-   The Crystal Radio Initiative (http://www.energeticforum.com/crystal-radio-initiative/)
-   -   Eric's "Crystal Radio Initiative" Challenge (http://www.energeticforum.com/crystal-radio-initiative/14371-erics-crystal-radio-initiative-challenge.html)
Sebacid 08-21-2013 10:30 AM
I thought this challenge needs some promoting to get us all involved in it.
I want people who are taking on this challenge to post their progress, results, questions, photos etc. in this thread.
Basically anything that involves this challenge belongs to this thread. We can assist each other in problems, setbacks, windings etc. and generally work together in completing Eric's challenge.
The objective would be to see how many of us can successfully complete this challenge. Hopefully it also encourages more people to experiment in this field.
Remember, the idea of the challenge is to get us thinking and doing things on our own, so please try it yourself first, then if you hit a wall that you can't breach, post here and ask help.
Don't give blueprints or schematics for a working system! If you manage to complete this challenge, post the date of completion here and we can compare results later in another thread specifically made for complete, tested and working setups.
In short, get off your monitor and start experimenting! ;)
-Sebastian Bowles -Lost in Northern Territory
Sebacid 08-22-2013 12:45 PM
Some excellent advice and info by Dr. Green
http://www.energeticforum.com/eric-d...ompendium.html
Some very helpfull scientific data and info on coil building etc. here. Use it to your advantage and learn from it. :)
:notworthy:
LutherG 08-22-2013 03:31 PM
Hi Sebastian,
What specifically is this challenge and where can I read up on it?
Best regards,
Luther
Sebacid 08-23-2013 07:52 AM
Originally Posted by LutherG (Post 238152)
Hi Sebastian,
Best regards,
Luther
Hi Luther,
The challenge is located amidst the jungle in this forum in Eric's posts as T-Rex.
Here is a short copy describing it:
"The objective here is to scale the “Crystal Set”, a step at a time, into a Tesla Transformer for the reception of medium wave band, 300 – 3000 kilocycle A.M. broadcasts. No license is required for this and the broadcast station provides the power.And this objective cooperates with the primary objective. That is; Who will be the first ham to disprove Einstein’s theory? An International contest, but who will sponsor it, Iran maybe?We have the good fortune in the “Crystal Set Initiative” that, in theory at least, a quarter wave A.M. broadcast tower, and its 120 quarter wave ground radials, must emit a pair of waves as shown by Tesla in his basic diagrams.
Hence it can be seen that a pair of waves are engendered by this transmission system. (Tower and Star Radials). One wave, Hertzian, is the over ground wave, the other wave, Telluric, is the under ground wave. These two waves arrive at the point of reception in their own distinct time frames, giving rise to a difference in phase. Hence, multiple rings of interference patterns are produced. Since the Hertzian portion, over ground, time frame is based upon the velocity of light, then the Telluric portion, under ground, time frame gives the Telluric velocity. Two crystal sets, one over ground, one under ground, and a basic oscilloscope , that simple. I have done this at Landers.Concluding, a Tesla Magnification Transformer, properly proportioned can, in theory, actually draw power from a local 50 kW station. Several hundred watts of power reception is likely. This would prove Tesla once and for all. No antenna, just a good ground, and a nice and bright 100 watt light bulb.This would overturn physics more than any billion dollar C.E.R.N. project. A ham radio operator overturns Einstein for 100 bucks. What a concept."
Read,
Tesla, “The True Wireless”
Tesla, “System of Concatenated Tuned Circuits”
Dollard, “System for the Transmission and Reception of Telluric Electric Waves”
A.R.R.L. “Radio Amatuers Handbook”. Chapter “H.F. Transmitters, & Tank Circuits”
Here is another link that has most of Eric's posts shortlisted:
Eric Dollard | Gestalt Reality
Hope this helps,
-Seb
wayne.ct 08-24-2013 11:42 PM
What would this look like?
I have looked at this and done a bit of reading at the context and I don't really have a good feeling for where to start. I am thinking perhaps I should apply some of the functions and formulae that EPD has gathered and perhaps compute the size and other parameters of the necessary coils and capacitors? If someone would suggest some specific numbers and create an example of the calculations, that would seem like a helpful starting point. First, pick a typical AM frequency, such as that of your local 50 KVA AM station, and use that as an example. It seems we need to solve a simultaneous equation. There are two values for inductors and also two? values for capacitors. Then there is the actual circuit diagram. Again, I have a picture in my mind, but I'm not sure if it is right. If you want to post you sample data, my eyes are open. Thx.
Attachment 13624
Sebacid 08-25-2013 05:14 AM
Attachment 13624
Hi Wayne,
All the information necessary to do this can be found in this forum under Eric's posts as T-Rex. See links in my previous reply. You just have to get your hands dirty and look for the information. That is a part of the challenge, to get people doing.
But here's some advice to get you started:
"The design of the Tesla Transformer starts with the secondary resonant coil. In its resonant mode it is a quadrapolar resonator. Two constants exist in the construction of this solenoidal resonator, one is that the height to length ratio must be 20%, the other is that the side by side spacing of the cylindrical conductor turns is 62% the diameter of the cylindrical conductor. The optimum number of turns is 20 on the secondary, with 2 on the primary. This gives the physical size of the coil for a given frequency. Increasing the number of turns reduces the size of the secondary coil in proportion to the increase in turns. Accordingly the conductor diameter also decreases as the copper is spread out over more windings. The ratio of secondary turns to primary turns must equal a constraint of 10 to 1. For a given number of turns the operating frequency becomes the sole independent variable in coil design.The primary coil is the same diameter as the secondary coil. The ratio of conductor width to coil diameter is 18%.
The sheet conductor is closely spiralled into two turns, for a secondary of twenty turns. For a conductor thickness as given by the maximum thickness vs frequency the volume of the primary metal must equal the volume of the secondary metal, based upon equal weights for primary and secondary metals. Brass can be 1.7 times thicker than copper, and bronze can be 2.8 times thicker than copper, for a given maximum thickness and frequency.The primary condenser should be made of the same amount of metal as the primary coil. Their weights should be about the same. The connecting leads must be short and the same width as the primary conductor. Large, multiplate air condensers are good, so are metal sheets and glass.The secondary capacitance is best a copper tubing ring around the outside of the H end of the coil. This ring must be open in one spot along its loop so as not to be a shorted turn. The end of the secondary wire connects to this capacity ring. Beer cans make the best elevated capacitors.The finished transformer must operate on a directly connected ground plane. A large plywood table with aluminum foil glued on to it, this covered with a plastic or glass sheet is the minimum required ground plane. Obviously the aluminum plane must be solidly earthed with special attention to minimizing ground lead inductance. In order to light a lamp a more broadcast station style of ground plane is required, but for testing purposes the metallized plywood “ten by” sheet is just fine. Good luck and good crystal set DX ing.
http://www.gestaltreality.com/wp-con...former-001.jpg
http://www.gestaltreality.com/wp-con...ndary-Coil.jpg
Hope this helps to get you started?
-Seb :thumbsup:
wayne.ct 08-26-2013 02:28 AM
Sample calculations
OK, based on your suggestions and the calculations you have posted, I can visualize the transformer. It will be small enough to hold in one hand.
Here is what I have done so far:
I will be using 750 KHz as my center frequency as an example. This frequency is used by the famous WSB.
WSB is a 50,000 watt clear channel broadcasting station in Atlanta, GA.
The antenna is located in Tucker, GA according to Wikipedia.
Calculation #1
L = Total length of coiled wire
L = f/w = 299,792,458 (meter / second) / 2 * PI * 750,000 (/second)
= 299,792,458 / 2 * 3.14159 * 750,000 (meters) = 63.62 meters = 63.62 meters * .3048 ft / meter
= 19.39 feet
Calculation #2
L = Length of each turn = 19.39 feet / 20 = 0.9695 feet = 11.63 inches
Calculation #3
Circumference C = L; Diameter = Circumference / PI = 3.7 inches
H = Coil height = 0.2 * Diameter = 0.2 * (11.63 inches / PI)
= 0.74 inches
Calculation #4
Max diameter of wire. Space between strands of wire is 62 percent of wire diameter.
20 turns take 0.74 inches ===> 1 turn takes 0.74 inches / 20 = 0.037 inches
0.037 inches = 162 percent of wire diameter ===> 100 percent of wire diameter = 0.037 / 1.62
Wire diameter = 0.02286 inches (max.)
AWG 23 has a diameter of 0.0226 inches / 0.573 mm.
AWG 23 has resistance of 66.79 ohms / Km. which is 20.36 mOhms / ft.
For 19.39 ft, the coil will have 395 mOhms or 0.395 Ohms resistance.
I thought it would be larger than this. So much for my intuition.
Sebacid 08-26-2013 09:47 AM
Calculation #1
= 19.39 feet
Calculation #2
Calculation #3
= 0.74 inches
Calculation #4
There is a small mistake in your calculations...
L = f/w THIS IS WRONG, it should be c/w! (but you have calculated it correctly) = 299,792,458 (meter / second) / 2 * PI * 750,000 (/second)
= 19.39 feet
THIS IS WRONG!
If converted then 63,62 meters gives roughly about 209 feet (63,62x3,28=208,67).
That shouldn't fit in your hand anymore... :)
Remember you need two different setups, one wave, Hertzian, is the over ground wave, the other wave, Telluric, is the under ground wave. These two waves arrive at the point of reception in their own distinct time frames, giving rise to a difference in phase. Hence, multiple rings of interference patterns are produced. Since the Hertzian portion, over ground, time frame is based upon the velocity of light, then the Telluric portion, under ground, time frame gives the Telluric velocity. Two crystal sets, one over ground, one under ground, and a basic oscilloscope , that simple.
A great link for most information needed is provided in my first answer in this thread. Happy experimenting!
-Seb
Sebacid 08-28-2013 05:03 PM
Just finished my calculations for my secondary coil and it will be a whopping 76cm in diameter! I am going with 1000Kc/sec Frequency.
I finished the work on the wooden bases and supports, all that is left is to bake and laquer them before assembling.
My extra coil's diameter/height is going to be 30cm.
Some calculations with other stuff is still going on, but I'm going to build two identical coils of the exact same size, one for overground Hertzian wave reception and the other for underground Tellurical wave reception.
The coils will be identical but the setup will be different as the goal is to light a 100W lightbulb with the other coil.
We'll see how things go once I have built them.
-Seb
Sebacid 08-30-2013 07:48 AM
-Seb
Thinking of replacing solid wooden supports, with hollow pvc tubing (thin) to minimize stray inductance? Any thoughts on this?
dR-Green 08-30-2013 10:43 AM
Hi Sebastian. Yes PVC tubing will be better than wood. Also ideally you should design the coil for a specific frequency/radio station, 1000 kc is a general example. When tuned to different frequencies the magnification factor will alter, the goal is to have highest magnification factor at the intended frequency so different tuning will work against this. Although you will need to experiment to find the highest magnification factor with a given design anyway.
For the overground wave reception you should use a normal crystal radio or a normal radio receiver. You need to receive the signal as normal and then measure the difference.
Sebacid 08-30-2013 12:04 PM
Hi Dr. Green,
Thank you for your insight, I will have to do some searching on a AM radio station near me (Finland). The problem here is that almost all of the broadcasting stations have ceased using the AM frequencys. I think the nearest one is in Holland?! Not sure on this, must check.
In the calculations for the extra coil, I get a totally different total lenght of coil if I use the formulae by Eric to calculate it?
Tesla's Colorado extra coil had the same amount of wire as the secondary (800m). Should I go with this or trust the formulae?
Thanks again,
-Seb
Post edit:
Found a radio station from Sweden, Stockholm radio that broadcasts at 1710Khz AM frequency. I think it is still operational, so I will try working with this frequency. The last AM radiostation in Finland ceased to operate in 2007. Any other known operational frequencys are welcome! :)
Time to do the calculations again! :)
dR-Green 08-30-2013 01:32 PM
I forgot to mention, use white or clear etc plastic rods. Apparently to make black and grey they put carbon in it, so that won't be good.
Eric's design is different to Tesla's. Eric's theory involves concatenated resonance with the extra coil as a distributed network, whereas Tesla's is lumped. So it's completely experimental. I've tried 3 different extra coil variations, and Eric's latest comments on it was that the secondary might need to be of a lower inductance, so my latest design is a bit different. I have 17 turns secondary with 15% height to diameter ratio, and the extra coil, when calculating wavelength from frequency and speed of light, has 1.19 times longer wire length because of the "faster than light" propagation, wire length is extended to bring the frequency back down.
[edit] Probably the easiest way to find whether a radio station is operational and suitable or not is to use a radio. When you find one then you can find info on it on the internet.
Kokomoj0 08-30-2013 05:44 PM
for accurate time comparison how do you compensate and adjust for delay differences that result from the inherent design differences between the telluric and atmospheric versions?
and one more....
how do we calculate the maximum theoretical (ideal conditions) power that can be drawn from a transmitter with a particular receiver design/situation
dR-Green 08-30-2013 06:07 PM
Use an oscillator and tune both receivers to be in phase.
Beats me. How's your geological skills?
wayne.ct 09-01-2013 05:14 PM
This is out of my league
Correcting my error and still using 750 KHz as my center frequency, this is what I get...
Calculation #1
L = c/w = 299,792,458 (meter / second) / 2 * PI * 750,000 (/second)
= 299,792,458 / 2 * 3.14159 * 750,000 (meters) = 63.62 meters = 63.62 meters / .3048 (meter / ft)
= 208.7 feet
Calculation #2
L = Length of each turn = 208.7 feet / 20 = 10.44 feet = 10 feet 5.23 inches
Calculation #3
Circumference C = L; Diameter = Circumference / PI = 3.32 feet = 3 feet 3.86 inches
H = Coil height = 0.2 * Diameter = 0.2 * (10.44 feet / PI)
= 7.97 inches
Calculation #4
20 turns take 7.97 inches ===> 1 turn takes 7.97 inches / 20 = 0.4 inches
0.4 inches = 162 percent of wire diameter ===> 100 percent of wire diameter = 0.4 / 1.62
Wire diameter = 0.246 inches (max.)
AWG 3 has a diameter of 0.2294 inches / 5.83 mm.
AWG 3 has resistance of 0.646 ohms / Km. which is 0.197 mOhms / ft.
For 208.7 ft, the coil will have 395 mOhms or 0.4111 Ohms resistance.
Now we have a manly sized inductor! 'Sorry to say I will not be building that any time soon! Thanks for the ride!
At the same time, my intuition was telling me this was going to be a large coil. So, I feel a bit better knowing my gut was in the ballpark.
Sebacid 09-02-2013 09:14 AM
Calculation #1
= 208.7 feet
Calculation #2
Calculation #3
= 7.97 inches
Calculation #4
You can always use another frequency (higher), then the coil, wire etc. size will be smaller. Try for something in between 2000-3000Kc/sec? As Dr. Green said earlier, the idea is to magnify the chosen frequency to the max!
Don't give up, build a smaller one first, experiment on it and if succesfull, upscale it on the next one!
Cheers,
-Seb
Sebacid 09-13-2013 08:22 AM
Wire?
Does it matter if I use insulated wire for the winding? Or is it better if it was copper?
orgonaut314 09-23-2013 02:02 PM
Every insulation will increase the self capacitance. Now I think it was better to keep that one low as possible.
Apart from that be careful with the material you use. If there is Orgon than organic materials like wood or materials like coper are preferable. In another type of research we found out that Orgon does become sickening if you use the wrong materials that your body does not like when you would eat or drink them. I would be careful with pvc that contains chlore. Even the thin insulation on the coper wire might be wrong. But this is only important if you want to make a coil that does not make people get an head-age.
Jeff Pearson 08-01-2014 07:02 PM
I was experimenting with crystal sets last year
Was listening to clear channel stations 2 states away at night with crappy antenna. Powered piezo headset i made. no power source for radio except radio waves. I learned a lot doing this. was gonna try ground antenna next Harris Rogers style.
parkham 08-07-2014 02:01 PM
I hope this isn't a completely question - When he says "Total number of turns", Given 20 - what does he mean by 20? Would that be 20 turns per inch?
The same for the next formula, "Given 20%" What exactly does that mean as well?
Please pardon my ignorance. I've got all the components together to start on a crystal radio - I want to fully understand before proceeding though.
dR-Green 08-07-2014 08:35 PM
"Total number of turns = 20" means exactly what it says. 20 turns in total on the coil.
The 20% is in reference to the height/length to diameter ratio of the coil. The coil is 20% high as it is wide. If diameter = 100cm then height = 20cm.
Sebacid 05-12-2015 08:03 AM
Would you agree that the smaller Ø the acrylic clear and hollow tubes the better?
Aaron 09-18-2015 07:04 PM
crystal radio initiative book updated
Book for Crystal Radio Initiative page 20 & 21 has been corrected and is available at same download link.
LeeBob84 03-26-2016 02:33 AM
Crystal radio initiative
2 Attachment(s)
I have been working on a large coil for the crystal radio initiative. This is a few pics of it
Attachment 16937
Attachment 16938
Frequency : 800khz
Coil diameter:4'10"
Number of turns: 18
Wire length : 247'
Coil height:14.4"
Wire diameter : 0.5"
I made a hemisphere from copper pipe, with a 16 point aluminum star as my top load. All that is left is to bury my 4 a/c radiators as my ground, wrap a 12" by 2 turn secondary coil on the bottom and build my resonant capacitor. Hopefully I can tune it up to receive some usable energy. U can follow me https://youtu.be/HyRhUStqzt4 , https://youtu.be/jncwulYUpV4
Aaron 03-27-2016 02:55 AM
Live call with Eric
That's great LeeBob!
If you have any questions for Eric, we have a live call tomorrow:
This coming Sunday the 27th at 11AM Pacific Daylight Savings Time, we will be having a LIVE Q & A call with Eric Dollard.
Conference Dial-in: 1-857-232-0155 and Conference Code: 582590 – It will be recorded in case you cannot make the call.
Attachment 16937
Attachment 16938
Frequency : 800khz
Coil diameter:4'10"
Number of turns: 18
Wire length : 247'
Coil height:14.4"
LeeBob84 04-14-2016 06:17 AM
Thanks Aaron,
Unfortunatlly I missed that call with Eric, Where would I be able to listen to the recording of the call?
One question I did want to ask him was about using a ribbon conductor supposed to the traditional round wire conductor and if there were significant differences calculating for it?
Aaron 06-11-2016 07:05 PM
Originally Posted by LeeBob84 (Post 287623)
Thanks Aaron,
The recording is on his site embedded as a youtube video.
What do you need to finish your project in terms of parts and funds?
LeeBob84 06-18-2016 01:50 AM
6 Attachment(s)
Wow that is awesome thanks Aaron.I have the primary and secondary windings wound, and have been trying to get a good ground system put in. I am living in a rental house at the moment so my original idea of digging four large holes with radiators buried in the yard is a no go. So i have come up with the idea of pounding holes about 4 to 6 feet deep with a 1 inch piece if pipe then removing the pipe, feeding a piece of 4 gauge copper wire to the bottom and pouring molten aluminum down the holes till they are full. I have finally completed mt foundry and poured about 3 pounds of aluminum in the first hole. My biggest hold up now is trying to come up with funds to buy scrap aluminum and fuel for my foundry. I figure that i will need a total of about 75 pounds of aluminum and probably 100lbs of propane to finish. Any Help with that would be more than appreciated. Also I am in need of a good adjustable capacitor for this project to.
Attachment 17235Attachment 17236Attachment 17237Attachment 17238Attachment 17239Attachment 17240
Thanks again
Let me know
Aaron 06-18-2016 05:47 PM
cri
Thanks again
Let me know
Please email me at info at emediapress dot com and copy and paste your message here to me - I can help.
