Discussion. Best way to use heat from HHO to generate electricity
Just found this thread today, awesome keep up the good work, will try this after the project Im on, similar tech.
Originally posted by altrez View PostWell seems like all I ended up with is ZnO Paste. I tried my best with what I had. looks exactly like it did when I started. Wet ZnO powder. If one of you manage to get this to work please post the results.
-Altrez
good job.
-Altrez
Originally posted by altrez View PostUpdate:
YouTube - znotest
So far it seems no crystals have formed. The next step is to heat it back up to 60 degrees Celsius and let it sit at that temp for 2 hours.
I will post an update around 6:00 PM CDT
-Altrez
Thank You Very Much!!
Thanks for what you have shared Power1. This is incredible stuff.
Originally posted by power1 View PostSlovenia, there is no such place for one stop knowledge, perhaps you can start a new site open freely and concile these findings there.
start changes with self first, cleanse your body, eat natural food, natural water - i have to travel miles and hike to unpoluted source for water weekly, not easy.
start with the Treatsie of Electricity book I posted, there are many online forums for making different things, books etc.
the knowledge comes to you naturally, overtime it's a natural sensory.
from my sea extract, i found ormus, take it, that helps too, look online.
you have to make sacrifices, abolish everything synthetic.
guys, your thoughts can continue into sleep REM where you are still conscious, you can answer a lot of questions there.
Tesla was right, ideas just flows to you, there is no Law to manifesting matter, everyone can come up with their own method and still arrive at the same result, that's the natural logic I hope that you will gain.
Originally posted by power1 View PostAltrez,
does not look right, ammonia should be 30% and water 70%, not dilute of household ammonia further, check your label for content %
it does not freeze at 0 deg C
you need to reflux by boiling it in ts own vapor, crystals is fused with ammonia, can not let vapor evaporate.
-Altrez
Originally posted by altrez View PostIt is %30 ammonia %70 water I checked it. I have no way to reflux and did not know you had to. I will keep it sealed during the last heat cycle but if I get no yield at all I am afraid this will be the last test for me as I must move on to other projects.
Once someone has posted videos and pictures with a step by step instruction then I will try again.
I will post the results of this last run. around 6:00 or so.
-Altrez
it took me many tries, follow your insctinct, do as you wish.
My solution turned into liquid again 2 minutes after being out of the freezer.
-Altrez
Originally posted by FRC View PostAfter all this new information. Went back to my previous concoction of
zinc gluconate and ammonia (still had not evaporated yet). Mixed in some more
ammonia, heated on stove with Mason jar (worked well but pyrex would be better) also mixed in some epsom salts- magnesium sulphate hepta hydrate.
Don't know whether it will work but sure works good rejuvenating batteries.
In the freezer now. Will see what happens.
FRC
trying again
FRC
-Altrez
