Bob Boyce HHO
  • Bob Boyce HHO
    Good day,
    Can anyone send me the gerber files of Mr.Bob Boyce? The PWM3G files which i suppose they are the gerber files so i can print them on a PCB. Does anyone have them? On ''hydroxy'' group on Yahoo, apparently nobody has them... I wonder how can that be? Mr.Boyce shared them on the ''Working WaterCars'' group on Yahoo, publicly. There is a document on google called ''pwm_1.pdf'' in which this is stated:
    ''This Group ( http://tech.groups.yahoo.com/group/WorkingWatercar/ ) has been given permission most graciously, by Mr.Boyce to present a compilation of his project so that it may perhaps be more easily understood and replicated by the general public.''
    Originally posted by Buddhafollower View Post
    Good day,
    http://www.hho4free.com/documents/BB101.pdf
    https://www.hydrogengarage.com/store/index.php?main_page=product_info&cPath=4&products_ id=20
    Bob was here and tested this circuit, use 3 of them together.
    http://flyer.thenetteam.net/pulsing594.jpg
      Thank you very much!
      The post remains open though. If someone has what i asked for please, you know what to do.
      Thank you,
        I gave you the link to the kit. HYDROGEN GARAGE he has the circuit. PWM3G kit comes with
        circuit dia. or maybe you lost your circuit diagram? And layout? Ask.
        His name is Andrew.
          Ok, i will ask them for the circuit diagram.
          One question i have, the diode in the above circuit isn't connected and it would appear that there is nowhere to connect it to. It is a special kind of diode, i don't think it's available in my country... Where do i connect it?
            http://flyer.thenetteam.net/pwm594tl.pdf
              WOW!!!! That is so good
              So this circuit itself is designed by Mr.Boyce?
              Thank you very much for your kindness!
                Yes Bob and Rich are friends and Rich worked on it for me. I spent
                $500 for the job well done. I put it in a box later. This one can
                run 50amps on a 3 phase motor starter too. It is not going to
                break down using it on water experiments. My favorite design.
                I am the only one with this circuit.
                  Parts List for PWM594TL REV.0
                  R1 100 ohm 1/4 watt resistor
                  R2 not used
                  R3 3.3k ohm 1/4 watt resistor
                  R4 6.8k ohm 1/4 watt resistor
                  R5 3.3k ohm 1/4 watt resistor
                  R6 390 ohm 1/4 watt resistor
                  R7 3.3k ohm 1/4 watt resistor
                  R8 6.8k ohm 1/4 watt resistor
                  R9 10k ohm 1/4 watt resistor
                  VR1 1k ohm 25 turn pcb mounted pot.
                  VR2 25k ohm 25 turn pcb mounted pot.
                  *VR3 1k ohm 10 turn panel mounted pot.
                  *VR4 10k ohm 10 turn panel mounted pot.
                  C1 .1uf 35v tantalum cap.
                  C2 1uf 35v tantalum cap.
                  *C3 .01uf 50v for chan.1 & 2/ .0039 50v for chan.3 polyproplene
                  C4 .001uf 50v polyproplene cap.
                  C5 1uf 50v polyproplene cap.
                  C6 not used
                  C7 .1uf 50v polyproplene cap.
                  C8 .1uf 50v polyproplene cap.
                  C9 4.7uf 35v tantalum cap.
                  U1 LM317AT Positve adjustable voltage regulator IC
                  U2 TL594 pulse width moduator IC
                  U3 TC4420 MOSFET driver IC
                  Q1 IRFP250N 200V 30A MOSFET
                  Q2 IRFP250N 200V 30A MOSFET
                  D1 HFA08TA60CPBF Diode Hexfred 600V 8A
                  D2 HFA08TA60CPBF Diode Hexfred 600V 8A
                  T1 T650-52 Toroid 3phase Prim.,single Phase Sec. Special wound by cust.
                    It is a very simple circuit but you need 3 of them ganged together and set
                    the duty @ 2.5%- 5% - 10% respectively. This is somewhere to start
                    Every box will need tuning and this circuit makes it a dream come
                    true for a wide range.
                      You are much too kind, my good sir.
                      Say what will the issue be if instead of the material T650-52 i use what i can find in my country, T650-26?
                      Because as far as i can remember this one is the replacement for the 650-52. Am i right?
                      I think they have identical constructive and electrical properties except the fact that T650-26 cannot go as high in frequency as the T650-52.
                        Will there be any serious problem if i use T650-26 instead of T650-52?
                        Please tell me.
                          Here it says:
                          -26Materials
                          The most popular material.It is a cost effective general purpose material that is useful in a wide variety of power conversion and line filter applications.
                          -52Materials
                          The material has lower core loss at high frequency and the same permeability as the -26 Material.It is very popular for high frequency choke designs.
                          https://micrometalsarnoldpowdercores...-DataSheet.pdf
                          I strongly believe these two cores are interchangeable. I will buy the first one as the -52 isn't available in my country.
                          Thank you again for your great kindness!!
                          With your permission i would like to post these files which you gave me, on other sites such as Yahoo and YouTube. Only with your permission.
                            Here it says:
                            -26Materials
                            -52Materials
                            Unless you have a 101 plate box it does not need the exact core so
                            you will have to experiment, have fun. Yes go ahead and share the circuit
                            with the box builders.
                              Thank you
