-   Water Fuel (http://www.energeticforum.com/water-fuel/)
-   -   JOe Cell research (http://www.energeticforum.com/water-fuel/2757-joe-cell-research.html)
Ozicell 09-19-2008 11:16 PM
Joe Cell research
2 Attachment(s)
At Jetijs suggestion, I am starting a new thread on the subject of Joe Cells in the hope that others maybe be able to shed light on things.
For those who don't know what Joe Cell is..........
It's a Stainless Steel canaster with 3 or more inner concentric tubes. The innermost tube is the cathode and the outer canister is the anode. This device is NOT for hydroxy production but rather the generation of torsion fields.
As at this date, this cell has produced interesting but frustrating results which seem to plague all Joe Cell researchers. On 2 separate occasions I have had my motor idling for up to 2 hours with fuel cut but vapour return line still connected. I have also driven the car fo up to 15 kilomtres with the same setup. The problem is, I can't get stability with it! I can't figure out why it soemtimes works and other times not. :thinking: So that's where I am at with this research. :wall:
Comments and questions are welcome.
swompwalker 09-20-2008 01:04 PM
The science behind the Joe is so far outside the range of the known– perhaps falling within Wilhelm Reich territory – Orgone. Has anyone encased the Joe in a pyramid? It’s certainly an interesting and fun phenomenon
It is said that no one up there in Joe Country actually uses a Joe on a regular basis for reliably commuting or just running about!
ashtweth 09-20-2008 03:15 PM
Oz
Mate look for Bernies research on the JC in the joe cell yahoo groups, he has the easiest stage three procedure mate.
Ps, i have met Joe, :)
He wont tell you jack shyte. It very confusing and frustrating.
boost your ride Bro, JC is R and D:cheers:
Ozicell 09-20-2008 09:21 PM
No I haven't tried this but the cell definitly has a measurable filed around it.
Ozicell 09-20-2008 09:31 PM
Originally Posted by ashtweth (Post 29856)
Oz
G'da Ash,
I have spoken to Bernie quite a bit over trhe last year or so, He's been very helpful as have other JC reasearchers. I have long since given up on Joe as a source of info, I look at his videos and tried some of his suggestions and to tell the you truth, to me it seems like smoke and mirrors. I have found S3 is not measured by bubbles but residual voltage which I have no trouble achieving. I have also found total electrical isolation from the vehicle works far better than grounding the cell to the vehicle.
At the moment I have for the first time in about 6 months, pulled the cell decanted the water - (which was still crystal clear) re passivated the cell and will hopefully be reinstalling it today into its engine bay housing but this time electricall isolated. All my experience so far shows this is the way to go so I am going to try.
The biggest problem I am facing is the changeover, it wants to but there just seems to be a bump in the process that it can't quite get past. Anyway, just one more area of my R & D. The plugs are still on the bench as is other stuff I am doing.
Thanks for the response Ash
Jeff
ashtweth 09-21-2008 01:52 AM
Jeff,
Sorry i missed the part of your post last night, was up late, that's amazing you got it running like you did, that's as far as i ever heard any one getting that i trust :) . This starts to remind me of the Ntiro cell, and how sensitive it is due to certain factors of the engine bay etc. I know wayne personally, this is just some thing to keep in mind, he states for the D18 cell (was not in the original instructions)
Cell must be away from engine block as you don't want electromagnetic mutual inductance from the cell to the engine
outer side of inner tube surface area should equal surface area of inner side of outer tube electric fields must be the same
horizontal tube mount for highway driving
vertical mount for city driving
solid wire roughly 0.2mm one winding around cell
-end
Mate if you have residual voltage form the cell, then perhaps people need to do load tests with other things to see how YOUR particular cell reacts? Is that possible? Given there are so many variables we don't know about the energy, it seems to me that there could be things around your shop like microwaves on or off? or any thing like that?
I know that some machinery effects it (i am told) perhaps its the environment around you:thinking:
Ozicell 09-21-2008 03:29 AM
Originally Posted by ashtweth (Post 29909)
Jeff,
-end
G'day Ash,
I am on several Yahoo forums where the Joe Cell is being research, many of these guys have had success in one form or another! The 9 volt charging has only recently been discussed, I stunble across it my self after days of charging with a 12 volt battery charger, the cell wouldn't retain more than 0.5 volts after 24 hours. I had some weak 9 volts lying around and thought what the heck. I left it on for an hours or so and wadda you know, the charge held. When I posted my findings, a very experienced researcher came out and back me up. He had found the same thing, so then others started looking into it and getting results. When the cell is really conditioned, it will hold a charge of 1.1 volts for around 3 days.
I have just pulled my cell down and am in the process of recharging. It's almost like going back to square 1. Anyway, the groups are as below.
joecellfreeenergydevice : Joe Cell Free Energy Device - Researching the Joe Cell Phenomena
JoesCell2 : Joe's Cell 2
There are plenty of other groups but these seem to be the most active with the leading researchers.
If you're not already a member and you are researching JC's, I'd recommend joining.
BTW I am a LONG way of having a workable cell. When I limped home with fuel cut, I had no power and 20K's was about top speed but it still was going in a manner of speaking. :thinking:
Jeff
lamare 02-05-2010 10:43 AM
I just stumbled across this paper on the Joe Cell:
http://www.soulsofdistortion.nl/down...xplanation.pdf
It mentions the following references:
Joe Cell interview Peter Stevens of Byron New Energy:
How to Make and Run a Joe Cell
Charge compression, implosion physics in water, Daniel Winter:
http://www.soulinvitation.com/watercharged/
Gravitational thrust produced by capacitors which accelerate charge by recursion
http://www.soulinvitation.com/thrust/
Hydrogen bonding and memory effect of water:
Water and its structure
Icosahedral water clusters. Martin Chaplin:
Water structure and science
Icosahedral water cluster symmetry and architecture
Dr. Emoto’s hexagonal water:
Hadolife
Torsion fields, Nikolai Kozyrev:
http://ascension2000.com/DivineCosmos/01.htm
E.H.D. Flying Sourcer, Jean Louis Naudin:
The EHD Fs v2.0
The EHD FS - Computer Simulations
Vortex gravity control, Paul Richard Price, 2004 :
http://www.americanantigravity.com/p...-article.shtml
Source charge problem, Tom Bearden:
http://www.cheniere.org/techpapers/F...0Problem10.doc
Electrogravitics Systems, Paul La Violette
Secrets of Antigravity Propulsion a book by Paul LaViolette
Biefeld-Brown effect:
http://www.americanantigravity.com/Lifter-Article.pdf
Blaze labs research, lifters in the vacuum
EHD Thrusters Research: Lifters in vacuum
The electric universe:
The Electric Universe
Cymatics, Hans Jenny
Cymatics a study of Wave Phenomena by Hans Jenny
Woutje Winkler-Prins and Donave water:
http://www.nulpuntenergie.net/dng/donave.htm
Also see:
Structured water or miracle water
Dan Winter
How Water Accumulates Orgone | AEONIA
Fractal Field Theory - Applied Quantum Fractal Field Theory
http://academysacredgeometry.com/Adm..._Implosion.pdf
phi1.62 10-02-2011 03:51 AM
Jenny Cells
I only found out about these recently:
SubQuantum Etheric Energy (aka Aetheric Energy) Site Home Page
Called a Jenny Cell, they're basically a Joe Cell but use high ormus materials instead of water. It seems to have been around for a few years but there seems to be few people researching this. Use of the cell in automobiles was not the primary intention of it's inventor but the inventor claims that those who have tried the cell on automobiles have seen fuel savings. Thought it would be of interest to Joe Cell researchers.
Sputins 04-23-2015 11:48 AM
A Fairy Tale.. (Or not)?
Once upon a time in the land Down-under, there was/were car(s) running on weird cells invented by Joe. Forever since called the Joe Cell. These cells used charged water, via a mode of electrolysis on the water then charged water was placed in the Joe cell and the output of the Joe Cell went not into the air intake of a vehicle but to the metal block of the engine. A few mysterious tweaks were done, electrical, timing etc. (only known by Joe) were made and the car suddenly runs with all fuel lines disconnected.
An incredible story, or to some just a fairy tale perhaps.
Story of the Joe Cell: https://www.youtube.com/watch?v=mAbuHe9X_cs
Joe himself clammed up on the whole process and wishes to remain that way for the protection of himself and his family, (understandably).
Many Joe Cell researchers have come and gone without much success. Although some success, enough to suggest that something is going on albeit very strange. But no one has been able achieve what Joe could do, or can prove it.
Some say it’s hydrogen and oxygen gas, monoatomic hydrogen, or an Orgone device of sorts. Joe called it a “frequency” and he says it’s not hydrogen and oxygen gas that runs the car.
Then more fantastic strange stories emerge where once a car levitated off the ground but could still drive and turn corners. There are also reports of reduction of inertia. Other reports of people feeling sick or unwell around the device while others report feeling lifted and energised.
Joe on the Levitating Car (edit): https://www.youtube.com/watch?v=pv-yEX_QPBw
I myself have played around with these cells without any or much success. Most of the interest and research from others has also died off because the lack of success from anyone other than Joe.
With regard to the levitating vehicle story, it is a fantastic story indeed. Most would not believe it and that’s fine.
However I would submit this in support of the fantastic story, what Eric Dollard says about the research of JJ Thompson and his lines of force theories.
Eric Dollard on JJ Thompson (edit): https://www.youtube.com/watch?v=kkfiM4fDV44
If one could establish a universal grounding point or universal reference point and ground the car to that, all the lines of force would detach from the vehicle and the resultant loss of inertia would begin to take place.
I do not know the secrets to charging a Joe cell or running a car with it, nor am I currently experimenting with it. (Although I think on the principals often). - I can imagine how charged water (positively, negatively or otherwise) contained within a certain vessel could become a universal grounding or reference point and produce the odd reported effects. Also the work of Gerald Pollack's 4th Phase of Water concepts can't be ignored either, with regard to the Joe Cell.
Food for thought.
BroMikey 12-06-2015 12:34 AM
The truth about the JOE CELL documentary
A phase conjugate geometry, the capacitor of choice.;)
MerLynn 07-31-2019 05:55 AM
How to turn water into oil using a JoeCell.
Videos – MAGNETIC WATER SCIENCE
use the password wizzzard777
Pot head 08-02-2019 12:33 AM
This is stupid
Wwhatss wwronngg?
Double posting is not allowed.
You are spamming and need to stop.
It's not even on topic!!
Any moderators want to remove this post and mine?
BroMikey 08-02-2019 08:12 AM
I thought that was really cool, I want the frequencies
Ozicell 08-05-2019 04:25 AM
Thanks for posting this! :thumbsup:
MerLynn 09-21-2019 04:58 AM
Having met Joe in 1996 and being Joe's friend since, few know Joe like I do.
I have seen Joe tear strips off Peter Stevens for his mistruths about what he says about Joecells several time in person. Peter know almost NOTHING about a Joecell. Following any of his advice will lead you to failure. Joe USES Peter to 'put out there' certain information about Joe's WATER SCIENCE.
I might add that after the first cell was constructed, some one of the group of four who were there in 1992, came back at 2 am and BORROWED the cell and some 2 years later he returned it. Joe just doesnt trust them any more with REAL IP.
Alex Shifflier who wrote the manual for experimenters couldnt have got it more wrong either. Following his advice will also Guarantee failure. Viny pintobrain who used the explanations from these two fake inventors also got it completely wrong. Gawd only knows what a jennycell does.
I was the Video operator for the water into oil demo posted earlier. I have many videos of Joe using his cells for MANY other uses. Im about the only one for the last 20 years to have the video rights to document Joe.
For the Book, I asked Joe to state clearly and concisely, what it is that a JoeCell Does.... his reply, Its a device for changing the Memory of Water. Memory is Frequency. Tesla said Every thing is Energy Frequency and Vibration. Let that sink in people. there are no electrons or protons nor any elements either.
Since the 'car' days of 1992 to 95 Joe has gone on to build many more cells dozens of them. Some so big they need a truck to move. Some fit in the palm of one's hand. No two are the same and in fact they are so radically different from the known design of FIVE tubes of 316L stainless that even that one is not interpreted right. There are 4 ways to connect the DC to the tubecell and ALL Joecells work BEST with a 12volt car battery for DC.
Read this for some understanding of how changing the Memory of (sea) water can make a liquid that one can drink and never eat again....
https://www.ebay.com.au/itm/Ocean-Wh...s/173841889962
MerLynn 09-21-2019 05:00 AM
power blackout double posted...
MerLynn 09-21-2019 08:53 AM
So you think its a Frequency that you require to Transmute Water into Atomic Carbon (the new NASA comet hunters term for what their instruments look for) How is a radio RECEIVER going to change the Memory of Water?
Wouldn't a Wave Form Propagation Antenna powered with Pure Flat-Line Plasma do a better job as per the video?
Here is some of the Data you've been looking for.
Two Electrode Electrolysis verses Multi-Electrode Magnetic Field Generation in Water.
The scientific branches of Physics and Chemistry are based upon this singular experiment that when 2 electrodes are placed in water, which is in fact a caustic solution, the two gases produced are ‘hydrogen’ and ‘oxygen’. This highly publicised experiment as taught to every student in the More progressive western schools, forms the corner stone of Belied that Water is H2O.
To quantify and qualify the Electric Universe Theory, (EU) we need to re-examine this 2 electrode experiment in a liquid solution. We need to look at it from an outside the box perspective and to do so, with an open mind.
Despite the fact one needs specific materials in the electrodes and specific additives in the water, and no mention of voltage or amperage requirements, this singular controlled experiment is hailed as the Holy Grail of the Atomic Structure and constitutes the foundations of all that man believes.
At
http://footbathtruth.com/documents/p...in%20Water.pdf
Is a device with 6 electrodes with DC applied and one neutral.
This “electrolysis” device offers independently verified PROOF that electrodes in water makes impurities disappear. With little to no production of gasses in any ratio that conforms with H2O.
The variation to the above PROOF that “electrolysis” with more than 2 electrodes does other stuff besides splitting water into two gases is that when water is injected with electrons first for 15 minutes then the Food Dye is added and again it fails to mix and “DISSAPPEARS” completely allows independent experimenters to do further experiments upon making ‘elements’ disappear.
The Device that turns water into silver is made with 4 electrodes. Colloidal silver makers use the standard 2 electrolysis electrodes and so the electrodes disintegrate. When 4 electrodes are used in a SPECIFIC electrical power hookup, the wires NEVER wear out and the water tests for silver. Further explanations at; joecellwaterscience.com
These multi electrode “FIELD SCIENCE” experiments are based 25 years of experiments, reports, some certified, video evidence testimony and devices that can be made by anyone and they are even commercially available.
What we have discovered, is that when more than 2 electrodes are powered with DC in an electrolysis like experiment, the water purifies like in the above experiment or it ‘dirties’ like in the silver experiment. NO gases that test H or O. The gases actually test….. Water vapor or moisture. Without heat even, in fact most experiments the container drops in temp.
The types of multiple electrodes (materials and shapes) Orientation to the earths magnetic field, The number of electrodes, and their ratio to Neutral plates effects the outcomes of the waters treated. In fact in most multi-electroded electrolysis experiments it’s the Neutral plates with NO DC hooked up that produce the most bubbles.
Brand new physics.
Brand new inventions
Brand new concepts
Multi-Electrode placements in Water, (H2O) is the new Field Science of Atomic Structure.
Depending upon the device’s polarity in electrode configuration, will see the device either clean or dirty the water. In some configurations with 4 plates and 2 neutral plates with the center positive instead of making H and O it turns the water into OIL see Videos – MAGNETIC WATER SCIENCE password still being wizzzard777
So what do we make of water being H2O by just applying ONLY 2 electrodes to the water giving H and O but when more electrodes and neutrals are added to the vessel of water you get salts/dyes/saline/oily and raw sewerage grey water turning into pure fresh drinking water or pure water being turned into silver or oil?
Does it not give new evidence about the makeup of water?
Thinking outside the box is usually a cognitive disassociation for those who must believe water is H2O in order to wear a lab coat and keep the faith.
This Field Science where one creates a magnetic field in water rather than electrolysis in water by the addition of more electrodes and neutral plates is actually bigger than Tesla in sending energy across the nation and is bigger than crystals replacing valves moving electronics into the space age. This is the next quantum leap of understanding for mankind
BroMikey 09-21-2019 10:04 AM
Bob Boyce says the same thing about putting a magnetic field into
water. He uses 99 neutral plates and what he calls a hex controller
connected to a 6.5" toroidal transformer that has a hundred foot
primary first and 3 short winding over top. A fundamental freqency and
2 harmonics 42.5- 21.3-10.7khz duty 10%-5%-2.5% respectively.
Ringing the bell so to speak not needing so much power
Running large engines on less than 200 watts, looks like there is more
than one or two ways to get the goods. Hey Mate?
Water conditioning produces forms of heavy water which offer vast
sums of energy. Transmutation of elements is on the list as well.
MerLynn 09-22-2019 12:56 AM
Bob Boyce is way behind the times in understanding the Atomic Structure.
Anything Joe can do with a car battery and SS tubes he can do with Ferrite ring magnets.
The 4 Way Cell, (like Alex Shifflier and Peter Stevens made famous) can be powered up FOUR different ways. Each producing a totally different effect in the Water. These 2 guys only ever said to connect the Negative lead to the Bottom of the Center Tube.
Joe's In-Line Magnetic Cell consisting of just a MILD steel pipe with 4 ferrite ring magnets and 2 mild steel washers will create what John Keely described as a Neutral Center for Radiant Energy manifestation (zero point) and ANY liquid pumped through the pipe will exit as PURE Fresh potable water. Any Liquid includes raw sewerage, acid mine waste, sea water, runny concrete and even oily ****. If the Magnets are reversed fresh water exits as oil so pure it doesnt need refining to be used in a VW Golf Diesel car. So a Tube Joecell and an Magnetic In-Line Cell will make oil or fresh water depending upon the orientation of the Magnets or the placement of the DC electrodes in 4 different positions to FORMAT the water. The Wave Form. Or as Walter Russell said as a Title of a Book... "In the Wave Lies the Secret of Creation"
A hundred neutral plates DOES NOT create a Neutral Center.
A JoeCell Tube Cell DOES create a Neutral Center.
Joe has only done it several 1000 times for several 1000 people. Its not like its new or anything. Its just Peter and Alex were dip shots who knew nothing about what they were looking at.
And Joe's Fisher and Paykel motor/generator is also a Neutral Center device leaving all other Radiant Energy Devices (cold fusion) for dead....
We are seeking interested persons who MUST View the cells before ANY offer is tendered.
Think about that. All them JoeCells that are in the garage of frustrated builders can be used to make oil for pennies a gallon. But only if one throws out electrons, protons, elements, ions, and thinks in terms of Wave Forms and Water Memory. Why? Because as you think so you create. and to use false science principles will give false results every time.
Sputins 09-24-2019 06:49 AM
Field Science
Good to see you on the Energetic Forum MerLynn…
I have followed some of MerLynn’s posts on another forum from since around July 2016…
So those reading his posts, in order to absorb and understand, I would suggest suspending your current standard (scientific) belief systems (programming), in order to better learn or understand the way of the thinking he’s trying to relay or teach, regarding Field Science. (Water Science).
It is a different thought process with understanding Field Science. - But in my opinion it is well worth the consideration and understanding, as you will pick up the principals of new knowledge…
Just saying…
Sputins
BroMikey 09-24-2019 06:57 AM
I Noticed MerLynn was talking way out there, but he does not talk
enough to get a full understanding. Where is his other info Sputins?
I would be interested to see where he is actually coming from. MerLynn
says magnetic fields not electric fields, so far that is all he has said
I can wrap my head around.
Sputins 09-25-2019 04:15 AM
@BroM; The link was posted earlier in this thread... – But the posts are scattered, lots of noise and a lot of mining will be required. – Wait for his book…
I doubt the instructions on how to build Joe's Fisher and Paykel motor/generator are going to be given out for nothing… (Fair enough).
(But we can speculate)... As most experimenters have at some point played with around with these motors and rewired them to be wind generators or similar, I wonder how Joe would do it? Given that there are a multitude of ways that these Fisher and Paykel direct drive motors can be configured…
There are 36 Stater coils and 12 ferrite magnets on the outside rotor. Each magnet spans the distance of three coils. So for each set of three coils when the magnet is directly aligned, one is North Pole, one is South Pole and one in the middle is Neutral at a given point in time… So I think Joe might be isolating and utilizing the neutral coil(s) at a given time in the rotation of the rotor. But exactly how he does that and the wiring and switching configuration is the tricky part that only Joe knows… No doubt such a generator would make for a good charging device as well...
BroMikey 09-25-2019 05:45 AM
Why did I know that a book would be the only true answer?
That idea to switch and coil field cancel and motor generator magic
starting with Adams all the way to Christopher Columbus to Tesla
to who knows has been around for sometime.
I hope he sells them because I doubt I will have enough lifetimes
to follow his work, recreate it and continue the speculation.
That is simply not very nice, it's all about getting paid not about helping
others to get a handle on the way nature works. Wizards and Warlocks,
magicians and clowns are everywhere on the web. Leading the people
down the wrong roads. A road to piles of money for the trickster.
I am glad he is making money and having fun but is of no interest to
me. Unless he is going to talk reasonably by teaching us all something
other than slinging colorful slogan's around about how we must think
outside the box. That is not enough.
Thank you Sputins for bringing up to speed. I knew he was selling books.
Sputins 09-25-2019 11:41 AM
It's not quite like that. You've jumped the gunn.
There is no book. But he said he might write one someday...
The thing is Joe's knowledge or intellectual property (IP) belongs only to Joe and no one else has the right to reveal it... (Although certain aspects have been mentioned or given).
Although MerLynn does go on to explain certain aspects of Field Science and people paying attention, can use that information towards their own understanding and applications.
It may not be suitable for everyone. As said, you do need to think outside the box to "get it".
BroMikey 09-26-2019 03:04 AM
There is no book.
I still have not heard any science. Where. All I here is that stupid
"Think outside the box" quote with nothing to follow. This all by itself
is a condescending behavior form of speech. Basically calling people
out saying that they should think outside the box is not science.
Show some? Is that to much to ask?
This is my response to Joe.
Thx Sputins:thumbsup:
PS A someday book? Interesting - yawn, science plz
MerLynn 09-28-2019 07:17 AM
Well Mike.... at https://www.magneticwaterscience.com/?page_id=46 using the password wizzzard777
You can watch water being excited with DC electricity and then it BURNS.
Is that showing some?
I have watched Joe do 'burning water' about a dozen times and video's it only once. Some times it was done with a near flat car battery.
There is NO WAY you can explain this with conventional science....
YOU MUST think outside the box....
So do it .... Tell me how the MIND Programs the DC from the hands to change the Memory of the water to release FIRE.
Give it your best shot.
HINT think Emoto changing the water crystal. Oh and another hint water is NOT HHO..... but we will get to that soon enough and with EXPERIMENTSso you can do to prove it to yourself toooooo
MerLynn 09-28-2019 07:29 AM
Look Mike.... it cant happen one one post.
Stop thinking you know everything because in reality all you know is wrong....
It took you a lifetime to get it wrong and one post to get it right is, even for me, pushing it.
Did you see the attached pdf in another thread, of the DISAPPEARING FOOD DYE with a magnetic Field created by a zero point Neutral Center Radiant Energy Device that you wouldnt recognize if you saw one and could even BUY it...... you are so wrapped up in electrons as the source of all energy. Am I wrong?
Out of the Box yet?
Sputins 09-30-2019 03:03 PM
I pre-warned that MerLynn's thinking is out-side of the box...
Dollard says when you want to understand someone's else's ideas, you have to try and get into their mind-set, it's their ideas, their point view... Don't try and filter it through any of your own pre-conceived ideas, understanding or notions, if you want to understand their concepts... - Very few it seems, can actually do that...
BroM - Given Merlynn's first few posts, you have not been a very welcoming host...
Merlynn can sometimes be a tad abrasive, particularly if provoked... (Merlynn, probably not the best idea to annoy Aarron thou, it's his house)...
I don't speak for him, or promote any products, that is all his deal...
*- It is my belief that Joe is no con-man, he is truthful in his convictions previous and current, as well as his abilities. Joe has a gift of insight that few people can understand or replicate. So most would just simply call him out as being a fake... But there is something phenomenal about about Joe... As in the Matrix movie, ''I don't know how I know, I just know''...
So you can choose to cast Merlynn's points of view and messages aside.. Or try to understand...? You won't get it in one or two posts, it takes an amount of acceptance, processing and absorption to get it...
Here, Ken Wheelers latest video...
https://www.youtube.com/watch?v=6lLlqyRiLEw
''The Cult of Atom-isum. - The belief that mother nature is interaction of bumping particles.. But that would never define a field... - "Everything is a field and fields are not particles''... - Ken Wheeler..
Guess What? Joe had been saying that, since forever...
MerLynn 09-30-2019 09:38 PM
Well Said Sputins.
One learns more in War than in Peace. And a faster pace too.
It doesnt need to be that way.... but its a human trait to reject ANY new info if it even remotely conflicts with already known info. Its just the way humans are.
Mike has a problem... he asked for experiments so he can learn and then he ignores the experiments and just demands that his conditions are met. Like a youtube vid will prove anything.... sheesh... Seeing is Believing. not watching vids.
As stated to Aaron. the vids are not meant to show how its done, but that it can be done and anyone can pay for the privilege to see it done in front of their very eyes and video it too. There is NO other way... Many have made the trek like 100's Many 100's more came but didnt get to see anything as Joe could see their 'honesty' rating as they walked in the door.
Its a fascinating story in itself how people seem to display their true colors so quickly when in the presence of a representative of the Universal Mind.
Oh and Mike....... when you say....
"I still have not heard any science. Where."
I have to ask myself is he really that stupid? How many times have I posted magneticwaterscience.com or Walter Russell science at philosophy.org
Leading to the postulation.... Mike just doent want to understand.
or A New Concept of the Universe....
https://www.philosophy.org/store/p9/..._Creation.html
Or google John Keely and Neutral Center.
