H2 Global claims 99% water as fuel ,touring USA
  • H2 Global claims 99% water as fuel ,touring USA
    Shared from an open source friend of ours..
    snip
    Norman Wootan posted this in EVGray
    "Announcing ! the H2G Water BUS tour of USA. An RV / Bus will leave Tampa for Washington DC to Demonstrate the H2G clean water fuel technology that will run this bus across America and back, WITHOUT STOPPING FOR FUEL. The tour is from Tampa to DC to Silicon Valley, Ca. and many stops in between. There we meet with Scientists, Technicians and Financial VIPs from around the globe to introduce our technology. H2 Global invented this unique process based on studies of lightning, and charged particles. It extracts water from the air, like a dehumidifier, and that water is converted in our 4" CUBEs to a clean near zero emission fuel which improves by 5-10 x the mpg. It runs on 99% water. It replaces toxic fossil fuels. An engine test run is posted on our site h2ge.com or h4gas.com which shows an engine running on 99% water. There is also a downloadable document on the website which describes in more detail this historic event. We will be doing media interviews across America as we go. We will be riding Congresspersons on the bus at a demo in DC, Some celebrities have asked to ride. You can actually participate and may ride in the bus. Email h2ge@... to find out how, You can help spread the word just by sharing this. This will be a ride into history and mark the turning point from toxic fossil fuels to a clean energy future. H2G has a solution for climate change."
    end snip
    links https://www.h2ge.com/
    video here https://www.h2ge.com/
    will add more info as received .
    Chet K
    BE that change !!
    Sounds great. Hopefully they consider the potential roadblocks to such a disruptive technology that could eliminate many other energy sources. They might want some armed guards on their tour
    One statement in their document on how it works didn't seem quite correct (at least from a grammar perspective) :
    "One box has electronics and one is a wet-box, the mix takes place in it. Inside the box the water is reformed and changes to the covalence bond angles and magnetic influences are affected. The result is a new bonded particle. Very explosive."
    Change covalence (adverb) to covalent (adjective) and it makes more sense. When you have PhD's working on this I would expect good grammer but maybe just a typo by someone else doing the document.
