Electric Field
  • Electric Field
    Why is it that we have essentially abandoned the electric field. We commonly make use of the magnetic field even though it constantly requires current to maintain yet here is the perfectly good tool which does not require anything to maintain it.
    You create a dipole or a monopole and there is an electric field however because of the way we design mass capacitors it is not easily accesible. By throwing away the electric field you loose the ability to do such a thing as polarize a near by conductor.
    By combining the ability of an electric field to polarize with cheap switching and an lc oscillator you have the ability to get something for free many times from one charge.
    I am no wizz on electrostatics and so could be wrong. If i am please speak up.
    Damo
    Amazing
    29 Views. Either what i posted is correct or it is so wrong people cant be bothered pointing it out.
    Damo
      I guess your post is so general, it is very hard to say something useful about it.
      You are right, tough, that there is energy in the static field. Prof. Turtur calculated the energy density of the static field, as I posted here: http://www.energeticforum.com/renewa...html#post77862
      However, it is not that easy to harnass. There's always Murpheys law.....
      So far, it appears that Bedini's charging methods can create a non-permanent electret inside a battery or a capacitor. It appears that gives you a static field you can use.
      I have posted quite a bit about this electret or dielectric relaxation effect.
      So, I don't think we have abandoned the electric field. The problem however is how to use it, without destroying the dipole that creates it, which is the single most difficult and important problem. You may want to look into Bearden's stuff, as I posted here:
      http://www.energeticforum.com/renewa...html#post75378
      Hope this helps,
      -- Arend --
        Destroying the Dipole
        Hi Lamare
        Not destroying the dipole is easy. If you have a + charge and bring a conductor near it the loose negative charge on the conductor will move closest to the + charge and the far side will become + charged. If you have a + and - charge that is a dipole this effect still occurs when you bring a conductor close to it.
        If you charged a capacitor you have a dipole however because the off the shelf capacitors typically make using the electric field surrounding it very difficult doing the above is impossible.
        What do you do? You make your own capacitor consisting of flats layers making the electric field avalable. Now bring a conductor close to the charge capacitor on the positive side of it and the conductors loose electrons will once again be attracted to closest to the positive charge and the positive charge will be repelled to the far side.
        Essentially this is what is occuring in electrophorus except a monopole is being used and the charged is fixed to the dialetric. When they explain electrophorus they say that even though you can repeatedly charge the top plate for free you still have to pay for lifting the panel up to discharge it. Sure thats one way of doing it.
        Lets automate all of this. We make a flat capacitor consisting of a metal plate a dieletric and a metal plate. Now we can charge it and discharge it. To automate this task we put it in an lc circuit. Ok so now we place a dialetric on top of the cap and essentially make another cap on top of that consisting of a metal plate a dialetric and a metal plate. We connect the two plates of the top capacitor together with a wire and a relay. When the bottom cap is charged we close the relay. The electric field forces the - charge to the bottom plate of the top and the + charge to the top plate of the cap. Now we open the relay and discharge the bottom cap. Now you can place a load across the top cap.
        I hear you say but you just discharged the bottom cap to turn the top cap into a dipole. Sure that would be true if you blew the bottom caps charge on a load however if you hook the bottom cap up to a inductor you have an oscillator.
        So the process is charge the bottom cap close the top cap relay discharge the bottom cap into the inductor utilize the top cap in a load now discharge the inductor into the bottom cap and repeat the process.
        For every charge of the bottom cap you can get many discharges from the top cap. If this process is correct it should be scalable.
        Damo
          well
          in my opinion electric field does not comsume that much energy as magnetic field so with no energy consumption there is not curent folwing so meter is not turning and our gouverments dont make money so its not practical right ??? al least for gouverments !!!
          and now imagine that you have engin that uses only the electric field but no current !!! you dont pay anything yet still work is done !! no more energy addiction and energy slave!!!
          and now use youtube and search static motor and yes this motor uses potential or voltage to run its just a prototype made by hobbist but its proff that this concept works ... but this would destroy our gouverments !!! no tax from energy ...no co2 tax etc... so noboody wants to touch it... or when tryies is stoped ....
          thats my point of view
          cheers from poland
          wojsciech
            Dipole
            I think, the Counter for this Thread do a Break.
            The EM Field is not to easy to tap in, and it has less power and low Pressure,
            when you only try to collect it, thats why most dont consider it.
            What in Batteries happens, i think its more a Event at a small Scale,
            and the Polarities interact closer in there.
            Last Times i did look some closer at the Tpu, and some Observations around the Vacuum Tubes, and it seems, the better Effects yoiu can get there is with Heat and right Plates, where the moving Current hits out more Electrons
            from the Plates, what creates an Avalanche Effect.
            And well, i think a Dipole is like a Origami Star.
            http://www.origami-kunst.de/galerie/...gami-stern.jpg
            Try to count the Stars, what are nested there, lol.
            But some Angles from the Corners match pretty well, to what i did observe.
            And when i compare Ferrofluid with this Forms, it even makes it logical for me.
              Picture Thousand Words
              Heres a picture to help. The bottom and top caps are not off the shelf caps. The setup requires the electric field and so you need to make your own little flat caps.
                Wimshurst
                Seems well worth investigation I'll be getting a wimshurst generator in the new year to research static electricity, and looking to make my own pre polarized Electret capacitors, just gotta experiment with slow setting dielectrics and disolvable electrolytes.
                  In the Know
                  I would really appreciate hearing from those in the know on the topic. Peter, Aaron, where are you. It just seems to simple and it is more than likely i have overlooked something which i virtually always do
                  Damo
                    Excellent
                    Excellent inquorote that would be good if you built it as well
                      Schematic incorrect
                      Sorry got the schem wrong. The top and the bottom layer are not directly coupled by a conductor but instead by the electric field
                      Damo
                        Response
                        Well i have to be honest given what might be such a simple method that utilizes textbook physics to produce extra energy I am quite surprised at the lack of enthusiasm, input or response.
                        There is nothing new science wise in it just a different way of organizing things. I thought i would of atleast heard from those who are familiar with the science.
                        I dont know just seems weird this whole forum is based on find free energy.
                        I am sure the idea must be wrong which is why i want to hear from someone whos in the know.
                        Anywho's
                        Damo
                          At the risk of being unpopular..
                          There are 4 types of people in the world - and this forum -
                          1 those that think
                          2 those that do
                          3 those that think and do
                          4 dissenters, and distracters
                          We're in short supply of number threes, but plenty of ones and twos. Luckily we have a shortage of 4's but they're here
                          To be fair Dmonarch, we need to show results and documented experiments to sway the people willing to donate their (valuable) time and effort to join in research of any phenomena.
                          It also takes time to 're tool' so to speak, and change direction and mindset.
                          Baby steps are the order of the day.
                          Love and light
                            True
                            Well put inquorote. I guess i need to make it reality now. Was just hoping for some input first. I guess thats just the way it is.
                            Damo
                              2 + 2, in theory
                              Electrophorus - Wikipedia, the free encyclopedia
                              Wimshurst machine - Wikipedia, the free encyclopedia
                              Electrostatic Motors & Generators -- Patents List & 6 Articles
                              YouTube - Water drop generator drives electrostatik engine
                              It'll make for some interesting experiments
