Today guy have a big surprise for u. I built a Radiant Energy Circuit simply with a 555 timer and with Power or filament transformer. Then i charge this powerful circuit to 100uf 250v cap surprising it charge way beyond the limit 350v+. Next i discharge cap into eletromagnet designed like Stan Deyo, but the bottom coil is winding vertically and the two separate coil are in series. To prove this electrogravitic propulsion i show a video with plastic cap on it being push off by the powerful magnetic field can be see on youtube. The schematic is on the bottom simple. Important factor like Tesla play close attention to resonance when charging a low and high cap size like 10uf 470v or 2200uf 63v the circuit won't charge it quickly or crate stronger thrust than 100uf 250v. I believe high volt on cap can increase effect, but plate size must be in resonance with transformer like Tesla Coil. Also frequency is important if change cap to 555 timer .39mfd 630v it will change the frequency from 500hz range to lower or higher ranges
Part list
-555 timer
-1k & 2.2k resistor 40/60 duty cycle
-330 resistor for LED (Signal light)
-Filament Transformer with Center Tap 6v .04 amp (you can use other transformer but it need fine tuning to charge cap quickly
-Ceramic Capacitor 39mfd
-NPN transistor ( I used NTE36)
-(Optional) NTE2389 MOSFET i discharge the current into NTE2389 haven't due test to see if make a difference
1N4007 diode (Optional) ultra diode NTE576
Plans
Plastic cap shoot off coil
YouTube - plastic cap jump to magnetic field
Part list
-555 timer
Plans
