I was getting ready to perform some experiments with HV to try to build something like a gray tube or at least I wanted to study the effect if possible, but before I even got to doing any of the experiments, just testing my power supply I observed something totally unexpected.
My HV power supply is just a car battery, 555 timer, and a flyback transformer. So I connected everything up and to make sure everything was working I wanted to just check the air gap discharge from the flyback transformer. So I held the negative terminal of the secondary where it was insulated in my fingers, and brought the exposed part of the wire close to the hv terminal. I didn't have my fingers anywhere near the HV terminal and the wire was well insulated, but as the discharge happened I noticed a fairly strong vibration in my fingers where I was holding the wire.
By the way, a flyback transformer internally has diodes at every layer of the windings, so each diode doesn't have to withstand high voltages, and as a result the output is uni-directional. That's why I figured the negative side would be relatively safe.
I could just hover my fingers very close to the wire and I could feel the vibrations just as strongly in the air. It felt like I had been holding a magnet over a coil that was oscillating. I can't be certain that the force wasn't in fact electrical, but it was not shocking, it was just tingly, like holding an electric toothbrush, or something.
I don't understand, why would this happen on the negative terminal? Why could I feel this so clearly even through the insulation?
I just tried replacing a segment of the negative terminal with about 8 inches of 1/2 inch aluminum round rod. I was too afraid to touch the exposed surface to see if I could feel the effect, so I put a few layers of clear packing tape, which I've learned is a pretty good insulator. I could still feel the effect in the area surrounding the rod, while I was discharging into the rod.
I'm going to try to learn more...
Any ideas?
Any ideas?
