-   -   Witts 3000 Watt Fuelless Generator ( Notes + Diagram ) (http://www.energeticforum.com/renewable-energy/16877-witts-3000-watt-fuelless-generator-notes-diagram.html)
Ajnabii 04-23-2014 04:06 PM
................................its over
wrtner 04-23-2014 04:14 PM
Originally Posted by Ajnabii (Post 254563)
Brothers and Sisters i hope you all will be fine
today i am going to share with you 3000 Watt Generator Notes + Diagram handed over from Witts Ministries to me.
We already have a thread discussing this topic.
Ajnabii 04-23-2014 04:21 PM
dear i know that but this thread is totally different and the machine is also different, you should to download the notes and diagram and read it first please, then we will discuss on it.
JohnnBlade 04-23-2014 04:27 PM
Good **** man!
Thnx!
today i am going to share with you 3000 Watt Generator Notes + Diagram handed over from Witts Ministries to me. i have paid 1000$ for this and today i am going to share with you just free of cost, i don't need money i just need the knowledge and also your all friends help, if there is anyone who make this after this thread, then share with us please, i hope you guys will give me a positive response.
Thank You
Ajnabii
Stephen Brown 04-23-2014 07:27 PM
Thank You
Ajnabii
Ajnabii,
Did you take a class with Witts along with the above plans?
The notes leave most of the work to be done by us.
This is the QMOGEN design that has a motor running a generator.
PESN has a number of these on his sight.
I'll start looking for a self exited generator.
Does anyone have a part number for a four quadrant generator?
Stephen
Joit 04-23-2014 08:18 PM
Seriously Ajnabii,
Witts give only another Reason that they are a Fraud with such Plans.
After this Plans its for sure not the machine what he did demonstrate.
Core is different, Capacitors are different, his statement you should took a class to learn about resonance first, and then pray and hope that it works?
Because you cant be sure, when, as this plans say, just buy a generator and simple rewind it, and the Coils on it are optimal to run on resonance and you only need to rewind it.
Shows the next statement, that they allegedly help since 200 years but make such plans like they are drawn from kids.
JohnnBlade 04-24-2014 12:45 AM
Originally Posted by Stephen Brown (Post 254571)
Ajnabii,
-------- part number for 4 quadrant generator? Aka out of phases generator from a shop or a homemade one?
Stephen
Thnx!
Greets JB
vidbid 04-24-2014 04:36 AM
Thank You
Ajnabii
Thanks for posting those files.
Now I can remove my "quotations" post.
VIDBID
Ajnabii 04-24-2014 03:19 PM
Ajnabii,
Stephen
Dear i took the class they said study up on resonant circuits, and also said
I suggest you study as well the effect of series or parallel connections of capacitors.
Ajnabii 04-24-2014 03:38 PM
Originally Posted by Joit (Post 254573)
Seriously Ajnabii,
Dear i study this Plans 100 times, if i shared it here openly this is why ? because i need you guys help they just answering me study up on resonant circuits, the same message is here you can see,
( Sir T said that this was covered several times in the class.
He suggests you study up on resonant circuits.
I suggest you study as well the effect of series or parallel connections of capacitors. (This is common in basic electrical theory, and I know there are basic electrical websites on the internet with lots of examples and formulas on how to calculate this so you can use any commonly available capacitors. )
so my Joit bro you seen this message ? you said pray for them I am praying for them and i will, but i have mention that above i have paid 1000$ for this plans, and you said ( as this plans say, just buy a generator and simple rewind it, and the Coils on it are optimal to run on resonance and you only need to rewind it. )
if this is so simple so why you are not going to build up this and share with us and also you suggest that for me to take the class but dude class is not free they will charge me 100$ again if i not understand ones again they will charge me again and again so how many times i will pay thousands $$$$ that's why i shared here with my friends!
there is nothing to leave with this plans, this is 100% complete.
But who is expert who will make it and show us the details of everything did you ????
Joit 04-24-2014 11:51 PM
I did NOT say its so simple, as they, or maybe only he, Thrapp, try to imply.
That is, what THEY say with this drawing from a Plan and her cover letter for 1000$ (what is simple a joke when you compare what documents you get today for this amount), what you posted above.
And second, i said pray, because you will build something with such plans, where you can only pray afterwards, and hope that it will once work, because it obviously dont will work. Hope is, what dies at last.
Show me that part where i did write that, that i suggested it to you.
But i will tell you few things.
First, when you buy a simple generator, you can be sure, that the coils on it are not made to be in resonance. They are probatly in resonance to eachother, means they both got the same capacitance, and are therefor in resonance, but doesnt mean, that you will reach a real resonance at the speed how the motor runs.
Second, you see the Generator he use has same as the QEG bridges build on the core, where the rotor can make a flux path to certain points at the Core.
A standard Generator is not build like that.
Did you ever take a Generator apart? It has most time 3 Coils in it, wire size is about 25#-22#Awg (0.4-0.6mm) That are standard Generators for maybe 3 KW, but for 3kw they are then actually big Motors, not toys.
That means once you have at last 3 Coils, (where you have to make it as 1 Coil? as this Plans say?) and then, you can not excite that one Coil, when you dont have a second, at last a resonance Coil, what is shown at the QEG Diagrams or a Magnet inside.
I very hard doubt, that a Antenna with an adjustable Variac to ground will give any 'excitement'.
Next, even the Antenna is not shown at the Videos what we have seen from the Motor.
Or are there other Videos to this kind of Plans what they gave you.
Third. Standard Motors and Generators run on about 60-80% efficency, means, you will still have losses there if you simple take the coils from it.
Fourth. The QEG and some other buildings from the TPU show 3 Coils at last, or even more, AND a very heavy gauge Wire, what is used for a pickup coils, what is totally missed here.
I remember one example from a guy what played around with a tpu like device, and first could get a strange effect, after he mixed 3 frequencys and suddenly he got a huge energy boost for a moment, until he got some of his equipment damaged.
Thats all not possible with this plans.
About that you should learn about resonance, what THEY suggest, you can really find some basics about that at the net, even on youtube like this.
https://www.youtube.com/watch?v=hqhV50852jA
But such Tutorials are only the half way that you get a coil into real resonance. This one is more about to bring the coil with the capacitor into Resonance. Usually, you should first find the resonance from a Coil with the frequency and the input power and then find a matching capacitor.
It then more looks like that then.
https://www.youtube.com/watch?v=dkcggzRIFnY
Even where i am not sure at this User Larsko because he posted some fraud devices, if that did really work for him, but i have seen a similar build what did seem to work too.
One more video for resonance, what shows it well.
https://www.youtube.com/watch?v=qtI1CPBSm-o
A simple experiment for it to try it out is to feed a Coil with pulses and see at what frequency and voltage it does shows a sinewave (from pulsed input).
Still, the disadvantage there is, that you feed the coil with a pulse, means you have a push from one side all time, means, only one half from the sinewave will have current, and the other side from the wave is only kinda forming. But then you may can compensate that with a tank circuit with capacitors, what charge up and decharge when the pulse is off. Just, you need all that coils tuned to eachother(just..).
So, a 'few' things what i showed, and this Plans from WITTS doesnt, like that Coils in a normal generator are for sure not tuned for the Power what it creates and kinda impossible to reproduce for someone who only buys this plans and does not have a lot knowledge
Btw, Witts allways offer help when you stuck with her Plans. Does that mean you have to pay again for further help from them?
I seriously would more start to build a device what looks different from a Motor/generator and what is more efficient then the parts what they suggest, like johnnblade does.
john_g 04-25-2014 05:46 AM
Hi Anjabii
Thanks for posting up the WITTs info. I noticed in the plans it talks about rewinding with 'quantum shield magnet wire' (which sounded all very BS) however it seems this term refers to corona resistant wire, ie wire with a superior coating.
Some info about wires at:
Corona-Resistant Insulation Enamels
Film Insulated Magnet Wire 200c Pulse Shield
I guess if this type of wire had been used in the QEG build then the arc-over may not have happened?
John
JohnnBlade 04-25-2014 08:40 PM
Good **** G, quantum shield magnet wire, sounds special to them like enamled copper wire is to us. Its all bout marketing a brand.
Greets JB
Originally Posted by john_g (Post 254656)
Hi Anjabii
John
john_g 04-26-2014 12:55 PM
Greets JB
Some interesting info on Hitachi wire, to show the differences:
http://www.hitachi-cable.co.jp/catalog/ME001.pdf
ewizard 04-26-2014 04:35 PM
Thank You for sharing Ajnabii ! I assume you are aware of the QEG also and that it is based on the Witts generator? There is a lot of activity with that going on right now. One of the main QEG forums: Home
Ajnabii 04-26-2014 07:19 PM
Ajnabii,
Stephen
Dear i am also looking this generator i don't know from where i can get this and how does it look like ?? 4 quadrant what does it mean exactly ?
Joit 04-27-2014 03:32 AM
Means 4 Coils around a Stator, like at a Clock the numbers 0, 3, 6, 9.
Standard AC generators have the coils at the numbers 0, 4, 8, and create a phase shift that way
nvisser 04-29-2014 04:21 PM
http://www.backgauges.com/Gen-E-Sys%20II/index.html
Thank You
Ajnabii
Ajnabii Dear
You should rather have spend your good money on this man. He will give you something to built that will solve your energy problems.
backgauges.com
jakarta24 06-13-2014 08:45 AM
hi. i have made the generator 3000watt, but i just have difficult to find the capasitor
Duncan 06-14-2014 07:31 AM
'Thrapped'
Originally Posted by nvisser (Post 254910)
Ajnabii Dear
Tec-Line / ASAP gauging systems
Hi Vissie .. great to read you again , all OK in sunny SA I hope. I have yet to hear any good reports from the Witts productions, rather a constant demand for 'gifts' and support and folks being 'Thrapped' The approach of the Backgauges website however seems very different because of your recomendation, and I know you to be an honest broker, I have read though that site now. I have looked at it before but in no real depth. It certainly explaines how machines such as this https://www.youtube.com/watch?featur...&v=98aiISB2DNw
do what they do and more importantly .. why . quite apart from what I have noted before, Still we do the thread an injustice going off subject .. so nuff said :cheers:
Duncan 06-14-2014 10:11 AM
quantum shield ?
Corona-Resistant Insulation Enamels :cheers:
OrionLightShip 06-15-2014 01:37 AM
For what it is worth
Just my opinion of the man behind backguages.com. I have talked for hours on skype with him more than once. I have google mapped his manufacturing facility and believe him to be an honest man of great integrity...something hard to come by these days.
I'm not smart enough to figure out what he is doing but I am convinced he has something worth investing time and money into if one were so inclined toward mechanical machines. :thumbsup:
:cheers:
