Self-Looped Motor-Generator by usweentop
  • Self-Looped Motor-Generator by usweentop
    I recently saw this video and thought I would post it here.
    1. Listrik Gratis 4000 watt dari Bangka Tengah Babel.3GP - YouTube
    2. Download mp4 copy of video by clicking here. Get your copy before it's removed!
    3. Q-Mo-Gen : Self-Looped Motor-Generator Open Source
    4. Directory:Self-Looped Motor-Generator by usweentop - PESWiki
    ASWIN LOOPED HOME GENERATOR SYSTEM
    Aswin says: I am using a Stavolt, voltage and frequency stabilizer to keep the voltage and frequency output exactly at 220Volts and 50 Hz. It is necessary to have the proper voltage and frequency to power the motor, to keep it spinning at the right rpm. Input power from generator is 180 - 240 VAC/ 43 - 55 Hz and Stavolt output must be 220 VAC/ 50 Hz. It must be keep at this voltage and frequency.*I have replaced the potentiometers to a larger size, so I can adjust the voltage and frequency for what the motor needs.
    1. The system is very simple. We just keep the voltage and frequency to at least 220v/50 Hz. Only slightly reduced, it will not work. Therefore, I modified the motor with permanent magnets on the rotor so that it becomes a generator. And I think, it will reduce the load off the generator, because it doesn’t have to expend any energy to energize the field windings on the rotor of the motor.
    2. I use 2 capacitors for the motor. All wiring is tuned in parallel.
    3. Yes, you right. Stavolt function is for frequency stabilization and voltage stabilization of power output and to keep it at the proper voltage and frequency to run the motor.*
    4. For the generator, size of pulleys is 4 inch. And motor pulleys is 2 inch. I got the ratio by experimentation.
    5. Generator voltage is 220 VAC/ 50 Hz/1500 rpm. Motor 220 VAC/ 50 Hz/ 2850 rpm. Both have been modified with permanent magnets on the rotor. ????? Maybe not the generator???
    6. Four pole, 1500 RPM 220 volts, single phase, 50HZ, 4000 or 5000 watt Dong Feng ST series Generator.
    7. Two pole 2850 RPM, 50 HZ, 220 volts, single phase motor.
    8. Modified potentiometers on AUTOMATIC VOLTAGE REGULATOR.
    9. Four inch pulley on Generator, Two inch pulley on Motor.
    10. ???? Microfarad Capacitors in parallel on MOTOR and possibly on GENERATOR. Tuned with decade boxes under load when all hooked up with belts.
    11. STAVOLT, Three thousand watt 220 volt single phase variable AC 180 - 240 VAC/ 43 - 55 Hz input with 220 volt AC VOLTAGE AND FREQUENCY STABILIZED output hooked to output of the Generator.
    12.
    Comments from Aswin
    Aswin comments from YouTube:
    Comments from YouTube
    usweentop commented
    Sep 30, 2012
    Greetings. Thank you for renpons of teman2 in the field of electricity. To
    exchange information, please email to usweentop@... eater. For video
    reference, please look at youtube:
    1) 3000 Watt Generator Powers Itself, Grinder & Drill Press
    2) Self-Running 40kW (40,000 Watt) Fuelless Generator
    3) Self Running 2000 Watt Fuelless Generator
    usweentop commented
    Oct 1, 2012
    1) AC Generator 220 V, 5000 kVA, 1500 rpm.
    2)Electric Motor 220 V, 1200 watt, 1 HP, 2850 rpm.
    3) Timer Delay.
    4) Magnetic Contactor. SALAM
    usweentop commented
    Oct 7, 2012
    Thank you for the response all my friends in the field of electricity. To
    reference, please see on youtube:
    & Drill Press
    2) Self-Running 40kW (40,000 Watt) fuelless Generator
    3) Self Running 2000 Watt fuelless Generator
    usweentop commented
    Oct 7, 2012
    We are sorry, this experiment still many shortcomings. And we continue to look for the best solution. To exchange information, please contact to my email.
    Usweentop@...
    usweentop commented
    Oct 7, 2012
    For equipment, I mentioned in the video comment. To exchange information, please contact to my email usweentop@...
    usweentop commented
    Oct 7, 2012
    You can see a list of components and specifications that I have written.
    Required power an electric motor must be smaller than the generated power
    generator.
    usweentop commented
    Oct 7, 2012
    Right. The theory basically like that. The tricky part is that you have to
    modify the generator AVR and seek appropriate comparisons poly
    usweentop commented
    Oct 7, 2012
    Generated power generators must be greater than the power needed electric motor driving
    usweentop commented
    Oct 7, 2012
    AVR generator to be modified to maintain a stable output. Only it
    usweentop commented
    Oct 7, 2012
    I have not tried
    usweentop commented
    Oct 7, 2012
    I have not tried. For a while, I focus on the circulation of air currents. Load
    power used must not be greater than or equal to the generated power generator. Output power should be limited. That's what the MCB. Congratulations for those of you who already tries to lighting in your area. Success always
    usweentop commented
    Oct 7, 2012
    Thanks for the correction. Free in question is free from pollution. Free from
    dependence on fossil fuels
    usweentop commented
    Oct 7, 2012
    Greetings also. For a while, the device is far from the market because it is
    still in the stage of experiment that should continue to be refined
    usweentop commented
    Oct 7, 2012
    220 V
    usweentop commented
    Oct 7, 2012
    Generator AVR must be modified slightly. If necessary, given the generator
    output voltage remains stable stavolt order that will keep the electric motor
    rotation. To exchange information, please contact to my email
    usweentop@...
    usweentop commented
    Oct 7, 2012
    usweentop commented
    Oct 11, 2012
    Yes, you right. But there is was modificated to be permanent magnet
    usweentop commented
    Oct 12, 2012
    The generator and electric motor has been modified to be permanent magnet. Time delay provides sufficient time for stability of voltage and frequency
    usweentop commented
    Oct 12, 2012
    Yes, I do it.
    usweentop commented
    Oct 12, 2012
    No, I'm not hide anything. I'm just waiting for right time and right place to share my experiment for right man.
    usweentop commented
    Oct 12, 2012
    So thank you for your advice. So far, I'm fine
    usweentop commented
    Oct 13, 2012
    I've already mentioned here, that the disadvantages are:
    1. Have not found the UPS to start early
    2. Often occurs over speed when the load is reduced
    3. Over heating
    usweentop commented
    Oct 15, 2012
    Sorry, I do not feel as inventor. Maybe there is earlier than me and probably
    better. Here I will just hold experiment. I just assemble and combine multiple
    comp
    > Satu kekurangan kami, kami tidak memiliki UPS yang berdaya 2000 watt atau
    lebih. Bila ada UPS tersebut, start pertama elektro motor tidak memakai listrik
    PLN. Semoga karya ini bisa memajukan IPTEK bangsa Indonesia. Bisa dibayangkan,
    suatu saat nanti seluruh rakyat Indonesia menikmati listrik gratis karena setiap
    rumah memiliki generator tanpa bahan bakar apapun. Mobil, motor, perahu nelayan,
    kapal, kereta api, PLN, pabrik-pabrik dll tidak membutuhkan BBM lagi bila
    menerapkan teknologi ini. Mohon dukungan dan saran atas karya ini. Maju Bangka
    Tengah... Majulah Indonesiaku.... Bangkitlah wahai anak negeri!!
    > Google Translate:
    > One shortcoming, we do not have a powerful 2000 watt UPS or so. If there is a UPS, the motor does not start the first electro electricity use. Hopefully this work can advance the science and technology of Indonesia. It is conceivable, that one day all the people of Indonesia enjoy free electricity for every home has a generator without any fuel. Cars, motorcycles, fishing boats, ships, trains, PLN, factories, etc. does not require fuel again when applying this technology. Please support and suggestions on this work. Central Bangka advanced
    ... Go ahead Indonesiaku .... Arise, O country boy!
      Tragedy For Inventor
      Aswin's wife killed in an automobile accident on 10/22/2012:
      Re: Hi Aswin; you okay?
      Posted By: sterlingda888
      Mon Oct 29, 2012 5:38 am
      Hi Aswin,
      I'm so sorry to hear about your loss.
      Remember: God will not give us trials beyond what we are able to handle.
      Our condolences and prayers go with you at this difficult time.
      Sterling
      ----- Original Message -----
      To: Sterling Allan
      Sent: Monday, October 29, 2012 4:59 AM
      Subject: Re: Hi Aswin; you okay?
      Dear Mr Sterling,
      On October 22, my wife had died by traffic accidents. I really sorry if I can not answer all the questions of my friends. I'm still sad. God Bless You.
      Best regards
      Aswin
      2012/11/20 Sterling Allan <sterlingda@...>
      Hi Aswin,
      You were being so helpful on the Q-Mo-Gen forum, then suddenly went quiet.
      You okay?
      | Sterling D. Allan,
      | New Energy Systems Trust (NEST), President
      | Birddogging How Valuable Would a Working Free Energy Device Be.docx | Home Page | Pretoria South Africa
      | (Pure Energy Systems) PES Network, Inc., CEO
      | Main Page - PESWiki
      | "The best news and directory service on the net
      | regarding cutting edge energy technologies."
      | Profile: Sterling D. Allan
      | Phone: +1-801-407-1292 (mountain time)
      | Ephraim, Utah, USA
      | "The government's job should be to protect freedom, not control our lives."
        What is a Stavolt
        Here's an example of what they mean by a Stavolt (Stavol):
        Matsunage Stavol Step Up Down 110 V 220 V Voltage Regulator 350 w Japan | eBay
          Stavol
          One of the things that I find interesting about the Stavol is its capacity to act as a automatic frequency and voltage stabilizer.
          I believe Aswin said in one of his messages that the frequency and voltage for the motor must be constant. That's why he's using a Stavol, but I believe he said it was modified.
