State ofthe Art Novel InFlowTech 1Gearturbine RotaryTurbo 2Imploturbocompressor 1Comp
  • State ofthe Art Novel InFlowTech 1Gearturbine RotaryTurbo 2Imploturbocompressor 1Comp
    Featured Project Development - State of the Art Novel InFlowTech; 1Gearturbine RotaryTurbo 2Imploturbocompressor One Compression Step:
    State of the Art - Novel InFlow Tech - Featured Project Development;
    *Wordpress Blog State of the Art Novel InFlow Gearturbine Imploturbocompressor
    *1-GEARTURBINE BEHANCE Images Gallery Portafolio
    *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
    *2-IMPLOTURBOCOMPRESSOR BEHANCE Images Gallery Portafolio
    *2; Imploturbocompressor; One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
    *State ofthe Art-Novel InFlowTech 1Gearturbine RotaryTurbo 2Imploturbocompressor From Macro to Micro
    +PLUS; *State of the Art, Novel Technology, Featured Project Development / Space, Satellite and Habitat, Power-Plant, Generator, Self-Feed Unit; H2O=>HHO=>H2O=>HHO=>Etc... *4 Systems All in One Unit, One By One, Plus Four-4 Projects added One to Other; *·1-Gearturbine, ·2-Imploturbocompressor, ·3-Dynamic Generator, ·4-Electrolysis System:
    ·1-GEARTURBINE; Rotary-Turbo-InFlow Tech,Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
    ·2-IMPLOTURBOCOMPRESSOR; One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
    *Note;Plus-this-Two Projects to complete all the System Work;
    -Self-Feed Unit Space Power-Plant-H2O=>HHO:
    ·3-Dynamic Generator/New Kind.
    ·4-Electrolysis System/BioDesign.
    *(3&4-Hide-Cards-on-the-Hand).
    State of the Art Novel InFlow Tech 1-Gearturbine/RotaryTurbo, Similar Aeolipile 10–70AD. 2-Imploturbocompressor/One Compression Step, From Macro to Micro.
