-   Agriculture (http://www.energeticforum.com/agriculture/)
-   -   alternative source of energy (http://www.energeticforum.com/agriculture/20315-alternative-source-energy.html)
maddriver 11-10-2015 11:04 AM
Hey guys
I have a small farm. I receive huge bills for the electricity. What are the easiest ways to reduce the energy consumption? I do not have solar panels.
thanks
bistander 11-10-2015 02:17 PM
Where does it go?
Originally Posted by maddriver (Post 282082)
Hey guys
thanks
Have you done an energy audit? Get a Killawatt meter, measure and record all usage. Lay it all out so you can see where you should concentrate effort for highest savings versus investment to improve efficiency or cut waste. It helps to write down the value each watt-hour provides.
Turning off lights and appliances when not in use is easy and will help. Do lots of little things which don't cost. Put your investment where you get the biggest return. Example might be switching electric heat/air to gas or go geothermal.
Solutions are personal depending on particular location and operation and/or lifestyle. You need to look at the big picture like 20 or even 30 years for ROI.
You'll find the real free energy is that which you no longer waste.
Stealth 11-10-2015 08:02 PM
whrere to start
Everyone is looking for a point from which to start. First, change all incandescent bulbs to LED. Next build or buy a wind turbine. During winter, (which is of higher electrical usage for most people), the wind blows more than does the sun shine. Solar panels are also a good investment for those days when the wind doesn't blow. A sufficient battery bank is a necessity. A solar water heater will have the largest impact on your electric bill. A solar passive heating system will be next. Good Luck. stealth
BroMikey 11-10-2015 09:41 PM
Hey guys
thanks
The best our official have for extra energy other than the current
hydroelectric plant, nuclear is to build one of these. They only run
$80 thousand on up to a half a mil.
This one is more but shows the basic structure of industrial grade
wind harvesting. When somebody does come up with a cheaper
source we will let you know where we buried them so the rest
can tremble in fear for the next decade.
If you have a stream? You could do a tiny plant for little stuff.
Paddles in the water or paddles in the air is about all we have for
now sorry. Who knows though, maybe one of the UFO's that the
government flies around will stop and give us some hints.:)
We see the farms here in Kansas trying the wind thing and the
brand new one are always broke off on their wings. When the wind
blows they must be turned off. Otherwise only a 7-10 mile an
hour wind is allowed. At 15 MPH the wind hold 4X energy so they
design machines that won't handle that. At 22mph the energy is 8X
energy. Very few turbines permit a 22MPH wind so shut down is
required.
http://thumbs.dreamstime.com/z/wind-...ay-2818822.jpg
maddriver 11-11-2015 10:00 AM
thanks everyone for the replies
How to choose good LEDs? I liked these LED wallpacks https://www.mrosupply.com/lighting/l..._rab-lighting/
They would be perfect for my barn. But it is very pricey for me now..
spacecase0 11-13-2015 05:58 AM
at one point I quit using electric light and heat,
power bill went to almost nothing
long ago farms used no electricity because they did not have any,
just figure out how they did it (I read the books they wrote about how they did things back then)
Stealth 11-13-2015 09:50 PM
All home improvement stores and most retail stores, even dollar stores have LED bulbs. 6.5 to 15 watt LED compare favorably to 40 to 100 watt incandescent bulbs. Even LED floodlight bulbs are readily available. Most automotive stores carry 12volt LED, which can save even more using a transformer. Flashlights and lanterns only use 4.5 volts and can output lots of light. individual LED's can be purchased at your local electronic supply store and easily make you own. A wind turbine can charge a battery and power many LED's, and more. Wins turbines can be purchase or easily built to supply power to charge batteries. I have several designs and will post one or two for your consideration. Good Luck. stealth
Stealth 11-13-2015 10:24 PM
A framework of pipe and several barrels or buckets cut in half lengthwise and provide all the power you need. Many sizes are available as are low RPM 12 volt DC motors*turn backwards). Belts and pulleys or chains and gears can provide needed RPM for you low RPM motor. Automotive bearings can run maintenance free for many years. Anyway the wind blows can turn this turbine. You could use an automotive type voltage regulator to prevent overcharging, and charge many batteries if needed to run you entire house or several smaller turbines for barns, workshops or other outbuildings. Good luck. stealth
