-   -   Earth Rods (http://www.energeticforum.com/renewable-energy/1663-earth-rods.html)
Aaron 02-12-2008 06:23 PM
Earth Rods
The purpose of this thread Earth Rods is to discuss Earth Rod applications on Bedini SG's or other circuits and maybe even with Peter's type of attraction motor concepts.
A variation was discovered with Technical Remote Viewing.The method Jetijs mentioned in the Bedini SG thread is the one discovered with TRV.
One thing to realize about Earth Rod applications from my experience is that the results are NOT consistent. This doesn't mean that you can't always have positive benefit, it just means the results change over time. ALSO, depending on other variables, the results can GROW over time.
I have shared this concept with a few Bedini experimenters and have received such a wide range of reports. I'm sure the geography has a lot to do with it...where are the Earth's acupuncture meridians in relation to the rods, etc...
I used to have Earth Rod systems going to grids laying under a bed mattress for healing purposes at a house about 7-8 years ago. John Bedini turned me onto the Earth Rod concepts back then.
A good way to find a good spot to put a rod is to get a multimeter and put it on DC volts. I had some long wires and alligator clips attached to the ends of the probes and the other end I had 3 foot rods...one steel and one copper. I would put one rod in the ground...doesnt' matter what rod you use for what charge because you're just looking for the largest potential difference you can get. One rod in ground...deep, then take the other rod and walk around with it sticking it in different spots. Wherever you get the highest reading, leave the second rod there.
Then mark where the first rod is, take it out and see if you can find a higher reading with it somewhere else, if not, put it back. If you get a higher reading, you can take the other rod and move it around and go back and forth. You're lucky if you can get 2 volts. I found 4 one time in my Qigong Master friend Rodger's backyard.
Anyway, this will show you some good spots either plus or negative.
For the TRV discovered rod method, it takes one rod...not for grounding purposes but to draw the aether from the ground.
EARTH -----> ROD -----> DIODE -----> POSITIVE ON CHARGING BATTERY
That's it! The TRV session was for logical next step enhancements to the overall SG circuits and with research combined with the data, the above is what it revealed. The line on the diode should be on the side of the battery so the positive voltage potential moves from Earth TOWARDS the charging battery positive terminal.
This is so easy for ANYONE to do that I would recommend that everyone at least play with it and try other variations if you want but the above is the exact method that was used on Kevin's SSG with the alternative superpole magnet configuration.
Be on the lookout for something else coming soon :)
Aaron 02-12-2008 07:17 PM
Bedini SG Earth Rod Video
Bedini SG Earth Rod video on youtube.
1 minute long.
Aaron 02-12-2008 07:24 PM
Bedini SG Earth Rod diagram
http://www.esmhome.org/library/john-...-earth-rod.jpg
peper10 02-12-2008 07:34 PM
I Aaron!!!!!
I have a question for you??
I look for a schematic for the earth magnetic poles and i find something
interesting!!!!!!
We can see that the globe is split in 2 parts.The upper part is equater field
going toward the north pole right??
And the other part is the equater field going down to the south pole.
My question is???
The earth rod would be pretty efficient if we used it as the core for the coil??
I think that,like 2 magnets ,the north attract the south right!!!
So if we are on the upper part of the globe we must arrange the coil to attract that field into the coil right?????
If i i'm out somewere please let me know!!!!!!
Thank's Aaron!!
peper10
peper10 02-12-2008 07:41 PM
HO i forget someting!!!
With the sg can we reverse the hole setup??
Having all magnet on the south side insted???
It's just to know if it's applicable to the earth rod..
My regards..
peper10
Aaron 02-12-2008 07:46 PM
earth rod as core
I like how you think... using the earth rod as the core! :thumbsup: Cool idea.
The whole SG CAN be reversed...can wind coil backwards and use south as the normal monopole field.
Can anyone see the video? I wonder why it tells me it is unavailable.
VIDEO IS FIXED.........
Aaron 02-12-2008 07:48 PM
rod as coil effects?
I wonder how the size of the rod (length down into the ground) will effect the coil charging and collapsing.
peper10 02-12-2008 07:57 PM
I think i catch something Jettis talk about.
He talk about the EATHER i think!!
Anyway the starting point for the SG is the coil catching more from the eather and a good timing for triggering RIGHT????
By the way Aaron, i try to see the vid on you tube and it's not working..
Thank's peper10
Aaron 02-12-2008 08:20 PM
NEW Bedini Earth Rod video link fixed
YouTube - Bedini SG Earth Rod
peper10 02-12-2008 08:25 PM
Originally Posted by Aaron (Post 16206)
Hey Aaron i wonder???:confused: :confused:
I'm i wrong or what??
The picture you show here suggest that we charge the battery by the positive side????
If so i'm completely off the track here...
I gonna do my homework and studdy it again..:thinking:
Thank's for you're patience
peper10
Aaron 02-12-2008 08:27 PM
coils on earth rods
Peper10,
John's link here:
New Page 2
Has this pic:
Coils on the ground probes:
http://www.icehouse.net/john1/stubrods1.jpg
Aaron 02-12-2008 08:29 PM
charging on positive
Hi Peper10,
That is for the positive potential and not electron current.
The Quantum Key book is a good primer on the aether theories involved with some of these circuits.
peper10 02-12-2008 08:36 PM
Originally Posted by Aaron (Post 16220)
Hi Peper10,
:v-peace: Ho!! Ok.
I think i misunderstand you.
peper10
elias 02-13-2008 07:12 AM
Pulling the Aether
I had experimented with charging capacitors before by using an antenna and an earth rod. So It may be possible to instead of drawing the aether only from the earth, draw it from the sky and the earth by a bridge rectifier. Isn't this reasonable?
Elias
peper10 02-13-2008 07:47 AM
Originally Posted by elias (Post 16229)
Elias
:thinking:
Hi Elias.
I'm not sure about that.If you look on the internet for(earth magnetic
poles) you gonna find that the drawings show that the 2 poles act as
they are sucking the magnetic.
So,the 2 poles are like the core of a magnet,and, the rest is the surrounding field of the magnet.
Like Aaron post earlier,you can see the earth rod have been used before.
It's not to proove something here!!!But i'm pretty sure if you dig in internet,
you gonna find much of information about that.
Thank's for you're idea.
peper10
CaptainScat 02-13-2008 08:07 AM
i found this schematic awhile back on the internet, i'm sorry i don't have the page address to give you also. thought it was sort of related. i haven't tried it yet, so i can't say if it actually works or not. maybe someone here wants to try it?
Aaron 02-13-2008 07:40 PM
antenna
Elias
I've used several antenna setups and did get benefit but I didn't do enough comparison to see what benefit came from where...antenna or ground rod. Either way, the effect seems to grow if left alone long enough...weeks to months. I'll bring some other things up soon.
If this particular setup is ground rod and diode to + on charging battery, try maybe antenna on the - of charging battery (same as + on input battery) if using SSG setup or not if using cap method. Try with no diodes, then try with diode pointing both directions.
Aaron 02-13-2008 07:42 PM
Radiant Garden?
As soon as it is time, my garden is going to be an earth battery coupled with an SG circuit.
peper10 02-13-2008 10:25 PM
:thumbsup: HI Aaron!!!!
Do you gonna try to put the earth rod into the core of you're last sg?????
Just wonder???
peper10
Aaron 02-13-2008 10:32 PM
earth rod as core in SG
Hi Peper10,
I have not used an earth rod as a core in a SG.
peper10 02-14-2008 02:12 AM
I would like PETER comments on this too!!!!!
Originally Posted by peper10 (Post 16208)
I Aaron!!!!!
interesting!!!!!!
My question is???
Thank's Aaron!!
peper10
I would appreciate if Peter Lindemann or John Bedini could give some comments on this setup.
I think they might have tried this before.
If so:What ares the results???
I realy appreciate if they can give some advices.
THANKS AGAIN..
peper10
Aaron 02-14-2008 03:02 AM
John Bedini and Earth Batteries
Peper10,
If you look at some of John's sites, he has a lot of research on earth battery concepts.
I have a compilation of his links here:
John Bedini | Radiant Energy
Also, Peter Lindemann has written about Earth Batteries in some of his older newsletters.
ronym 08-03-2014 08:40 AM
earth as negative pole
i think earth has capacity to become negative pole than positive pole
few years ago i have "weird" result from my "ground" pole
i using earth as negative pole against positive pole from ignition coil
this setup make it as unusual electrical circuit
because usually if we use earth as "grounding" we attach it with negative pole of battery
but this time i am not connecting negative pole of battery to the ground
( i just connecting negative pole of battery to 555+Transistor and negative pole of ignition coil )
"theoretically" this circuit will not work ( positive pole of coil are not against negative pole of coil... rather it's agains "nothing" )
but i am surprize by it's result :
1. high voltage DC, jump between positive pole of ignition coil and the earth. as if the earth become negative pole
( just make few mm gap between positive cable from coil agains floor or soil will do the same )
2. in this electric jump, i heard "humming" or "cracking" sound
3. transistor become colder ( compared to "normal" setup )
4. 555 output freq seems increasing ( if we attach it to running LED or freq counter we get freq of circuit jumping )
and when i turn the potentiometer i am failed to change it's freq
as if it's freq lock in the circuit
Bob Smith 08-04-2014 12:07 AM
Ronym,
This is very interesting. Am I right in understanding this is the way your set your circuit up?
- grounding rod connected to positive of battery (Lead acid battery?)
- negative of battery to 555 timer (astable mode)
- output of 555 timer to negative terminal of ignition coil
- positive terminal of ignition coil to earth with 2 mm spark gap between pos. terminal and wire
Is this the way you set your circuit up?
Bob
