Geocentrism and the corruption of science
  • #16
    GEM=Geometrical Electricity Multiplier
    You just have to be multiplying AC electricity, when you only input one spark
    = small amount of DC electricity that it takes to rotate a motor one single time,
    + get a return of 1000 cycles of AC electricity
    These AC generators run free of most all torque, as they only need to generate one spark of DC current, to make this free energy technology self powered, + crank over your DC motor one time
    This works on the simplicity of only having to pay the small amount of electricity, (massive voltage + only one spark of current) for the one single rotation of a DC motor with a large 100 cm circumference pulley attached. Then you take the 100 cm of moving belt, that comes from the one rotation of your 100 cm circumference pulley, and run it past 10 of the 1 cm circumference pulleys. This would multiply your # of rotations to 10 X 100 = 1000, and if you added AC generators to these 10 mini-pulleys you would gain a total of 1000 cycles of AC electricity.
    These AC generators would run free of most any torque, as they are just winding up massive voltage,(which is what you need to crank over your DC motor=electrical pressure) as the only current that they need to generate is the one spark, or practically zero. You only need to generate one spark of current, because that is how much current that it takes to rotate your DC motor, with the 100 cm circumference pulley one single time. Of course you would also need 10 full wave bridge rectifiers, (4 diodes each) to convert your AC outputs back into your DC input.
    you are trading one rotation of a 100 cm circumference pulley, (taking massive voltage) for 1000 rotations = 100 rotations each from 10 mini-pulleys with AC generators (creating massive voltage)
    This is so simple that it just has to work.
    It only takes one spark of DC current to rotate a DC motor one single time,
    + If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm
    of moving belt Then, if you run this 100 cm of belt past 10 of these free running 1 cm circumference mini pulleys you would get 10 X 100 = 1000 rotations.
    If you add 10 AC generators, one to each mini-pulley,
    These 10 AC generators run torque free, as they only need to generate one spark of DC current,
    which is practically zero, and practically zero current, times even massive voltage,
    is still equal to practically zero.
    • #17
      forces in a geocentric universe
      It is easy to visualize centrifugal force holding the stars outward against gravity of the spinning universe, but that only applies along the equatorial plain. That force decreases as a function of angle above the the equator. So what is holding the North star suspended, theoretically directly on the axis of rotation? Well it is the coriolis force, twice as strong as centrifugal and acts at right angles to the plain of rotation. This was taken into account by Mach and Euler in their analysis of forces at play in a universe in motion. These forces are called "artificial", not to be confused with emf, magnetism or gravity. But they are very real and essentially strange. Why in the world the coriolis force acts as it does, I would say you have to ask God. But it makes a geocentric view of the universe obey the math. To describe how we may understand this force, quite simply, we could not balance and ride even a bicycle without it. Dr Sungenis has provided me an example proof how to work this force into a derivation provided by Dr. Gerry Bouw. He states after deriving a final formula based on angular momentum, Radius, declination, and others:
      "Not only will each celestial object be held in place by this equation, light itself will also obey this equation. In the geocentric Universe light can assume any speed since (a) limitations to light speed do not apply to rotating frames, and (b) inertial forces can accelerate or decelerate light’s speed."
      Up, Up and Away
      • #18
        A request to Dingus for more explanation
        Originally posted by Dingus View Post
        Atoms consume aether at a constant rate that varies depending on the element. Gravity is the movement of atoms from a high-pressure zone of aether to a low-pressure zone. Magnetic fields as well as the positions of the moon, sun & other large bodies with gravitational fields strong enough to affect earth will produce measurable changes in the pressure & direction of the flow of aether/gravity. The speed of light changes depending on the density of the medium it travels through, just like sound.
        If Michelson & Morely had tested the speed of light every hour in a day for a month rather than once every six months, they would have understood why geocentrism is wrong.
        Ok, you've planted the hook. Sagnac and Michelson Gale showed that the earth and the ether have a rotational velocity difference, which verifies interferometery works and that Michelson-Morely detected a nominal null value for translational velocity of the Earth around the sun or through the ether, making the conclusion that the earth is in the center of the universe plausible. Not familiar with the details of the data collection in those two experiments, I assume it may be similar to what you have proposed. It is understandable conclusion from those two experiments that ether is either rotating around a stationary earth at the rate of one day, or the earth is spinning at that rate. Can you offer more explanation about what you are saying?
        Up, Up and Away
        • #19
          I have often wondered where to find out knowledge about the so-called hidden science, for instance, the ether and spin properties, etc. You sir, exhibit some depth in knowledge about the ether as if you have it based on some text book. Where do you get your information about such strange properties of the substance as if it is common knowledge?
          Up, Up and Away
