, it seems to continue spin! if i hold the non magnetic metals on each side of the generator and move one of the pieces, the other piece reacts [moves].this force is not at all localized. crystals are going play an important role with this energy field. i was playing with some crystals near the generator [garnet,quartz,rodonite pyrite etc.] they all react in this field and exhibit polar alignment. the laser is a bit strange...from over 10 feet away, i can feel the push of force when laser is pointed at the generator. this is the lowest wattage laser [diode] that is made. my brother Ben [masters degree in physics] has access to a higher wattage laser....experiment time!! i wonder what pyrolitic graphite or bismuth is going to do? hmmmm. also ferrofluid -- when a small container is held over axis, a vortex forms in the fluid!! remember this generator is made from junk from around the house! ... one mans trash.....the bottom of the generator is an old sander housing[stator removed] for the bearings. there is a disc of nylon[cutting board]that the 24 segments mount to. the outer ring is made of 12 two inch pieces of inch and a quarter pipe. i then split the sections in half=24.i had to squeeze the sections in a vice -to get 24 pieces around the nylon disc. only 4 sections are attached to the disc, the rest are held in place with duct tape and zip ties. it is not balanced and the sections are uneven.....and works!....i know that a precision machine will do much better. please be patient i promise you will NOT be disappointed....thanks.
broli 05-09-2010 08:47 AM
I think a lot will be wanting to replicate, the setup seems simple but you need to elaborate more on it. If you are going for HD videos can you make a separate video on the setup it self preferably using day light for clarity. Thanks for your understanding.
I assume that the pull is proportional to spin? If it can already bend a laser at such low rpms then what can it do at 1000's of rpm.
david lambright 05-09-2010 07:03 PM
last nights expirements/discovery..
because this wave is the underlying force for all other wave forms, physical laws dictate that it should behave like all wave forms! ...so i tested this... and it does every thing.. i tried reflecting this wave and it does reflect...so physical laws dictate that it should be direct-able via fiber optic cable and yes it does ..i took a fiber optic cable and held one end at the plane and the other end at the opposite side and i feel a pushing force .. this wave must adhere to all physical laws governing light.. focusable, reflect-able etc. if it does not ,then it is not what i say it is ... but it does!!..this wave will do any thing any other wave form will do...think about this carefully for a minute..sound can manipulated to form a standing wave.. so according to physical laws this wave MUST do that too!...and it will..any minute now,someone following leesksalnins work[build a generator]and will test this and it will be proven!..this wave MUST follow all laws governing all wave forms and it will!! and all EM wave forms... ed was right and levitation is the next step and will not violate any physical laws .math will prove this theory..take all we know about EMF and we can predict what will happen!...happy mothers day!! PS..the candle experiment i saw on youtube ..just to show convection is anti gravity artificial or natural...questions????.... PMH+parabolic reflector... think about that for a minute......david
uusedman 05-09-2010 07:11 PM
David you have got a lot of enthusiasm. Can you please make a video of the setup and another of video of the experiment? Also, possible a video of a conclusion of the experiment.
Thanks in advance for sharing.
Jetijs 05-09-2010 09:09 PM
Hi David.
Thank you for sharing your work!
I have been researching Leedskalnin for some time now, I have also built several PMH's. Can you elaborate more on how the energized PMH is attached to your rotating disc? Also I did not fully understand your cut pipe segment setup. Can you elaborate more?
Thank you
:notworthy:
CLaNZeR 05-09-2010 09:45 PM
Hi David
Look forward to a clearer video.
Can you post some pictures of your rig?
Sean.
Cloxxki 05-09-2010 10:18 PM
David, thank you for coming forward and crediting this invention to Leedskalnin. This lends great credibility to you research.
I am subscriber to your Youtube channel, and greatly look forward for you to help the capable replicators on here to let them do their think.
If this wave and the technology that will come from it, obey laws of physics, does this mean that simple formulae will offer us the power required to generate full lift-off in say, a personal vehicle? And a second, 90 degree angled force, would propel this vehicle horizontally at 1g initial acceleration?
Again, thanks for coming forward. If you are right, you'll be one of the greats of modern time.
All the best from The Netherlands
J
rave154 05-09-2010 10:47 PM
cant wait to see more from David Lambright,
this leedskalnin / phm magnetics / levitation connection is starting to make a bit more sense to me now. :thumbsup:
David, we dont know what your schedule or time available is etc, but if you find time, could you document / diagram exactly/precisely what your pmh is, ie... direction of windings of coils, connections, etc etc... be specific ...youll only have to it once, then everyone will be able to replicate precisely without confusion.
re:- the pmh details, the reaso ni ask for you to be very specific regarding winding directions & connections is because obviously with two coils there are multiple ways of winding them and also connecting them up together etc.
David.D
Harvey 05-10-2010 05:33 AM
So David, if I understand what you are saying, you see light disruption similar to heat waves on a hot road, but they seem to be leaving the wheel and moving outward, right?
Also, you say you feel pressure on the laser pointer?
The wheel construction is Nylon cutting board (or HDPE probably?) and metal water pipe on a sander housing and bearings? No coils or wires or magnets, just a spinning disc with sections of pipe right?
Just trying to fit all the pieces together in my mind.
If I know Sean, this will be a fun thing to reproduce :thumbsup:
Looking forward to the progress here.
Cheers!
:cool:
david lambright 05-10-2010 08:38 AM
david lambrights photos and description
david lambrights photos....the copper wire is 14 or 16 ga transformer wire about 10 turns...when energized,9.6v dc,this configuration starts to emanate a wave that looks like heat...when spun,the extra g force seems to radiate at the plane and drawn in at the poles....try it and you will see this wave for yourself.....more soon..the photo is on energetic tube under david lambrights photos and description....thank you all.....david
CLaNZeR 05-10-2010 08:56 AM
Sorry David I am confused, where are the photos?
You can insert them on your posts.
Sean.
