Earth Grounding Energy Extraction
  • Earth Grounding Energy Extraction
    Here is an extra place to show random experiments people are
    doing using earth grounds and exciter circuits to stimulate
    these energy currents.
    https://www.youtube.com/watch?v=bGSI...ZhnnYVqG81kCZg
    https://www.youtube.com/watch?v=cibqtywpLSI
    https://www.youtube.com/watch?v=iwIv4tA3eLg
    https://www.youtube.com/watch?v=yHkqn2cG-no
    https://www.youtube.com/watch?v=B5qw...ature=youtu.be
    https://www.youtube.com/watch?v=EDH7s3IMTtE
    https://www.youtube.com/watch?v=E0bOK7ChwbQ
    Also the subject of earth grounds has been mentioned lately grounding technique if you can still find the old copper car radiators.
    The Tariel Kapanadze ground experiment results not verified that I am aware of, However the grounding system can be understood and makes some sense that it may be better to use surface area with all those copper fins, the iron oxide soil, bucket of water and heavy cable rather than driving a rod down. In some cases 10 feet away from metal pipes and buildings.
    https://www.youtube.com/watch?v=Mxa_G4X8Y7k
      https://www.youtube.com/watch?v=ImXCEev1nUY
      https://www.youtube.com/watch?v=gGo1Ze7a3VY
      good videos
      https://www.youtube.com/watch?v=12tk0xjxxvk
      https://www.youtube.com/watch?v=BydisQbVTCo
      https://www.youtube.com/watch?v=KZYm9brl_WA
      https://www.youtube.com/watch?v=WrEBghRJllM
        This looks like a fun and inexpensive project. over 1 minute on a 470 uF cap
        lazersabre's potted super joule ringer looper getting some kind of assist from ground.
        He does'nt make any official claim yet. great runtime and maybe needs it just a little ... ?
        https://www.youtube.com/watch?v=lGIJ...=TLM9NlSx0yxjk
          Recycled energy through the boost coil and back again. He is not getting
          any energy from the ground in this configuration. The grounding is used
          to drain energy from the circuit.
          Mikey
            Lasersabre was standing on the ground, his finger was touching one end of the LED connection creating a capacitive link between earth and his body. He later explains that then uses a variable air capacitor to control it.
              Lasersaber's website and sjr looper page:
              Joule Ringer | Laser Hacker Alternative Energy
              I captured two scope shots.
              The first is something like a micro exciter wave having three components. Initially there are two sine waves.
              Sometimes found in circuits often between dielectric and ground or object with less potential.
              Sometimes these are found naturally as charge separators, the faint blurry one common to parasitics.
              When he uses an adjustable resistor(pot) he can get it to ring even 2 or 3 ringings.
              When he uses the clip lead as sort of a counterpoise it rings.
              When he uses one side of of a dead 9V battery the ringing starts, when he uses earth ground it rings.
              When he uses a variable capacitor he finds resonant spots in tuning or moving the plates
              there are some larger spikes with the large air variable suggests adding open path capacitance.
              The second picture is the output, possible flow from the capacitor through a bled resistor
              into the potted inductor then into the leds. Not sure ?
                Yeah Yeah
                The part about the battery hooked to only one terminal is an entirely different subject. One end to earth ground only sets up an oscillation so Laser alway hooks the battery for a second and then it goes dead
                after a few then back on the battery so earth only sends a signal to the transistor base to start the draining process.
                The battery hooked to one terminalNo that blows me away.
                Do you think energy leave the battery?No way, It can't can it?
                This is interesting. Running on one battery post only plus earth grounding Now maybe the energy comes from the earth
                in that setup.
                [ATTACH]15731[/ATTACH]
                [ATTACH]15730[/ATTACH]
                  Energy from ground Captor
                    I can light an LED from the negative of the battery and the top of the case and
                    I don't even need an oscillator running from it. This is almost exactly the same
                    effect that is seen when people light LED's from the case of the battery that is
                    powering or being charged by an SSG ect.
                    Case of Battery conduction.
                    https://www.youtube.com/watch?v=yKeIzFabINU
                    All effects have an explanation even if it is not immediately apparent. The
                    explanation is the most important part.
                    Simply put, the case has electrolyte on it and this allows conduction of current
                    outside the battery. The battery needs to be cleaned because that is a
                    parasitic drain on it all the time.
                    A similar effect can be achieved by using a HF oscillator and holding the LED, by
                    one leg and touching the other leg to the battery case or a single battery
                    terminal, then the LED is lit by displacement current via the body or even by
                    straight conduction, both work in different conditions.
                    Grid leakage and leakage from our own HF devices will also light LED's, This
                    is not new or novel.
                      Yes this is all true. I have explored these facets of fooling one's self. Right when I thought I had the gold.
                      Yet we must not stop learning about what else is around too.
                      Good to see you are still around.
                        FWIW:
                        Originally posted by ronym View Post
                        i think earth has capacity to become negative pole than positive pole
                        few years ago i have "weird" result from my "ground" pole
                        i using earth as negative pole against positive pole from ignition coil
                        this setup make it as unusual electrical circuit
                        because usually if we use earth as "grounding" we attach it with negative pole of battery
                        but this time i am not connecting negative pole of battery to the ground
                        ( i just connecting negative pole of battery to 555+Transistor and negative pole of ignition coil )
                        "theoretically" this circuit will not work ( positive pole of coil are not against negative pole of coil... rather it's agains "nothing" )
                        but i am surprize by it's result :
                        1. high voltage DC, jump between positive pole of ignition coil and the earth. as if the earth become negative pole
                        ( just make few mm gap between positive cable from coil agains floor or soil will do the same )
                        2. in this electric jump, i heard "humming" or "cracking" sound
                        3. transistor become colder ( compared to "normal" setup )
                        4. 555 output freq seems increasing ( if we attach it to running LED or freq counter we get freq of circuit jumping )
                        and when i turn the potentiometer i am failed to change it's freq
                        as if it's freq lock in the circuit
                        Two things that grabbed my attention about this post:
                        1. That the earth is supplying charge to the ignition coil positive pole (instead of grounding it out)
                        - this charge seems to be running opposite to what one would expect from conventional electrical charge
                        2. The frequency of the 555 timer seems driven by the load
                        - Change in potentiometer's resistance has no apparent effect on frequency (turning the pots usually changes the frequency in astable mode)
                        So what is it about this setup that enables it to access this unique kind of electrical charge?
                        Bob
                        Last edited by Bob Smith; 05-01-2015, 04:25 PM. Reason: Quoting post (rather than just URL), adding observations.
                          It's simple to see solutions in a complicated form, it's far more complicated to see the same thing in its simplest form. Follow nature itself.... so simple in its elegant ability to maintain balance - alter that balance in a natural way and it allows us the use of it.
                            Wonderfull Wikipedia
                            Amazing stuff that was discovered a long time ago but perhaps someone will
                            give it a new twist.
                            https://en.wikipedia.org/wiki/Earth_battery
                              That sounds better than every thing around I heard. Where does this all come from? Is there a website?
                              Originally posted by Bob Smith View Post
                              FWIW:
                              Bob
