-   Health, Fitness & Nutrition (http://www.energeticforum.com/health-fitness-nutrition/)
-   -   Immunity from Electro-Smog while Bionically Grounding the Body to the Earth (http://www.energeticforum.com/health-fitness-nutrition/21188-immunity-electro-smog-while-bionically-grounding-body-earth.html)
Vinyasi 07-10-2019 03:46 PM
Healing PTSD and Immunity from Electro-Smog while Grounding the Body to the Earth
This post concerns anyone suffering from PTSD in which the subconscious mind defends its state of panic. It also concerns those people who are so electrosensitive that they may benefit from how to reduce or eliminate electrosmog while "Earthing" when they sleep at night.
Earthing is bionically grounding the body to the Earth especially whenever sleeping, but also at any time, to shut off auto-immune disorder and all of its consequences.
Earthing Institute ? Reconnecting People To The Earth
It's been determined by Clint Ober, author of the book: "Earthing", that our body was designed to remain electrically connected to the Earth at all times.
He was a cable guy (owned a cable company before retiring) when he discovered that we are insulated from our Mother Earth to our own misfortune.
John Cejka was a friend of John Bedini. The former invented a psychotronic device to kill pests in a farmer's field without having to directly apply insecticide.
BIOHARMONICS MACHINE
https://is.gd/moviti
CEJKA FILES
https://is.gd/ojoxut
I'm an empath. I'm sensitive to electro-pollution, also known as: electrosmog. So much so, that when I ground myself to the Earth when I sleep at night, I have to avoid the use of the house wiring ground connection due to its proximity to the hot wire which bleeds an A/C hum into the ground and neutral wires as an EM broadcast occurring between adjoining wires running through the same electrical conduit inside the walls of our buildings.
I also have to run my Earthing connecting wire outside my bedroom window and plant it into the Earth many feet (yards) away from any house mains since that is where the building's ground wire is connected to the Earth.
But that's not enough...
For short duration whenever panic grips me and drives me to a heightened frenzy of voluntary service to help others, and hopefully build a little good karma for myself, I also have to connect the positive terminal of a dry cell battery to my Earthing line (and NOT connect the negative battery terminal to anything) to suppress electrosmog and invert an adverse PTSD voltage polarity of the body that, without all of these protective measures, my heart would weaken its beat and increase the likelihood of heart failure a little earlier in life than it should otherwise.
Voltage sources are considered to be voltage regulators. And a D/C signal will suppress voltage perturbations arising from electrosmog....
http://vinyasi.info/energy/happy-me-40pc.jpg
happy me at peace with myself living in this world while not wrapped up in it...:whistle:
take care of the body and the rest will take care of itself...
This is the first video I made in this series...
This is the second showing a gradual development of thought...
...which resulted in my making the following warning / image...
Then, I made this penultimate video ...
...drawing some interesting conclusions which helped me to more fully appreciate my endeavor to understand free energy in the context of my simulations...
Then, I made this video along with these diagrams to highlight my opinion gathered from my recent series of experiments...
Pot head 07-19-2019 12:18 AM
Okay, if you use a grounded faraday cage that you sleep in that should be enough to allow the DNA to rebuild itself, but if a DC voltage works then how do you use it with a faraday cage to promote maximum benefits?
Hmm...
