-   -   The Physics of the Primary State of Matter (http://www.energeticforum.com/renewable-energy/3781-physics-primary-state-matter.html)
Bodkins 02-15-2009 02:33 PM
Please read
Karl Schappeller The Physics of the Primary State of Matter
MEGAUPLOAD - The leading online storage and file delivery service
you need to put in the code at the side of the download button
also
A Treatise on Astronomy - Google Book Search
by Herschel
Please Read some
The Plant Im sure is Algae if this is the case making anything out of nothing is possible.
Enjoy:thumbsup:
The Motive(Spirit) Is Here
Bodkins 02-15-2009 03:12 PM
If You cancel out stressfields you could move Large Block of Stone:thinking:
Bodkins 02-17-2009 02:18 PM
Missing page 112
Ether is a carbon static potential it is a homogeneous mixture of its two components, Hydrogen and Oxygen energy.
If stressed between two potential differences the two componets (as in magnetism)North (Hydrogen energy) and South (Oxtgen energy) we have suction, attraction to the centre which it carbon in the steel rod!
EVERYTHING is made using this process the Trinity of the Three H and O Plus the carbon static potential all matter comes from this place.
Like a number eight on its side 8 the center is the stressfield Meeting.
All magnetic action is indepentent of pressure of air and occurs also in the vacuum. So magnetism is a state of space devoid of matter.
i.e. A state of the Ether
Aristole held that the four elements had two qualities, either hot (Hydrogen energy)or cold (Oxygen energy) PRIMARY PHYSICS and wet or dry (Secordary or Present Physics).
Earth is cold and dry;
Air is hot and wet;
Fire is hot and dry;
Water is cold and wet;
If you cross the stressfield of H and O this changes the Secordary or Present Physics
Fire crossing the stressfield of water,water is a resistor the water will boil.
Arron Understanding so for!!
I think by your description of the stressfield, what I see it is..is like this. You take a ball and put in in a bathtub. The ball displaces volume of water (aether). The water tries to rebound back towards the center of the mass that displaces it pushing back on it from all sides. That is what holds the matter together. The universe is pushing back onto the matter from all sides. That is microgravity. On the large scale...Earth for example displaces a certain volume of the aether. The aether tries to rebound back to the center of the mass. As it does, the positive potential of the ather pushes on the positive charges of the atoms that make up mass pushing them in the direction of the center of the mass...when the aether gets to the center of the mass...it is so dense that other "particles" are created...such as electrons and those rise to the surface of the Earth like artesian water. That is the cycle..otherwise if nothing came back up, it would be equilibrium and would just stop and there would be no gravitation effect.
One last thing we have a problem with some of the pages Missing if anyone Has a copy of the book or anyidea where it maybe found please look for page 112
Take Care
Bx
Bodkins 02-17-2009 03:18 PM
Algae
In 2005, the Woods Hole Oceanographic Institute announced the results of research they'd done on certain bacteria that are known to carry magnetic crystals. These are called magnetotactic bacteria. In 1970, magnetotactic bacteria were also discovered in the Southern Hemisphere whose magnetic crystals were flipped around. The purpose of these tiny internal compasses has never been known, but since the 1970 discovery, the working hypothesis has been that they use the compasses to help navigate either up or down to find water with the best oxygen concentration. This would be consistent with the need for the polarity to be reversed in the Southern Hemisphere.
Alas for the pond magnet manufacturers, Woods Hole's research found that north-polarity and south-polarity bacteria are both found intermixed in both hemispheres, and also that there are numerous individuals who lack the crystals completely. All three types of bacteria navigate equally well to the water depths with the most desirable oxygen levels. The conclusion of the research is that the purpose of the magnetic crystals remains unknown, but it's clear that its reversal or even its total lack makes no difference to the health or life cycle of the bacteria. And, once the bar magnet was removed from the microscope slide, the magnetotactic bacteria realigned themselves normally with the earth's magnetic field, according to the polarity of each.
Cladophora glomerata (L.) Kz. was grown in Jaworski's algal culture medium and exposed to a fluctuating electromagnetic field which induced development of dark colouration, increased density and brittleness, After 4 weeks exposure, algae were unable to grow when transferred to unexposed culture medium. In addition, algal growth in culture medium exposed to a fluctuating magnetic field before the algae were introduced, was inhibited significantly compared with an appropriate control after 4 days, indicating a transfer of effect from the brief exposure to a magnetic field of less than 1 second to the 4-day period when growth was active.
wpage 02-18-2009 02:04 AM
Good reads
Bodkins,
Thanks for the links...
Was there nothing more current than the 19th century book on elemental astro physics:) :)
As Sherlock Holms always told Watson. "Elementary"
Bodkins 02-18-2009 08:32 AM
Chinese Space Seeds
Evidence; of stressfield interaction
Space Vegetables - NATURE archives - MDG 2008-09
Futuristic greenhouses in southern China give birth to 15-stone pumpkins - 10 times their normal size - 160lb Chinese winter melons, chilli plants the size of small trees with fiery 9in-long fruit which look more like exotic peppers. Alongside are 14lb aubergines, 2lb tomatoes and 2ft cucumbers.
Scientists have yet to offer a definitive explanation of why space causes the seeds to mutate but they believe that cosmic radiation, micro-gravity and magnetic fields may play a part, but beyond that guesswork, there's seemingly no reason that space seeds should be a miracle food. Our MINA correspondent, a physicist, believes micro gravity plays a major role.
The scientists dont see it at all, so no wpage.
but you can see evidence if you look for it, and the evidence is not for the places you may think?
YouTube - Jeff Buckley - Hallelujah
and a great brother of mine made this, hes reading the Book.
YouTube - How Bacon Saves The Universe - 1
YouTube - God Particle to God Field - Ultra Zoom - How Bacon Saves The Universe - 2
Bodkins 02-18-2009 09:16 AM
Ether
This short and cryptic text was highly regarded by European alchemists as the foundation of their art, in particular of its Hermetic tradition.
1) This is true and remote from all cover of falsehood.
2) Whatever is below is similar to that which is above. Through this the marvels of the work of one thing are procured and perfected.
3) Also, as all things are made from one, by the consideration of one, so all things were made from this one, by conjunction.
4) The father of it is the sun, the mother the moon.
5) The wind bore it in the womb. Its nurse is the earth, the mother of all perfection.
6) Its power is perfected.
7) If it is turned into earth,
7) Separate the earth from the fire, the subtle and thin from the crude and coarse, prudently, with modesty and wisdom.
8) This ascends from the earth into the sky and again descends from the sky to the earth, and receives the power and efficacy of things above and of things below.
9) By this means you will acquire the glory of the whole world, and so you will drive away all shadows and blindness.
10) For this by its fortitude snatches the palm from all other fortitude and power. For it is able to penetrate and subdue everything subtle and everything crude and hard.
11) By this means the world was founded
12) And hence the marvelous cojunctions of it and admirable effects, since this is the way by which these marvels may be brought about.
13) And because of this they have called me Hermes Tristmegistus since I have the three parts of the wisdom and Philosophy of the whole universe.
14) My speech is finished which I have spoken concerning the solar work.
ren 02-18-2009 09:22 AM
Thanks for the link Bodkins, been looking for the full version of this for some time. :thumbsup:
Read it and re-read it mate, and then grab some others!
Vortex 02-18-2009 01:34 PM
Flower of Life
If PP is the why it is, then the Flower of Life is the how it is, geometrically.
Everything we know of is created using shapes found in the Flower of Life.
This is the way everything works, geometrically.
Every part of the world has the Flower of Life in it's history and it
is the Sacred Geometry of the ancients.
Flower of Life contains the torus, 5 Platonic solids, golden ratio of phi / Fibonacci spiral (vortex / implosion).
Flower of Life
Golden ratio
I claim to know nothing beyond the Flower of Life is very important.
This can not be ignored, the entire ancient world had this knowledge.
(how is unknown ..)
One should study it as to know of the importance.
:thanks: for being
Randy
Vortex 02-19-2009 11:10 PM
Platonic Solids
five special polyhedra — known collectively as the Platonic solids — that are different from all the others.
What makes the Platonic solids special? Well, two things, actually.
1. They are the only polyhedra whose faces are all exactly the same. Every face is identical to every other face. For instance, a cube is a Platonic solid because all six of its faces are congruent squares.
2. The same number of faces meet at each vertex. Every vertex has the same number of adjacent faces as every other vertex. For example, three equilateral triangles meet at each vertex of a tetrahedron.
No other polyhedra satisfy both of these conditions
Interactive Platonic Solids And how to create them.
Vortex 02-20-2009 12:17 AM
Originally Posted by Bodkins (Post 46102)
Just to Get a Idea Of what is Happening with the Ether.
YouTube - Think out of the BOX Primary Phyics
Yes, intersection of circles is a good visual.
Stress is +/-, 2 ways, pressure / suction, expansion / contraction, explosion / implosion. Everything has an opposite.
A triangle is a 2D visual of a 3D Tetrahedron.
A Tetrahedron is a shape, a visual which along it's edges can be drawn spiral or the vortex (pressure/suction).
Here is another visual that is along the lines of PP but is not.
http://www.vxm.com/511.10.GIF
I'm just looking, as you are, for a way to visualize this.
A way to wrap your head around the information.
I'm way behind you right now in reading. I got side tracked.
The Star Tetrahedron is said to be behind the 19.5 degree forces found on planets.
http://www.psychicchildren.co.uk/Gra...ii19-5Grid.jpg
sucahyo 02-20-2009 05:41 AM
What do you think about chinese 5 element?
http://en.wikipedia.org/wiki/Five_el...ese_philosophy)
Bodkins 02-20-2009 07:37 AM
its all the same just different words and styles :thumbsup:
Bodkins 02-20-2009 09:41 AM
Your looking for a way to visualize it yes and if it work for you it will work for many:thumbsup:
but the heavenly bodys are spheres that all Im saying Randy
Your looking from the angle of HOW but if you have got WHY you dont need HOW.
HOW is because of WHY:heartbeat:
Anyway I dont want to get in to this bit yet.:sshh:
Has anyone got a fishbowl?:rofl:
Vortex 02-21-2009 08:21 AM
Don't we all live inside a fishbowl?:D
What's PD? .. I looked at the dictionary in the book does not have PD listed or I missed it
Stressfields / everything wants to be a sphere, as energy, yes.. The Why.
I'm still way behind on reading. I'm doing that now.
We must use matter to build a device that interfaces with the stressfields.
Putting matter into / under stress (potential) allows tapping into, ah, that energy-matter ..
I don't know yet how to say it, what the point is I'm trying to get at,
except no matter except matter in the void (space / air) is a sphere.
All (large) matter takes on a non-sphere shape, the HOW.
We can only see "glowing" energy.
Which brings up a thought / idea, about the energy we can see isn't the same as that we can't see.
It's different. A spark isn't the same energy that travels down a copper wire.
It must change into "glowing" energy state to cross the air, thus we can see it.
What's PD?:confused:
Randy
Bodkins 02-21-2009 08:55 AM
when did i talk of PD? I dont understand the question:confused:
Vortex 02-21-2009 09:23 AM
Defs of PD and viz.
PD is used over and over again in the book about PP
and is not in the list of definitions. The book can not be search for words.
To define something else I didn't know what it was:
* viz. (videlicet) means "namely, to wit, precisely, that is to say".[1] In contradistinction to i.e. and e.g., viz. is used to indicate a detailed description of something stated before, and when it precedes a list of group members, it implies (near) completeness. Example: "The noble gases, viz. helium, neon, argon, xenon, krypton and radon, show a non-expected behaviour when exposed to this new element."
Trying to pour water upon the blazing fire of my Ignorance :D
Randy
Vortex 02-21-2009 09:38 AM
Defs Keeper
PDF page 115, same as, PP page 122
Second to last paragraph uses the word keeper.
What's a keeper?
Is that like the bar you put on a horseshoe magnet?
Bodkins 02-21-2009 09:46 AM
I see Randy:)
Primary Phyics Definition (PD)Cosmos= An ordered system of finite and spherical form,form out of ultra-space
Secondary Phyics Definition (SD)Cosmos=Harmony,any self inclusive charactised by order or harmony amid complexity of detail.
Page 29:blowout:
Arron I waiting for you input, because if you aggree your words have more weight than mine.:whistle:
will get back to you on the keeper going away for a couple of days!
Bodkins 02-25-2009 04:17 PM
What's a keeper?
I think your right on the keeper, will be studying the text again next week if different will update.
Vortex 02-25-2009 05:46 PM
Ref. Link Along right hand side of web page, many ref. links.
... Do not use ‘electrical teaching’ to presuppose ...
... This is a recycling of a stabilized magnetic/electro energy not electro/magnetic
because the field of force is not a case of electrical input, an input that created
the magnetic, but rather a build-up of magnetic energy which caused an energy thrust. ...
... This power source is not predicated on a continuous flow of energy but
predicated on the consistency of the transmutation process of the magnetic
molecular structures within the Earth’s pressure flow.
Sounds like PP (Primary Physics) to me.:rolleyes: :thumbsup:
Strange how I wasn't even looking for this and I found it.:thinking:
Image of interest, makes ya go: ":suprise:, that's different."
http://jnaudin.free.fr/images/magconfig.gif
SCIENCE TEACHINGS ABOUT THE UNIVERSE
MINI-ROMAG GENERATOR
This is the link given above in the quote.
Free Energy Mini Romag Generator: How 50 HP Romag Generator Function.
It's hours since I started this post and I'm still reading stuff at this web site.
Randy
Bodkins 02-25-2009 06:37 PM
:rofl: Nice I like it ! It pops out at you sometimes:thumbsup: ......THATS PP!!!!!
Im still on Algae
http://books.google.co.uk/books?id=xI_500ggNagC&pg=PA428&lpg=PA428&dq=algae+ earth's+magnetic+field&source=bl&ots=eQb62njQwl&si g=5dRy2EFXrsQuQJlxilNXQvt1iyQ&hl=en&ei=goqlSeb6CdS zjAf4vO3OBQ&sa=X&oi=book_result&resnum=4&ct=result #PPA428,M1
Looks like a good book abit pricey
Bodkins 02-25-2009 06:48 PM
Randy
The Mini Romag generator from Magnetic Energy uses the principle of moving magnetic flow named the magnetic current
How To Build a Free Magnetic Energy Generator (Mini Romag) | Free Energy | The Green Optimistic
Bodkins 02-25-2009 07:53 PM
Magnetotaxis in Bacteria
magbac1/01.html
Vortex 02-26-2009 07:02 AM
karlsoen - NEXT PAGE 3
Electrical fields are incompatible with the entire earth system, causing numerous problems. We must and we will stop using electricity in the near future. There will be a shift in the earth's magnetic field that will prevent the generation of electricity. The earth's new polarity will not allow present generators to gather magnetic molecular structures from the ionosphere to form them into electrons.
Maybe it's time to error on the side of caution.
Unsure if cold electricity qualifies as a replacement.
Bodkins 02-26-2009 08:59 AM
The glowing sphere will replace all energy needs because it can be what you what it to be.:thumbsup:
Great research, A very good read :cheers:
Vortex 02-26-2009 09:43 AM
Magnetic Energy To Heal
I shall duplicate a post here.
(source link)
EBook (pdf) Magnetic Energy To Heal The Planet
There are a lot of plans and drawings about:
Magnetic Water Purifier
Magnetic Water Purifier Drawings
Magnetic Water Pump
Magnetic Water Pump Drawings
Magnogen Motor
Magnogen Motor Drawings
Magnetic Current Generator
Magnetic Current Generator Drawings
Magnetic Light Box
Magnetic Light Box Drawings
Romag Generator
Romag Generator Drawings
Mini-Romag Generator
Mini-Romag Generator Drawings
Pyramid Unit
Pyramid Unit Drawings
Magnetic Piston
Magnetic Piston Drawings
Cold Fusion Motor
Cold Fusion Motor Drawings
TiAlCo-B Metal
Celestial Particle Transmuter
Celestial Particle Transmuter Drawings
Magnetic Motor
Magnetic Motor Drawings
Magnetic Heating Unit
Magnetic Heating Unit Drawings
Space Craft
Space Craft Drawings
I just obtained the book. I've yet to begin reading.
I've been reading other stuff than PP as it seems to be rounding off
the edges of understanding of PP .. as then I might better absorb
PP than I was during my initial readings.
Word of the Day: Diamagnetic
:peaceflag:
Vortex 02-26-2009 12:10 PM
Magnetic Spin Reversal Units
Magnetic Spin Reversal Units - Science and Mechanics Magazine, Written by Jorma Hyypia for the Spring 1980 Edition
Web page above Commemorates
Mr. Howard R. Johnson (or Rory Johnson)
June 1st, 1919, – January 2nd, 2008.
an unsung magnet pioneer and visionary
Commentary:
Before Mr. Howard R. Johnson no one knew that a magnet can fire a momentary burst of energy a thousand times greater than its static field strength, repeatedly..... for the life of the magnet; potentially forever. Few people understand that today.
Mr. Johnson discovered that similar magnetic poles can be made to attract, not repel; and that standard texts teaching the patterns of iron filings around a magnet have mislead us about the larger nature of magnetic force fields, which are double helix vortexes of energy.
Mr. Johnson demonstrated that magnets meet all the requirements to be considered an example of room temperature super conductivity.
It is especially important to appreciate that Mr. Johnson did not utilize simple or ordinary concepts of magnetic repulsion and attraction in the design of his magnetic engines.
Johnson designed circuits to evoke exchange forces via sudden spin flipping, or reversals of magnetic forces, which can momentarily produce a reaction with hundreds or thousand times more force than the normal static field strength of the magnet.
When the "spin flipping" reaction is evoked, substantial macroscopic (clearly visible) exchange forces are generated.
Mr. Johnson discovered that through the assembly of magnetic materials in geometric patterns which he called "spin units" or "spin flipping units" such that when exposed to the magnetic field of another magnet in motion, would induce sudden spin flipping, or reversal of magnetic attraction into a magnetic release force such that a momentary and substantial release force would come into existence in the magnet circuit.
By controlling where this occurs in a rotor / stator relationship, this sudden energy impulse could be timed to produce remarkably strong linear or rotational propulsion force(s).
Story by someone that worked on the Johnson motor.
Rory Johnson Gallium-Deuterium Fusion Magnetic Motor
sucahyo 02-27-2009 01:25 AM
Similar prinsiple with kundel magnet?
http://www.energeticforum.com/renewa...ead.php?t=1491
It seem Dr Johnson already wrote a book:
The secret worlds of magnet
Vortex 02-27-2009 05:32 AM
Vacuum + Sunlight = Vortexes .. What?
Sunlight causes vortex motion
We've been told light moves in a straight line, therefore this isn't light, is it.:thinking:
Connect the DOTS.:thumbsup:
Quote Link
Ehrenhaft and his colleague, Ernst Reeger, have proved that there is more than a little truth in the suspicion that tiny particles of dust tend to rotate when exposed to the rays of the sun. For they have not only reproduced this phenomenon in the laboratory, but they have succeeded in photographing it as well. In order to do this, Ehrenhaft placed tiny graphite particles into a glass flask, from which the air was completely evacuated. Then the flask was exposed to focused beams of sunlight. Instantly a large number of particles were seen to rise from the bottom of the flask and start to weave elliptical, circular and spiral-shaped paths, which were quite visible to the naked eye. The phenomenon ceased as soon as the light was weakened or cut off completely. Photographs taken at one-fifth and one-tenth of a second proved that not only were the particles orbiting, but more significantly, they were spinning on their own axis.
It is of interest to note that Ehrenhaft would like to relate the phenomenon to his own theory of a new type of physical force. He suggests that it is a purely ‘magnetic’ force which permeates throughout the known universe.
