New permanent magnet motor video
  • New permanent magnet motor video
    Saw this on overunity.com and I have a feeling this fellow might be on the right track.
    YouTube - Magnet Motor Prototype
    The problem I have seen with all permanent magnet motors so far is that everyone keeps thinking in two dimensions which is a big shortcoming.
    This fellow has expanded into the third dimension and you can already see improvement over those two dimensional spiral motors.
    I would take this a few steps further (or turn it up couple of notches ). Instead of a cylinder use an inverted cone (apex down) so that we have a vortex/spiral, and pieces on the cone are constantly spiraling or "falling" down into the vortex. I remember reading about David Hamel and his revelations where he said that his device is all about being out of alignment and constantly "falling" so that clicked in right away after seeing this.
    First, try to duplicate!
    Amigo,
    This is very interesting. It certainly represents a new and different method for a permanent magnet motor. If you are interested in this idea, I highly recommend that you first try to DUPLICATE the design shown in the video clip. IF you can get it to run, THEN you should think about modifying it or improving it.
    There are still a few unknowns. We don't know what magnets he used or the polarity he used to face the screws. Did he use all the same poles facing the screws, or did he alternate the poles? Or did he face the edge of the magnets to the screws, with the poles facing each other?
    The idea seems simple enough to work with.
    Good find!
    Peter
    Peter Lindemann, D.Sc.
      constantly falling
      Stefan Marinov had an "infinitely long Siberian Coleiu (spelling???) magnet".
      Infinitely long seems to be the same concept of "constantly falling"
        Aaron, this must be it, will take a read at the paper: Coliu
        Peter, I usually try to visualize something and at the same time recollect things I have seen, heard or read from the past that might apply to the task at hand.
        This process is seemingly transparent for me most of the times, and so I see it as a gift - being able to connect abstracts that at first sight do not have anything in common.
        Though I'm not Tesla who could visualize a machine in his mind, set it up and let it run until it breaks, then figure out why it broke and make his physical design with corrected parameters, thus succeeding with it the first time around.
          YouTube - How to Power Your Car Using Magnets - HacknMod.com
          Check out this video for an upgrade of that same device
            Witts
            HoJo Motor A Working Free Energy Machine - BANNED FOOTAGE! - YouTube
            Mag Motor video. I have been seeing this type of free energy demo for 40 years now with no end in sight. I am sure one exists some where.
            Even displaying the principle operation as demo is very threatening to the big oil cartel.
            This vid must be from waaaay back when with most of us sitting on the fence.
            That is WILTS not Witts sorry.
            Keep Duckin
            Mikey
              [QUOTE=BroMikey;261179][url=http://www.youtube.com
              Mikey[/QUOTE]
              That motor wont work
              Why? because at high speed the mutual induction will create slippage and the whole thing will fly apart (or shake like an earthquake).
              You cannot make a machine that works off centrifugal and centripetal field reciprocation, rather only one that runs off of (.......X.........) no comment.
              Id give him $100 to run it even at 60 RPM, much less 100, it would slip and shake like Hades warmed over.
              That machine will "operate" beautifully at VERY LOW RPM, otherwise its a steaming pile
              You have to understand magnetism before you can use it properly.
                Just like to say that every kind of magnet motor that I have tried to build, and there's been a few, have always balance themselves out. Not that I've tried everything by any means, but whatever I've done forces just end up equalizing.
                  I, too have built many magnetic motors. Almost all have equalized after a brief running period. Only two prototypes have caused me to reevaluate what is happening and why. Both use magnetism and gravity working in unison to propel the machines. I think a pure magnetic motor is possible given the correct alignment and dimentions. But I also feel that a combo motor is more practical, using magnetic and another energy source to compliment each other. I am now designing a new motor to utilize these energy forces to enhance the power and adding to the magnetic power already inherent in the magnets. I have two such machines on the drawing board(cad) as we speak. With some tweaking and experimenting, it should be very possible to get one, if not both up and self running. Both use the same concept but very different configurations. Only after I build a prototype will I know their limitations and parameters. I have hope that, at least one will be feasible as a self running motor. One will be very simple to build, while the other one will require major machining and strict tolerances. Good Luck with your designs. Stealth
                    Thats because you (and everyone else also) think they're messing with magnets when they use "magnets"
                    they aren't. Whats that mean?
                    It means any and all magnets you ever had your hands on are electrified dielectric objects with (under perfect conditions) a ratio of 3.23606 units of dielectricity to 1 part magnetism. At 90 degrees from any "pole" around the center is the inertial plane , or dielectric 'flywheel'.
                    Everyone is 'looking' at the precessing and reciprocating axes of a magnet, just like someone who can only see the precessing axes of a gyroscope but is utterly ignoring the giant spinning flywheel at 90 degrees to the precessing axes.
                    See the book for reference. https://archive.org/details/magnetism1small
                      Congratulations This is the correct approach I'm sure. However I still think magnetic motor is not much usable due to costs per output power...
                        Easy Magmotor
                        @Boguslaw
                        @Stealth
                        @ Theo
                        Here is a vid of magmotor just simple magnets on an angle. I have never seen such a simple arrangement that produces power for free.
                        Free Energy Magnet Motor fan used as Free Energy Generator "Free Energy" light bulb - YouTube
                        If a set of magnets could be put on any fan blade you could have a free fan.
                        Is this possible? Has anyone used magnets like this?
                        This one is big NO scam (it's a REAL DEAL) Muammer Yildiz Magnet Motor demo at Delft University - YouTube
                          yes, that Indian guy and his watch batteries taped to the side of the fan motor. Either than or an induction field under the table.
                          Ive seen that bogus video a few times.
                          Some people send me links to that video.
                          He should become an illusionist
                          HE MAKES A HUGE MISTAKE AT 2:17 ON THE VIDEO, where you can see the fan blades stop moving VERY QUICKLY, hes got it powered externally
                          Field pressures always find equalization, you can build one yourself, it wont work.
                            Magnet secrets
                            Thanks Theo
                            Here is the secret of magmotors
                            I think?
                            Self Running Magnetic Motor Stator Test #2 update - YouTube
                            See the speed of acceleration.
                            Is this a fake? Is everything a fake?
                            Free Energy Selfrunning Magnet Motor ??? - Fact or Fake ? Wasif
                            Kahloon challenge to the engineers - YouTube
                            Discovery Of Magnetic Shielding For All-Magnet Motor. The Holy Grail Of Free Energy. - YouTube
                              also fake, Ive seen that one before.
                              THIS ONE IS REAL:
                              https://www.youtube.com/watch?v=b-MSiQTXIG0
                              however he doesnt understand WHY he needs to have a missing magnet
                              AND what 'destroys' his experiment is that he keeps having to move his tube which is inducing counter precession to the reciprocating fields of the magnet on the table.
                              He has to create precession to get the 'results' he thinks is power generation.
                              THIS ONE IS REAL TOO:
                              https://www.youtube.com/watch?v=rZIrTUenGAE
                              I mess around a lot with pyrolytic graphite
                              however at PERFECT design (which his certainly is NOT), you might get only a very few milliwatts out of it.
