A Book On Atmospheric Energy
  • A Book On Atmospheric Energy
    Hello Everyone.......
    I had been a long-time lurker in the forums and doing experiments on my own. I believe it is time for me to announce a circuit that runs on Atmospheric Electricity.
    The latest blog post can be found at STEEMIT:
    https://steemit.com/offgrid/@lightin...he-steemit-way
    This is an already working circuit, we only need to "upgrade" this if we want to. I already made sure it is capable of running non-stop at low-power applications. This thread is for the purpose of helping anybody here who may want to apply it for their own benefit.
    The approach and my journey along with the collaborative efforts of good experimenters are laid out in the simplest way in my Amazon published ebook that can be found:
    US: https://www.amazon.com/dp/B07HR5G4PB
    UK: https://www.amazon.co.uk/dp/B07HR5G4PB
    DE: https://www.amazon.de/dp/B07HR5G4PB
    AU: https://www.amazon.com.au/dp/B07HR5G4PB
    CA: https://www.amazon.ca/dp/B07HR5G4PB
    I am opensourcing this work and will be sharing one-third of whatever earnings I can receive from the book's sale for the benefit of this free energy forum site (energeticforum.com).
    Collaboration and the helping minds of many will be the force that will conquer all. It has arrived my friends, I invite each one to do their part here. Thank you.
    Mario
    Engineer, Experimenter, Writer
    Mario
    Thanks, very interesting and useful. BTW, I took note of the comment and your reply on https://steemit.com/offgrid/@lightin...he-steemit-way
      Thank you for the prompt response @Gambeir.....
      Yes, do take note of the answer to the lone comment at my STEEMIT blog; curiosity and persistence reall have a place in the experimenter's world Sir.
      I will be privileged if the approach can be tried. I am eagerly waiting for any opportunity that I can be of help. Regards.
        looking at your schematic,
        does it have any change in how it runs if you remove what is labeled "big capacitor" ?
        it is in parallel with batteries, and batteries really do act as a large capacitor.
        if it does change anything removing it or connecting it right at the battery terminals, then I would like to know what it changes.
        also, if it changes how it works, then there is likely something to your physical layout of the hardware that is not apparent in your schematic. and in that case, we would need more details to reproduce it.
          Thank you for your interest. Let me explain what happens here, and since these are all unseen forces, I am but visualizing what really happens behind the scenes:
          a. If I remove the big electrolytic capacitor, the "atmospheric electricity" or radiant electricity from the GI metal railing can only go to the charge battery if the transistor is closed or to the source battery at any time.
          b. Problem with radiant/atmospheric power is that it seems to "not like" batteries. I explained this in my book and as hinted by Tesla that the capacitor is the key to unlimited energy.
          c. If I place the big CAP in its proper location, the radiant/atmospheric electricity somehow likes to fill it up with charges; it really seems that the circuit functions much better if the capacitor is there.
          Let me know of your replications. I deliberately designed it to be a very simple arrangement so that more can easily replicate.
          Mario
            Mario
            Hello Mario,
            Fascinating Stuff!!
            Thanks and Regards
            luc2010
              ok,
              next question,
              what transistor are you using ?
                @luc2010:
                Thank you for your encouraging words... I will do my best to answer all questions here.
                @spacecase0:
                The transistor I used is 2SC3552, but any high-voltage (more than 700 volts) fast-switching transistor will do. For your antenna try a coaxial cable and just use the outer conductor to connect it to the transistor base.
                Mario
                  The latest circuit has efficiencies unheard of, see the latest post at my STEEMIT blog here:
                  A diode added to the source battery to shield it from the CAP "return" enables the CAP to accumulate more atmospheric voltage. It greatly prolonged the CAP's dump time going into the charge battery and the circuit.
                  Scrutinize this my friends, I urge everyone willing.
                  Mario
                    CORRECTION:
                    Sorry guys, the latest STEEMIT post is here:
                    Thanks.
                      Mario
                      Some speculation as to why the capacitor makes a difference.
                      The reason the capacitor is significant is that it is holding (separated) charges and which are then being subjected to a native surrounding environment. This changes the speed of light in a local area under the right conditions. At least that's a kind of simple idea to hold in your mind so that you can make sense of what takes place and to understand that the HV charge in the capacitor is the reason that this alteration in the environment becomes possible, not that it necessary does happen automatically. Now it's possible that by arrangement of the capacitor and the passing electromagnetic circuitry that an artificially induced local environment can be created which alters the reaction time of the the whole and which could offer even greater improvements if correctly laid out.
                      In other words, you're changing the speed of light using the forces involved. How much or how little the capacitor produces an effect is dependent upon the arrangement of the circuit. The concept is akin to the idea that to produce a current you must move a conductor through a magnetic field. In this case the moving magnetic field is a product of the circuit and so that circuit has to be positioned to create the effect the same as you need to put the wire through the magnetic field to generate an electrical outcome, but in this case it's the capacitors charge that reacts to produce what James Cox called a non-uniform electrical field. This means that the device is no longer working in the same space and time as you are. Instead it's now got it's own little world to function inside of, one where the speed of light is now altered.
                      Understand that I've put this in the vernacular of Einsteinian Physics. A true understanding is different since really what you've done is to replace the local counter space with an artificially induced one which moves at a vastly slower speed, and ideally you'd aim for something like say around 1/10th the speed of light where electricity is happy, and whereas the space you yourself are existing inside of is actually moving at billions and billions of times faster than light speed. Once you get the gist of that idea down then you sort of wonder why electrical anything works.
                      #Post 74
                      http://www.energeticforum.com/renewa...cations-3.html
                        You are one genius Sir!!!
                        The youtube expert channel "MUDFOSSIL UNIVERSITY" speaks of the things that you just described, behaviour of light, and even if I must admit I can not fully understand it, I can clearly see that there is so much going on around our world.
                        I have always been an open experimenter, and I believe people around the world if pooled into one mind can do more things.
                        I can only see the "tangibles" at my side of the skills, and for this, I salute your ideas.
                          I just posted a Charger-only variant of the JOULESTEEM circuit that exhibited the most efficiency of all arrangements that I had tried. Described in my STEEMIT blog here:
                          Do support these experiments and replicate yourselves. Tell the whole world what you find out. I welcome any questions thru this forum.
                            Hello mgveloso,
                            Is the 9 w bulb lit when the circuit is connected?
                              Hi Mario
                              What is GI metal railling in your schematic ?
                              Tank you for sharing!
